These IDs are no longer referenced since kernel 3.1 so I suppose we can
remove them from pci_ids.h.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Pull first round of SCSI updates from James Bottomley:
"This patch consists of the usual driver updates (megaraid_sas,
scsi_debug, qla2xxx, qla4xxx, lpfc, bnx2fc, be2iscsi, hpsa, ipr) plus
an assortment of minor fixes and the first precursors of SCSI-MQ (the
code path simplifications) and the bug fix for the USB oops on remove
(which involves an infrastructure change, so is sent via the main tree
with a delayed backport after a cycle in which it is shown to
introduce no new bugs)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (196 commits)
[SCSI] sd: Quiesce mode sense error messages
[SCSI] add support for per-host cmd pools
[SCSI] simplify command allocation and freeing a bit
[SCSI] megaraid: simplify internal command handling
[SCSI] ses: Use vpd information from scsi_device
[SCSI] Add EVPD page 0x83 and 0x80 to sysfs
[SCSI] Return VPD page length in scsi_vpd_inquiry()
[SCSI] scsi_sysfs: Implement 'is_visible' callback
[SCSI] hpsa: update driver version to 3.4.4-1
[SCSI] hpsa: fix bad endif placement in RAID 5 mapper code
[SCSI] qla2xxx: Fix build errors related to invalid print fields on some architectures.
[SCSI] bfa: Replace large udelay() with mdelay()
[SCSI] vmw_pvscsi: Some improvements in pvscsi driver.
[SCSI] vmw_pvscsi: Add support for I/O requests coalescing.
[SCSI] vmw_pvscsi: Fix pvscsi_abort() function.
[SCSI] remove deprecated IRQF_DISABLED from SCSI
[SCSI] bfa: Updating Maintainers email ids
[SCSI] ipr: Add new CCIN definition for Grand Canyon support
[SCSI] ipr: Format HCAM overlay ID 0x21
[SCSI] ipr: Use pci_enable_msi_range() and pci_enable_msix_range()
Pull EDAC updates from Borislav Petkov:
"A bunch of EDAC updates all over the place:
- Support for new AMD models, along with more graceful fallback for
unsupported hw.
- Bunch of fixes from SUSE accumulated from bug reports
- Misc other fixes and cleanups"
* tag 'edac_for_3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Add support for newer F16h models
i7core_edac: Drop unused variable
i82875p_edac: Drop redundant call to pci_get_device()
amd8111_edac: Fix leaks in probe error paths
e752x_edac: Drop pvt->bridge_ck
MCE, AMD: Fix decoding module loading on unsupported hw
i5100_edac: Remove an unneeded condition in i5100_init_csrows()
sb_edac: Degrade log level for device registration
amd64_edac: Fix logic to determine channel for F15 M30h processors
edac/85xx: Remove deprecated IRQF_DISABLED
i3200_edac: Add a missing pci_disable_device() on the exit path
i5400_edac: Disable device when unloading module
e752x_edac: Simplify call to pci_get_device()
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Extend ECC decoding support for F16h M30h. Tested on F16h M30h with ECC
turned on using mce_amd_inj module and the patch works fine.
Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
Link: http://lkml.kernel.org/r/1392913726-16961-1-git-send-email-Aravind.Gopalakrishnan@amd.com
Tested-by: Arindam Nath <Arindam.Nath@amd.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
This patch adds the PCI ids for the Intel SandyBridge,
IvyBridge, Haswell Client memory controller (IMC).
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: ak@linux.intel.com
Cc: zheng.z.yan@intel.com
Cc: peterz@infradead.org
Signed-off-by: Stephane Eranian <eranian@google.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1392132015-14521-4-git-send-email-eranian@google.com
Pull misc SCSI driver updates from James Bottomley:
"This patch set is a set of driver updates (megaraid_sas, fnic, lpfc,
ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and
ibmvfc error handling) and the first round of esas2r checker fixes and
finally the much anticipated big endian additions for megaraid_sas"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits)
[SCSI] fnic: fnic Driver Tuneables Exposed through CLI
[SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg
[SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset
[SCSI] fnic: Remove QUEUE_FULL handling code
[SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up
[SCSI] fnic: FC stat param seconds_since_last_reset not getting updated
[SCSI] sd: Fix potential out-of-bounds access
[SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42
[SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout
[SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage.
[SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted
[SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices
[SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads
[SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection
[SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space
[SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic
[SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret
[SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure.
[SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling
[SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode
This patch adds the PCI ID's for HP Smart Array Gen9 controllers. Please
consider this patch for inclusion.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Pull x86 RAS changes from Ingo Molnar:
"[ The reason for drivers/ updates is that Boris asked for the
drivers/edac/ changes to go via x86/ras in this cycle ]
Main changes:
- AMD CPUs:
. Add ECC event decoding support for new F15h models
. Various erratum fixes
. Fix single-channel on dual-channel-controllers bug.
- Intel CPUs:
. UC uncorrectable memory error parsing fix
. Add support for CMC (Corrected Machine Check) 'FF' (Firmware
First) flag in the APEI HEST
- Various cleanups and fixes"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
amd64_edac: Fix incorrect wraparounds
amd64_edac: Correct erratum 505 range
cpc925_edac: Use proper array termination
x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured
amd64_edac: Get rid of boot_cpu_data accesses
amd64_edac: Add ECC decoding support for newer F15h models
x86, amd_nb: Clarify F15h, model 30h GART and L3 support
pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models.
x38_edac: Make a local function static
i3200_edac: Make a local function static
x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors
APEI/ERST: Fix error message formatting
amd64_edac: Fix single-channel setups
EDAC: Replace strict_strtol() with kstrtol()
mce: acpi/apei: Soft-offline a page on firmware GHES notification
mce: acpi/apei: Add a boot option to disable ff mode for corrected errors
mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
Add PCI device IDs for AMD F15h, model 30h. They will be used in
amd_nb.c and amd64_edac.c
These two defines are no longer used. They were only used by the PCI
serial driver "8250_pci" to support the original ADDI-DATA APCI-7800
card. In that driver, PCI_VENDOR_ID_ADDIDATA_OLD has been replaced with
PCI_VENDOR_ID_AMCC which has the same value (0x10e8), and
PCI_DEVICE_ID_ADDIDATA_APCI7800 has been replaced with a local #define
PCI_DEVICE_ID_AMCC_ADDIDATA_APCI7800 with the same value (0x818e).
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
PCI_VENDOR_ID_AMCC is defined locally in
"drivers/staging/comedi/comedidev.h" for a few comedi hardware drivers,
namely "adl_pci9118", "addi_apci_1500" and "addi_apci_3120" (also
"addi_apci_1710" but that is not currently built and will probably be
removed soon). Move the define into "include/linux/pci_ids.h" as it is
shared by several drivers (albeit all comedi drivers currently).
PCI_VENDOR_ID_AMCC happens to have the same value (0x10e8) as
PCI_VENDOR_ID_ADDIDATA_OLD. The vendor ID is actually assigned to
Applied Micro Circuits Corporation and Addi-Data were using device IDs
assigned by AMCC on some of their earlier PCI boards. The
PCI_VENDOR_ID_ADDIDATA_OLD define is still being used by the "8250_pci"
PCI serial board driver.
* pci/misc:
MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci
PCI: Add CircuitCo vendor ID and subsystem ID
PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)
Add CircuitCo's newly created VENDOR ID and their first board subsystem
ID for the MinnowBoard.
[bhelgaas: sort, change DEVICE_ID to SUBSYSTEM_ID]
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
To put all AMD Hudson-2 device IDs together for better maintenance.
[bhelgaas: also sort Hudson-2 devices by ID]
Signed-off-by: Shane Huang <shane.huang@amd.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
[jejb: move PCI_DEVICE_ID definitions to include/pci_ids.h]
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
- Add an Intel CMCI hotplug fix
- Add AMD family 16h EDAC support
- Make the AMD MCE banks code more flexible for virtual environments
amd64_edac: Add Family 16h support
x86/mce: Rework cmci_rediscover() to play well with CPU hotplug
x86, MCE, AMD: Use MCG_CAP MSR to find out number of banks on AMD
x86, MCE, AMD: Replace shared_bank array with is_shared_bank() helper
Add code to handle DRAM ECC errors decoding for Fam16h.
Tested on Fam16h with ECC turned on using the mce_amd_inj facility and
works fine.
[ Boris: cleanups and clarifications ]
Define PCI_VENDOR_ID_MARVELL_EXT macro for 0x1b4b vendor ID
Signed-off-by: Xiangliang Yu <yuxiangl@marvell.com>
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
Pull EDAC fixes and ghes-edac from Mauro Carvalho Chehab:
"For:
- Some fixes at edac drivers (i7core_edac, sb_edac, i3200_edac);
- error injection support for i5100, when EDAC debug is enabled;
- fix edac when it is loaded builtin (early init for the subsystem);
- a "Firmware First" EDAC driver, allowing ghes to report errors via
EDAC (ghes-edac).
With regards to ghes-edac, this fixes a longstanding BZ at Red Hat
that happens with Nehalem and Sandy Bridge CPUs: when both GHES and
i7core_edac or sb_edac are running, the error reports are
unpredictable, as both BIOS and OS race to access the registers. With
ghes-edac, the EDAC core will refuse to register any other concurrent
memory error driver.
This patchset moves the ghes struct definitions to a separate header
file (include/acpi/ghes.h) and adds 3 hooks at apei/ghes.c to
register/unregister and to report errors via ghes-edac. Those changes
were acked by ghes driver maintainer (Huang)."
* 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: (30 commits)
i5100_edac: convert to use simple_open()
ghes_edac: fix to use list_for_each_entry_safe() when delete list items
ghes_edac: Fix RAS tracing
ghes_edac: Make it compliant with UEFI spec 2.3.1
ghes_edac: Improve driver's printk messages
ghes_edac: Don't credit the same memory dimm twice
ghes_edac: do a better job of filling EDAC DIMM info
ghes_edac: add support for reporting errors via EDAC
ghes_edac: Register at EDAC core the BIOS report
ghes: add the needed hooks for EDAC error report
ghes: move structures/enum to a header file
edac: add support for error type "Info"
edac: add support for raw error reports
edac: reduce stack pressure by using a pre-allocated buffer
edac: lock module owner to avoid error report conflicts
edac: remove proc_name from mci structure
edac: add a new memory layer type
edac: initialize the core earlier
edac: better report error conditions in debug mode
i5100_edac: Remove two checkpatch warnings
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial patches from Greg Kroah-Hartman:
"Here's the big tty/serial driver patches for 3.9-rc1.
More tty port rework and fixes from Jiri here, as well as lots of
individual serial driver updates and fixes.
All of these have been in the linux-next tree for a while."
* tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: mxser: improve error handling in mxser_probe() and mxser_module_init()
serial: imx: fix uninitialized variable warning
serial: tegra: assume CONFIG_OF
TTY: do not update atime/mtime on read/write
lguest: select CONFIG_TTY to build properly.
ARM defconfigs: add missing inclusions of linux/platform_device.h
fb/exynos: include platform_device.h
ARM: sa1100/assabet: include platform_device.h directly
serial: imx: Fix recursive locking bug
pps: Fix build breakage from decoupling pps from tty
tty: Remove ancient hardpps()
pps: Additional cleanups in uart_handle_dcd_change
pps: Move timestamp read into PPS code proper
pps: Don't crash the machine when exiting will do
pps: Fix a use-after free bug when unregistering a source.
pps: Use pps_lookup_dev to reduce ldisc coupling
pps: Add pps_lookup_dev() function
tty: serial: uartlite: Support uartlite on big and little endian systems
tty: serial: uartlite: Fix sparse and checkpatch warnings
serial/arc-uart: Miscll DT related updates (Grant's review comments)
Fix up trivial conflicts, mostly just due to the TTY config option
clashing with the EXPERIMENTAL removal.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree update from Greg Kroah-Hartman:
"Here's the big staging tree merge for 3.9-rc1
Lots of cleanups and updates for drivers all through the staging tree.
We are pretty much "code neutral" here, adding just about as many
lines as we removed.
All of these have been in linux-next for a while."
* tag 'staging-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (804 commits)
staging: comedi: vmk80xx: wait for URBs to complete
staging: comedi: drivers: addi-data: hwdrv_apci3200.c: Add a missing semicolon
staging: et131x: Update TODO list
staging: et131x: Remove assignment of skb->dev
staging: wlan-ng: hfa384x.h: fix for error reported by smatch
staging/zache checkpatch ERROR: spaces prohibited around that
staging/ozwpan: Mark read only parameters and structs as const
staging/ozwpan: Remove empty and unused function oz_cdev_heartbeat
staging/ozwpan: Mark local functions as static (fix sparse warnings)
staging/ozwpan: Add missing header includes
staging/usbip: Mark local functions as static (fix sparse warnings)
staging/xgifb: Remove duplicated code in loops.
staging/xgifb: Consolidate return paths
staging/xgifb: Remove code without effect
staging/xgifb: Remove unnecessary casts
staging/xgifb: Consolidate if/else if with identical code branches
staging: vt6656: replaced custom TRUE definition with true
staging: vt6656: replaced custom FALSE definition with false
staging: vt6656: replace custom BOOL definition with bool
staging/rtl8187se: Mark functions as static to silence sparse
Probe and store the device handle for the device 19 function 0 during
driver initialization. The device is used during fault injection.
Signed-off-by: Niklas Söderlund <niklas.soderlund@ericsson.com>
The BCM4785 or sometimes named BMC4705 is a Broadcom SoC which a
Gigabit 5750 Ethernet core. The core is connected via PCI with the rest
of the SoC, but it uses some extension.
This core does not use a firmware or an eeprom.
Some devices only have a switch which supports 100MBit/s, this
currently does not work with this driver.
This patch was original written by Michael Buesch <m@bues.ch> and is in
OpenWrt for some years now.
This was tested on a Linksys WRT610N V1 and older versions of this patch
were tested by other people on different devices.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Michael Chan <mchan@broadcom.com>
There are a number of pci vendor ids that are used in multiple
drivers in the comedi subsystem. Move these ids to pci_ids.h.
This also fixes some build warnings reported by the kbuild test
robot about PCI_VENDOR_ID_AMPLICON being undeclared.
Jonathan Woithe posted an out of tree enabler/control module for these
cards. Lift the relevant identifiers and put them in the 8250_pci driver
along with code used to control custom registers on these cards.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Signed-off-by: Jonathan Woithe <jwoithe@just42.net>
Otherwise it fails like this on cards like the Transcend 16GB SDHC card:
mmc0: new SDHC card at address b368
mmcblk0: mmc0:b368 SDC 15.0 GiB
mmcblk0: error -110 sending status command, retrying
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0
Tested on my Lenovo x200 laptop.
[bhelgaas: changelog]
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Chris Ball <cjb@laptop.org>
CC: Manoj Iyer <manoj.iyer@canonical.com>
CC: stable@vger.kernel.org
cards
Add support for Commtech's Fastcom Async-335 and Fastcom Async-PCIe cards
Signed-off-by: Matt Schulte <matts@commtech-fastcom.com>
PCIe UARTs
Add support for new devices: Exar's XR17V35x family of multi-port PCIe UARTs.
Acked-by: Alan Cox <alan@linux.intel.com>
The SMBus controller in the VIA VX900 appears to be compatible with
the VIA VX855, so just add the device ID.
This closes kernel bug #43096.
"This is a large set of updates, mostly for drivers (qla2xxx [including
support for new 83xx based card], qla4xxx, mpt2sas, bfa, zfcp, hpsa,
be2iscsi, isci, lpfc, ipr, ibmvfc, ibmvscsi, megaraid_sas).
There's also a rework for tape adding virtually unlimited numbers of
tape drives plus a set of dif fixes for sd and a fix for a live lock
on hot remove of SCSI devices.
This round includes a signed tag pull of isci-for-3.6
Signed-off-by: James Bottomley <JBottomley@Parallels.com>"
Fix up trivial conflict in drivers/scsi/qla2xxx/qla_nx.c due to new PCI
helper function use in a function that was removed by this pull.
* tag 'scsi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (198 commits)
[SCSI] st: remove st_mutex
[SCSI] sd: Ensure we correctly disable devices with unknown protection type
[SCSI] hpsa: gen8plus Smart Array IDs
[SCSI] qla4xxx: Update driver version to 5.03.00-k1
[SCSI] qla4xxx: Disable generating pause frames for ISP83XX
[SCSI] qla4xxx: Fix double clearing of risc_intr for ISP83XX
[SCSI] qla4xxx: IDC implementation for Loopback
[SCSI] qla4xxx: update copyrights in LICENSE.qla4xxx
[SCSI] qla4xxx: Fix panic while rmmod
[SCSI] qla4xxx: Fail probe_adapter if IRQ allocation fails
[SCSI] qla4xxx: Prevent MSI/MSI-X falling back to INTx for ISP82XX
[SCSI] qla4xxx: Update idc reg in case of PCI AER
[SCSI] qla4xxx: Fix double IDC locking in qla4_8xxx_error_recovery
[SCSI] qla4xxx: Clear interrupt while unloading driver for ISP83XX
[SCSI] qla4xxx: Print correct IDC version
[SCSI] qla4xxx: Added new mbox cmd to pass driver version to FW
[SCSI] scsi_dh_alua: Enable STPG for unavailable ports
[SCSI] scsi_remove_target: fix softlockup regression on hot remove
[SCSI] ibmvscsi: Fix host config length field overflow
[SCSI] ibmvscsi: Remove backend abstraction
Apparently the same card model has two IDs, so this patch
complements the commit 39aced68d664291db3324d0fcf0985ab5626aac2
adding the missing one.
Signed-off-by: Flavio Leitner <fbl@redhat.com>
Cc: stable <stable@vger.kernel.org>
Commit c3def943c7117d42caaed3478731ea7c3c87190e have added support for
new pci ids of the 57840 board, while failing to change the obsolete value
in 'pci_ids.h'.
This patch does so, allowing the probe of such devices.
Signed-off-by: Yuval Mintz <yuvalmin@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
Pull x86/mce changes from Ingo Molnar:
"This tree improves the AMD thresholding bank code and includes a
memory fault signal handling fixlet."
* 'x86-mce-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mce: Fix siginfo_t->si_addr value for non-recoverable memory faults
x86, MCE, AMD: Update copyrights and boilerplate
x86, MCE, AMD: Give proper names to the thresholding banks
x86, MCE, AMD: Make error_count read only
x86, MCE, AMD: Cleanup reading of error_count
x86, MCE, AMD: Print decimal thresholding values
x86, MCE, AMD: Move shared bank to node descriptor
x86, MCE, AMD: Remove local_allocate_... wrapper
x86, MCE, AMD: Remove shared banks sysfs linking
x86, amd_nb: Export model 0x10 and later PCI id
The uncore subsystem in Sandy Bridge-EP consists of 8 components:
Ubox, Cacheing Agent, Home Agent, Memory controller, Power Control,
QPI Link Layer, R2PCIe, R3QPI.
Signed-off-by: Zheng Yan <zheng.z.yan@intel.com>
Link: http://lkml.kernel.org/r/1339741902-8449-9-git-send-email-zheng.z.yan@intel.com
Add the F3 PCI id of F15h, model 0x10 to pci_ids.h and to the amd_nb
code which generates the list of northbridges on an AMD box. Shorten
define name while at it so that it fits into pci_ids.h.
Acked-by: Clemens Ladisch <clemens@ladisch.de>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
This patch adds the Integrated Legacy Block DeviceID for the Centerton CPU. It will be used in the GPIO and Multifunction Devices driver.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
This patch recodes the MRRS cap for 5719 A0 devices as a PCI quirk.
Signed-off-by: Matt Carlson <mcarlson@broadcom.com>
The chip is an I/O hub used by some Atom boards. Most of those
symbols are used in arch/x86/platform/sta2x11/sta2x11.c (to be
introduced) and in the specific drivers as well.
Signed-off-by: Alessandro Rubini <rubini@gnudd.com>
Acked-by: Giancarlo Asnaghi <giancarlo.asnaghi@st.com>
Cc: Alan Cox <alan@linux.intel.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
northbridge functions
I've received complaints that the numa_node attribute for family
15h model 00-0fh (e.g. Interlagos) northbridge functions shows
-1 instead of the proper node ID.
Correct this with attached quirks (similar to quirks for other
AMD CPU families used in multi-socket systems).
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Frank Arnold <frank.arnold@amd.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Link: http://lkml.kernel.org/r/20111202072143.GA31916@alberich.amd.com
Signed-off-by: Keng-Yu Lin <kengyu@canonical.com>
In the OCZ RevoDrive3/zDrive R4 series, the "OCZ SuperScale Storage
Controller" with "Virtualized Controller Architecture 2.0" really seems
to be a Marvell 88SE9485 part, with OCZ firmware/BIOS.
Developed and tested on OCZ RevoDrive3 120GB [PCI 1b85:1021]
Should work on:
- OCZ RevoDrive3 (2x SandForce 2281)
- OCZ RevoDrive3 X2 (4x SandForce 2281)
- OCZ zDrive R4 CM84 (4x SandForce 2281)
- OCZ zDrive R4 CM88 (8x SandForce 2281)
- OCZ zDrive R4 RM84 (4x SandForce 2582)
- OCZ zDrive R4 RM88 (8x SandForce 2582)
All of this because a friend recently bought a OCZ RevoDrive3 and was
bitten by the lack of Linux support.
Notes from testing:
- SMART works.
- VPD Device Identification is "OCZ-REVODRIVE3"
- Thin provisioning/TRIM seems to be implemented as WRITE SAME UNMAP,
with deterministic (non-zero) read after TRIM, but I'm not sure if it
works 100% in my testing.
- Some of the tuning in the firmware seems to ensure much better
performance when in a RAID0 setup than using the two devices
seperately.
I have not tested booting from the SSD, because all of this was
developed and tested remotely from the actual hardware.
Signed-off-by: Robin H. Johnson <robbat2@gentoo.org>
Thanks-To: Gordon Pritchard <gordp@sfu.ca>
Acked-by: Xiangliang Yu <yuxiangl@marvell.com>
These will be shared between the sfc driver and a PCI quirk.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx:
dmaengine: use DEFINE_IDR for static initialization
ioat: fix xor_idx_to_desc
Avoid section type conflict in dma/ioat/dma_v3.c
ioat: Adding PCI IDs for IOAT devices on SandyBridge platforms
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (26 commits)
amba pl011: workaround for uart registers lockup
n_gsm: fix the wrong FCS handling
pch_uart: add missing comment about OKI ML7223
pch_uart: Add MSI support
tty: fix "IRQ45: nobody cared"
PTI feature to allow user to name and mark masterchannel request.
0 for o PTI Makefile bug.
tty: serial: samsung.c remove legacy PM code.
SERIAL: SC26xx: Fix link error.
serial: mrst_max3110: initialize waitqueue earlier
mrst_max3110: Change max missing message priority.
tty: s5pv210: Add delay loop on fifo reset function for UART
tty/serial: Fix XSCALE serial ports, e.g. ce4100
serial: bfin_5xx: fix off-by-one with resource size
drivers/tty: use printk_ratelimited() instead of printk_ratelimit()
tty: n_gsm: Added refcount usage to gsm_mux and gsm_dlci structs
tty: n_gsm: Add raw-ip support
tty: n_gsm: expose gsmtty device nodes at ldisc open time
pch_phub: Fix register miss-setting issue
serial: 8250, increase PASS_LIMIT
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits)
ALSA: asihpi - Replace with snd_ctl_boolean_mono_info()
ALSA: asihpi - HPI version 4.08
ALSA: asihpi - Add volume mute controls
ALSA: asihpi - Control name updates
ALSA: asihpi - Use size_t for sizeof result
ALSA: asihpi - Explicitly include mutex.h
ALSA: asihpi - Add new node and message defines
ALSA: asihpi - Make local function static
ALSA: asihpi - Fix minor typos and spelling
ALSA: asihpi - Remove unused structures, macros and functions
ALSA: asihpi - Remove spurious adapter index check
ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro
ALSA: asihpi - DSP code loader API now independent of OS
ALSA: asihpi - Remove controlex structs and associated special data transfer code
ALSA: asihpi - Increase request and response buffer sizes
ALSA: asihpi - Give more meaningful name to hpi request message type
ALSA: usb-audio - Add quirk for Roland / BOSS BR-800
ALSA: hda - Remove a superfluous argument of via_auto_init_output()
ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs
ALSA: hda - Add documentation for codec-specific mixer controls
Adding to pci_id.h and the device table for ioat.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
