NFSv42 CLONE operation is supposed to respect it.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Create file with attributs as NFS4_CREATE_EXCLUSIVE4_1 mode
depends on suppattr_exclcreat attribut.
v3, same as v2.
Signed-off-by: Kinglong Mee <kinglongmee@gmail.com>
Setting the change attribute has been mandatory for all NFS versions, since
commit 3a1556e8662c ("NFSv2/v3: Simulate the change attribute"). We should
therefore not have anything be conditional on it being set/unset.
Make it so, by checking the return value for NFS4ERR_MOTSUPP and
caching the information as a server capability.
The flexfiles layout wants to create DS connection over NFSv3.
Add nfs3_set_ds_client to allow that to happen.
Signed-off-by: Tom Haynes <Thomas.Haynes@primarydata.com>
Ensure that we cache the NFSv4/v4.1 client owner_id so that we can
verify it when we're doing trunking detection.
This patch adds support for using the NFS v4.2 operation DEALLOCATE to
punch holes in a file.
Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
This patch adds support for using the NFS v4.2 operation ALLOCATE to
preallocate data in a file.
The SEEK operation is used when an application makes an lseek call with
either the SEEK_HOLE or SEEK_DATA flags set. I fall back on
nfs_file_llseek() if the server does not have SEEK support.
The current CB_COMPOUND handling code tries to compare the principal
name of the request with the cl_hostname in the client. This is not
guaranteed to ever work, particularly if the client happened to mount
a CNAME of the server or a non-fqdn.
Fix this by instead comparing the cr_principal string with the acceptor
name that we get from gssd. In the event that gssd didn't send one
down (i.e. it was too old), then we fall back to trying to use the
cl_hostname as we do today.
Signed-off-by: Jeff Layton <jlayton@poochiereds.net>
Cache the auth_info structure in nfs_server and pass these values to submounts.
This lays the groundwork for supporting multiple sec= options.
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Migration recovery and state recovery must be serialized, so handle
both in the state manager thread.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
NFS_SB() returns the pointer to an nfs_server struct, given a
pointer to a super_block. But we have no way to go back the other
way.
Add a super_block backpointer field so that, given an nfs_server
struct, it is easy to get to the filesystem's root dentry.
The spec states that the client should not resend requests because
the server will disconnect if it needs to drop an RPC request.
Commit 4edaa308 "NFS: Use "krb5i" to establish NFSv4 state whenever possible"
uses the nfs_client cl_rpcclient for all state management operations, and
will use krb5i or auth_sys with no regard to the mount command authflavor
choice.
The MDS, as any NFSv4.1 mount point, uses the nfs_server rpc client for all
non-state management operations with a different nfs_server for each fsid
encountered traversing the mount point, each with a potentially different
auth flavor.
pNFS data servers are not mounted in the normal sense as there is no associated
nfs_server structure. Data servers can also export multiple fsids, each with
a potentially different auth flavor.
Data servers need to use the same authflavor as the MDS server rpc client for
non-state management operations. Populate a list of rpc clients with the MDS
server rpc client auth flavor for the DS to use.
Signed-off-by: Andy Adamson <andros@netapp.com>
WRITE and COMMIT can use the machine credential.
If WRITE is supported and COMMIT is not, make all (mach cred) writes FILE_SYNC4.
TEST_STATEID and FREE_STATEID can use the machine credential.
SECINFO and SECINFO_NONAME can use the machine credential.
CLOSE and LOCKU can use the machine credential.
This is a minimal client side implementation of SP4_MACH_CRED. It will
attempt to negotiate SP4_MACH_CRED iff the EXCHANGE_ID is using
krb5i or krb5p auth. SP4_MACH_CRED will be used if the server supports the
minimal operations:
BIND_CONN_TO_SESSION
EXCHANGE_ID
CREATE_SESSION
DESTROY_SESSION
DESTROY_CLIENTID
This patch only includes the EXCHANGE_ID negotiation code because
the client will already use the machine cred for these operations.
If the server doesn't support SP4_MACH_CRED or doesn't support the minimal
operations, the exchange id will be resent with SP4_NONE.
Anchor an nfs4_slot_table in the nfs_client for use with NFSv4.0
transport blocking. It is initialized only for NFSv4.0 nfs_client's.
Introduce appropriate minor version ops to handle nfs_client
initialization and shutdown requirements that differ for each minor
version.
This patch implements the client transport and handling support for labeled
NFS. The patch adds two functions to encode and decode the security label
recommended attribute which makes use of the LSM hooks added earlier. It also
adds code to grab the label from the file attribute structures and encode the
label to be sent back to the server.
Acked-by: James Morris <james.l.morris@oracle.com>
Signed-off-by: Matthew N. Dodd <Matthew.Dodd@sparta.com>
Signed-off-by: Miguel Rodel Felipe <Rodel_FM@dsi.a-star.edu.sg>
Signed-off-by: Phua Eu Gene <PHUA_Eu_Gene@dsi.a-star.edu.sg>
Signed-off-by: Khin Mi Mi Aung <Mi_Mi_AUNG@dsi.a-star.edu.sg>
Signed-off-by: Steve Dickson <steved@redhat.com>
The fattr handling bitmap code only uses the first two fattr words sofar. This
patch adds the 3rd word to being sent but doesn't populate it yet.
This patch adds several new flags to allow the NFS client and server to
determine if this attribute is supported and if it is being sent over the wire.
This ensures that the RPC layer doesn't override the NFS session
negotiation.
Sometimes, we actually _want_ to do open-by-filehandle, for instance
when recovering opens after a network partition, or when called
from nfs4_file_open.
Enable that functionality using a new capability NFS_CAP_ATOMIC_OPEN_V1,
and which is only enabled for NFSv4.1 servers that support it.
Follow the practice described in section 8.2.2 of RFC5661: When sending a
read/write or setattr stateid, set the seqid field to zero in order to
signal that the NFS server should apply the most recent locking state.
Clean up. Gather NFSv4.1 slot definitions in fs/nfs/nfs4session.h.
Allow the server to control the size of the session slot table
by adjusting the value of sr_target_max_slots in the reply to the
SEQUENCE operation.
When the server tells us that it is dynamically resizing the session
replay cache, we should reset the sequence number for those slots
that have been deallocated.
Dynamic slot allocation in NFSv4.1 depends on the client being able to
track the server's target value for the highest slotid in the
slot table. See the reference in Section 2.10.6.1 of RFC5661.
To avoid ordering problems in the case where 2 SEQUENCE replies contain
conflicting updates to this target value, we also introduce a generation
counter, to track whether or not an RPC containing a SEQUENCE operation
was launched before or after the last update.
Also rename the nfs4_slot_table target_max_slots field to
'target_highest_slotid' to avoid confusion with a slot
table size or number of slots.
Move the session pointer into the slot table, then have struct nfs4_slot
point to that slot table.
Don't store the target request and response sizes in the same
variables used to store the server's replies to those targets.
"Server trunking" is a fancy named for a multi-homed NFS server.
Trunking might occur if a client sends NFS requests for a single
workload to multiple network interfaces on the same server. There
are some implications for NFSv4 state management that make it useful
for a client to know if a single NFSv4 server instance is
multi-homed. (Note this is only a consideration for NFSv4, not for
legacy versions of NFS, which are stateless).
If a client cares about server trunking, no NFSv4 operations can
proceed until that client determines who it is talking to. Thus
server IP trunking discovery must be done when the client first
encounters an unfamiliar server IP address.
The nfs_get_client() function walks the nfs_client_list and matches
on server IP address. The outcome of that walk tells us immediately
if we have an unfamiliar server IP address. It invokes
nfs_init_client() in this case. Thus, nfs4_init_client() is a good
spot to perform trunking discovery.
Discovery requires a client to establish a fresh client ID, so our
client will now send SETCLIENTID or EXCHANGE_ID as the first NFS
operation after a successful ping, rather than waiting for an
application to perform an operation that requires NFSv4 state.
The exact process for detecting trunking is different for NFSv4.0 and
NFSv4.1, so a minorversion-specific init_client callout method is
introduced.
CLID_INUSE recovery is important for the trunking discovery process.
CLID_INUSE is a sign the server recognizes the client's nfs_client_id4
id string, but the client is using the wrong principal this time for
the SETCLIENTID operation. The SETCLIENTID must be retried with a
series of different principals until one works, and then the rest of
trunking discovery can proceed.
Currently, the Linux client uses a unique nfs_client_id4.id string
when identifying itself to distinct NFS servers.
To support transparent state migration, the Linux client will have to
use the same nfs_client_id4 string for all servers it communicates
with (also known as the "uniform client string" approach). Otherwise
NFS servers can not recognize that open and lock state need to be
merged after a file system transition.
Unfortunately, there are some NFSv4.0 servers currently in the field
that do not tolerate the uniform client string approach.
Thus, by default, our NFSv4.0 mounts will continue to use the current
approach, and we introduce a mount option that switches them to use
the uniform model. Client administrators must identify which servers
can be mounted with this option. Eventually most NFSv4.0 servers will
be able to handle the uniform approach, and we can change the default.
The first mount of a server controls the behavior for all subsequent
mounts for the lifetime of that set of mounts of that server. After
the last mount of that server is gone, the client erases the data
structure that tracks the lease. A subsequent lease may then honor
a different "migration" setting.
This patch adds only the infrastructure for parsing the new mount
option. Support for uniform client strings is added in a subsequent
patch.
This patch exports symbols needed by the v4 module. In addition, I also
switch over to using IS_ENABLED() to check if CONFIG_NFS_V4 or
CONFIG_NFS_V4_MODULE are set.
The module (nfs4.ko) will be created in the same directory as nfs.ko and
will be automatically loaded the first time you try to mount over NFS v4.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
This patch adds in the code to track multiple versions of the NFS
protocol. I created default structures for v2, v3 and v4 so that each
version can continue to work while I convert them into kernel modules.
I also removed the const parameter from the rpc_version array so that I
can change it at runtime.
For NFSv4 minor version 0, currently the cl_id_uniquifier allows the
Linux client to generate a unique nfs_client_id4 string whenever a
server replies with NFS4ERR_CLID_INUSE.
This implementation seems to be based on a flawed reading of RFC
3530. NFS4ERR_CLID_INUSE actually means that the client has presented
this nfs_client_id4 string with a different principal at some time in
the past, and that lease is still in use on the server.
For a Linux client this might be rather difficult to achieve: the
authentication flavor is named right in the nfs_client_id4.id
string. If we change flavors, we change strings automatically.
So, practically speaking, NFS4ERR_CLID_INUSE means there is some other
client using our string. There is not much that can be done to
recover automatically. Let's make it a permanent error.
Remove the recovery logic in nfs4_proc_setclientid(), and remove the
cl_id_uniquifier field from the nfs_client data structure. And,
remove the authentication flavor from the nfs_client_id4 string.
Keeping the authentication flavor in the nfs_client_id4.id string
means that we could have a separate lease for each authentication
flavor used by mounts on the client. But we want just one lease for
all the mounts on this client.
Currently there is a 'chicken and egg' issue when the DS is also the mounted
MDS. The nfs_match_client() reference from nfs4_set_ds_client bumps the
cl_count, the nfs_client is not freed at umount, and nfs4_deviceid_purge_client
is not called to dereference the MDS usage of a deviceid which holds a
reference to the DS nfs_client. The result is the umount program returns,
but the nfs_client is not freed, and the cl_session hearbeat continues.
The MDS (and all other nfs mounts) lose their last nfs_client reference in
nfs_free_server when the last nfs_server (fsid) is umounted.
The file layout DS lose their last nfs_client reference in destroy_ds
when the last deviceid referencing the data server is put and destroy_ds is
called. This is triggered by a call to nfs4_deviceid_purge_client which
removes references to a pNFS deviceid used by an MDS mount.
The fix is to track how many pnfs enabled filesystems are mounted from
this server, and then to purge the device id cache once that count reaches
zero.
Reported-by: Jorge Mora <Jorge.Mora@netapp.com>
Reported-by: Andy Adamson <andros@netapp.com>
Save the server major and minor ID results from EXCHANGE_ID, as they
are needed for detecting server trunking.
"noresvport" and "discrtry" can be passed to nfs_create_rpc_client()
by setting flags in the passed-in nfs_client. This change makes it
easy to add new flags.
Note that these settings are now "sticky" over the lifetime of a
struct nfs_client, and may even be copied when an nfs_client is
cloned.
Currently our NFS client assigns a unique SETCLIENTID boot verifier
for each server IP address it knows about. It's set to CURRENT_TIME
when the struct nfs_client for that server IP is created.
During the SETCLIENTID operation, our client also presents an
nfs_client_id4 string to servers, as an identifier on which the server
can hang all of this client's NFSv4 state. Our client's
nfs_client_id4 string is unique for each server IP address.
An NFSv4 server is obligated to wipe all NFSv4 state associated with
an nfs_client_id4 string when the client presents the same
nfs_client_id4 string along with a changed SETCLIENTID boot verifier.
When our client unmounts the last of a server's shares, it destroys
that server's struct nfs_client. The next time the client mounts that
NFS server, it creates a fresh struct nfs_client with a fresh boot
verifier. On seeing the fresh verifer, the server wipes any previous
NFSv4 state associated with that nfs_client_id4.
However, NFSv4.1 clients are supposed to present the same
nfs_client_id4 string to all servers. And, to support Transparent
State Migration, the same nfs_client_id4 string should be presented
to all NFSv4.0 servers so they recognize that migrated state for this
client belongs with state a server may already have for this client.
(This is known as the Uniform Client String model).
If the nfs_client_id4 string is the same but the boot verifier changes
for each server IP address, SETCLIENTID and EXCHANGE_ID operations
from such a client could unintentionally result in a server wiping a
client's previously obtained lease.
Thus, if our NFS client is going to use a fixed nfs_client_id4 string,
either for NFSv4.0 or NFSv4.1 mounts, our NFS client should use a
boot verifier that does not change depending on server IP address.
Replace our current per-nfs_client boot verifier with a per-nfs_net
boot verifier.
Clean up: When naming fields and data types, follow established
conventions to facilitate accurate grep/cscope searches.
Introduced by commit e50a7a1a "NFS: make NFS client allocated per
network namespace context," Tue Jan 10, 2012.
Additionally, for consistency, move the impl_id field into the NFSv4-
specific part of the nfs_client, and free that memory in the logic
that shuts down NFSv4 nfs_clients.
Introduced by commit 7d2ed9ac "NFSv4: parse and display server
implementation ids," Fri Feb 17, 2012.
Additionally, for consistency, move the scope field into the NFSv4-
Introduced by commit 99fe60d0 "nfs41: exchange_id operation", April
1 2009.
The fh_expire_type file attribute is a filesystem wide attribute that
consists of flags that indicate what characteristics file handles
on this FSID have.
Our client doesn't support volatile file handles. It should find
out early (say, at mount time) whether the server is going to play
shenanighans with file handles during a migration.
Shows the implementation ids in /proc/self/mountstats. This doesn't break
the nfs-utils mountstats tool.
