[ Upstream commit 817f9916a6e96ae43acdd4e75459ef4f92d96eb1 ]
The CONFIG_PCI=y case got a new parameter long time ago. Sync the stub as
well.
[bhelgaas: add parameter names]
Fixes: 725522b5453d ("PCI: add the sysfs driver name to all modules")
Link: https://lore.kernel.org/r/20210813153619.89574-1-andriy.shevchenko@linux.intel.com
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit e784930bd645e7df78c66e7872fec282b0620075 upstream.
Export pcie_find_root_port() so we can use it outside of PCIe-AER error
injection.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
commit 67b4eab91caf2ad574cab1b17ae09180ea2e116e upstream.
Revert 811a4e6fce09 ("PCI: Add helpers to manage pci_dev->irq and
pci_dev->irq_managed").
This is part of reverting 991de2e59090 ("PCI, x86: Implement
pcibios_alloc_irq() and pcibios_free_irq()") to fix regressions it
introduced.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=111211
Fixes: 991de2e59090 ("PCI, x86: Implement pcibios_alloc_irq() and pcibios_free_irq()")
Acked-by: Rafael J. Wysocki <rafael@kernel.org>
CC: Jiang Liu <jiang.liu@linux.intel.com>
commit b84106b4e2290c081cdab521fa832596cdfea246 upstream.
The PCI config header (first 64 bytes of each device's config space) is
defined by the PCI spec so generic software can identify the device and
manage its usage of I/O, memory, and IRQ resources.
Some non-spec-compliant devices put registers other than BARs where the
BARs should be. When the PCI core sizes these "BARs", the reads and writes
it does may have unwanted side effects, and the "BAR" may appear to
describe non-sensical address space.
Add a flag bit to mark non-compliant devices so we don't touch their BARs.
Turn off IO/MEM decoding to prevent the devices from consuming address
space, since we can't read the BARs to find out what that address space
would be.
Tested-by: Andi Kleen <ak@linux.intel.com>
Commit b3a72384fe29 ("ARM/PCI: Replace pci_sys_data->align_resource with
global function pointer") introduced an ARM-specific align_resource()
function pointer. This is not portable to other arches and doesn't work
for platforms with two different PCIe host bridge controllers.
Move the function pointer to the pci_host_bridge structure so each host
bridge driver can specify its own align_resource() function.
Signed-off-by: Gabriele Paoloni <gabriele.paoloni@huawei.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
The Chelsio T5 has a PCIe compliance erratum that causes Malformed TLP or
Unexpected Completion errors in some systems, which may cause device access
timeouts.
Per PCIe r3.0, sec 2.2.9, "Completion headers must supply the same values
for the Attribute as were supplied in the header of the corresponding
Request, except as explicitly allowed when IDO is used."
Instead of copying the Attributes from the Request to the Completion, the
T5 always generates Completions with zero Attributes. The receiver of a
Completion whose Attributes don't match the Request may accept it (which
itself seems non-compliant based on sec 2.3.2), or it may handle it as a
Malformed TLP or an Unexpected Completion, which will probably lead to a
device access timeout.
Work around this by disabling "Relaxed Ordering" and "No Snoop" in the Root
Port so it always generate Requests with zero Attributes.
This does affect all other devices which are downstream of that Root Port,
but these are performance optimizations that should not make a functional
difference.
Note that Configuration Space accesses are never supposed to have TLP
Attributes, so we're safe waiting till after any Configuration Space
accesses to do the Root Port "fixup".
Based on original work by Casey Leedom <leedom@chelsio.com>
[bhelgaas: changelog, comments, rename to pci_find_pcie_root_port(), rework
to use pci_upstream_bridge() and check for Root Port device type, edit
diagnostics to clarify intent and devices affected]
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
In f309d4443130 ("platform_device: better support builtin boilerplate
avoidance"), we introduced the builtin_driver() macro.
Here we use that support and extend it to PCI driver registration, so where
a driver is clearly non-modular and builtin-only, we can register it in a
similar fashion. Existing code that is clearly non-modular can be updated
with the simple mapping of
module_pci_driver(...) ---> builtin_pci_driver(...)
We've essentially cloned the former to make the latter, and taken out the
remove/module_exit parts since those never get used in a non-modular build
of the code.
Add a wrapper function for pci_pool_alloc() to get zeroed memory.
Signed-off-by: Sean O. Stalley <sean.stalley@intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Gilles Muller <Gilles.Muller@lip6.fr>
Cc: Nicolas Palix <nicolas.palix@imag.fr>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Jonathan Corbet <corbet@lwn.net>
Pull irq updates from Thomas Gleixner:
"This updated pull request does not contain the last few GIC related
patches which were reported to cause a regression. There is a fix
available, but I let it breed for a couple of days first.
The irq departement provides:
- new infrastructure to support non PCI based MSI interrupts
- a couple of new irq chip drivers
- the usual pile of fixlets and updates to irq chip drivers
- preparatory changes for removal of the irq argument from interrupt
flow handlers
- preparatory changes to remove IRQF_VALID"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
irqchip/imx-gpcv2: IMX GPCv2 driver for wakeup sources
irqchip: Add bcm2836 interrupt controller for Raspberry Pi 2
irqchip: Add documentation for the bcm2836 interrupt controller
irqchip/bcm2835: Add support for being used as a second level controller
irqchip/bcm2835: Refactor handle_IRQ() calls out of MAKE_HWIRQ
PCI: xilinx: Fix typo in function name
irqchip/gic: Ensure gic_cpu_if_up/down() programs correct GIC instance
irqchip/gic: Only allow the primary GIC to set the CPU map
PCI/MSI: pci-xgene-msi: Consolidate chained IRQ handler install/remove
unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
tile/pci_gx: Prepare trio_handle_level_irq for irq argument removal
m68k/irq: Prepare irq handlers for irq argument removal
C6X/megamode-pic: Prepare megamod_irq_cascade for irq argument removal
blackfin: Prepare irq handlers for irq argument removal
arc/irq: Prepare idu_cascade_isr for irq argument removal
sparc/irq: Use access helper irq_data_get_affinity_mask()
sparc/irq: Use helper irq_data_get_irq_handler_data()
parisc/irq: Use access helper irq_data_get_affinity_mask()
mn10300/irq: Use access helper irq_data_get_affinity_mask()
irqchip/i8259: Prepare i8259_irq_dispatch for irq argument removal
Pull x86 mm updates from Ingo Molnar:
"The dominant change in this cycle was the continued work to isolate
kernel drivers from MTRR legacies: this tree gets rid of all kernel
internal driver interfaces to MTRRs (mostly by rewriting it to proper
PAT interfaces), the only access left is the /proc/mtrr ABI.
This work was done by Luis R Rodriguez.
There's also some related PCI interface additions for which I've
Cc:-ed Bjorn"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
x86/mm/mtrr: Remove kernel internal MTRR interfaces: unexport mtrr_add() and mtrr_del()
s390/io: Add pci_iomap_wc() and pci_iomap_wc_range()
drivers/dma/iop-adma: Use dma_alloc_writecombine() kernel-style
drivers/video/fbdev/vt8623fb: Use arch_phys_wc_add() and pci_iomap_wc()
drivers/video/fbdev/s3fb: Use arch_phys_wc_add() and pci_iomap_wc()
drivers/video/fbdev/arkfb.c: Use arch_phys_wc_add() and pci_iomap_wc()
PCI: Add pci_iomap_wc() variants
drivers/video/fbdev/gxt4500: Use pci_ioremap_wc_bar() to map framebuffer
drivers/video/fbdev/kyrofb: Use arch_phys_wc_add() and pci_ioremap_wc_bar()
drivers/video/fbdev/i740fb: Use arch_phys_wc_add() and pci_ioremap_wc_bar()
PCI: Add pci_ioremap_wc_bar()
x86/mm: Make kernel/check.c explicitly non-modular
x86/mm/pat: Make mm/pageattr[-test].c explicitly non-modular
x86/mm/pat: Add comments to cachemode translation tables
arch/*/io.h: Add ioremap_uc() to all architectures
drivers/video/fbdev/atyfb: Use arch_phys_wc_add() and ioremap_wc()
drivers/video/fbdev/atyfb: Replace MTRR UC hole with strong UC
drivers/video/fbdev/atyfb: Clarify ioremap() base and length used
drivers/video/fbdev/atyfb: Carve out framebuffer length fudging into a helper
x86/mm, asm-generic: Add IOMMU ioremap_uc() variant default
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"PCI changes for the v4.3 merge window:
Enumeration:
- Allocate ATS struct during enumeration (Bjorn Helgaas)
- Embed ATS info directly into struct pci_dev (Bjorn Helgaas)
- Reduce size of ATS structure elements (Bjorn Helgaas)
- Stop caching ATS Invalidate Queue Depth (Bjorn Helgaas)
- iommu/vt-d: Cache PCI ATS state and Invalidate Queue Depth (Bjorn Helgaas)
- Move MPS configuration check to pci_configure_device() (Bjorn Helgaas)
- Set MPS to match upstream bridge (Keith Busch)
- ARM/PCI: Set MPS before pci_bus_add_devices() (Murali Karicheri)
- Add pci_scan_root_bus_msi() (Lorenzo Pieralisi)
- ARM/PCI, designware, xilinx: Use pci_scan_root_bus_msi() (Lorenzo Pieralisi)
Resource management:
- Call pci_read_bridge_bases() from core instead of arch code (Lorenzo Pieralisi)
PCI device hotplug:
- pciehp: Remove unused interrupt events (Bjorn Helgaas)
- pciehp: Remove ignored MRL sensor interrupt events (Bjorn Helgaas)
- pciehp: Handle invalid data when reading from non-existent devices (Jarod Wilson)
- pciehp: Simplify pcie_poll_cmd() (Yijing Wang)
- Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot (Yijing Wang)
- Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem (Yijing Wang)
- Hold pci_slot_mutex while searching bus->slots list (Yijing Wang)
Power management:
- Disable async suspend/resume for JMicron multi-function SATA/AHCI (Zhang Rui)
Virtualization:
- Add ACS quirks for Intel I219-LM/V (Alex Williamson)
- Restore ACS configuration as part of pci_restore_state() (Alexander Duyck)
MSI:
- Add pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- x86: Implement pcibios_alloc_irq() and pcibios_free_irq() (Jiang Liu)
- Add helpers to manage pci_dev->irq and pci_dev->irq_managed (Jiang Liu)
- Free legacy IRQ when enabling MSI/MSI-X (Jiang Liu)
- ARM/PCI: Remove msi_controller from struct pci_sys_data (Lorenzo Pieralisi)
- Remove unused pcibios_msi_controller() hook (Lorenzo Pieralisi)
Generic host bridge driver:
- Remove dependency on ARM-specific struct hw_pci (Jayachandran C)
- Build setup-irq.o for arm64 (Jayachandran C)
- Add arm64 support (Jayachandran C)
APM X-Gene host bridge driver:
- Add APM X-Gene PCIe 64-bit prefetchable window (Duc Dang)
- Add support for a 64-bit prefetchable memory window (Duc Dang)
- Drop owner assignment from platform_driver (Krzysztof Kozlowski)
Broadcom iProc host bridge driver:
- Allow BCMA bus driver to be built as module (Hauke Mehrtens)
- Delete unnecessary checks before phy calls (Markus Elfring)
- Add arm64 support (Ray Jui)
Synopsys DesignWare host bridge driver:
- Don't complain missing *config* reg space if va_cfg0 is set (Murali Karicheri)
TI DRA7xx host bridge driver:
- Disable pm_runtime on get_sync failure (Kishon Vijay Abraham I)
- Add PM support (Kishon Vijay Abraham I)
- Clear MSE bit during suspend so clocks will idle (Kishon Vijay Abraham I)
- Add support to make GPIO drive PERST# line (Kishon Vijay Abraham I)
Xilinx AXI host bridge driver:
- Check for MSI interrupt flag before handling as INTx (Russell Joyce)
Miscellaneous:
- Fix Intersil/Techwell TW686[4589] AV capture class code (Krzysztof Hałasa)
- Use PCI_CLASS_SERIAL_USB instead of bare number (Bjorn Helgaas)
- Fix generic NCR 53c810 class code quirk (Bjorn Helgaas)
- Fix TI816X class code quirk (Bjorn Helgaas)
- Remove unused "pci_probe" flags (Bjorn Helgaas)
- Host bridge driver code simplifications (Fabio Estevam)
- Add dev_flags bit to access VPD through function 0 (Mark Rustad)
- Add VPD function 0 quirk for Intel Ethernet devices (Mark Rustad)
- Kill off set_irq_flags() usage (Rob Herring)
- Remove Intel Cherrytrail D3 delays (Srinidhi Kasagar)
- Clean up pci_find_capability() (Wei Yang)"
* tag 'pci-v4.3-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (72 commits)
PCI: Disable async suspend/resume for JMicron multi-function SATA/AHCI
PCI: Set MPS to match upstream bridge
PCI: Move MPS configuration check to pci_configure_device()
PCI: Drop references acquired by of_parse_phandle()
PCI/MSI: Remove unused pcibios_msi_controller() hook
PCI: Add pci_scan_root_bus_msi()
ARM/PCI: Replace panic with WARN messages on failures
PCI: generic: Add arm64 support
PCI: Build setup-irq.o for arm64
PCI: generic: Remove dependency on ARM-specific struct hw_pci
PCI: imx6: Simplify a trivial if-return sequence
PCI: spear: Use BUG_ON() instead of condition followed by BUG()
PCI: dra7xx: Remove unneeded use of IS_ERR_VALUE()
PCI: Remove pci_ats_enabled()
PCI: Stop caching ATS Invalidate Queue Depth
PCI: Move ATS declarations to linux/pci.h so they're all together
PCI: Clean up ATS error handling
PCI: Use pci_physfn() rather than looking up physfn by hand
* pci/enumeration:
* pci/misc:
Commit 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel
doesn't support MSI") changed the location of the code that initialises
dev->msi_cap/msix_cap and then disables MSI/MSI-X interrupts at PCI
probe time in devices that have this flag set. It moved the code from
pci_msi_init_pci_dev() to a new function named pci_msi_setup_pci_dev(),
called by pci_setup_device().
The pseries PCI probing code does not call pci_setup_device(), so since
the aforementioned commit the function pci_msi_setup_pci_dev() is not
called and MSI/MSI-X interrupts are left enabled. Additionally because
dev->msi_cap/msix_cap are not initialised no driver can ever enable
MSI/MSI-X.
To fix this, the pseries PCI probe should manually call
pci_msi_setup_pci_dev(), so this patch makes it non-static.
Fixes: 1851617cd2da ("PCI/MSI: Disable MSI at enumeration even if kernel doesn't support MSI")
[mpe: Update change log to mention dev->msi_cap/msix_cap]
Signed-off-by: Guilherme G. Piccoli <gpiccoli@linux.vnet.ibm.com>
This lets drivers take advantage of PAT when available. It
should help with the transition of converting video drivers over
to ioremap_wc() to help with the goal of eventually using
_PAGE_CACHE_UC over _PAGE_CACHE_UC_MINUS on x86 on
ioremap_nocache(), see:
de33c442ed2a ("x86 PAT: fix performance drop for glx, use UC minus for ioremap(), ioremap_nocache() and pci_mmap_page_range()")
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Cc: <syrjala@sci.fi>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Ville Syrjälä <syrjala@sci.fi>
Cc: airlied@linux.ie
Cc: benh@kernel.crashing.org
Cc: dan.j.williams@intel.com
Cc: konrad.wilk@oracle.com
Cc: linux-fbdev@vger.kernel.org
Cc: linux-pci@vger.kernel.org
Cc: mst@redhat.com
Cc: vinod.koul@intel.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1440443613-13696-2-git-send-email-mcgrof@do-not-panic.com
Firmware typically configures the PCIe fabric with a consistent Max Payload
Size setting based on the devices present at boot. A hot-added device
typically has the power-on default MPS setting (128 bytes), which may not
match the fabric.
The previous Linux default, in the absence of any "pci=pcie_bus_*" options,
was PCIE_BUS_TUNE_OFF, in which we never touch MPS, even for hot-added
devices.
Add a new default setting, PCIE_BUS_DEFAULT, in which we make sure every
device's MPS setting matches the upstream bridge. This makes it more
likely that a hot-added device will work in a system with optimized MPS
configuration.
Note that if we hot-add a device that only supports 128-byte MPS, it still
likely won't work because we don't reconfigure the rest of the fabric.
Booting with "pci=pcie_bus_peer2peer" is a workaround for this because it
sets MPS to 128 for everything.
[bhelgaas: changelog, new default, rework for pci_configure_device() path]
Tested-by: Keith Busch <keith.busch@intel.com>
Tested-by: Jordan Hargrave <jharg93@gmail.com>
Signed-off-by: Keith Busch <keith.busch@intel.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Add a pci_scan_root_bus_msi() interface so an arch can specify the MSI
controller up front. This removes the need for a pcibios callback to set
the MSI controller later.
This is not exported because I'd like to replace the variety of "scan root
bus" interfaces with a single, more extensible interface that can handle
the MSI controller, domain, pci_ops, resources, etc. I hope this interface
is temporary.
[bhelgaas: changelog, split into separate patch]
Suggested-by: Russell King <linux@arm.linux.org.uk>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Jingoo Han <jingoohan1@gmail.com>
'pci/virtualization' into next
* pci/hotplug:
PCI: pciehp: Remove ignored MRL sensor interrupt events
PCI: pciehp: Remove unused interrupt events
PCI: pciehp: Handle invalid data when reading from non-existent devices
PCI: Hold pci_slot_mutex while searching bus->slots list
PCI: Protect pci_bus->slots with pci_slot_mutex, not pci_bus_sem
PCI: pciehp: Simplify pcie_poll_cmd()
PCI: Use "slot" and "pci_slot" for struct hotplug_slot and struct pci_slot
* pci/iommu:
PCI: Inline the ATS setup code into pci_ats_init()
PCI: Rationalize pci_ats_queue_depth() error checking
PCI: Reduce size of ATS structure elements
PCI: Embed ATS info directly into struct pci_dev
PCI: Allocate ATS struct during enumeration
* pci/irq:
PCI: Kill off set_irq_flags() usage
* pci/virtualization:
PCI: Add ACS quirks for Intel I219-LM/V
Remove pci_ats_enabled(). There are no callers outside the ATS code
itself. We don't need to check ats_cap, because if we don't find an ATS
capability, we'll never set ats_enabled.
Reviewed-by: Joerg Roedel <jroedel@suse.de>
Stop caching the Invalidate Queue Depth in struct pci_dev.
pci_ats_queue_depth() is typically called only once per device, and it
returns a fixed value per-device, so callers who need the value frequently
can cache it themselves.
Move ATS declarations to linux/pci.h so they're all in one place.
The extended capabilities list is linked with 12-bit pointers, and the ATS
Smallest Translation Unit and Invalidate Queue Depth fields are both 5
bits.
Use u16 and u8 to hold the extended capability address and the stu and qdep
values. No functional change.
The pci_ats struct is small and will get smaller, so I don't think it's
worth allocating it separately from the pci_dev struct.
Embed the ATS fields directly into struct pci_dev.
Previously, we allocated pci_ats structures when an IOMMU driver called
pci_enable_ats(). An SR-IOV VF shares the STU setting with its PF, so when
enabling ATS on the VF, we allocated a pci_ats struct for the PF if it
didn't already have one. We held the sriov->lock to serialize threads
concurrently enabling ATS on several VFS so only one would allocate the PF
pci_ats.
Gregor reported a deadlock here:
pci_enable_sriov
sriov_enable
virtfn_add
mutex_lock(dev->sriov->lock) # acquire sriov->lock
pci_device_add
device_add
BUS_NOTIFY_ADD_DEVICE notifier chain
iommu_bus_notifier
amd_iommu_add_device # iommu_ops.add_device
init_iommu_group
iommu_group_get_for_dev
iommu_group_add_device
__iommu_attach_device
amd_iommu_attach_device # iommu_ops.attach_device
attach_device
pci_enable_ats
mutex_lock(dev->sriov->lock) # deadlock
There's no reason to delay allocating the pci_ats struct, and if we
allocate it for each device at enumeration-time, there's no need for
locking in pci_enable_ats().
Allocate pci_ats struct during enumeration, when we initialize other
capabilities.
Note that this implementation requires ATS to be enabled on the PF first,
before on any of the VFs because the PF controls the STU for all the VFs.
Link: http://permalink.gmane.org/gmane.linux.kernel.iommu/9433
Reported-by: Gregor Dick <gdick@solarflare.com>
* pci/irq:
PCI/MSI: Free legacy IRQ when enabling MSI/MSI-X
PCI: Add helpers to manage pci_dev->irq and pci_dev->irq_managed
PCI: Add pcibios_alloc_irq() and pcibios_free_irq()
* pci/misc:
PCI: Remove unused "pci_probe" flags
PCI: Add VPD function 0 quirk for Intel Ethernet devices
PCI: Add dev_flags bit to access VPD through function 0
PCI / ACPI: Fix pci_acpi_optimize_delay() comment
PCI: Remove a broken link in quirks.c
PCI: Remove useless redundant code
PCI: Simplify pci_find_(ext_)capability() return value checks
PCI: Move PCI_FIND_CAP_TTL to pci.h and use it in quirks
PCI: Add pcie_downstream_port() (true for Root and Switch Downstream Ports)
PCI: Fix pcie_port_device_resume() comment
PCI: Shift PCI_CLASS_NOT_DEFINED consistently with other classes
PCI: Revert aeb30016fec3 ("PCI: add Intel USB specific reset method")
PCI: Fix TI816X class code quirk
PCI: Fix generic NCR 53c810 class code quirk
PCI: Use PCI_CLASS_SERIAL_USB instead of bare number
PCI: Add quirk for Intersil/Techwell TW686[4589] AV capture cards
PCI: Remove Intel Cherrytrail D3 delays
* pci/resource:
PCI: Call pci_read_bridge_bases() from core instead of arch code
PCI: Restore ACS configuration as part of pci_restore_state()
Previously, pci_setup_device() and similar functions searched the
pci_bus->slots list without any locking. It was possible for another
thread to update the list while we searched it.
Add pci_dev_assign_slot() to search the list while holding pci_slot_mutex.
[bhelgaas: changelog, fold in CONFIG_SYSFS fix]
Tested-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Rajat Jain reported a deadlock when PCIe hot-add and AER recovery happen at
the same time:
thread 1:
pciehp_enable_slot
pciehp_configure_device
pci_bus_add_devices
pci_bus_add_device
device_attach
device_lock(dev) # acquire device lock
pciehp_probe
init_slot
pci_hp_register
pci_create_slot
down_write(pci_bus_sem) # deadlock here
thread 2:
aer_isr_one_error
aer_process_err_device
do_recovery
broadcast_error_message(..., report_error_detected)
pci_walk_bus(..., cb=report_error_detected, ...)
down_read(&pci_bus_sem) # acquire pci_bus_sem
report_error_detected(dev) # cb()
device_lock(dev) # deadlock here
Previously, the bus->devices and bus->slots list were protected by
pci_bus_sem. In pci_create_slot(), we held it for writing so we could
add to the bus->slots list.
Add a new local pci_slot_mutex to protect bus->slots. Hold pci_bus_sem for
reading while searching the bus->devices list.
[bhelgaas: changelog]
Link: http://lkml.kernel.org/r/CAA93t1qpPqbih+UB0McA_d_+2rVaNkXsinAUxYzK9+JXSS+L-g@mail.gmail.com
Reported-by: Rajat Jain <rajatja@google.com>
Add pci_has_managed_irq(), pci_set_managed_irq(), and
pci_reset_managed_irq() to simplify code. No functional change.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Add pcibios_alloc_irq() and pcibios_free_irq(), which are called when
binding/unbinding PCI device drivers.
PCI arch code may implement these to manage IRQ resources for hotplugged
devices.
In order to populate the PCI host bridge msi_domain, use the
"msi-parent" attribute to lookup a corresponding irq domain.
If found, this is our MSI domain.
This gets plugged into the core PCI code.
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Cc: <linux-arm-kernel@lists.infradead.org>
Cc: Yijing Wang <wangyijing@huawei.com>
Cc: Ma Jun <majun258@huawei.com>
Cc: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: Duc Dang <dhdang@apm.com>
Cc: Hanjun Guo <hanjun.guo@linaro.org>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/1438091186-10244-6-git-send-email-marc.zyngier@arm.com
Move msi_list from struct pci_dev into struct device, so we can
support non-PCI-device based generic MSI interrupts.
msi_list is now conditional under CONFIG_GENERIC_MSI_IRQ, which is
selected from CONFIG_PCI_MSI, so no functional change for PCI MSI
users.
Reviewed-by: Yijing Wang <wangyijing@huawei.com>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Stuart Yoder <stuart.yoder@freescale.com>
Cc: Joe Perches <joe@perches.com>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Joerg Roedel <jroedel@suse.de>
Cc: Alexander Gordeev <agordeev@redhat.com>
Link: http://lkml.kernel.org/r/1436428847-8886-10-git-send-email-jiang.liu@linux.intel.com
Add a dev_flags bit, PCI_DEV_FLAGS_VPD_REF_F0, to access VPD through
function 0 to provide VPD access on other functions. This is for hardware
devices that provide copies of the same VPD capability registers in
multiple functions. Because the kernel expects that each function has its
own registers, both the locking and the state tracking are affected by VPD
accesses to different functions.
On such devices for example, if a VPD write is performed on function 0,
*any* later attempt to read VPD from any other function of that device will
hang. This has to do with how the kernel tracks the expected value of the
F bit per function.
Concurrent accesses to different functions of the same device can not only
hang but also corrupt both read and write VPD data.
When hangs occur, typically the error message:
vpd r/w failed. This is likely a firmware bug on this device.
will be seen.
Never set this bit on function 0 or there will be an infinite recursion.
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
CC: stable@vger.kernel.org
'pci/msi', 'pci/resource' and 'pci/virtualization' into next
* pci/aspm:
PCI/ASPM: Simplify Clock Power Management setting
PCI: Use dev->has_secondary_link to find downstream PCIe links
PCI/ASPM: Use dev->has_secondary_link to find downstream links
PCI: Add dev->has_secondary_link to track downstream PCIe links
PCI/ASPM: Remove redundant PCIe port type checking
PCI/ASPM: Drop __pci_disable_link_state() useless "force" parameter
* pci/enumeration:
PCI: Remove unused pci_scan_bus_parented()
xen/pcifront: Don't use deprecated function pci_scan_bus_parented()
PCI: designware: Use pci_scan_root_bus() for simplicity
PCI: tegra: Remove tegra_pcie_scan_bus()
PCI: mvebu: Remove mvebu_pcie_scan_bus()
* pci/hotplug:
PCI: pciehp: Wait for hotplug command completion where necessary
PCI: Propagate the "ignore hotplug" setting to parent
ACPI / hotplug / PCI: Check ignore_hotplug for all downstream devices
PCI: pciehp: Drop pointless label from pciehp_probe()
PCI: pciehp: Drop pointless ACPI-based "slot detection" check
* pci/misc:
PCI: Remove unused pci_dma_burst_advice()
PCI: Remove unused pcibios_select_root() (again)
PCI: Remove unnecessary #includes of <asm/pci.h>
PCI: Include <linux/pci.h>, not <asm/pci.h>
* pci/msi:
PCI/MSI: Remove unused pci_msi_off()
PCI/MSI: Drop pci_msi_off() calls from quirks
ntb: Drop pci_msi_off() call during probe
virtio_pci: drop pci_msi_off() call during probe
PCI/MSI: Export pci_msi_set_enable(), pci_msix_clear_and_set_ctrl()
PCI/MSI: Rename msi_set_enable(), msix_clear_and_set_ctrl()
* pci/resource:
PCI: Add pci_bus_addr_t
ACPI / PCI: Account for ARI in _PRT lookups
PCI: Move pci_ari_enabled() to global header
PCI: Add function 1 DMA alias quirk for Marvell 9120
PCI: Add ACS quirks for Intel 9-series PCH root ports
No one uses pci_scan_bus_parented() any more, remove it.
pci_dma_burst_advice() was added by e24c2d963a60 ("[PATCH] PCI: DMA
bursting advice") but apparently never used. Remove it.
Acked-by: Michal Simek <monstr@monstr.eu> # microblaze
CC: David S. Miller <davem@davemloft.net>
David Ahern reported that d63e2e1f3df9 ("sparc/PCI: Clip bridge windows
to fit in upstream windows") fails to boot on sparc/T5-8:
pci 0000:06:00.0: reg 0x184: can't handle BAR above 4GB (bus address 0x110204000)
The problem is that sparc64 assumed that dma_addr_t only needed to hold DMA
addresses, i.e., bus addresses returned via the DMA API (dma_map_single(),
etc.), while the PCI core assumed dma_addr_t could hold *any* bus address,
including raw BAR values. On sparc64, all DMA addresses fit in 32 bits, so
dma_addr_t is a 32-bit type. However, BAR values can be 64 bits wide, so
they don't fit in a dma_addr_t. d63e2e1f3df9 added new checking that
tripped over this mismatch.
Add pci_bus_addr_t, which is wide enough to hold any PCI bus address,
including both raw BAR values and DMA addresses. This will be 64 bits
on 64-bit platforms and on platforms with a 64-bit dma_addr_t. Then
dma_addr_t only needs to be wide enough to hold addresses from the DMA API.
[bhelgaas: changelog, bugzilla, Kconfig to ensure pci_bus_addr_t is at
least as wide as dma_addr_t, documentation]
Fixes: d63e2e1f3df9 ("sparc/PCI: Clip bridge windows to fit in upstream windows")
Fixes: 23b13bc76f35 ("PCI: Fail safely if we can't handle BARs larger than 4GB")
Link: http://lkml.kernel.org/r/CAE9FiQU1gJY1LYrxs+ma5LCTEEe4xmtjRG0aXJ9K_Tsu+m9Wuw@mail.gmail.com
Link: http://lkml.kernel.org/r/1427857069-6789-1-git-send-email-yinghai@kernel.org
Link: https://bugzilla.kernel.org/show_bug.cgi?id=96231
Reported-by: David Ahern <david.ahern@oracle.com>
Tested-by: David Ahern <david.ahern@oracle.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
CC: stable@vger.kernel.org # v3.19+
pci_ari_enabled() is useful outside of drivers/pci, particularly for
deriving INTx routing via ACPI _PRT, so move it to the global header.
Also convert to bool return.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Reviewed-by: Don Dutile <ddutile@redhat.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Refine the mechanism introduced by commit f244d8b623da ("ACPIPHP / radeon /
nouveau: Fix VGA switcheroo problem related to hotplug") to propagate the
ignore_hotplug setting of the device to its parent bridge in case hotplug
notifications related to the graphics adapter switching are given for the
bridge rather than for the device itself (they need to be ignored in both
cases).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=61891
Link: https://bugs.freedesktop.org/show_bug.cgi?id=88927
Fixes: b440bde74f04 ("PCI: Add pci_ignore_hotplug() to ignore hotplug events for a device")
Reported-and-tested-by: tiagdtd-lava <tiagdtd-lava@yahoo.de>
CC: stable@vger.kernel.org # v3.17+
A PCIe Port is an interface to a Link. A Root Port is a PCI-PCI bridge in
a Root Complex and has a Link on its secondary (downstream) side. For
other Ports, the Link may be on either the upstream (closer to the Root
Complex) or downstream side of the Port.
The usual topology has a Root Port connected to an Upstream Port. We
previously assumed this was the only possible topology, and that a
Downstream Port's Link was always on its downstream side, like this:
+------+ | Downstream |
| Root | | Upstream Port +--Link--
| Port +--Link--+ Port |
| Port +--Link--
But systems do exist (see URL below) where the Root Port is connected to a
Downstream Port. In this case, a Downstream Port's Link may be on either
the upstream or downstream side:
+------+ | Upstream |
| Root | | Downstream Port +--Link--
| Port +--Link--
We can't use the Port type to determine which side the Link is on, so add a
bit in struct pci_dev to keep track.
A Root Port's Link is always on the Port's secondary side. A component
(Endpoint or Port) on the other end of the Link obviously has the Link on
its upstream side. If that component is a Port, it is part of a Switch or
a Bridge. A Bridge has a PCI or PCI-X bus on its secondary side, not a
Link. The internal bus of a Switch connects the Port to another Port whose
Link is on the downstream side.
[bhelgaas: changelog, comment, cache "type", use if/else]
Link: http://lkml.kernel.org/r/54EB81B2.4050904@pobox.com
Link: https://bugzilla.kernel.org/show_bug.cgi?id=94361
Suggested-by: Bjorn Helgaas <bhelgaas@google.com>
pci_msi_off() is unused, so remove it.
Removes the exported symbol pci_msi_off().
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux
Pull powerpc updates from Michael Ellerman:
- Numerous minor fixes, cleanups etc.
- More EEH work from Gavin to remove its dependency on device_nodes.
- Memory hotplug implemented entirely in the kernel from Nathan
Fontenot.
- Removal of redundant CONFIG_PPC_OF by Kevin Hao.
- Rewrite of VPHN parsing logic & tests from Greg Kurz.
- A fix from Nish Aravamudan to reduce memory usage by clamping
nodes_possible_map.
- Support for pstore on powernv from Hari Bathini.
- Removal of old powerpc specific byte swap routines by David Gibson.
- Fix from Vasant Hegde to prevent the flash driver telling you it was
flashing your firmware when it wasn't.
- Patch from Ben Herrenschmidt to add an OPAL heartbeat driver.
- Fix for an oops causing get/put_cpu_var() imbalance in perf by Jan
Stancek.
- Some fixes for migration from Tyrel Datwyler.
- A new syscall to switch the cpu endian by Michael Ellerman.
- Large series from Wei Yang to implement SRIOV, reviewed and acked by
Bjorn.
- A fix for the OPAL sensor driver from Cédric Le Goater.
- Fixes to get STRICT_MM_TYPECHECKS building again by Michael Ellerman.
- Large series from Daniel Axtens to make our PCI hooks per PHB rather
than per machine.
- Small patch from Sam Bobroff to explicitly abort non-suspended
transactions on syscalls, plus a test to exercise it.
- Numerous reworks and fixes for the 24x7 PMU from Sukadev Bhattiprolu.
- Small patch to enable the hard lockup detector from Anton Blanchard.
- Fix from Dave Olson for missing L2 cache information on some CPUs.
- Some fixes from Michael Ellerman to get Cell machines booting again.
- Freescale updates from Scott: Highlights include BMan device tree
nodes, an MSI erratum workaround, a couple minor performance
improvements, config updates, and misc fixes/cleanup.
* tag 'powerpc-4.1-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (196 commits)
powerpc/powermac: Fix build error seen with powermac smp builds
powerpc/pseries: Fix compile of memory hotplug without CONFIG_MEMORY_HOTREMOVE
powerpc: Remove PPC32 code from pseries specific find_and_init_phbs()
powerpc/cell: Fix iommu breakage caused by controller_ops change
powerpc/eeh: Fix crash in eeh_add_device_early() on Cell
powerpc/perf: Cap 64bit userspace backtraces to PERF_MAX_STACK_DEPTH
powerpc/perf/hv-24x7: Fail 24x7 initcall if create_events_from_catalog() fails
powerpc/pseries: Correct memory hotplug locking
powerpc: Fix missing L2 cache size in /sys/devices/system/cpu
powerpc: Add ppc64 hard lockup detector support
oprofile: Disable oprofile NMI timer on ppc64
powerpc/perf/hv-24x7: Add missing put_cpu_var()
powerpc/perf/hv-24x7: Break up single_24x7_request
powerpc/perf/hv-24x7: Define update_event_count()
powerpc/perf/hv-24x7: Whitespace cleanup
powerpc/perf/hv-24x7: Define add_event_to_24x7_request()
powerpc/perf/hv-24x7: Rename hv_24x7_event_update
powerpc/perf/hv-24x7: Move debug prints to separate function
powerpc/perf/hv-24x7: Drop event_24x7_request()
powerpc/perf/hv-24x7: Use pr_devel() to log message
tools/testing/selftests/powerpc/Makefile
tools/testing/selftests/powerpc/tm/Makefile
* pci/misc:
PCI: Read capability list as dwords, not bytes
PCI: Don't clear ASPM bits when the FADT declares it's unsupported
PCI: Clarify policy for vendor IDs in pci.txt
PCI/ACPI: Optimize device state transition delays
PCI: Export pci_find_host_bridge() for use inside PCI core
PCI: Make a shareable UUID for PCI firmware ACPI _DSM
PCI: Fix typo in Thunderbolt kernel message
The PCI "ACPI additions for FW latency optimizations" ECN (link below)
defines two functions in the PCI _DSM:
Function 8, "Reset Delay," applies to the entire hierarchy below a PCI
host bridge. If it returns one, the OS may assume that all devices in
the hierarchy have already completed power-on reset delays.
Function 9, "Device Readiness Durations," applies only to the object
where it is located. It returns delay durations required after various
events if the device requires less time than the spec requires. Delays
from this function take precedence over the Reset Delay function.
Add support for Reset Delay and part of Device Readiness Durations.
[bhelgaas: changelog, comments]
Link: https://www.pcisig.com/specifications/conventional/pci_firmware/ECN_fw_latency_optimization_final.pdf
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Per the SR-IOV spec r1.1, sec 3.3.14, the required alignment of a PF's IOV
BAR is the size of an individual VF BAR, and the size consumed is the
individual VF BAR size times NumVFs.
The PowerNV platform has additional alignment requirements to help support
its Partitionable Endpoint device isolation feature (see
Documentation/powerpc/pci_iov_resource_on_powernv.txt).
Add a pcibios_iov_resource_alignment() interface to allow platforms to
request additional alignment.
[bhelgaas: changelog, adapt to reworked pci_sriov_resource_alignment(),
drop "align" parameter]
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
On PowerNV, some resource reservation is needed for SR-IOV VFs that don't
exist at the bootup stage. To do the match between resources and VFs, the
code need to get the VF's BDF in advance.
Rename virtfn_bus() and virtfn_devfn() to pci_iov_virtfn_bus() and
pci_iov_virtfn_devfn() and export them.
[bhelgaas: changelog, make "busnr" int]
Currently we don't store the individual VF BAR size. We calculate it when
needed by dividing the PF's IOV resource size (which contains space for
*all* the VFs) by total_VFs or by reading the BAR in the SR-IOV capability
again.
Keep the individual VF BAR size in struct pci_sriov.barsz[], add
pci_iov_resource_size() to retrieve it, and use that instead of doing the
division or reading the SR-IOV capability BAR.
[bhelgaas: rename to "barsz[]", simplify barsz[] index computation, remove
SR-IOV capability BAR sizing]
Add helper functions to get/put the root bus's host bridge device.
Tested-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com> (AMD Seattle)
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
Reviewed-by: Catalin Marinas <catalin.marinas@arm.com>
Acked-by: Will Deacon <will.deacon@arm.com>
CC: Joerg Roedel <joro@8bytes.org>
CC: Grant Likely <grant.likely@linaro.org>
CC: Rob Herring <robh+dt@kernel.org>
CC: Russell King <linux@arm.linux.org.uk>
CC: Arnd Bergmann <arnd@arndb.de>
Pull ACPI and power management updates from Rafael Wysocki:
"We have a few new features this time, including a new SFI-based
cpufreq driver, a new devfreq driver for Tegra Activity Monitor, a new
devfreq class for providing its governors with raw utilization data
and a new ACPI driver for AMD SoCs.
Still, the majority of changes here are reworks of existing code to
make it more straightforward or to prepare it for implementing new
features on top of it. The primary example is the rework of ACPI
resources handling from Jiang Liu, Thomas Gleixner and Lv Zheng with
support for IOAPIC hotplug implemented on top of it, but there is
quite a number of changes of this kind in the cpufreq core, ACPICA,
ACPI EC driver, ACPI processor driver and the generic power domains
core code too.
The most active developer is Viresh Kumar with his cpufreq changes.
Specifics:
- Rework of the core ACPI resources parsing code to fix issues in it
and make using resource offsets more convenient and consolidation
of some resource-handing code in a couple of places that have grown
analagous data structures and code to cover the the same gap in the
core (Jiang Liu, Thomas Gleixner, Lv Zheng).
- ACPI-based IOAPIC hotplug support on top of the resources handling
rework (Jiang Liu, Yinghai Lu).
- ACPICA update to upstream release 20150204 including an interrupt
handling rework that allows drivers to install raw handlers for
ACPI GPEs which then become entirely responsible for the given GPE
and the ACPICA core code won't touch it (Lv Zheng, David E Box,
Octavian Purdila).
- ACPI EC driver rework to fix several concurrency issues and other
problems related to events handling on top of the ACPICA's new
support for raw GPE handlers (Lv Zheng).
- New ACPI driver for AMD SoCs analogous to the LPSS (Low-Power
Subsystem) driver for Intel chips (Ken Xue).
- Two minor fixes of the ACPI LPSS driver (Heikki Krogerus, Jarkko
Nikula).
- Two new blacklist entries for machines (Samsung 730U3E/740U3E and
510R) where the native backlight interface doesn't work correctly
while the ACPI one does (Hans de Goede).
- Rework of the ACPI processor driver's handling of idle states to
make the code more straightforward and less bloated overall (Rafael
J Wysocki).
- Assorted minor fixes related to ACPI and SFI (Andreas Ruprecht,
Andy Shevchenko, Hanjun Guo, Jan Beulich, Rafael J Wysocki, Yaowei
Bai).
- PCI core power management modification to avoid resuming (some)
runtime-suspended devices during system suspend if they are in the
right states already (Rafael J Wysocki).
- New SFI-based cpufreq driver for Intel platforms using SFI
(Srinidhi Kasagar).
- cpufreq core fixes, cleanups and simplifications (Viresh Kumar,
Doug Anderson, Wolfram Sang).
- SkyLake CPU support and other updates for the intel_pstate driver
(Kristen Carlson Accardi, Srinivas Pandruvada).
- cpufreq-dt driver cleanup (Markus Elfring).
- Init fix for the ARM big.LITTLE cpuidle driver (Sudeep Holla).
- Generic power domains core code fixes and cleanups (Ulf Hansson).
- Operating Performance Points (OPP) core code cleanups and kernel
documentation update (Nishanth Menon).
- New dabugfs interface to make the list of PM QoS constraints
available to user space (Nishanth Menon).
- New devfreq driver for Tegra Activity Monitor (Tomeu Vizoso).
- New devfreq class (devfreq_event) to provide raw utilization data
to devfreq governors (Chanwoo Choi).
- Assorted minor fixes and cleanups related to power management
(Andreas Ruprecht, Krzysztof Kozlowski, Rickard Strandqvist, Pavel
Machek, Todd E Brandt, Wonhong Kwon).
- turbostat updates (Len Brown) and cpupower Makefile improvement
(Sriram Raghunathan)"
* tag 'pm+acpi-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (151 commits)
tools/power turbostat: relax dependency on APERF_MSR
tools/power turbostat: relax dependency on invariant TSC
Merge branch 'pci/host-generic' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci into acpi-resources
tools/power turbostat: decode MSR_*_PERF_LIMIT_REASONS
tools/power turbostat: relax dependency on root permission
ACPI / video: Add disable_native_backlight quirk for Samsung 510R
ACPI / PM: Remove unneeded nested #ifdef
USB / PM: Remove unneeded #ifdef and associated dead code
intel_pstate: provide option to only use intel_pstate with HWP
ACPI / EC: Add GPE reference counting debugging messages
ACPI / EC: Add query flushing support
ACPI / EC: Refine command storm prevention support
ACPI / EC: Add command flushing support.
ACPI / EC: Introduce STARTED/STOPPED flags to replace BLOCKED flag
ACPI: add AMD ACPI2Platform device support for x86 system
ACPI / table: remove duplicate NULL check for the handler of acpi_table_parse()
ACPI / EC: Update revision due to raw handler mode.
ACPI / EC: Reduce ec_poll() by referencing the last register access timestamp.
ACPI / EC: Fix several GPE handling issues by deploying ACPI_GPE_DISPATCH_RAW_HANDLER mode.
ACPICA: Events: Enable APIs to allow interrupt/polling adaptive request based GPE handling model
Pull PCI changes from Bjorn Helgaas:
"Enumeration
- Move domain assignment from arm64 to generic code (Lorenzo Pieralisi)
- ARM: Remove artificial dependency on pci_sys_data domain (Lorenzo Pieralisi)
- ARM: Move to generic PCI domains (Lorenzo Pieralisi)
- Generate uppercase hex for modalias var in uevent (Ricardo Ribalda Delgado)
- Add and use generic config accessors on ARM, PowerPC (Rob Herring)
Resource management
- Free resources on failure in of_pci_get_host_bridge_resources() (Lorenzo Pieralisi)
- Fix infinite loop with ROM image of size 0 (Michel Dänzer)
PCI device hotplug
- Handle surprise add even if surprise removal isn't supported (Bjorn Helgaas)
Virtualization
- Mark AMD/ATI VGA devices that don't reset on D3hot->D0 transition (Alex Williamson)
- Add DMA alias quirk for Adaptec 3405 (Alex Williamson)
- Add Wellsburg (X99) to Intel PCH root port ACS quirk (Alex Williamson)
- Add ACS quirk for Emulex NICs (Vasundhara Volam)
MSI
- Fail MSI-X mappings if there's no space assigned to MSI-X BAR (Yijing Wang)
Freescale Layerscape host bridge driver
- Fix platform_no_drv_owner.cocci warnings (Julia Lawall)
NVIDIA Tegra host bridge driver
- Remove unnecessary tegra_pcie_fixup_bridge() (Lucas Stach)
Renesas R-Car host bridge driver
- Fix error handling of irq_of_parse_and_map() (Dmitry Torokhov)
TI Keystone host bridge driver
- Fix misspelling of current function in debug output (Julia Lawall)
- Fix harmless format string warning (Arnd Bergmann)
Miscellaneous
- Use standard parsing functions for ASPM sysfs setters (Chris J Arges)
- Add pci_device_to_OF_node() stub for !CONFIG_OF (Kevin Hao)
- Delete unnecessary NULL pointer checks (Markus Elfring)
- Add and use defines for PCIe Max_Read_Request_Size (Rafał Miłecki)
- Include clk.h instead of clk-private.h (Stephen Boyd)"
* tag 'pci-v3.20-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits)
PCI: Add pci_device_to_OF_node() stub for !CONFIG_OF
PCI: xilinx: Convert to use generic config accessors
PCI: xgene: Convert to use generic config accessors
PCI: tegra: Convert to use generic config accessors
PCI: rcar: Convert to use generic config accessors
PCI: generic: Convert to use generic config accessors
powerpc/powermac: Convert PCI to use generic config accessors
powerpc/fsl_pci: Convert PCI to use generic config accessors
ARM: ks8695: Convert PCI to use generic config accessors
ARM: sa1100: Convert PCI to use generic config accessors
ARM: integrator: Convert PCI to use generic config accessors
PCI: versatile: Add DT-based ARM Versatile PB PCIe host driver
ARM: dts: versatile: add PCI controller binding
of/pci: Free resources on failure in of_pci_get_host_bridge_resources()
PCI: versatile: Add DT docs for ARM Versatile PB PCIe driver
PCI: Fail MSI-X mappings if there's no space assigned to MSI-X BAR
r8169: use PCI define for Max_Read_Request_Size
[SCSI] esas2r: use PCI define for Max_Read_Request_Size
tile: use PCI define for Max_Read_Request_Size
rapidio/tsi721: use PCI define for Max_Read_Request_Size
* pci/misc:
Use common resource list management data structure and interfaces
instead of private implementation.
