commit 72f2ff0deb870145a5a2d24cd75b4f9936159a62 upstream.
The PCIe Root Port in Hip06/Hip07 SoCs advertises an MSI capability, but it
cannot generate MSIs. It can transfer MSI/MSI-X from downstream devices,
but does not support MSI/MSI-X itself.
Add a quirk to prevent use of MSI/MSI-X by the Root Port.
[bhelgaas: changelog, sort vendor ID #define, drop device ID #define]
Signed-off-by: Dongdong Liu <liudongdong3@huawei.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Gabriele Paoloni <gabriele.paoloni@huawei.com>
Reviewed-by: Zhou Wang <wangzhou1@hisilicon.com>
commit 591b6bb605785c12a21e8b07a08a277065b655a5 upstream.
Several legacy devices such as Geode-based Cisco ASA appliances
and DB800 development board do possess CS5536 IDE controller
with different PCI id than existing one. Using pata_generic is
not always feasible as at least DB800 requires MSR quirk from
pata_cs5536 to be used with vendor firmware.
Signed-off-by: Andrey Korolyov <andrey@xdel.ru>
commit 69874ec233871a62e1bc8c89e643993af93a8630 upstream.
Add the device ID for the PF of the NFP4000. The device ID for the VF,
0x6003, is already present as PCI_DEVICE_ID_NETRONOME_NFP6000_VF.
Signed-off-by: Simon Horman <simon.horman@netronome.com>
commit a755e169031dac9ebaed03302c4921687c271d62 upstream.
Device IDs for the Netronome NFP3200, NFP3240, NFP6000, and NFP6000 SR-IOV
devices.
Signed-off-by: Jason S. McMullan <jason.mcmullan@netronome.com>
[simon: edited changelog]
This commits moves the Intersil/Techwell PCI vendor ID, and
the device IDs for the TW68 PCI video capture cards.
This will allow to support future Intersil/Techwell devices
without duplicating the IDs.
Signed-off-by: Ezequiel Garcia <ezequiel@vanguardiasur.com.ar>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Pull networking updates from David Miller:
1) Add TX fast path in mac80211, from Johannes Berg.
2) Add TSO/GRO support to ibmveth, from Thomas Falcon
3) Move away from cached routes in ipv6, just like ipv4, from Martin
KaFai Lau.
4) Lots of new rhashtable tests, from Thomas Graf.
5) Run ingress qdisc lockless, from Alexei Starovoitov.
6) Allow servers to fetch TCP packet headers for SYN packets of new
connections, for fingerprinting. From Eric Dumazet.
7) Add mode parameter to pktgen, for testing receive. From Alexei
Starovoitov.
8) Cache access optimizations via simplifications of build_skb(), from
Alexander Duyck.
9) Move page frag allocator under mm/, also from Alexander.
10) Add xmit_more support to hv_netvsc, from KY Srinivasan.
11) Add a counter guard in case we try to perform endless reclassify
loops in the packet scheduler.
12) Extern flow dissector to be programmable and use it in new "Flower"
classifier. From Jiri Pirko.
13) AF_PACKET fanout rollover fixes, performance improvements, and new
statistics. From Willem de Bruijn.
14) Add netdev driver for GENEVE tunnels, from John W Linville.
15) Add ingress netfilter hooks and filtering, from Pablo Neira Ayuso.
16) Fix handling of epoll edge triggers in TCP, from Eric Dumazet.
17) Add an ECN retry fallback for the initial TCP handshake, from Daniel
Borkmann.
18) Add tail call support to BPF, from Alexei Starovoitov.
19) Add several pktgen helper scripts, from Jesper Dangaard Brouer.
20) Add zerocopy support to AF_UNIX, from Hannes Frederic Sowa.
21) Favor even port numbers for allocation to connect() requests, and
odd port numbers for bind(0), in an effort to help avoid
ip_local_port_range exhaustion. From Eric Dumazet.
22) Add Cavium ThunderX driver, from Sunil Goutham.
23) Allow bpf programs to access skb_iif and dev->ifindex SKB metadata,
24) Add support for T6 chips in cxgb4vf driver, from Hariprasad Shenai.
25) Double TCP Small Queues default to 256K to accomodate situations
like the XEN driver and wireless aggregation. From Wei Liu.
26) Add more entropy inputs to flow dissector, from Tom Herbert.
27) Add CDG congestion control algorithm to TCP, from Kenneth Klette
Jonassen.
28) Convert ipset over to RCU locking, from Jozsef Kadlecsik.
29) Track and act upon link status of ipv4 route nexthops, from Andy
Gospodarek.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1670 commits)
bridge: vlan: flush the dynamically learned entries on port vlan delete
bridge: multicast: add a comment to br_port_state_selection about blocking state
net: inet_diag: export IPV6_V6ONLY sockopt
stmmac: troubleshoot unexpected bits in des0 & des1
net: ipv4 sysctl option to ignore routes when nexthop link is down
net: track link-status of ipv4 nexthops
net: switchdev: ignore unsupported bridge flags
net: Cavium: Fix MAC address setting in shutdown state
drivers: net: xgene: fix for ACPI support without ACPI
ip: report the original address of ICMP messages
net/mlx5e: Prefetch skb data on RX
net/mlx5e: Pop cq outside mlx5e_get_cqe
net/mlx5e: Remove mlx5e_cq.sqrq back-pointer
net/mlx5e: Remove extra spaces
net/mlx5e: Avoid TX CQE generation if more xmit packets expected
net/mlx5e: Avoid redundant dev_kfree_skb() upon NOP completion
net/mlx5e: Remove re-assignment of wq type in mlx5e_enable_rq()
net/mlx5e: Use skb_shinfo(skb)->gso_segs rather than counting them
net/mlx5e: Static mapping of netdev priv resources to/from netdev TX queues
net/mlx4_en: Use HW counters for rx/tx bytes/packets in PF device
The KERNCZ is new AMD SB/FCH generation name, like HUDSON2.
0x790b is the device ID for this generation.
Signed-off-by: Wan ZongShun <Vincent.Wan@amd.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
This vendor id will be used by network (vNIC), USB (xHCI),
SATA (AHCI), GPIO, I2C, MMC and maybe other drivers
for ThunderX SoC.
Signed-off-by: Sunil Goutham <sgoutham@cavium.com>
Signed-off-by: Aleksey Makarov <aleksey.makarov@caviumnetworks.com>
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, but also an uncore PMU driver fix and an uncore
PMU driver hardware-enablement addition"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf probe: Fix segfault if passed with ''.
perf report: Fix -T/--threads option to work again
perf bench numa: Fix immediate meeting of convergence condition
perf bench numa: Fixes of --quiet argument
perf bench futex: Fix hung wakeup tasks after requeueing
perf probe: Fix bug with global variables handling
perf top: Fix a segfault when kernel map is restricted.
tools lib traceevent: Fix build failure on 32-bit arch
perf kmem: Fix compiles on RHEL6/OL6
tools lib api: Undefine _FORTIFY_SOURCE before setting it
perf kmem: Consistently use PRIu64 for printing u64 values
perf trace: Disable events and drain events when forked workload ends
perf trace: Enable events when doing system wide tracing and starting a workload
perf/x86/intel/uncore: Move PCI IDs for IMC to uncore driver
perf/x86/intel/uncore: Add support for Intel Haswell ULT (lower power Mobile Processor) IMC uncore PMUs
perf/x86/intel: Add cpu_(prepare|starting|dying) for core_pmu
This keeps all the related PCI IDs together in the driver where
they are used.
Signed-off-by: Sonny Rao <sonnyrao@chromium.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1429644791-25724-1-git-send-email-sonnyrao@chromium.org
Removed FIXME from usb/dwc3/dwc3-pci.c by moving definition of
PCI_VENDOR_ID_SYNOPSYS shared with usb/dwc2 to linux/pci_ids.h.
Signed-off-by: Joseph Kogut <joseph.kogut@gmail.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big set of USB and PHY patches for 3.19-rc1.
The normal churn in the USB gadget area is in here, as well as xhci
and other individual USB driver updates. The PHY tree is also in
here, as there were dependancies on the USB tree.
All of these have been in linux-next"
* tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits)
arm: omap3: twl: remove usb phy init data
usbip: fix error handling in stub_probe()
usb: gadget: udc: missing curly braces
USB: mos7720: delete some unneeded code
wusb: replace memset by memzero_explicit
usbip: remove unneeded structure
usb: xhci: fix comment for PORT_DEV_REMOVE
xhci: don't use the same variable for stopped and halted rings current TD
xhci: clear extra bits from slot context when setting max exit latency
xhci: cleanup finish_td function
USB: adutux: NULL dereferences on disconnect
usb: chipidea: fix platform_no_drv_owner.cocci warnings
usb: chipidea: Fixed a few typos in comments
Documentation: bindings: add doc for the USB2 ChipIdea USB driver
usb: chipidea: add a usb2 driver for ci13xxx
usb: chipidea: fix phy handling
usb: chipidea: remove duplicate dev_set_drvdata for host_start
usb: chipidea: parameter 'mode' isn't needed for hw_device_reset
usb: chipidea: add controller reset API
usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER
This patch adds PCI id for USB3 Dual-Role Device of AMD Nolan (NL) SoC.
It will be used for PCI quirks and DWC3 device driver.
Signed-off-by: Jason Chang <jason.chang@amd.com>
Signed-off-by: Huang Rui <ray.huang@amd.com>
Add F3, F4 device IDs to be used in amd_nb.c and amd64_edac.c
Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
Link: http://lkml.kernel.org/r/1411070195-10177-1-git-send-email-Aravind.Gopalakrishnan@amd.com
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Changes to existing drivers:
- DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030
- Export symbols for use in modules in max14577
- Plenty of static code analysis/Coccinelle fixes throughout the SS
- Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808
- Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona
- Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr
- IRQ fixups in arizona, stmpe, max14577
- Regulator related changes in axp20x
- Pass DMA coherency information from parent => child in MFD core
- Rename DT document files for consistency
- Add ACPI support to the MFD core
- Add Andreas Werner to MAINTAINERS for MEN F21BMC
New drivers/supported devices:
- New driver for MEN 14F021P00 Board Management Controller
- New driver for Ricoh RN5T618 PMIC
- New driver for Rockchip RK808
- New driver for HiSilicon Hi6421 PMIC
- New driver for Qualcomm SPMI PMICs
- Add support for Intel Braswell in lpc_ich
- Add support for Intel 9 Series PCH in lpc_ich
- Add support for Intel Quark ILB in lpc_sch"
[ Delayed to after the poweer/reset pull due to Kconfig problems with
recursive Kconfig select/depends-on chains. - Linus ]
* tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits)
mfd: cros_ec: wait for completion of commands that return IN_PROGRESS
i2c: i2c-cros-ec-tunnel: Set retries to 3
mfd: cros_ec: move locking into cros_ec_cmd_xfer
mfd: cros_ec: stop calling ->cmd_xfer() directly
mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC
MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC
mfd: arizona: Correct mask to allow setting micbias external cap
mfd: Add ACPI support
Revert "mfd: wm5102: Manually apply register patch"
mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS
mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention
mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention
mfd: Inherit coherent_dma_mask from parent device
mfd: Document DT bindings for Qualcomm SPMI PMICs
mfd: Add support for Qualcomm SPMI PMICs
mfd: dt-bindings: pm8xxx: Add new compatible string
mfd: axp209x: Drop the parent supplies field
mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off
mfd: dt-bindings: twl4030-power: Use the standard property to mark power control
mfd: syscon: Add Atmel GPBR DT bindings documention
Pull x86 platform updates from Ingo Molnar:
"The main changes in this tree are:
- fix and update Intel Quark [Galileo] SoC platform support
- update IOSF chipset side band interface and make it available via
debugfs
- enable HPETs on Soekris net6501 and other e6xx based systems"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Add cpu_detect_cache_sizes to init_intel() add Quark legacy_cache()
x86: Quark: Comment setup_arch() to document TLB/PGE bug
x86/intel/quark: Switch off CR4.PGE so TLB flush uses CR3 instead
x86/platform/intel/iosf: Add debugfs config option for IOSF
x86/platform/intel/iosf: Add better description of IOSF driver in config
x86/platform/intel/iosf: Add Braswell PCI ID
x86/platform/pmc_atom: Fix warning when CONFIG_DEBUG_FS=n
x86: HPET force enable for e6xx based systems
x86/iosf: Add debugfs support
x86/iosf: Add Kconfig prompt for IOSF_MBI selection
Pull perf updates from Ingo Molnar:
"Kernel side updates:
- Fix and enhance poll support (Jiri Olsa)
- Re-enable inheritance optimization (Jiri Olsa)
- Enhance Intel memory events support (Stephane Eranian)
- Refactor the Intel uncore driver to be more maintainable (Zheng
Yan)
- Enhance and fix Intel CPU and uncore PMU drivers (Peter Zijlstra,
Andi Kleen)
- [ plus various smaller fixes/cleanups ]
User visible tooling updates:
- Add +field argument support for --field option, so that one can add
fields to the default list of fields to show, ie now one can just
do:
perf report --fields +pid
And the pid will appear in addition to the default fields (Jiri
Olsa)
- Add +field argument support for --sort option (Jiri Olsa)
- Honour -w in the report tools (report, top), allowing to specify
the widths for the histogram entries columns (Namhyung Kim)
- Properly show submicrosecond times in 'perf kvm stat' (Christian
Borntraeger)
- Add beautifier for mremap flags param in 'trace' (Alex Snast)
- perf script: Allow callchains if any event samples them
- Don't truncate Intel style addresses in 'annotate' (Alex Converse)
- Allow profiling when kptr_restrict == 1 for non root users, kernel
samples will just remain unresolved (Andi Kleen)
- Allow configuring default options for callchains in config file
(Namhyung Kim)
- Support operations for shared futexes. (Davidlohr Bueso)
- "perf kvm stat report" improvements by Alexander Yarygin:
- Save pid string in opts.target.pid
- Enable the target.system_wide flag
- Unify the title bar output
- [ plus lots of other fixes and small improvements. ]
Tooling infrastructure changes:
- Refactor unit and scale function parameters for PMU parsing
routines (Matt Fleming)
- Improve DSO long names lookup with rbtree, resulting in great
speedup for workloads with lots of DSOs (Waiman Long)
- We were not handling POLLHUP notifications for event file
descriptors
Fix it by filtering entries in the events file descriptor array
after poll() returns, refcounting mmaps so that when the last fd
pointing to a perf mmap goes away we do the unmap (Arnaldo Carvalho
de Melo)
- Intel PT prep work, from Adrian Hunter, including:
- Let a user specify a PMU event without any config terms
- Add perf-with-kcore script
- Let default config be defined for a PMU
- Add perf_pmu__scan_file()
- Add a 'perf test' for tracking with sched_switch
- Add 'flush' callback to scripting API
- Use ring buffer consume method to look like other tools (Arnaldo
Carvalho de Melo)
- hists browser (used in top and report) refactorings, getting rid of
unused variables and reducing source code size by handling similar
cases in a fewer functions (Namhyung Kim).
- Replace thread unsafe strerror() with strerror_r() accross the
whole tools/perf/ tree (Masami Hiramatsu)
- Rename ordered_samples to ordered_events and allow setting a queue
size for ordering events (Jiri Olsa)
- [ plus lots of fixes, cleanups and other improvements ]"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (198 commits)
perf/x86: Tone down kernel messages when the PMU check fails in a virtual environment
perf/x86/intel/uncore: Fix minor race in box set up
perf record: Fix error message for --filter option not coming after tracepoint
perf tools: Fix build breakage on arm64 targets
perf symbols: Improve DSO long names lookup speed with rbtree
perf symbols: Encapsulate dsos list head into struct dsos
perf bench futex: Sanitize -q option in requeue
perf bench futex: Support operations for shared futexes
perf trace: Fix mmap return address truncation to 32-bit
perf tools: Refactor unit and scale function parameters
perf tools: Fix line number in the config file error message
perf tools: Convert {record,top}.call-graph option to call-graph.record-mode
perf tools: Introduce perf_callchain_config()
perf callchain: Move some parser functions to callchain.c
perf tools: Move callchain config from record_opts to callchain_param
perf hists browser: Fix callchain print bug on TUI
perf tools: Use ACCESS_ONCE() instead of volatile cast
perf tools: Modify error code for when perf_session__new() fails
perf tools: Fix perf record as non root with kptr_restrict == 1
perf stat: Fix --per-core on multi socket systems
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac
Pull edac updates from Mauro Carvalho Chehab:
"Nothing really exiting here: just one bug fix at sb_edac, and some
changes to allow other drivers to use some shared PCI addresses"
* tag 'edac/v3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac:
sb_edac: Claim a different PCI device
Move Intel SNB device ids from sb_edac to pci_ids.h
sb_edac: avoid INTERNAL ERROR message in EDAC with unspecified channel
The i2c_imc driver will use two of them, and moving only part of
the list seems messier.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Acked-by: Aristeu Rozanski <aris@redhat.com>
This patch adds the PCI id for Intel Quark ILB.
It will be used for GPIO and Multifunction device driver.
Signed-off-by: Josef Ahmad <josef.ahmad@intel.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Move PCI_VENDOR_ID_VMWARE from device-specific files to pci_ids.h.
It is useful to always have access to it, especially when accessing
subsystem_vendor_id on emulated devices.
[bhelgaas: keep pci_ids.h sorted and use lower-case hex]
Signed-off-by: Francesco Ruggeri <fruggeri@arista.com>
This patch restructures the memory controller (IMC) uncore PMU support
for client SNB/IVB/HSW processors. The main change is that it can now
cope with more than one PCI device ID per processor model. There are
many flavors of memory controllers for each processor. They have
different PCI device ID, yet they behave the same w.r.t. the memory
controller PMU that we are interested in.
The patch now supports two distinct memory controllers for IVB
processors: one for mobile, one for desktop.
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20140917090616.GA11281@quad
Cc: ak@linux.intel.com
Cc: kan.liang@intel.com
Cc: Bjorn Helgaas <bhelgaas@google.com>
As the Soekris net6501 and other e6xx based systems do not have
any ACPI implementation, HPET won't get enabled.
This patch enables HPET on such platforms.
[ 0.430149] pci 0000:00:01.0: Force enabled HPET at 0xfed00000
[ 0.644838] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
Original patch by Peter Neubauer (http://www.mail-archive.com/soekris-tech@lists.soekris.com/msg06462.html)
slightly modified by Conrad Kostecki <ck@conrad-kostecki.de> and massaged
accoring to Thomas Gleixners <tglx@linutronix.de> by me.
Suggested-by: Conrad Kostecki <ck@conrad-kostecki.de>
Signed-off-by: Eric Sesterhenn <eric.sesterhenn@lsexperts.de>
Cc: Peter Neubauer <pneubauer@bluerwhite.org>
Link: http://lkml.kernel.org/r/5412D3A5.2030909@lsexperts.de
Adding an include guard frees the preprocessor from reparsing over 2600
#defines in the cases where pci_ids.h is somehow included more than once.
This gives a tiny-but-measurable performance improvement when compiling
such files.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
These IDs are no longer referenced since kernel 3.1 so I suppose we can
remove them from pci_ids.h.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Pull first round of SCSI updates from James Bottomley:
"This patch consists of the usual driver updates (megaraid_sas,
scsi_debug, qla2xxx, qla4xxx, lpfc, bnx2fc, be2iscsi, hpsa, ipr) plus
an assortment of minor fixes and the first precursors of SCSI-MQ (the
code path simplifications) and the bug fix for the USB oops on remove
(which involves an infrastructure change, so is sent via the main tree
with a delayed backport after a cycle in which it is shown to
introduce no new bugs)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (196 commits)
[SCSI] sd: Quiesce mode sense error messages
[SCSI] add support for per-host cmd pools
[SCSI] simplify command allocation and freeing a bit
[SCSI] megaraid: simplify internal command handling
[SCSI] ses: Use vpd information from scsi_device
[SCSI] Add EVPD page 0x83 and 0x80 to sysfs
[SCSI] Return VPD page length in scsi_vpd_inquiry()
[SCSI] scsi_sysfs: Implement 'is_visible' callback
[SCSI] hpsa: update driver version to 3.4.4-1
[SCSI] hpsa: fix bad endif placement in RAID 5 mapper code
[SCSI] qla2xxx: Fix build errors related to invalid print fields on some architectures.
[SCSI] bfa: Replace large udelay() with mdelay()
[SCSI] vmw_pvscsi: Some improvements in pvscsi driver.
[SCSI] vmw_pvscsi: Add support for I/O requests coalescing.
[SCSI] vmw_pvscsi: Fix pvscsi_abort() function.
[SCSI] remove deprecated IRQF_DISABLED from SCSI
[SCSI] bfa: Updating Maintainers email ids
[SCSI] ipr: Add new CCIN definition for Grand Canyon support
[SCSI] ipr: Format HCAM overlay ID 0x21
[SCSI] ipr: Use pci_enable_msi_range() and pci_enable_msix_range()
Pull EDAC updates from Borislav Petkov:
"A bunch of EDAC updates all over the place:
- Support for new AMD models, along with more graceful fallback for
unsupported hw.
- Bunch of fixes from SUSE accumulated from bug reports
- Misc other fixes and cleanups"
* tag 'edac_for_3.15' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Add support for newer F16h models
i7core_edac: Drop unused variable
i82875p_edac: Drop redundant call to pci_get_device()
amd8111_edac: Fix leaks in probe error paths
e752x_edac: Drop pvt->bridge_ck
MCE, AMD: Fix decoding module loading on unsupported hw
i5100_edac: Remove an unneeded condition in i5100_init_csrows()
sb_edac: Degrade log level for device registration
amd64_edac: Fix logic to determine channel for F15 M30h processors
edac/85xx: Remove deprecated IRQF_DISABLED
i3200_edac: Add a missing pci_disable_device() on the exit path
i5400_edac: Disable device when unloading module
e752x_edac: Simplify call to pci_get_device()
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
Extend ECC decoding support for F16h M30h. Tested on F16h M30h with ECC
turned on using mce_amd_inj module and the patch works fine.
Link: http://lkml.kernel.org/r/1392913726-16961-1-git-send-email-Aravind.Gopalakrishnan@amd.com
Tested-by: Arindam Nath <Arindam.Nath@amd.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
This patch adds the PCI ids for the Intel SandyBridge,
IvyBridge, Haswell Client memory controller (IMC).
Cc: mingo@elte.hu
Cc: acme@redhat.com
Cc: zheng.z.yan@intel.com
Cc: peterz@infradead.org
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1392132015-14521-4-git-send-email-eranian@google.com
Pull misc SCSI driver updates from James Bottomley:
"This patch set is a set of driver updates (megaraid_sas, fnic, lpfc,
ufs, hpsa) we also have a couple of bug fixes (sd out of bounds and
ibmvfc error handling) and the first round of esas2r checker fixes and
finally the much anticipated big endian additions for megaraid_sas"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (47 commits)
[SCSI] fnic: fnic Driver Tuneables Exposed through CLI
[SCSI] fnic: Kernel panic while running sh/nosh with max lun cfg
[SCSI] fnic: Hitting BUG_ON(io_req->abts_done) in fnic_rport_exch_reset
[SCSI] fnic: Remove QUEUE_FULL handling code
[SCSI] fnic: On system with >1.1TB RAM, VIC fails multipath after boot up
[SCSI] fnic: FC stat param seconds_since_last_reset not getting updated
[SCSI] sd: Fix potential out-of-bounds access
[SCSI] lpfc 8.3.42: Update lpfc version to driver version 8.3.42
[SCSI] lpfc 8.3.42: Fixed issue of task management commands having a fixed timeout
[SCSI] lpfc 8.3.42: Fixed inconsistent spin lock usage.
[SCSI] lpfc 8.3.42: Fix driver's abort loop functionality to skip IOs already getting aborted
[SCSI] lpfc 8.3.42: Fixed failure to allocate SCSI buffer on PPC64 platform for SLI4 devices
[SCSI] lpfc 8.3.42: Fix WARN_ON when driver unloads
[SCSI] lpfc 8.3.42: Avoided making pci bar ioremap call during dual-chute WQ/RQ pci bar selection
[SCSI] lpfc 8.3.42: Fixed driver iocbq structure's iocb_flag field running out of space
[SCSI] lpfc 8.3.42: Fix crash on driver load due to cpu affinity logic
[SCSI] lpfc 8.3.42: Fixed logging format of setting driver sysfs attributes hard to interpret
[SCSI] lpfc 8.3.42: Fixed back to back RSCNs discovery failure.
[SCSI] lpfc 8.3.42: Fixed race condition between BSG I/O dispatch and timeout handling
[SCSI] lpfc 8.3.42: Fixed function mode field defined too small for not recognizing dual-chute mode
This patch adds the PCI ID's for HP Smart Array Gen9 controllers. Please
consider this patch for inclusion.
Signed-off-by: Mike Miller <mike.miller@hp.com>
Pull x86 RAS changes from Ingo Molnar:
"[ The reason for drivers/ updates is that Boris asked for the
drivers/edac/ changes to go via x86/ras in this cycle ]
Main changes:
- AMD CPUs:
. Add ECC event decoding support for new F15h models
. Various erratum fixes
. Fix single-channel on dual-channel-controllers bug.
- Intel CPUs:
. UC uncorrectable memory error parsing fix
. Add support for CMC (Corrected Machine Check) 'FF' (Firmware
First) flag in the APEI HEST
- Various cleanups and fixes"
* 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
amd64_edac: Fix incorrect wraparounds
amd64_edac: Correct erratum 505 range
cpc925_edac: Use proper array termination
x86/mce, acpi/apei: Only disable banks listed in HEST if mce is configured
amd64_edac: Get rid of boot_cpu_data accesses
amd64_edac: Add ECC decoding support for newer F15h models
x86, amd_nb: Clarify F15h, model 30h GART and L3 support
pci_ids: Add PCI device ID functions 3 and 4 for newer F15h models.
x38_edac: Make a local function static
i3200_edac: Make a local function static
x86/mce: Pay no attention to 'F' bit in MCACOD when parsing 'UC' errors
APEI/ERST: Fix error message formatting
amd64_edac: Fix single-channel setups
EDAC: Replace strict_strtol() with kstrtol()
mce: acpi/apei: Soft-offline a page on firmware GHES notification
mce: acpi/apei: Add a boot option to disable ff mode for corrected errors
mce: acpi/apei: Honour Firmware First for MCA banks listed in APEI HEST CMC
Add PCI device IDs for AMD F15h, model 30h. They will be used in
These two defines are no longer used. They were only used by the PCI
serial driver "8250_pci" to support the original ADDI-DATA APCI-7800
card. In that driver, PCI_VENDOR_ID_ADDIDATA_OLD has been replaced with
PCI_VENDOR_ID_AMCC which has the same value (0x10e8), and
PCI_DEVICE_ID_ADDIDATA_APCI7800 has been replaced with a local #define
PCI_DEVICE_ID_AMCC_ADDIDATA_APCI7800 with the same value (0x818e).
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
PCI_VENDOR_ID_AMCC is defined locally in
"drivers/staging/comedi/comedidev.h" for a few comedi hardware drivers,
namely "adl_pci9118", "addi_apci_1500" and "addi_apci_3120" (also
"addi_apci_1710" but that is not currently built and will probably be
removed soon). Move the define into "include/linux/pci_ids.h" as it is
shared by several drivers (albeit all comedi drivers currently).
PCI_VENDOR_ID_AMCC happens to have the same value (0x10e8) as
PCI_VENDOR_ID_ADDIDATA_OLD. The vendor ID is actually assigned to
Applied Micro Circuits Corporation and Addi-Data were using device IDs
assigned by AMCC on some of their earlier PCI boards. The
PCI_VENDOR_ID_ADDIDATA_OLD define is still being used by the "8250_pci"
PCI serial board driver.
* pci/misc:
MAINTAINERS: Add ACPI folks for ACPI-related things under drivers/pci
PCI: Add CircuitCo vendor ID and subsystem ID
PCI: Use pdev->pm_cap instead of pci_find_capability(..,PCI_CAP_ID_PM)
Add CircuitCo's newly created VENDOR ID and their first board subsystem
ID for the MinnowBoard.
[bhelgaas: sort, change DEVICE_ID to SUBSYSTEM_ID]
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
To put all AMD Hudson-2 device IDs together for better maintenance.
[bhelgaas: also sort Hudson-2 devices by ID]
Signed-off-by: Shane Huang <shane.huang@amd.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Jean Delvare <khali@linux-fr.org>
[jejb: move PCI_DEVICE_ID definitions to include/pci_ids.h]
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
- Add an Intel CMCI hotplug fix
- Add AMD family 16h EDAC support
- Make the AMD MCE banks code more flexible for virtual environments
amd64_edac: Add Family 16h support
x86/mce: Rework cmci_rediscover() to play well with CPU hotplug
x86, MCE, AMD: Use MCG_CAP MSR to find out number of banks on AMD
x86, MCE, AMD: Replace shared_bank array with is_shared_bank() helper
Add code to handle DRAM ECC errors decoding for Fam16h.
Tested on Fam16h with ECC turned on using the mce_amd_inj facility and
works fine.
[ Boris: cleanups and clarifications ]
Define PCI_VENDOR_ID_MARVELL_EXT macro for 0x1b4b vendor ID
Signed-off-by: Xiangliang Yu <yuxiangl@marvell.com>
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
Pull EDAC fixes and ghes-edac from Mauro Carvalho Chehab:
"For:
- Some fixes at edac drivers (i7core_edac, sb_edac, i3200_edac);
- error injection support for i5100, when EDAC debug is enabled;
- fix edac when it is loaded builtin (early init for the subsystem);
- a "Firmware First" EDAC driver, allowing ghes to report errors via
EDAC (ghes-edac).
With regards to ghes-edac, this fixes a longstanding BZ at Red Hat
that happens with Nehalem and Sandy Bridge CPUs: when both GHES and
i7core_edac or sb_edac are running, the error reports are
unpredictable, as both BIOS and OS race to access the registers. With
ghes-edac, the EDAC core will refuse to register any other concurrent
memory error driver.
This patchset moves the ghes struct definitions to a separate header
file (include/acpi/ghes.h) and adds 3 hooks at apei/ghes.c to
register/unregister and to report errors via ghes-edac. Those changes
were acked by ghes driver maintainer (Huang)."
* 'linux_next' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-edac: (30 commits)
i5100_edac: convert to use simple_open()
ghes_edac: fix to use list_for_each_entry_safe() when delete list items
ghes_edac: Fix RAS tracing
ghes_edac: Make it compliant with UEFI spec 2.3.1
ghes_edac: Improve driver's printk messages
ghes_edac: Don't credit the same memory dimm twice
ghes_edac: do a better job of filling EDAC DIMM info
ghes_edac: add support for reporting errors via EDAC
ghes_edac: Register at EDAC core the BIOS report
ghes: add the needed hooks for EDAC error report
ghes: move structures/enum to a header file
edac: add support for error type "Info"
edac: add support for raw error reports
edac: reduce stack pressure by using a pre-allocated buffer
edac: lock module owner to avoid error report conflicts
edac: remove proc_name from mci structure
edac: add a new memory layer type
edac: initialize the core earlier
edac: better report error conditions in debug mode
i5100_edac: Remove two checkpatch warnings
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty/serial patches from Greg Kroah-Hartman:
"Here's the big tty/serial driver patches for 3.9-rc1.
More tty port rework and fixes from Jiri here, as well as lots of
individual serial driver updates and fixes.
All of these have been in the linux-next tree for a while."
* tag 'tty-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (140 commits)
tty: mxser: improve error handling in mxser_probe() and mxser_module_init()
serial: imx: fix uninitialized variable warning
serial: tegra: assume CONFIG_OF
TTY: do not update atime/mtime on read/write
lguest: select CONFIG_TTY to build properly.
ARM defconfigs: add missing inclusions of linux/platform_device.h
fb/exynos: include platform_device.h
ARM: sa1100/assabet: include platform_device.h directly
serial: imx: Fix recursive locking bug
pps: Fix build breakage from decoupling pps from tty
tty: Remove ancient hardpps()
pps: Additional cleanups in uart_handle_dcd_change
pps: Move timestamp read into PPS code proper
pps: Don't crash the machine when exiting will do
pps: Fix a use-after free bug when unregistering a source.
pps: Use pps_lookup_dev to reduce ldisc coupling
pps: Add pps_lookup_dev() function
tty: serial: uartlite: Support uartlite on big and little endian systems
tty: serial: uartlite: Fix sparse and checkpatch warnings
serial/arc-uart: Miscll DT related updates (Grant's review comments)
Fix up trivial conflicts, mostly just due to the TTY config option
clashing with the EXPERIMENTAL removal.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree update from Greg Kroah-Hartman:
"Here's the big staging tree merge for 3.9-rc1
Lots of cleanups and updates for drivers all through the staging tree.
We are pretty much "code neutral" here, adding just about as many
lines as we removed.
All of these have been in linux-next for a while."
* tag 'staging-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (804 commits)
staging: comedi: vmk80xx: wait for URBs to complete
staging: comedi: drivers: addi-data: hwdrv_apci3200.c: Add a missing semicolon
staging: et131x: Update TODO list
staging: et131x: Remove assignment of skb->dev
staging: wlan-ng: hfa384x.h: fix for error reported by smatch
staging/zache checkpatch ERROR: spaces prohibited around that
staging/ozwpan: Mark read only parameters and structs as const
staging/ozwpan: Remove empty and unused function oz_cdev_heartbeat
staging/ozwpan: Mark local functions as static (fix sparse warnings)
staging/ozwpan: Add missing header includes
staging/usbip: Mark local functions as static (fix sparse warnings)
staging/xgifb: Remove duplicated code in loops.
staging/xgifb: Consolidate return paths
staging/xgifb: Remove code without effect
staging/xgifb: Remove unnecessary casts
staging/xgifb: Consolidate if/else if with identical code branches
staging: vt6656: replaced custom TRUE definition with true
staging: vt6656: replaced custom FALSE definition with false
staging: vt6656: replace custom BOOL definition with bool
staging/rtl8187se: Mark functions as static to silence sparse
Probe and store the device handle for the device 19 function 0 during
driver initialization. The device is used during fault injection.
Signed-off-by: Niklas Söderlund <niklas.soderlund@ericsson.com>
The BCM4785 or sometimes named BMC4705 is a Broadcom SoC which a
Gigabit 5750 Ethernet core. The core is connected via PCI with the rest
of the SoC, but it uses some extension.
This core does not use a firmware or an eeprom.
Some devices only have a switch which supports 100MBit/s, this
currently does not work with this driver.
This patch was original written by Michael Buesch <m@bues.ch> and is in
OpenWrt for some years now.
This was tested on a Linksys WRT610N V1 and older versions of this patch
were tested by other people on different devices.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Acked-by: Michael Chan <mchan@broadcom.com>
There are a number of pci vendor ids that are used in multiple
drivers in the comedi subsystem. Move these ids to pci_ids.h.
This also fixes some build warnings reported by the kbuild test
robot about PCI_VENDOR_ID_AMPLICON being undeclared.
Jonathan Woithe posted an out of tree enabler/control module for these
cards. Lift the relevant identifiers and put them in the 8250_pci driver
along with code used to control custom registers on these cards.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Signed-off-by: Jonathan Woithe <jwoithe@just42.net>
