Add support for the Broadcom HT1100 LD chipset (SMBus function.)
Signed-off-by: Flavio Leitner <fbl@redhat.com>
The MCP78S and MCP79 appear to be compatible with the previous nForce
chips as far as the SMBus controller is concerned. The MCP67 and MCP73
were not tested yet but I'd be very surprised if they weren't
compatible too.
Cc: Oleg Ryjkov <olegr@olegr.ca>
Cc: Malcolm Lalkaka <mlalkaka@gmail.com>
Cc: Zbigniew Luszpinski <zbiggy@o2.pl>
Add vendor ID for Quanta Microsystems and update the led table with the reported device.
Reported-by: Scott Barnes <nekoreeve@gmail.com>
Signed-off-by: Tulio Magno Quites Machado Filho <tuliom@gmail.com>
drivers/net/wimax/i2400m/usb-notif.c
On the Compaq Evo D510 SFF/CMT, a PCI quirk activated the SMBus device
based on detection of the on-board VGA controller, but the on-board
VGA is disabled if an AGP card is inserted, so look for one of the USB
controllers instead.
Signed-off-by: David O'Shea <dcoshea@hotmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Intel 8257x Ethernet boards have a feature called Serial Over Lan.
This feature works by emulating a serial port, and it is detected by
kernel as a normal 8250 port. However, this emulation is not perfect, as
also noticed on changeset 7500b1f602aad75901774a67a687ee985d85893f.
Before this patch, the kernel were trying to check if the serial TX is
capable of work using IRQ's.
This were done with a code similar this:
serial_outp(up, UART_IER, UART_IER_THRI);
lsr = serial_in(up, UART_LSR);
iir = serial_in(up, UART_IIR);
serial_outp(up, UART_IER, 0);
if (lsr & UART_LSR_TEMT && iir & UART_IIR_NO_INT)
up->bugs |= UART_BUG_TXEN;
This works fine for other 8250 ports, but, on 8250-emulated SoL port, the
chip is a little lazy to down UART_IIR_NO_INT at UART_IIR register.
Due to that, UART_BUG_TXEN is sometimes enabled. However, as TX IRQ keeps
working, and the TX polling is now enabled, the driver miss-interprets the
IRQ received later, hanging up the machine until a key is pressed at the
serial console.
This is the 6 version of this patch. Previous versions were trying to
introduce a large enough delay between serial_outp and serial_in(up,
UART_IIR), but not taking forever. However, the needed delay couldn't be
safely determined.
At the experimental tests, a delay of 1us solves most of the cases, but
still hangs sometimes. Increasing the delay to 5us was better, but still
doesn't solve. A very high delay of 50 ms seemed to work every time.
However, poking around with delays and pray for it to be enough doesn't
seem to be a good approach, even for a quirk.
So, instead of playing with random large arbitrary delays, let's just
disable UART_BUG_TXEN for all SoL ports.
[akpm@linux-foundation.org: fix warnings]
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: <stable@kernel.org>
I have a Digi Neo 8 PCI card (114f:00b1) Serial controller: Digi
International Digi Neo 8 (rev 05)
that works with the jsm driver after using the following patch.
Signed-off-by: Adam Lackorzynski <adam@os.inf.tu-dresden.de>
Cc: Scott H Kilau <Scott_Kilau@digi.com>
Cc: Wendy Xiong <wendyx@us.ibm.com>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Manual merge of:
arch/powerpc/include/asm/pgtable-ppc32.h
Signed-off-by: Zlatko Calusic <zlatko.calusic@iskon.hr>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
drivers/net/Kconfig
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI hotplug: Change link order of pciehp & acpiphp
PCI hotplug: fakephp: Allocate PCI resources before adding the device
PCI MSI: Fix undefined shift by 32
PCI PM: Do not wait for buses in B2 or B3 during resume
PCI PM: Power up devices before restoring their state
PCI PM: Fix hibernation breakage on EeePC 701
PCI: irq and pci_ids patch for Intel Tigerpoint DeviceIDs
PCI PM: Fix suspend error paths and testing facility breakage
Add vendor ID for AMBIT and use it to set the ath5k LED gpio.
base.c:
Changes-licensed-under: 3-Clause-BSD
Acked-by: Bob Copeland <me@bobcopeland.com>
Add vendor ID for Foxconn and use it to set the ath5k LED gpio and
polarity for Acer branded laptops.
base.c:
Reported-by: Maxim Levitsky <maximlevitsky@gmail.com>
Tested-by: Maxim Levitsky <maximlevitsky@gmail.com>
Tested-by: Andreas Mohr <andi@lisas.de>
Signed-off-by: Bob Copeland <me@bobcopeland.com>
This patch adds support for PCI-Express controllers as found on the
newer MPC83xx chips.
The work is loosely based on the Tony Li's patch[1], but unlike the
original patch, this patch implements sliding window for the Type 1
transactions using outbound window translations, so we don't have to
ioremap the whole PCI-E configuration space.
[1] http://ozlabs.org/pipermail/linuxppc-dev/2008-January/049028.html
Signed-off-by: Tony Li <tony.li@freescale.com>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This patch adds the Intel Tigerpoint LPC Controller DeviceIDs.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
It supports VX855 and future chips whose IDE controller uses PCI ID 0x0571.
Signed-off-by: Joseph Chan <josephchan@via.com.tw>
Acked-by: Tejun Heo <tj@kernel.org>
Add a define for DFI PCI vendor id.
Signed-off-by: Matthew Ranostay <mranostay@embeddedalley.com>
Instead of making up a name for the device ids, put them directly in the
device id table. Also move the vendor id to pci_ids.h.
Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net>
On Vortex86SX with IDE controller revision 0x11 ultra DMA must be
disabled. This patch was tested by DMP and seems to work.
It is a cleaned up version of their older Kernel patch:
http://www.dmp.com.tw/tech/vortex86sx/patch-2.6.24-DMP.gz
Tested-by: Shawn Lin <shawn@dmp.com.tw>
Signed-off-by: Brandon Philips <bphilips@suse.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Support for the IT8172 IDE controller was removed from the kernel
sometime after 2.6.18. Support for the only boards that used the IT8172
was removed from the kernel after 2.6.18, as they had never compiled
since 2.6.0. However, there are a couple of platforms that use this
chip: the PMC-Sierra Xiao Hu thin-client computer, which is no longer
in production, and the Linksys NSS4000 Network Attached Storage box,
which is based on the Xiao Hu board. I am attempting to add support
for the Xiao Hu to the kernel, and this IT8172 IDE controller is the
first bit of code in this effort.
This patch resurrects the IT8172 IDE controller code. I began with
the 2.6.18 version of the it8172.c file, and have moved it forward so
that it works with the latest version of the kernel. I have run this
driver on a PMC-Sierra Xiao Hu board with the 2.6.28 kernel, and
I have had no problems with it in my configuration. The attached patch
applies cleanly against 2.6.28.
Signed-off-by: Shane McDonald <mcdonald.shane@gmail.com>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Cc: alan@lxorguk.ukuu.org.uk
[bart: s/HWIF(drive)/drive->hwif/]
Add support for Sealevel Systems Model 7803 COMM+8
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
Signed-off-by: Alan Cox <alan@redhat.com>
Dual 16950 Serial adapter
The PCI-card identified as "Oxford Semiconductor Ltd EXSYS EX-41092 Dual
16950 Serial adapter" is only usable with other devices (i.e. not the same
card) after doing a "setserial /dev/ttyS<n> baud_base 115200". This
baud_base should be default for this card.
Signed-off-by: Niels de Vos <niels.devos@wincor-nixdorf.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (123 commits)
dock: make dock driver not a module
ACPI: fix ia64 build warning
ACPI: hack around sysfs warning with link order
ACPI suspend: fix build warning when CONFIG_ACPI_SLEEP=n
intel_menlo: fix build warning
panasonic-laptop: fix build
ACPICA: Update version to 20080926
ACPICA: Add support for zero-length buffer-to-string conversions
ACPICA: New: Validation for predefined ACPI methods/objects
ACPICA: Fix for implicit return compatibility
ACPICA: Fixed a couple memory leaks associated with "implicit return"
ACPICA: Optimize buffer allocation procedure
ACPICA: Fix possible memory leak, error exit path
ACPICA: Fix fault after mem allocation failure in AML parser
ACPICA: Remove unused ACPI register bit definition
ACPICA: Update version to 20080829
ACPICA: Fix possible memory leak in acpi_ns_get_external_pathname
ACPICA: Cleanup for internal Reference Object
ACPICA: Update comments - no functional changes
ACPICA: Update for Reference ACPI_OPERAND_OBJECT
Add support for the OxSemi 'Tornado' devices.
Reformatted and reworked a bit by Alan Cox
Signed-off-by: Lee Howard <lee.howard@mainpine.com>
MAINTAINERS
arch/x86/kernel/acpi/boot.c
arch/x86/kernel/acpi/sleep.c
drivers/acpi/Kconfig
drivers/pnp/Makefile
drivers/pnp/quirks.c
Signed-off-by: Len Brown <len.brown@intel.com>
The Intel 7300 Memory Controller supports dynamic throttling of memory which can
be used to save power when system is idle. This driver does the memory
throttling when all CPUs are idle on such a system.
Refer to "Intel 7300 Memory Controller Hub (MCH)" datasheet
for the config space description.
Signed-off-by: Andy Henroid <andrew.d.henroid@intel.com>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
This patch updates the Intel Ibex Peak (PCH) LPC and SMBus Controller
DeviceIDs.
The LPC Controller ID is set by Firmware within the range of
0x3b00-3b1f. This range is included in pci_ids.h using min and max
values, and irq.c now has code to handle the range (in lieu of 32
additions to a SWITCH statement).
The SMBus Controller ID is a fixed-value and will not change.
Acked-by: Jean Delvare <khali@linux-fr.org>
Support the Matrox G200eV chip, based on timings that I found in the X.org
matrox driver.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Cc: Petr Vandrovec <vandrove@vc.cvut.cz>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
include/asm-x86/statfs.h
* 'x86-v28-for-linus-phase3-B' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (74 commits)
AMD IOMMU: use iommu_device_max_index, fix
x86: add PCI IDs for AMD Barcelona PCI devices
x86/iommu: use __GFP_ZERO instead of memset for GART
x86/iommu: convert GART need_flush to bool
x86/iommu: make GART driver checkpatch clean
x86 gart: remove unnecessary initialization
x86: restore old GART alloc_coherent behavior
revert "x86: make GART to respect device's dma_mask about virtual mappings"
x86: export pci-nommu's alloc_coherent
iommu: remove fullflush and nofullflush in IOMMU generic option
x86: remove set_bit_string()
iommu: export iommu_area_reserve helper function
AMD IOMMU: use coherent_dma_mask in alloc_coherent
add AMD IOMMU tree to MAINTAINERS file
AMD IOMMU: use cmd_buf_size when freeing the command buffer
AMD IOMMU: calculate IVHD size with a function
AMD IOMMU: remove unnecessary cast to u64 in the init code
AMD IOMMU: free domain bitmap with its allocation order
AMD IOMMU: simplify dma_mask_to_pages
Signed-off-by: Robert Richter <robert.richter@amd.com>
Cc: oprofile-list <oprofile-list@lists.sourceforge.net>
Cc: Barry Kasindorf <barry.kasindorf@amd.com>
Define old and new pci vendor and device ids.
Signed-off-by: Dhananjay Phadke <dhananjay@netxen.com>
Signed-off-by: Scott Feldman <scofeldm@cisco.com>
Driver for Atheros L2 10/100 network device. Includes necessary
changes for Kconfig, Makefile, and pci_ids.h.
Signed-off-by: Chris Snook <csnook@redhat.com>
Signed-off-by: Jay Cliburn <jacliburn@bellsouth.net>
The PCI device ids for AMD family 0x11 processors are missing in pci_ids.h.
This patch adds them.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Also, stop looking at the NAND controller (0x4100) and checking the
device class. For a while during development, all three functions on the
chip had the same ID. We made them fix that fairly promptly, and we can
forget about it now.
Acked-by: Jonathan Corbet <corbet@lwn.net>
Probably better to use the official designation.
Acked-by: Pierre Ossman <drzeus@drzeus.cx>
This patch adds the Intel Ibex Peak (PCH) LPC and SMBus Controller DeviceIDs.
pci.ids.h: remove a duplicated symbol
Cc: Doug Thompson <dougthompson@xmission.com>
Signed-off-by: Grant Coady <gcoady.lk@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: state userland requirements in Kconfig help
firewire: avoid memleak after phy config transmit failure
firewire: fw-ohci: TSB43AB22/A dualbuffer workaround
firewire: queue the right number of data
firewire: warn on unfinished transactions during card removal
firewire: small fw_fill_request cleanup
firewire: fully initialize fw_transaction before marking it pending
firewire: fix race of bus reset with request transmission
Enable support for cards with Cologne Chip AG's HFC multiport
chip.
Signed-off-by: Karsten Keil <kkeil@suse.de>
