path: root/include/linux/of_serial.h
2012-04-18tegra, serial8250: add ->handle_break() uart_port opDan Williams
The "KT" serial port has another use case for a "received break" quirk, so before adding another special case to the 8250 core take this opportunity to push such quirks out of the core and into a uart_port op. Stephen says: "If the callback function is to no longer live in 8250.c itself, arch/arm/mach-tegra/devices.c isn't logically a good place to put it, and that file will be going away once we get rid of all the board files and move solely to device tree." ...so since 8250_pci.c houses all the quirks for pci serial devices this quirk is similarly housed in of_serial.c. Once the open firmware conversion completes the infrastructure details (include/linux/of_serial.h, and the export) can all be removed to make this self contained to of_serial.c. Cc: Nhan H Mai <nhan.h.mai@intel.com> Cc: Colin Cross <ccross@android.com> Cc: Olof Johansson <olof@lixom.net> [stephen: kill CONFIG_SERIAL_TEGRA in favor just using CONFIG_ARCH_TEGRA] Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sudhakar Mamillapalli <sudhakar@fb.com> Reported-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
