page_get_storage_key() and page_set_storage_key() expect a page address
and not its page frame number. This got inconsistent with 2d42552d
"[S390] merge page_test_dirty and page_clear_dirty".
Result is that we read/write storage keys from random pages and do not
have a working dirty bit tracking at all.
E.g. SetPageUpdate() doesn't clear the dirty bit of requested pages, which
for example ext4 doesn't like very much and panics after a while.
Unable to handle kernel paging request at virtual user address (null)
Oops: 0004 [#1] PREEMPT SMP DEBUG_PAGEALLOC
Modules linked in:
CPU: 1 Not tainted 2.6.39-07551-g139f37f-dirty #152
Process flush-94:0 (pid: 1576, task: 000000003eb34538, ksp: 000000003c287b70)
Krnl PSW : 0704c00180000000 0000000000316b12 (jbd2_journal_file_inode+0x10e/0x138)
R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:3 CC:0 PM:0 EA:3
Krnl GPRS: 0000000000000000 0000000000000000 0000000000000000 0700000000000000
0000000000316a62 000000003eb34cd0 0000000000000025 000000003c287b88
0000000000000001 000000003c287a70 000000003f1ec678 000000003f1ec000
0000000000000000 000000003e66ec00 0000000000316a62 000000003c287988
Krnl Code: 0000000000316b04: f0a0000407f4 srp 4(11,%r0),2036,0
0000000000316b0a: b9020022 ltgr %r2,%r2
0000000000316b0e: a7740015 brc 7,316b38
>0000000000316b12: e3d0c0000024 stg %r13,0(%r12)
0000000000316b18: 4120c010 la %r2,16(%r12)
0000000000316b1c: 4130d060 la %r3,96(%r13)
0000000000316b20: e340d0600004 lg %r4,96(%r13)
0000000000316b26: c0e50002b567 brasl %r14,36d5f4
Call Trace:
([<0000000000316a62>] jbd2_journal_file_inode+0x5e/0x138)
[<00000000002da13c>] mpage_da_map_and_submit+0x2e8/0x42c
[<00000000002daac2>] ext4_da_writepages+0x2da/0x504
[<00000000002597e8>] writeback_single_inode+0xf8/0x268
[<0000000000259f06>] writeback_sb_inodes+0xd2/0x18c
[<000000000025a700>] writeback_inodes_wb+0x80/0x168
[<000000000025aa92>] wb_writeback+0x2aa/0x324
[<000000000025abde>] wb_do_writeback+0xd2/0x274
[<000000000025ae3a>] bdi_writeback_thread+0xba/0x1c4
[<00000000001737be>] kthread+0xa6/0xb0
[<000000000056c1da>] kernel_thread_starter+0x6/0xc
[<000000000056c1d4>] kernel_thread_starter+0x0/0xc
INFO: lockdep is turned off.
Last Breaking-Event-Address:
[<0000000000316a8a>] jbd2_journal_file_inode+0x86/0x138
Reported-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
The page_clear_dirty primitive always sets the default storage key
which resets the access control bits and the fetch protection bit.
That will surprise a KVM guest that sets non-zero access control
bits or the fetch protection bit. Merge page_test_dirty and
page_clear_dirty back to a single function and only clear the
dirty bit from the storage key.
In addition move the function page_test_and_clear_dirty and
page_test_and_clear_young to page.h where they belong. This
requires to change the parameter from a struct page * to a page
frame number.
TestSetPageLocked() isn't being used anywhere. Also, using it would
likely be an error, since the proper interface trylock_page() provides
stronger ordering guarantees.
Signed-off-by: Michel Lespinasse <walken@google.com>
PG_buddy can be converted to _mapcount == -2. So the PG_compound_lock can
be added to page->flags without overflowing (because of the sparse section
bits increasing) with CONFIG_X86_PAE=y and CONFIG_X86_PAT=y. This also
has to move the memory hotplug code from _mapcount to lru.next to avoid
any risk of clashes. We can't use lru.next for PG_buddy removal, but
memory hotplug can use lru.next even more easily than the mapcount
instead.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Lately I've been working to make KVM use hugepages transparently without
the usual restrictions of hugetlbfs. Some of the restrictions I'd like to
see removed:
1) hugepages have to be swappable or the guest physical memory remains
locked in RAM and can't be paged out to swap
2) if a hugepage allocation fails, regular pages should be allocated
instead and mixed in the same vma without any failure and without
userland noticing
3) if some task quits and more hugepages become available in the
buddy, guest physical memory backed by regular pages should be
relocated on hugepages automatically in regions under
madvise(MADV_HUGEPAGE) (ideally event driven by waking up the
kernel deamon if the order=HPAGE_PMD_SHIFT-PAGE_SHIFT list becomes
not null)
4) avoidance of reservation and maximization of use of hugepages whenever
possible. Reservation (needed to avoid runtime fatal faliures) may be ok for
1 machine with 1 database with 1 database cache with 1 database cache size
known at boot time. It's definitely not feasible with a virtualization
hypervisor usage like RHEV-H that runs an unknown number of virtual machines
with an unknown size of each virtual machine with an unknown amount of
pagecache that could be potentially useful in the host for guest not using
O_DIRECT (aka cache=off).
hugepages in the virtualization hypervisor (and also in the guest!) are
much more important than in a regular host not using virtualization,
becasue with NPT/EPT they decrease the tlb-miss cacheline accesses from 24
to 19 in case only the hypervisor uses transparent hugepages, and they
decrease the tlb-miss cacheline accesses from 19 to 15 in case both the
linux hypervisor and the linux guest both uses this patch (though the
guest will limit the addition speedup to anonymous regions only for
now...). Even more important is that the tlb miss handler is much slower
on a NPT/EPT guest than for a regular shadow paging or no-virtualization
scenario. So maximizing the amount of virtual memory cached by the TLB
pays off significantly more with NPT/EPT than without (even if there would
be no significant speedup in the tlb-miss runtime).
The first (and more tedious) part of this work requires allowing the VM to
handle anonymous hugepages mixed with regular pages transparently on
regular anonymous vmas. This is what this patch tries to achieve in the
least intrusive possible way. We want hugepages and hugetlb to be used in
a way so that all applications can benefit without changes (as usual we
leverage the KVM virtualization design: by improving the Linux VM at
large, KVM gets the performance boost too).
The most important design choice is: always fallback to 4k allocation if
the hugepage allocation fails! This is the _very_ opposite of some large
pagecache patches that failed with -EIO back then if a 64k (or similar)
allocation failed...
Second important decision (to reduce the impact of the feature on the
existing pagetable handling code) is that at any time we can split an
hugepage into 512 regular pages and it has to be done with an operation
that can't fail. This way the reliability of the swapping isn't decreased
(no need to allocate memory when we are short on memory to swap) and it's
trivial to plug a split_huge_page* one-liner where needed without
polluting the VM. Over time we can teach mprotect, mremap and friends to
handle pmd_trans_huge natively without calling split_huge_page*. The fact
it can't fail isn't just for swap: if split_huge_page would return -ENOMEM
(instead of the current void) we'd need to rollback the mprotect from the
middle of it (ideally including undoing the split_vma) which would be a
big change and in the very wrong direction (it'd likely be simpler not to
call split_huge_page at all and to teach mprotect and friends to handle
hugepages instead of rolling them back from the middle). In short the
very value of split_huge_page is that it can't fail.
The collapsing and madvise(MADV_HUGEPAGE) part will remain separated and
incremental and it'll just be an "harmless" addition later if this initial
part is agreed upon. It also should be noted that locking-wise replacing
regular pages with hugepages is going to be very easy if compared to what
I'm doing below in split_huge_page, as it will only happen when
page_count(page) matches page_mapcount(page) if we can take the PG_lock
and mmap_sem in write mode. collapse_huge_page will be a "best effort"
that (unlike split_huge_page) can fail at the minimal sign of trouble and
we can try again later. collapse_huge_page will be similar to how KSM
works and the madvise(MADV_HUGEPAGE) will work similar to
madvise(MADV_MERGEABLE).
The default I like is that transparent hugepages are used at page fault
time. This can be changed with
/sys/kernel/mm/transparent_hugepage/enabled. The control knob can be set
to three values "always", "madvise", "never" which mean respectively that
hugepages are always used, or only inside madvise(MADV_HUGEPAGE) regions,
or never used. /sys/kernel/mm/transparent_hugepage/defrag instead
controls if the hugepage allocation should defrag memory aggressively
"always", only inside "madvise" regions, or "never".
The pmd_trans_splitting/pmd_trans_huge locking is very solid. The
put_page (from get_user_page users that can't use mmu notifier like
O_DIRECT) that runs against a __split_huge_page_refcount instead was a
pain to serialize in a way that would result always in a coherent page
count for both tail and head. I think my locking solution with a
compound_lock taken only after the page_first is valid and is still a
PageHead should be safe but it surely needs review from SMP race point of
view. In short there is no current existing way to serialize the O_DIRECT
final put_page against split_huge_page_refcount so I had to invent a new
one (O_DIRECT loses knowledge on the mapping status by the time gup_fast
returns so...). And I didn't want to impact all gup/gup_fast users for
now, maybe if we change the gup interface substantially we can avoid this
locking, I admit I didn't think too much about it because changing the gup
unpinning interface would be invasive.
If we ignored O_DIRECT we could stick to the existing compound refcounting
code, by simply adding a get_user_pages_fast_flags(foll_flags) where KVM
(and any other mmu notifier user) would call it without FOLL_GET (and if
FOLL_GET isn't set we'd just BUG_ON if nobody registered itself in the
current task mmu notifier list yet). But O_DIRECT is fundamental for
decent performance of virtualized I/O on fast storage so we can't avoid it
to solve the race of put_page against split_huge_page_refcount to achieve
a complete hugepage feature for KVM.
Swap and oom works fine (well just like with regular pages ;). MMU
notifier is handled transparently too, with the exception of the young bit
on the pmd, that didn't have a range check but I think KVM will be fine
because the whole point of hugepages is that EPT/NPT will also use a huge
pmd when they notice gup returns pages with PageCompound set, so they
won't care of a range and there's just the pmd young bit to check in that
case.
NOTE: in some cases if the L2 cache is small, this may slowdown and waste
memory during COWs because 4M of memory are accessed in a single fault
instead of 8k (the payoff is that after COW the program can run faster).
So we might want to switch the copy_huge_page (and clear_huge_page too) to
not temporal stores. I also extensively researched ways to avoid this
cache trashing with a full prefault logic that would cow in 8k/16k/32k/64k
up to 1M (I can send those patches that fully implemented prefault) but I
concluded they're not worth it and they add an huge additional complexity
and they remove all tlb benefits until the full hugepage has been faulted
in, to save a little bit of memory and some cache during app startup, but
they still don't improve substantially the cache-trashing during startup
if the prefault happens in >4k chunks. One reason is that those 4k pte
entries copied are still mapped on a perfectly cache-colored hugepage, so
the trashing is the worst one can generate in those copies (cow of 4k page
copies aren't so well colored so they trashes less, but again this results
in software running faster after the page fault). Those prefault patches
allowed things like a pte where post-cow pages were local 4k regular anon
pages and the not-yet-cowed pte entries were pointing in the middle of
some hugepage mapped read-only. If it doesn't payoff substantially with
todays hardware it will payoff even less in the future with larger l2
caches, and the prefault logic would blot the VM a lot. If one is
emebdded transparent_hugepage can be disabled during boot with sysfs or
with the boot commandline parameter transparent_hugepage=0 (or
transparent_hugepage=2 to restrict hugepages inside madvise regions) that
will ensure not a single hugepage is allocated at boot time. It is simple
enough to just disable transparent hugepage globally and let transparent
hugepages be allocated selectively by applications in the MADV_HUGEPAGE
region (both at page fault time, and if enabled with the
collapse_huge_page too through the kernel daemon).
This patch supports only hugepages mapped in the pmd, archs that have
smaller hugepages will not fit in this patch alone. Also some archs like
power have certain tlb limits that prevents mixing different page size in
the same regions so they will not fit in this framework that requires
"graceful fallback" to basic PAGE_SIZE in case of physical memory
fragmentation. hugetlbfs remains a perfect fit for those because its
software limits happen to match the hardware limits. hugetlbfs also
remains a perfect fit for hugepage sizes like 1GByte that cannot be hoped
to be found not fragmented after a certain system uptime and that would be
very expensive to defragment with relocation, so requiring reservation.
hugetlbfs is the "reservation way", the point of transparent hugepages is
not to have any reservation at all and maximizing the use of cache and
hugepages at all times automatically.
Some performance result:
vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largep
ages3
memset page fault 1566023
memset tlb miss 453854
memset second tlb miss 453321
random access tlb miss 41635
random access second tlb miss 41658
vmx andrea # LD_PRELOAD=/usr/lib64/libhugetlbfs.so HUGETLB_MORECORE=yes HUGETLB_PATH=/mnt/huge/ ./largepages3
memset page fault 1566471
memset tlb miss 453375
memset second tlb miss 453320
random access tlb miss 41636
random access second tlb miss 41637
vmx andrea # ./largepages3
memset page fault 1566642
memset tlb miss 453417
memset second tlb miss 453313
random access tlb miss 41630
random access second tlb miss 41647
memset page fault 1566872
memset tlb miss 453418
memset second tlb miss 453315
random access tlb miss 41618
random access second tlb miss 41659
vmx andrea # echo 0 > /proc/sys/vm/transparent_hugepage
memset page fault 2182476
memset tlb miss 460305
memset second tlb miss 460179
random access tlb miss 44483
random access second tlb miss 44186
memset page fault 2182791
memset tlb miss 460742
memset second tlb miss 459962
random access tlb miss 43981
random access second tlb miss 43988
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/time.h>
#define SIZE (3UL*1024*1024*1024)
int main()
char *p = malloc(SIZE), *p2;
struct timeval before, after;
gettimeofday(&before, NULL);
memset(p, 0, SIZE);
gettimeofday(&after, NULL);
printf("memset page fault %Lu\n",
(after.tv_sec-before.tv_sec)*1000000UL +
after.tv_usec-before.tv_usec);
memset(p, 0, SIZE);
printf("memset tlb miss %Lu\n",
memset(p, 0, SIZE);
printf("memset second tlb miss %Lu\n",
for (p2 = p; p2 < p+SIZE; p2 += 4096)
*p2 = 0;
printf("random access tlb miss %Lu\n",
*p2 = 0;
printf("random access second tlb miss %Lu\n",
return 0;
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
This should work for both hugetlbfs and transparent hugepages.
[akpm@linux-foundation.org: bring forward PageTransCompound() addition for bisectability]
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
split_huge_page must transform a compound page to a regular page and needs
ClearPageCompound.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Add a new compound_lock() needed to serialize put_page against
__split_huge_page_refcount().
Temporary IO failures, eg. due to loss of both multipath paths, can
permanently leave the PageError bit set on a page, resulting in msync or
fsync returning -EIO over and over again, even if IO is now getting to the
disk correctly.
We already clear the AS_ENOSPC and AS_IO bits in mapping->flags in the
filemap_fdatawait_range function. Also clearing the PageError bit on the
page allows subsequent msync or fsync calls on this file to return without
an error, if the subsequent IO succeeds.
Unfortunately data written out in the msync or fsync call that returned
-EIO can still get lost, because the page dirty bit appears to not get
restored on IO error. However, the alternative could be potentially all
of memory filling up with uncleanable dirty pages, hanging the system, so
there is no nice choice here...
Signed-off-by: Rik van Riel <riel@redhat.com>
Acked-by: Valerie Aurora <vaurora@redhat.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Acked-by: Jan Kara <jack@suse.cz>
Improve performance of the sske operation by using the nonquiescing
variant if the affected page has no mappings established. On machines
with no support for the new sske variant the mask bit will be ignored.
The cacheline with the flags is reachable from the hot paths after the
percpu allocator changes went in. So there is no need anymore to put a
flag into each slab page. Get rid of the SlubDebug flag and use
the flags in kmem_cache instead.
Acked-by: David Rientjes <rientjes@google.com>
Signed-off-by: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
* 'for-33' of git://repo.or.cz/linux-kbuild: (29 commits)
net: fix for utsrelease.h moving to generated
gen_init_cpio: fixed fwrite warning
kbuild: fix make clean after mismerge
kbuild: generate modules.builtin
genksyms: properly consider EXPORT_UNUSED_SYMBOL{,_GPL}()
score: add asm/asm-offsets.h wrapper
unifdef: update to upstream revision 1.190
kbuild: specify absolute paths for cscope
kbuild: create include/generated in silentoldconfig
scripts/package: deb-pkg: use fakeroot if available
scripts/package: add KBUILD_PKG_ROOTCMD variable
scripts/package: tar-pkg: use tar --owner=root
Kbuild: clean up marker
net: add net_tstamp.h to headers_install
kbuild: move utsrelease.h to include/generated
kbuild: move autoconf.h to include/generated
drop explicit include of autoconf.h
kbuild: move compile.h to include/generated
kbuild: drop include/asm
kbuild: do not check for include/asm-$ARCH
Fixed non-conflicting clean merge of modpost.c as per comments from
Stephen Rothwell (modpost.c had grown an include of linux/autoconf.h
that needed to be changed to generated/autoconf.h)
Rename get_uflags() to stable_page_flags() and make it a global function
for use in the hwpoison page flags filter, which need to compare user
page flags with the value provided by user space.
Also move KPF_* to kernel-page-flags.h for use by user space tools.
Acked-by: Matt Mackall <mpm@selenic.com>
CC: Nick Piggin <npiggin@suse.de>
CC: Christoph Lameter <cl@linux-foundation.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
The unpoisoning interface is useful for stress testing tools to
reclaim poisoned pages (to prevent OOM)
There is no hardware level unpoisioning, so this
cannot be used for real memory errors, only for software injected errors.
Note that it may leak pages silently - those who have been removed from
LRU cache, but not isolated from page cache/swap cache at hwpoison time.
Especially the stress test of dirty swap cache pages shall reboot system
before exhausting memory.
AK: Fix comments, add documentation, add printks, rename symbol
Remove three degrees of obfuscation, left over from when we had
CONFIG_UNEVICTABLE_LRU. MLOCK_PAGES is CONFIG_HAVE_MLOCKED_PAGE_BIT is
CONFIG_HAVE_MLOCK is CONFIG_MMU. rmap.o (and memory-failure.o) are only
built when CONFIG_MMU, so don't need such conditions at all.
Somehow, I feel no compulsion to remove the CONFIG_HAVE_MLOCK* lines from
169 defconfigs: leave those to evolve in due course.
Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk>
Cc: Izik Eidus <ieidus@redhat.com>
Cc: Nick Piggin <npiggin@suse.de>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits)
HWPOISON: Enable error_remove_page on btrfs
HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs
HWPOISON: Add madvise() based injector for hardware poisoned pages v4
HWPOISON: Enable error_remove_page for NFS
HWPOISON: Enable .remove_error_page for migration aware file systems
HWPOISON: The high level memory error handler in the VM v7
HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process
HWPOISON: shmem: call set_page_dirty() with locked page
HWPOISON: Define a new error_remove_page address space op for async truncation
HWPOISON: Add invalidate_inode_page
HWPOISON: Refactor truncate to allow direct truncating of page v2
HWPOISON: check and isolate corrupted free pages v2
HWPOISON: Handle hardware poisoned pages in try_to_unmap
HWPOISON: Use bitmask/action code for try_to_unmap behaviour
HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2
HWPOISON: Add poison check to page fault handling
HWPOISON: Add basic support for poisoned pages in fault handler v3
HWPOISON: Add new SIGBUS error codes for hardware poison signals
HWPOISON: Add support for poison swap entries v2
HWPOISON: Export some rmap vma locking to outside world
Make page_has_private() return a true boolean value and remove the double
negations from the two callsites using it for arithmetic.
By the time PG_mlocked is cleared in the page freeing path, nobody else is
looking at our page->flags anymore.
It is thus safe to make the test-and-clear non-atomic and thereby removing
an unnecessary and expensive operation from a hotpath.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Hardware poisoned pages need special handling in the VM and shouldn't be
touched again. This requires a new page flag. Define it here.
The page flags wars seem to be over, so it shouldn't be a problem
to get a new one.
v2: Add TestSetHWPoison (suggested by Johannes Weiner)
Acked-by: Christoph Lameter <cl@linux.com>
Only IA64 was using PG_uncached as of now. We now intend to use this bit
in x86 as well, to keep track of memory type of those addresses that
have page struct for them. So, generalize the use of that bit across
ia64 and x86.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
'slub/fixes' into for-linus
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this
configurability is unnecessary.
Acked-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
For the sake of consistency.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Recruit a page flag to aid in cache management. The following extra flag is
defined:
(1) PG_fscache (PG_private_2)
The marked page is backed by a local cache and is pinning resources in the
cache driver.
If PG_fscache is set, then things that checked for PG_private will now also
check for that. This includes things like truncation and page invalidation.
The function page_has_private() had been added to make the checks for both
PG_private and PG_private_2 at the same time.
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
The attached patch causes read_cache_pages() to release page-private data on a
page for which add_to_page_cache() fails. If the filler function fails, then
the problematic page is left attached to the pagecache (with appropriate flags
set, one presumes) and the remaining to-be-attached pages are invalidated and
discarded. This permits pages with caching references associated with them to
be cleaned up.
The invalidatepage() address space op is called (indirectly) to do the honours.
The mlock() facility does not exist for NOMMU since all mappings are
effectively locked anyway, so we don't make the bits available when
they're not useful.
Cc: Greg Ungerer <gerg@snapgear.com>
Cc: Enrik Berkhan <Enrik.Berkhan@ge.com>
Simplify the PAGE_FLAGS checking and clearing when freeing and allocating
a page: check the same flags as before when freeing, clear ALL the flags
(unless PageReserved) when freeing, check ALL flags off when allocating.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
If we add NOOP stubs for SetPageSwapCache() and ClearPageSwapCache(), then
we can remove the #ifdef CONFIG_SWAPs from mm/migrate.c.
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Make sure that mlocked pages also live on the unevictable LRU, so kswapd
will not scan them over and over again.
This is achieved through various strategies:
1) add yet another page flag--PG_mlocked--to indicate that
the page is locked for efficient testing in vmscan and,
optionally, fault path. This allows early culling of
unevictable pages, preventing them from getting to
page_referenced()/try_to_unmap(). Also allows separate
accounting of mlock'd pages, as Nick's original patch
did.
Note: Nick's original mlock patch used a PG_mlocked
flag. I had removed this in favor of the PG_unevictable
flag + an mlock_count [new page struct member]. I
restored the PG_mlocked flag to eliminate the new
count field.
2) add the mlock/unevictable infrastructure to mm/mlock.c,
with internal APIs in mm/internal.h. This is a rework
of Nick's original patch to these files, taking into
account that mlocked pages are now kept on unevictable
LRU list.
3) update vmscan.c:page_evictable() to check PageMlocked()
and, if vma passed in, the vm_flags. Note that the vma
will only be passed in for new pages in the fault path;
and then only if the "cull unevictable pages in fault
path" patch is included.
4) add try_to_unlock() to rmap.c to walk a page's rmap and
ClearPageMlocked() if no other vmas have it mlocked.
Reuses as much of try_to_unmap() as possible. This
effectively replaces the use of one of the lru list links
as an mlock count. If this mechanism let's pages in mlocked
vmas leak through w/o PG_mlocked set [I don't know that it
does], we should catch them later in try_to_unmap(). One
hopes this will be rare, as it will be relatively expensive.
Original mm/internal.h, mm/rmap.c and mm/mlock.c changes:
Signed-off-by: Nick Piggin <npiggin@suse.de>
splitlru: introduce __get_user_pages():
New munlock processing need to GUP_FLAGS_IGNORE_VMA_PERMISSIONS.
because current get_user_pages() can't grab PROT_NONE pages theresore it
cause PROT_NONE pages can't munlock.
[akpm@linux-foundation.org: fix this for pagemap-pass-mm-into-pagewalkers.patch]
[akpm@linux-foundation.org: untangle patch interdependencies]
[akpm@linux-foundation.org: fix things after out-of-order merging]
[hugh@veritas.com: fix page-flags mess]
[lee.schermerhorn@hp.com: fix munlock page table walk - now requires 'mm']
[kosaki.motohiro@jp.fujitsu.com: build fix]
[kosaki.motohiro@jp.fujitsu.com: fix truncate race and sevaral comments]
[kosaki.motohiro@jp.fujitsu.com: splitlru: introduce __get_user_pages()]
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
When the system contains lots of mlocked or otherwise unevictable pages,
the pageout code (kswapd) can spend lots of time scanning over these
pages. Worse still, the presence of lots of unevictable pages can confuse
kswapd into thinking that more aggressive pageout modes are required,
resulting in all kinds of bad behaviour.
Infrastructure to manage pages excluded from reclaim--i.e., hidden from
vmscan. Based on a patch by Larry Woodman of Red Hat. Reworked to
maintain "unevictable" pages on a separate per-zone LRU list, to "hide"
them from vmscan.
Kosaki Motohiro added the support for the memory controller unevictable
lru list.
Pages on the unevictable list have both PG_unevictable and PG_lru set.
Thus, PG_unevictable is analogous to and mutually exclusive with
PG_active--it specifies which LRU list the page is on.
The unevictable infrastructure is enabled by a new mm Kconfig option
[CONFIG_]UNEVICTABLE_LRU.
A new function 'page_evictable(page, vma)' in vmscan.c tests whether or
not a page may be evictable. Subsequent patches will add the various
!evictable tests. We'll want to keep these tests light-weight for use in
shrink_active_list() and, possibly, the fault path.
To avoid races between tasks putting pages [back] onto an LRU list and
tasks that might be moving the page from non-evictable to evictable state,
the new function 'putback_lru_page()' -- inverse to 'isolate_lru_page()'
-- tests the "evictability" of a page after placing it on the LRU, before
dropping the reference. If the page has become unevictable,
putback_lru_page() will redo the 'putback', thus moving the page to the
unevictable list. This way, we avoid "stranding" evictable pages on the
unevictable list.
[akpm@linux-foundation.org: fix fallout from out-of-order merge]
[riel@redhat.com: fix UNEVICTABLE_LRU and !PROC_PAGE_MONITOR build]
[nishimura@mxp.nes.nec.co.jp: remove redundant mapping check]
[kosaki.motohiro@jp.fujitsu.com: unevictable-lru-infrastructure: putback_lru_page()/unevictable page handling rework]
[kosaki.motohiro@jp.fujitsu.com: kill unnecessary lock_page() in vmscan.c]
[kosaki.motohiro@jp.fujitsu.com: revert migration change of unevictable lru infrastructure]
[kosaki.motohiro@jp.fujitsu.com: revert to unevictable-lru-infrastructure-kconfig-fix.patch]
[kosaki.motohiro@jp.fujitsu.com: restore patch failure of vmstat-unevictable-and-mlocked-pages-vm-events.patch]
Debugged-by: Benjamin Kidwell <benjkidwell@yahoo.com>
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Define proper false/noop inline functions for noreclaim page flags when
!defined(CONFIG_UNEVICTABLE_LRU)
Define page_file_cache() function to answer the question:
is page backed by a file?
Originally part of Rik van Riel's split-lru patch. Extracted to make
available for other, independent reclaim patches.
Moved inline function to linux/mm_inline.h where it will be needed by
subsequent "split LRU" and "noreclaim" patches.
Unfortunately this needs to use a page flag, since the PG_swapbacked state
needs to be preserved all the way to the point where the page is last
removed from the LRU. Trying to derive the status from other info in the
page resulted in wrong VM statistics in earlier split VM patchsets.
The total number of page flags in use on a 32 bit machine after this patch
is 19.
[akpm@linux-foundation.org: fix up out-of-order merge fallout]
[hugh@veritas.com: splitlru: shmem_getpage SetPageSwapBacked sooner[
Signed-off-by: MinChan Kim <minchan.kim@gmail.com>
Converting page lock to new locking bitops requires a change of page flag
operation naming, so we might as well convert it to something nicer
(!TestSetPageLocked_Lock => trylock_page, SetPageLocked => set_page_locked).
This also facilitates lockdeping of page lock.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
For anonymous pages without a swap cache backing the check in
page_remove_rmap for the physical dirty bit in page_remove_rmap is
unnecessary. The instructions that are used to check and reset the dirty
bit are expensive. Removing the check noticably speeds up process exit.
In addition the clearing of the dirty bit in __SetPageUptodate is
pointless as well. With these two changes there is no storage key
operation for an anonymous page anymore if it does not hit the swap
space.
The micro benchmark which repeatedly executes an empty shell script
gets about 5% faster.
SLOB reuses two page bits for internal purposes, it overlays PG_active and
PG_private. This is hidden away in slob.c. Document these overlays
explicitly in the main page-flags enum along with all the others.
Signed-off-by: Andy Whitcroft <apw@shadowen.org>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
SLUB reuses two page bits for internal purposes, it overlays PG_active and
PG_error. This is hidden away in slub.c. Document these overlays
Tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
With the recent page flag reorganisation we have a single enum which
defines the valid page flags and their values, nice and clear. However
there are a number of bits which are overloaded by different subsystems.
Firstly there is PG_owner_priv_1 which is used by filesystems and by XEN.
Secondly both SLOB and SLUB use a couple of extra page bits to manage
internal state for pages they own; both overlay other bits. All of these
"aliases" are scattered about the source making it very hard for a reader
to know if the bits are safe to rely on in all contexts; confusion here is
bad.
As we now have a single place where the bits are clearly assigned it makes
sense to clarify the reuse of bits by making the aliases explicit and
visible with the original bit assignments. This patch creates explicit
aliases within the enum itself for the overloaded bits, creates standard
bit accessors PageFoo etc. and uses those throughout.
This version pulls the bit manipulation out to standard named page bit
accessors as suggested by Christoph, it retains the explicit mapping to
the overlayed bits. A fusion of both ideas. This has been SLUB and SLOB
have been compile tested on x86_64 only, and SLUB boot tested. If people
feel this is worth doing then I can run a fuller set of testing.
This patch:
Some page flags are used for more than one purpose, for example
PG_owner_priv_1. Currently there are individual accessors for each user,
each built using the common flag name far away from the bit definitions.
This makes it hard to see all possible uses of these bits.
Now that we have a single enum to generate the bit orders it makes sense
to express overlays in the same place. So create per use aliases for this
bit in the main page-flags enum and use those in the accessors.
[akpm@linux-foundation.org: fix xen]
Minor source code cleanup of page flags in mm/page_alloc.c.
Move the definition of the groups of bits to page-flags.h.
The purpose of this clean up is that the next patch will
conditionally add a page flag to the groups. Doing that
in a header file is cleaner than adding #ifdefs to the
C code.
Signed-off-by: Russ Anderson <rja@sgi.com>
This patch implements Xen save/restore and migration.
Saving is triggered via xenbus, which is polled in
drivers/xen/manage.c. When a suspend request comes in, the kernel
prepares itself for saving by:
1 - Freeze all processes. This is primarily to prevent any
partially-completed pagetable updates from confusing the suspend
process. If CONFIG_PREEMPT isn't defined, then this isn't necessary.
2 - Suspend xenbus and other devices
3 - Stop_machine, to make sure all the other vcpus are quiescent. The
Xen tools require the domain to run its save off vcpu0.
4 - Within the stop_machine state, it pins any unpinned pgds (under
construction or destruction), performs canonicalizes various other
pieces of state (mostly converting mfns to pfns), and finally
5 - Suspend the domain
Restore reverses the steps used to save the domain, ending when all
the frozen processes are thawed.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Having separate page flags for the head and the tail of a compound page allows
the compiler to use bitops instead of operations on a word to check for a tail
page. That is f.e. important for virt_to_head_page() which is used in
various critical code paths (kfree for example):
Code for PageTail(page)
Before:
mov (%rdi),%rdx page->flags
mov %rdx,%rax 3 bytes
and $0x12000,%eax 5 bytes
cmp $0x12000,%rax 6 bytes
je 897 <kfree+0xa7>
After:
mov (%rdi),%rax
test $0x40,%ah (3 bytes)
jne 887 <kfree+0x97>
So we go from 14 bytes to 3 bytes and from 3 instructions to one. From the
use of 2 registers we go to none.
We can only use page flags for this if we have page flags available. This
patch introduces CONFIG_PAGEFLAGS_EXTENDED that is set if pageflags are not
scarce due to SPARSEMEM using page flags for its sectionid on 32 bit NUMA
platforms.
Additional page flag definitions can be added to the CONFIG_PAGEFLAGS_EXTENDED
section in page-flags.h if the functionality depends on PAGEFLAGS_EXTENDED or
if more page flag overlapping tricks are used for the !PAGEFLAGS_EXTENDED
fallback (the upcoming virtual compound patch may hook in here and Rik's/Lee's
additional page flags to solve the reclaim issues could also be added there
[hint... hint... where are these patchsets?]).
Avoiding the overlaying of Pg_reclaim also clears the way for possible use of
compound pages for the pagecache or on the LRU.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Turns out that there are a number of times that a flag is simply always
returning 0. Define a macro for that.
Remove the special setup for PG_uncached and simply make it part of the enum.
The page flag will only be allocated when the kernel build includes the
uncached allocator.
Acked-by: Dean Nelson <dcn@sgi.com>
Cc: Jes Sorensen <jes@trained-monkey.org>
Remove aliases of PG_xxx. We can easily drop those now and alias by
specifying the PG_xxx flag in the macro that generates the functions.
Cc: Andy Whitcroft <apw@shadowen.org>
Xen uses bitops to manipulate page flags. Make it use proper page flag
functions.
Replace explicit definitions of page flags through the use of macros.
Significantly reduces the size of the definitions and removes a lot of
opportunity for errors. Additonal page flags can typically be generated with
a single line.
Introduce a set of macros that generate functions to handle page flags.
A page flag function group typically starts with either
SETPAGEFLAG(<part of function name>,<part of PG_ flagname>)
to create a set of page flag operations that are atomic. Or
__SETPAGEFLAG(<part of function name>,<part of PG_ flagname)
to create a set of page flag operations that are not atomic.
Then additional operations can be added using the following macros
TESTSCFLAG Create additional atomic test-and-set and
test-and-clear functions
TESTSETFLAG Create additional test and set function
TESTCLEARFLAG Create additional test and clear function
SETPAGEFLAG Create additional atomic set function
CLEARPAGEFLAG Create additional atomic clear function
__TESTPAGEFLAG Create additional non atomic set function
__SETPAGEFLAG Create additional non atomic clear function
NR_PAGEFLAGS specifies the number of page flags we are using. From that we
can calculate the number of bits leftover that can be used for zone, node (and
maybe the sections id). There is no need anymore for FLAGS_RESERVED if we use
NR_PAGEFLAGS.
Use the new methods to make NR_PAGEFLAGS available via the preprocessor.
NR_PAGEFLAGS is used to calculate field boundaries in the page flags fields.
These field widths have to be available to the preprocessor.
Use an enum to ease the maintenance of page flags. This is going to change
the numbering from 0 to 18.
