path: root/include/linux/opp.h
2012-03-16device.h: audit and cleanup users in main include dirPaul Gortmaker
The <linux/device.h> header includes a lot of stuff, and it in turn gets a lot of use just for the basic "struct device" which appears so often. Clean up the users as follows: 1) For those headers only needing "struct device" as a pointer in fcn args, replace the include with exactly that. 2) For headers not really using anything from device.h, simply delete the include altogether. 3) For headers relying on getting device.h implicitly before being included themselves, now explicitly include device.h 4) For files in which doing #1 or #2 uncovers an implicit dependency on some other header, fix by explicitly adding the required header(s). Any C files that were implicitly relying on device.h to be present have already been dealt with in advance. Total removals from #1 and #2: 51. Total additions coming from #3: 9. Total other implicit dependencies from #4: 7. As of 3.3-rc1, there were 110, so a net removal of 42 gives about a 38% reduction in device.h presence in include/* Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-11-04PM / OPP: Fix build when CONFIG_PM_OPP is not setTony Lindgren
Commit 03ca370fbf7b76d6d002380dbdc2cdc2319f9c80 (PM / OPP: Add OPP availability change notifier) does not compile if CONFIG_PM_OPP is not set: arch/arm/plat-omap/omap-pm-noop.o: In function `opp_get_notifier': include/linux/opp.h:103: multiple definition of `opp_get_notifier' include/linux/opp.h:103: first defined here Also fix incorrect comment. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-09-30PM / OPP: Add OPP availability change notifier.MyungJoo Ham
The patch enables to register notifier_block for an OPP-device in order to get notified for any changes in the availability of OPPs of the device. For example, if a new OPP is inserted or enable/disable status of an OPP is changed, the notifier is executed. This enables the usage of opp_add, opp_enable, and opp_disable to directly take effect with any connected entities such as cpufreq or devfreq. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mike Turquette <mturquette@ti.com> Reviewed-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-15PM / OPP: Introduce function to free cpufreq tableNishanth Menon
cpufreq table allocated by opp_init_cpufreq_table is better freed by OPP layer itself. This allows future modifications to the table handling to be transparent to the users. Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM: Introduce library for device-specific OPPs (v7)Nishanth Menon
SoCs have a standard set of tuples consisting of frequency and voltage pairs that the device will support per voltage domain. These are called Operating Performance Points or OPPs. The actual definitions of OPP varies over silicon versions. For a specific domain, we can have a set of {frequency, voltage} pairs. As the kernel boots and more information is available, a default set of these are activated based on the precise nature of device. Further on operation, based on conditions prevailing in the system (such as temperature), some OPP availability may be temporarily controlled by the SoC frameworks. To implement an OPP, some sort of power management support is necessary hence this library depends on CONFIG_PM. Contributions include: Sanjeev Premi for the initial concept: http://patchwork.kernel.org/patch/50998/ Kevin Hilman for converting original design to device-based. Kevin Hilman and Paul Walmsey for cleaning up many of the function abstractions, improvements and data structure handling. Romit Dasgupta for using enums instead of opp pointers. Thara Gopinath, Eduardo Valentin and Vishwanath BS for fixes and cleanups. Linus Walleij for recommending this layer be made generic for usage in other architectures beyond OMAP and ARM. Mark Brown, Andrew Morton, Rafael J. Wysocki, Paul E. McKenney for valuable improvements. Discussions and comments from: http://marc.info/?l=linux-omap&m=126033945313269&w=2 http://marc.info/?l=linux-omap&m=125482970102327&w=2 http://marc.info/?t=125809247500002&r=1&w=2 http://marc.info/?l=linux-omap&m=126025973426007&w=2 http://marc.info/?t=128152609200064&r=1&w=2 http://marc.info/?t=128468723000002&r=1&w=2 incorporated. v1: http://marc.info/?t=128468723000002&r=1&w=2 Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
