path: root/include/linux/parser.h
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-06parser: add u64 number parserJames Smart
Will be used by the nvme-fabrics FC transport in parsing options Signed-off-by: James Smart <james.smart@broadcom.com> Signed-off-by: Sagi Grimberg <sagi@grimberg.me>
2014-01-23lib/parser.c: add match_wildcard() functionDu, Changbin
match_wildcard function is a simple implementation of wildcard matching algorithm. It only supports two usual wildcardes: '*' - matches zero or more characters '?' - matches one character This algorithm is safe since it is non-recursive. Signed-off-by: Du, Changbin <changbin.du@gmail.com> Cc: Jason Baron <jbaron@akamai.com> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-04Revert "UFS: add const to parser token table"Linus Torvalds
This reverts commit f9247273cb69ba101877e946d2d83044409cc8c5 (and fb2e405fc1fc8b20d9c78eaa1c7fd5a297efde43 - "fix fs/nfs/nfsroot.c compilation" - that fixed a missed conversion). The changes cause problems for at least the sparc build. Let's re-do them when the exact issues are resolved. Requested-by: Andrew Morton <akpm@linux-foundation.org> Requested-by: Steven Whitehouse <swhiteho@redhat.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24UFS: add const to parser token tableSteven Whitehouse
This patch adds a "const" to the parser token table. I've done an allmodconfig build to see if this produces any warnings/failures and the patch includes a fix for the only warning that was produced. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Alexander Viro <aviro@redhat.com> Acked-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14add match_strlcpy() us it to make v9fs make uname and remotename parsing ↵Markus Armbruster
more robust match_strcpy() is a somewhat creepy function: the caller needs to make sure that the destination buffer is big enough, and when he screws up or forgets, match_strcpy() happily overruns the buffer. There's exactly one customer: v9fs_parse_options(). I believe it currently can't overflow its buffer, but that's not exactly obvious. The source string is a substing of the mount options. The kernel silently truncates those to PAGE_SIZE bytes, including the terminating zero. See compat_sys_mount() and do_mount(). The destination buffer is obtained from __getname(), which allocates from name_cachep, which is initialized by vfs_caches_init() for size PATH_MAX. We're safe as long as PATH_MAX <= PAGE_SIZE. PATH_MAX is 4096. As far as I know, the smallest PAGE_SIZE is also 4096. Here's a patch that makes the code a bit more obviously correct. It doesn't depend on PATH_MAX <= PAGE_SIZE. Signed-off-by: Markus Armbruster <armbru@redhat.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Jim Meyering <meyering@redhat.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-05-05Fix nfsroot buildRalf Baechle
CC fs/nfs/nfsroot.o fs/nfs/nfsroot.c:131: error: tokens causes a section type conflict make[2]: *** [fs/nfs/nfsroot.o] Error 1 This is due to mixing const and non-const content in the same section which halfway recent gccs absolutely hate. Fixed by dropping the const. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03[AFS]: Make the match_*() functions take const options.David Howells
Make the match_*() functions take a const pointer to the options table and make strings pointers in the options table const too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
