path: root/include/linux/omap-mailbox.h
2014-11-27mailbox/omap: adapt to the new mailbox frameworkSuman Anna
The OMAP mailbox driver and its existing clients (remoteproc for OMAP4+) are adapted to use the generic mailbox framework. The main changes for the adaptation are: - The tasklet used for Tx is replaced with the state machine from the generic mailbox framework. The workqueue used for processing the received messages stays intact for minimizing the effects on the OMAP mailbox clients. - The existing exported client API, omap_mbox_get, omap_mbox_put and omap_mbox_send_msg are deleted, as the framework provides equivalent functionality. A OMAP-specific omap_mbox_request_channel is added though to support non-DT way of requesting mailboxes. - The OMAP mailbox driver is integrated with the mailbox framework through the proper implementations of mbox_chan_ops, except for .last_tx_done and .peek_data. The OMAP mailbox driver does not need these ops, as it is completely interrupt driven. - The OMAP mailbox driver uses a custom of_xlate controller ops that allows phandles for the pargs specifier instead of indexing to avoid any channel registration order dependencies. - The new framework does not support multiple clients operating on a single channel, so the reference counting logic is simplified. - The remoteproc driver (current client) is adapted to use the new API. The notifier callbacks used within this client is replaced with the regular callbacks from the newer framework. - The exported OMAP mailbox API are limited to omap_mbox_save_ctx, omap_mbox_restore_ctx, omap_mbox_enable_irq & omap_mbox_disable_irq, with the signature modified to take in the new mbox_chan handle instead of the OMAP specific omap_mbox handle. The first 2 will be removed when the OMAP mailbox driver is adapted to runtime_pm. The other exported API omap_mbox_request_channel will be removed once existing legacy users are converted to DT. Signed-off-by: Suman Anna <s-anna@ti.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org>
2013-06-11mailbox/omap: move the OMAP mailbox framework to driversSuman Anna
The mailbox hardware (in OMAP) uses a queued mailbox interrupt mechanism that provides a communication channel between processors through a set of registers and their associated interrupt signals by sending and receiving messages. The OMAP mailbox framework/driver code is moved to be under drivers/mailbox, in preparation for adapting to a common mailbox driver framework. This allows the build for OMAP mailbox to be enabled (it was disabled during the multi-platform support). As part of the migration from plat and mach code: - Kconfig symbols have been renamed to build OMAP1 or OMAP2+ drivers. - mailbox.h under plat-omap/plat/include has been split into a public and private header files. The public header has only the API related functions and types. - The module name mailbox.ko from plat-omap is changed to omap-mailbox.ko - The module name mailbox_mach.ko from mach-omapX is changed as mailbox_omap1.ko for OMAP1 mailbox_omap2.ko for OMAP2+ Cc: Tony Lindgren <tony@atomide.com> [gregkh@linuxfoundation.org: ack for staging part] Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Omar Ramirez Luna <omar.ramirez@copitl.com> Signed-off-by: Suman Anna <s-anna@ti.com>
