[ Upstream commit 591a3d7c09fa08baff48ad86c2347dbd28a52753 ]
0day testing by Fengguang Wu triggered this crash while running Trinity:
kernel BUG at include/linux/pagemap.h:151!
CPU: 0 PID: 458 Comm: trinity-c0 Not tainted 4.11.0-rc2-00251-g2947ba0 #1
Call Trace:
__get_user_pages_fast()
get_futex_key()
futex_requeue()
do_futex()
SyS_futex()
do_syscall_64()
entry_SYSCALL64_slow_path()
It' VM_BUG_ON() due to false-negative in_atomic(). We call
page_cache_get_speculative() with disabled local interrupts.
It should be atomic enough.
So let's check for disabled interrupts in the VM_BUG_ON() condition
too, to resolve this.
( This got triggered by the conversion of the x86 GUP code to the
generic GUP code. )
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: LKP <lkp@01.org>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/20170324114709.pcytvyb3d6ajux33@black.fi.intel.com
commit e23d4159b109167126e5bcd7f3775c95de7fee47 upstream.
Switching iov_iter fault-in to multipages variants has exposed an old
bug in underlying fault_in_multipages_...(); they break if the range
passed to them wraps around. Normally access_ok() done by callers will
prevent such (and it's a guaranteed EFAULT - ERR_PTR() values fall into
such a range and they should not point to any valid objects).
However, on architectures where userland and kernel live in different
MMU contexts (e.g. s390) access_ok() is a no-op and on those a range
with a wraparound can reach fault_in_multipages_...().
Since any wraparound means EFAULT there, the fix is trivial - turn
those
while (uaddr <= end)
into
if (unlikely(uaddr > end))
return -EFAULT;
do
while (uaddr <= end);
Reported-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
There are many places which use mapping_gfp_mask to restrict a more
generic gfp mask which would be used for allocations which are not
directly related to the page cache but they are performed in the same
context.
Let's introduce a helper function which makes the restriction explicit and
easier to track. This patch doesn't introduce any functional changes.
Signed-off-by: Michal Hocko <mhocko@suse.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
That function was declared in a lot of filesystems to calculate
directory pages.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
When modifying PG_Dirty on cached file pages, update the new
MEM_CGROUP_STAT_DIRTY counter. This is done in the same places where
global NR_FILE_DIRTY is managed. The new memcg stat is visible in the
per memcg memory.stat cgroupfs file. The most recent past attempt at
this was http://thread.gmane.org/gmane.linux.kernel.cgroups/8632
The new accounting supports future efforts to add per cgroup dirty
page throttling and writeback. It also helps an administrator break
down a container's memory usage and provides evidence to understand
memcg oom kills (the new dirty count is included in memcg oom kill
messages).
The ability to move page accounting between memcg
(memory.move_charge_at_immigrate) makes this accounting more
complicated than the global counter. The existing
mem_cgroup_{begin,end}_page_stat() lock is used to serialize move
accounting with stat updates.
Typical update operation:
memcg = mem_cgroup_begin_page_stat(page)
if (TestSetPageDirty()) {
mem_cgroup_update_page_stat(memcg)
mem_cgroup_end_page_stat(memcg)
Summary of mem_cgroup_end_page_stat() overhead:
- Without CONFIG_MEMCG it's a no-op
- With CONFIG_MEMCG and no inter memcg task movement, it's just
rcu_read_lock()
- With CONFIG_MEMCG and inter memcg task movement, it's
rcu_read_lock() + spin_lock_irqsave()
A memcg parameter is added to several routines because their callers
now grab mem_cgroup_begin_page_stat() which returns the memcg later
needed by for mem_cgroup_update_page_stat().
Because mem_cgroup_begin_page_stat() may disable interrupts, some
adjustments are needed:
- move __mark_inode_dirty() from __set_page_dirty() to its caller.
__mark_inode_dirty() locking does not want interrupts disabled.
- use spin_lock_irqsave(tree_lock) rather than spin_lock_irq() in
__delete_from_page_cache(), replace_page_cache_page(),
invalidate_complete_page2(), and __remove_mapping().
8925147 1774832 1785856 12485835 be84cb vmlinux-!CONFIG_MEMCG-before
8925339 1774832 1785856 12486027 be858b vmlinux-!CONFIG_MEMCG-after
+192 text bytes
8965977 1784992 1785856 12536825 bf4bf9 vmlinux-CONFIG_MEMCG-before
8966750 1784992 1785856 12537598 bf4efe vmlinux-CONFIG_MEMCG-after
+773 text bytes
Performance tests run on v4.0-rc1-36-g4f671fe2f952. Lower is better for
all metrics, they're all wall clock or cycle counts. The read and write
fault benchmarks just measure fault time, they do not include I/O time.
* CONFIG_MEMCG not set:
baseline patched
kbuild 1m25.030000(+-0.088% 3 samples) 1m25.426667(+-0.120% 3 samples)
dd write 100 MiB 0.859211561 +-15.10% 0.874162885 +-15.03%
dd write 200 MiB 1.670653105 +-17.87% 1.669384764 +-11.99%
dd write 1000 MiB 8.434691190 +-14.15% 8.474733215 +-14.77%
read fault cycles 254.0(+-0.000% 10 samples) 253.0(+-0.000% 10 samples)
write fault cycles 2021.2(+-3.070% 10 samples) 1984.5(+-1.036% 10 samples)
* CONFIG_MEMCG=y root_memcg:
baseline patched
kbuild 1m25.716667(+-0.105% 3 samples) 1m25.686667(+-0.153% 3 samples)
dd write 100 MiB 0.855650830 +-14.90% 0.887557919 +-14.90%
dd write 200 MiB 1.688322953 +-12.72% 1.667682724 +-13.33%
dd write 1000 MiB 8.418601605 +-14.30% 8.673532299 +-15.00%
read fault cycles 266.0(+-0.000% 10 samples) 266.0(+-0.000% 10 samples)
write fault cycles 2051.7(+-1.349% 10 samples) 2049.6(+-1.686% 10 samples)
* CONFIG_MEMCG=y non-root_memcg:
baseline patched
kbuild 1m26.120000(+-0.273% 3 samples) 1m25.763333(+-0.127% 3 samples)
dd write 100 MiB 0.861723964 +-15.25% 0.818129350 +-14.82%
dd write 200 MiB 1.669887569 +-13.30% 1.698645885 +-13.27%
dd write 1000 MiB 8.383191730 +-14.65% 8.351742280 +-14.52%
read fault cycles 265.7(+-0.172% 10 samples) 267.0(+-0.000% 10 samples)
write fault cycles 2070.6(+-1.512% 10 samples) 2084.4(+-2.148% 10 samples)
As expected anon page faults are not affected by this patch.
tj: Updated to apply on top of the recent cancel_dirty_page() changes.
Signed-off-by: Sha Zhengju <handai.szj@gmail.com>
Signed-off-by: Greg Thelen <gthelen@google.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Commit 2457aec63745 ("mm: non-atomically mark page accessed during page
cache allocation where possible") has added a separate parameter for
specifying gfp mask for radix tree allocations.
Not only this is less than optimal from the API point of view because it
is error prone, it is also buggy currently because
grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if
fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by
AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then
the radix tree allocation wouldn't obey the restriction and might
recurse into filesystem and cause deadlocks. This is the case for most
filesystems unfortunately because only ext4 and gfs2 are using
AOP_FLAG_NOFS.
Let's simply remove radix_gfp_mask parameter because the allocation
context is same for both page cache and for the radix tree. Just make
sure that the radix tree gets only the sane subset of the mask (e.g. do
not pass __GFP_WRITE).
Long term it is more preferable to convert remaining users of
AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this
interface even further.
Reported-by: Dave Chinner <david@fromorbit.com>
Now ballooned pages are detected using PageBalloon(). Fake mapping is no
longer required. This patch links ballooned pages to balloon device using
field page->private instead of page->mapping. Also this patch embeds
balloon_dev_info directly into struct virtio_balloon.
Signed-off-by: Konstantin Khlebnikov <k.khlebnikov@samsung.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Pull NFS client updates from Trond Myklebust:
"Highlights include:
Stable fixes:
- fix an NFSv4.1 state renewal regression
- fix open/lock state recovery error handling
- fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails
- fix statd when reconnection fails
- don't wake tasks during connection abort
- don't start reboot recovery if lease check fails
- fix duplicate proc entries
Features:
- pNFS block driver fixes and clean ups from Christoph
- More code cleanups from Anna
- Improve mmap() writeback performance
- Replace use of PF_TRANS with a more generic mechanism for avoiding
deadlocks in nfs_release_page"
* tag 'nfs-for-3.18-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (66 commits)
NFSv4.1: Fix an NFSv4.1 state renewal regression
NFSv4: fix open/lock state recovery error handling
NFSv4: Fix lock recovery when CREATE_SESSION/SETCLIENTID_CONFIRM fails
NFS: Fabricate fscache server index key correctly
SUNRPC: Add missing support for RPC_CLNT_CREATE_NO_RETRANS_TIMEOUT
NFSv3: Fix missing includes of nfs3_fs.h
NFS/SUNRPC: Remove other deadlock-avoidance mechanisms in nfs_release_page()
NFS: avoid waiting at all in nfs_release_page when congested.
NFS: avoid deadlocks with loop-back mounted NFS filesystems.
MM: export page_wakeup functions
SCHED: add some "wait..on_bit...timeout()" interfaces.
NFS: don't use STABLE writes during writeback.
NFSv4: use exponential retry on NFS4ERR_DELAY for async requests.
rpc: Add -EPERM processing for xs_udp_send_request()
rpc: return sent and err from xs_sendpages()
lockd: Try to reconnect if statd has moved
SUNRPC: Don't wake tasks during connection abort
Fixing lease renewal
nfs: fix duplicate proc entries
pnfs/blocklayout: Fix a 64-bit division/remainder issue in bl_map_stripe
Pull "trivial tree" updates from Jiri Kosina:
"Usual pile from trivial tree everyone is so eagerly waiting for"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Remove MN10300_PROC_MN2WS0038
mei: fix comments
treewide: Fix typos in Kconfig
kprobes: update jprobe_example.c for do_fork() change
Documentation: change "&" to "and" in Documentation/applying-patches.txt
Documentation: remove obsolete pcmcia-cs from Changes
Documentation: update links in Changes
Documentation: Docbook: Fix generated DocBook/kernel-api.xml
score: Remove GENERIC_HAS_IOMAP
gpio: fix 'CONFIG_GPIO_IRQCHIP' comments
tty: doc: Fix grammar in serial/tty
dma-debug: modify check_for_stack output
treewide: fix errors in printk
genirq: fix reference in devm_request_threaded_irq comment
treewide: fix synchronize_rcu() in comments
checkstack.pl: port to AArch64
doc: queue-sysfs: minor fixes
init/do_mounts: better syntax description
MIPS: fix comment spelling
powerpc/simpleboot: fix comment
This will allow NFS to wait for PG_private to be cleared and,
particularly, to send a wake-up when it is.
Signed-off-by: NeilBrown <neilb@suse.de>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
In commit c1221321b7c25b53204447cff9949a6d5a7ddddc
sched: Allow wait_on_bit_action() functions to support a timeout
I suggested that a "wait_on_bit_timeout()" interface would not meet my
need. This isn't true - I was just over-engineering.
Including a 'private' field in wait_bit_key instead of a focused
"timeout" field was just premature generalization. If some other
use is ever found, it can be generalized or added later.
So this patch renames "private" to "timeout" with a meaning "stop
waiting when "jiffies" reaches or passes "timeout",
and adds two of the many possible wait..bit..timeout() interfaces:
wait_on_page_bit_killable_timeout(), which is the one I want to use,
and out_of_line_wait_on_bit_timeout() which is a reasonably general
example. Others can be added as needed.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Corrected a minor typo in a code comment where 'be' was missing.
Signed-off-by: Raymond L. Rivera <ray.l.rivera@gmail.com>
Add a comment describing the circumstances in which
__lock_page_or_retry() will or will not release the mmap_sem when
returning 0.
Add comments to lock_page_or_retry()'s callers (filemap_fault(),
do_swap_page()) noting the impact on VM_FAULT_RETRY returns.
Add comments on up the call tree, particularly replacing the false "We
return with mmap_sem still held" comments.
Signed-off-by: Paul Cassella <cassella@cray.com>
I triggered VM_BUG_ON() in vma_address() when I tried to migrate an
anonymous hugepage with mbind() in the kernel v3.16-rc3. This is
because pgoff's calculation in rmap_walk_anon() fails to consider
compound_order() only to have an incorrect value.
This patch introduces page_to_pgoff(), which gets the page's offset in
PAGE_CACHE_SIZE.
Kirill pointed out that page cache tree should natively handle
hugepages, and in order to make hugetlbfs fit it, page->index of
hugetlbfs page should be in PAGE_CACHE_SIZE. This is beyond this patch,
but page_to_pgoff() contains the point to be fixed in a single function.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Naoya Horiguchi <nao.horiguchi@gmail.com>
possible
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
cold is a bool, make it one. Make the likely case the "if" part of the
block instead of the else as according to the optimisation manual this is
preferred.
page_endio() takes care of updating all the appropriate page flags once
I/O has finished to a page. Switch to using mapping_set_error() instead
of setting AS_EIO directly; this will handle thin-provisioned devices
correctly.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Cc: Dheeraj Reddy <dheeraj.reddy@intel.com>
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
Reclaim will be leaving shadow entries in the page cache radix tree upon
evicting the real page. As those pages are found from the LRU, an
iput() can lead to the inode being freed concurrently. At this point,
reclaim must no longer install shadow pages because the inode freeing
code needs to ensure the page tree is really empty.
Add an address_space flag, AS_EXITING, that the inode freeing code sets
under the tree lock before doing the final truncate. Reclaim will check
for this flag before installing shadow pages.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
The radix tree hole searching code is only used for page cache, for
example the readahead code trying to get a a picture of the area
surrounding a fault.
It sufficed to rely on the radix tree definition of holes, which is
"empty tree slot". But this is about to change, though, as shadow page
descriptors will be stored in the page cache after the actual pages get
evicted from memory.
Move the functions over to mm/filemap.c and make them native page cache
operations, where they can later be adapted to handle the new definition
of "page cache hole".
Most of the VM_BUG_ON assertions are performed on a page. Usually, when
one of these assertions fails we'll get a BUG_ON with a call stack and
the registers.
I've recently noticed based on the requests to add a small piece of code
that dumps the page to various VM_BUG_ON sites that the page dump is
quite useful to people debugging issues in mm.
This patch adds a VM_BUG_ON_PAGE(cond, page) which beyond doing what
VM_BUG_ON() does, also dumps the page before executing the actual
BUG_ON.
[akpm@linux-foundation.org: fix up includes]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
There is an ifdef in page_cache_get_speculative() that checks for !SMP
and TREE_RCU, which has been an impossible combination since the advent
of TINY_RCU. The ifdef enables a fastpath that is valid when preemption
is disabled by rcu_read_lock() in UP systems, which is the case when
TINY_RCU is enabled. This commit therefore adjusts the ifdef to
generate the fastpath when TINY_RCU is enabled.
Reported-by: Andi Kleen <andi@firstfloor.org>
Create a helper function to check if a backing device requires stable
page writes and, if so, performs the necessary wait. Then, make it so
that all points in the memory manager that handle making pages writable
use the helper function. This should provide stable page write support
to most filesystems, while eliminating unnecessary waiting for devices
that don't require the feature.
Before this patchset, all filesystems would block, regardless of whether
or not it was necessary. ext3 would wait, but still generate occasional
checksum errors. The network filesystems were left to do their own
thing, so they'd wait too.
After this patchset, all the disk filesystems except ext3 and btrfs will
wait only if the hardware requires it. ext3 (if necessary) snapshots
pages instead of blocking, and btrfs provides its own bdi so the mm will
never wait. Network filesystems haven't been touched, so either they
provide their own stable page guarantees or they don't block at all.
The blocking behavior is back to what it was before 3.0 if you don't
have a disk requiring stable page writes.
Here's the result of using dbench to test latency on ext2:
3.8.0-rc3:
Operation Count AvgLat MaxLat
WriteX 109347 0.028 59.817
ReadX 347180 0.004 3.391
Flush 15514 29.828 287.283
Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms
3.8.0-rc3 + patches:
WriteX 105556 0.029 4.273
ReadX 335004 0.005 4.112
Flush 14982 30.540 298.634
Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms
As you can see, the maximum write latency drops considerably with this
patch enabled. The other filesystems (ext3/ext4/xfs/btrfs) behave
similarly, but see the cover letter for those results.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Memory fragmentation introduced by ballooning might reduce significantly
the number of 2MB contiguous memory blocks that can be used within a guest,
thus imposing performance penalties associated with the reduced number of
transparent huge pages that could be used by the guest workload.
This patch introduces a common interface to help a balloon driver on
making its page set movable to compaction, and thus allowing the system
to better leverage the compation efforts on memory defragmentation.
[akpm@linux-foundation.org: use PAGE_FLAGS_CHECK_AT_PREP, s/__balloon_page_flags/page_flags_cleared/, small cleanups]
[rientjes@google.com: allow balloon compaction for any system with memory compaction enabled, which is the defconfig]
Signed-off-by: Rafael Aquini <aquini@redhat.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Minchan Kim <minchan@kernel.org>
Signed-off-by: David Rientjes <rientjes@google.com>
In order to teach filesystems to handle swap cache pages, three new page
functions are introduced:
pgoff_t page_file_index(struct page *);
loff_t page_file_offset(struct page *);
struct address_space *page_file_mapping(struct page *);
page_file_index() - gives the offset of this page in the file in
PAGE_CACHE_SIZE blocks. Like page->index is for mapped pages, this
function also gives the correct index for PG_swapcache pages.
page_file_offset() - uses page_file_index(), so that it will give the
expected result, even for PG_swapcache pages.
page_file_mapping() - gives the mapping backing the actual page; that is
for swap cache pages it will give swap_file->f_mapping.
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Eric Paris <eparis@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Neil Brown <neilb@suse.de>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: Xiaotian Feng <dfeng@redhat.com>
Commit f56f821feb7b ("mm: extend prefault helpers to fault in more than
PAGE_SIZE") added in the new functions: fault_in_multipages_writeable()
and fault_in_multipages_readable().
However, we currently see:
include/linux/pagemap.h:492: warning: 'ret' may be used uninitialized in this function
include/linux/pagemap.h:492: note: 'ret' was declared here
Unlike a lot of gcc nags, this one appears somewhat legit. i.e. passing
in an invalid negative value of "size" does make it look like all the
conditionals in there would be bypassed and the uninitialized value would
be returned.
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
This regression has been introduced in
commit f56f821feb7b36223f309e0ec05986bb137ce418
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Sun Mar 25 19:47:41 2012 +0200
mm: extend prefault helpers to fault in more than PAGE_SIZE
I have failed to notice this because x86 asm seems to happily compile
things as-is.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
drm/i915 wants to read/write more than one page in its fastpath
and hence needs to prefault more than PAGE_SIZE bytes.
Add new functions in filemap.h to make that possible.
Also kill a copy&pasted spurious space in both functions while at it.
v2: As suggested by Andrew Morton, add a multipage parameter to both
functions to avoid the additional branch for the pagemap.c hotpath.
My gcc 4.6 here seems to dtrt and indeed reap these branches where not
needed.
v3: Becaus I couldn't find a way around adding a uaddr += PAGE_SIZE to
the filemap.c hotpaths (that the compiler couldn't remove again),
let's go with separate new functions for the multipage use-case.
v4: Adjust comment to CodingStlye and fix spelling.
The often-NULL data arg to read_cache_page() and read_mapping_page()
functions is misdescribed as "destination for read data": no, it's the
first arg to the filler function, often struct file * to ->readpage().
Satisfy checkpatch.pl on those filler prototypes, and tidy up the
declarations in linux/pagemap.h.
Create a new CONFIG_PREEMPT_COUNT that handles the inc/dec
of preempt count offset independently. So that the offset
can be updated by preempt_disable() and preempt_enable()
even without the need for CONFIG_PREEMPT beeing set.
This prepares to make CONFIG_DEBUG_SPINLOCK_SLEEP working
with !CONFIG_PREEMPT where it currently doesn't detect
code that sleeps inside explicit preemption disabled
sections.
Pass __GFP_NORETRY|__GFP_NOWARN for readahead page allocations.
readahead page allocations are completely optional. They are OK to fail
and in particular shall not trigger OOM on themselves.
Reported-by: Dave Young <hidave.darkstar@gmail.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: Pekka Enberg <penberg@kernel.org>
commit 2687a356 ("Add lock_page_killable") introduced killable
lock_page(). Similarly this patch introdues killable
wait_on_page_locked().
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
Now we renamed remove_from_page_cache with delete_from_page_cache. As
consistency of __remove_from_swap_cache and remove_from_swap_cache, we
change internal page cache handling function name, too.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Now delete_from_page_cache() replaces remove_from_page_cache(). So we
remove remove_from_page_cache so fs or something out of mainline will
notice it when compile time and can fix it.
Presently we increase the page refcount in add_to_page_cache() but don't
decrease it in remove_from_page_cache(). Such asymmetry adds confusion,
requiring that callers notice it and a comment explaining why they release
a page reference. It's not a good API.
A long time ago, Hugh tried it (http://lkml.org/lkml/2004/10/24/140) but
gave up because reiser4's drop_page() had to unlock the page between
removing it from page cache and doing the page_cache_release(). But now
the situation is changed. I think at least things in current mainline
don't have any obstacles. The problem is for out-of-mainline filesystems
- if they have done such things as reiser4, this patch could be a problem
but they will discover this at compile time since we remove
This patch:
This function works as just wrapper remove_from_page_cache(). The
difference is that it decreases page references in itself. So caller have
to make sure it has a page reference before calling.
This patch is ready for removing remove_from_page_cache().
Cc: Edward Shishkin <edward.shishkin@gmail.com>
This function basically does:
remove_from_page_cache(old);
page_cache_release(old);
add_to_page_cache_locked(new);
Except it does this atomically, so there's no possibility for the "add" to
fail because of a race.
If memory cgroups are enabled, then the memory cgroup charge is also moved
from the old page to the new.
This function is currently used by fuse to move pages into the page cache
on read, instead of copying the page contents.
[minchan.kim@gmail.com: add freepage() hook to replace_page_cache_page()]
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
The mapping_unevictable() has a likely() around the mapping parameter.
This mapping parameter comes from page_mapping() which has an unlikely()
that the page will be set as PAGE_MAPPING_ANON, and if so, it will return
NULL. One would think that this unlikely() means that the mapping
returned by page_mapping() would not be NULL, but where page_mapping() is
used just above mapping_unevictable(), that unlikely() is incorrect most
of the time. This means that the "likely(mapping)" in
mapping_unevictable() is incorrect most of the time.
Running the annotated branch profiler on my main box which runs firefox,
evolution, xchat and is part of my distcc farm, I had this:
correct incorrect % Function File Line
12872836 1269443893 98 mapping_unevictable pagemap.h 51
35935762 1270265395 97 page_mapping mm.h 659
1306198001 143659 0 page_mapping mm.h 657
203131478 121586 0 page_mapping mm.h 657
5415491 1116 0 page_mapping mm.h 657
74899487 1116 0 page_mapping mm.h 657
203132845 224 0 page_mapping mm.h 659
5415464 27 0 page_mapping mm.h 659
13552 0 0 page_mapping mm.h 657
13552 0 0 page_mapping mm.h 659
242630 0 0 page_mapping mm.h 657
242630 0 0 page_mapping mm.h 659
74899487 0 0 page_mapping mm.h 659
The page_mapping() is a static inline, which is why it shows up multiple
times. The mapping_unevictable() is also a static inline but seems to be
used only once in my setup.
The unlikely in page_mapping() was correct a total of 1909540379 times and
incorrect 1270533123 times, with a 39% being incorrect. Perhaps this is
enough to remove the unlikely from page_mapping() as well.
Acked-by: Nick Piggin <npiggin@kernel.dk>
This change reduces mmap_sem hold times that are caused by waiting for
disk transfers when accessing file mapped VMAs.
It introduces the VM_FAULT_ALLOW_RETRY flag, which indicates that the call
site wants mmap_sem to be released if blocking on a pending disk transfer.
In that case, filemap_fault() returns the VM_FAULT_RETRY status bit and
do_page_fault() will then re-acquire mmap_sem and retry the page fault.
It is expected that the retry will hit the same page which will now be
cached, and thus it will complete with a low mmap_sem hold time.
Tests:
- microbenchmark: thread A mmaps a large file and does random read accesses
to the mmaped area - achieves about 55 iterations/s. Thread B does
mmap/munmap in a loop at a separate location - achieves 55 iterations/s
before, 15000 iterations/s after.
- We are seeing related effects in some applications in house, which show
significant performance regressions when running without this change.
[akpm@linux-foundation.org: fix warning & crash]
Signed-off-by: Michel Lespinasse <walken@google.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Reviewed-by: Wu Fengguang <fengguang.wu@intel.com>
Cc: Ying Han <yinghan@google.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Cc: <linux-arch@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6
* 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6:
hugetlb: add missing unlock in avoidcopy path in hugetlb_cow()
hwpoison: rename CONFIG
HWPOISON, hugetlb: support hwpoison injection for hugepage
HWPOISON, hugetlb: detect hwpoison in hugetlb code
HWPOISON, hugetlb: isolate corrupted hugepage
HWPOISON, hugetlb: maintain mce_bad_pages in handling hugepage error
HWPOISON, hugetlb: set/clear PG_hwpoison bits on hugepage
HWPOISON, hugetlb: enable error handling path for hugepage
hugetlb, rmap: add reverse mapping for hugepage
hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h
Fix up trivial conflicts in mm/memory-failure.c
This patch adds reverse mapping feature for hugepage by introducing
mapcount for shared/private-mapped hugepage and anon_vma for
private-mapped hugepage.
While hugepage is not currently swappable, reverse mapping can be useful
for memory error handler.
Without this patch, memory error handler cannot identify processes
using the bad hugepage nor unmap it from them. That is:
- for shared hugepage:
we can collect processes using a hugepage through pagecache,
but can not unmap the hugepage because of the lack of mapcount.
- for privately mapped hugepage:
we can neither collect processes nor unmap the hugepage.
This patch solves these problems.
This patch include the bug fix given by commit 23be7468e8, so reverts it.
Dependency:
"hugetlb: move definition of is_vm_hugetlb_page() to hugepage_inline.h"
ChangeLog since May 24.
- create hugetlb_inline.h and move is_vm_hugetlb_index() in it.
- move functions setting up anon_vma for hugepage into mm/rmap.c.
ChangeLog since May 13.
- rebased to 2.6.34
- fix logic error (in case that private mapping and shared mapping coexist)
- move is_vm_hugetlb_page() into include/linux/mm.h to use this function
from linear_page_index()
- define and use linear_hugepage_index() instead of compound_order()
- use page_move_anon_rmap() in hugetlb_cow()
- copy exclusive switch of __set_page_anon_rmap() into hugepage counterpart.
- revert commit 24be7468 completely
Cc: Larry Woodman <lwoodman@redhat.com>
Acked-by: Fengguang Wu <fengguang.wu@intel.com>
is_vm_hugetlb_page() is a widely used inline function to insert hooks
into hugetlb code.
But we can't use it in pagemap.h because of circular dependency of
the header files. This patch removes this limitation.
Avoid quite a lot of warnings in header files in a gcc 4.6 -Wall builds
It's a simplified 'read_cache_page()' which takes a page allocation
flag, so that different paths can control how aggressive the memory
allocations are that populate a address space.
In particular, the intel GPU object mapping code wants to be able to do
a certain amount of own internal memory management by automatically
shrinking the address space when memory starts getting tight. This
allows it to dynamically use different memory allocation policies on a
per-allocation basis, rather than depend on the (static) address space
gfp policy.
The actual new function is a one-liner, but re-organizing the helper
functions to the point where you can do this with a single line of code
is what most of the patch is all about.
Tested-by: Chris Wilson <chris@chris-wilson.co.uk>
A couple of references to CONFIG_CLASSIC_RCU have survived.
Although these are harmless, it is past time for them to go.
The one in hardirq.h is strictly a readability problem.
The two in pagemap.h appear to disable a !SMP performance
optimization (which this patch re-enables).
This does raise the issue as to whether pagemap.h should really
be referring to the CPU implementation. Long term, I intend to
make the RCU implementation driven by CONFIG_PREEMPT, at which
point these should change from defined(CONFIG_TREE_RCU) to
!defined(CONFIG_PREEMPT). In the meantime, is there something
else that could be done in pagemap.h?
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: akpm@linux-foundation.org
Cc: mathieu.desnoyers@polymtl.ca
Cc: josht@linux.vnet.ibm.com
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
LKML-Reference: <20090822050851.GA8414@linux.vnet.ibm.com>
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this
configurability is unnecessary.
Acked-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Add a function to install a monitor on the page lock waitqueue for a particular
page, thus allowing the page being unlocked to be detected.
This is used by CacheFiles to detect read completion on a page in the backing
filesystem so that it can then copy the data to the waiting netfs page.
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
