path: root/include/linux/parport_pc.h
2007-05-08parport->dev driver model supportDavid Brownell
Currently a parport_driver can't get a handle on the device node for the underlying parport (PNPACPI, PCI, etc). That prevents correct placement of sysfs child nodes, which can affect things like power management. This patch adds a field to "struct parport" pointing to that device node, and updates non-legacy port drivers to initialize that device pointer. That field replaces the analagous PCI-only support in parport_pc. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-06[PATCH] include/linux/parport_pc.h: "extern inline" -> "static inline"Adrian Bunk
"extern inline" doesn't make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] parport: DEBUG_PARPORT build fixMarko Kohtala
Add missing "struct" keyword preventing compilation with DEBUG_PARPORT defined. Also add some "const". Signed-off-by: Marko Kohtala <marko.kohtala@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] broken cast in parport_pcDave Jones
Spotted by a Fedora user. Compiling with DEBUG_PARPORT set fails due to the broken cast. Just remove it. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
