In non-SMP mode, the variable section attribute specified by DECLARE_PER_CPU()
does not agree with that specified by DEFINE_PER_CPU(). This means that
architectures that have a small data section references relative to a base
register may throw up linkage errors due to too great a displacement between
where the base register points and the per-CPU variable.
On FRV, the .h declaration says that the variable is in the .sdata section, but
the .c definition says it's actually in the .data section. The linker throws
up the following errors:
kernel/built-in.o: In function `release_task':
kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o
To fix this, DECLARE_PER_CPU() should simply apply the same section attribute
as does DEFINE_PER_CPU(). However, this is made slightly more complex by
virtue of the fact that there are several variants on DEFINE, so these need to
be matched by variants on DECLARE.
For the time being, move the generic percpu_*() accessors to
linux/percpu.h.
asm-generic/percpu.h is meant to carry generic stuff for low level
stuff - declarations, definitions and pointer offset calculation
and so on but not for generic interface.
Impact: code reorganization
Separate out embedding first chunk setup helper from x86 embedding
first chunk allocator and put it in mm/percpu.c. This will be used by
the default percpu first chunk allocator and possibly by other archs.
Impact: cleanup, more flexibility for first chunk init
Non-negative @dyn_size used to be allowed iff @unit_size wasn't auto.
This restriction stemmed from implementation detail and made things a
bit less intuitive. This patch allows @dyn_size to be specified
regardless of @unit_size and swaps the positions of @dyn_size and
@unit_size so that the parameter order makes more sense (static,
reserved and dyn sizes followed by enclosing unit_size).
While at it, add @unit_size >= PCPU_MIN_UNIT_SIZE sanity check.
Impact: fix relocation overflow during module load
x86_64 uses 32bit relocations for symbol access and static percpu
symbols whether in core or modules must be inside 2GB of the percpu
segement base which the dynamic percpu allocator doesn't guarantee.
This patch makes x86_64 reserve PERCPU_MODULE_RESERVE bytes in the
first chunk so that module percpu areas are always allocated from the
first chunk which is always inside the relocatable range.
This problem exists for any percpu allocator but is easily triggered
when using the embedding allocator because the second chunk is located
beyond 2GB on it.
This patch also changes the meaning of PERCPU_DYNAMIC_RESERVE such
that it only indicates the size of the area to reserve for dynamic
allocation as static and dynamic areas can be separate. New
PERCPU_DYNAMIC_RESERVED is increased by 4k for both 32 and 64bits as
the reserved area separation eats away some allocatable space and
having slightly more headroom (currently between 4 and 8k after
minimal boot sans module area) makes sense for common case
performance.
x86_32 can address anywhere from anywhere and doesn't need reserving.
Mike Galbraith first reported the problem first and bisected it to the
embedding percpu allocator commit.
Reported-by: Mike Galbraith <efault@gmx.de>
Reported-by: Jaswinder Singh Rajput <jaswinder@kernel.org>
variables
Impact: add reserved allocation functionality and use it for module
percpu variables
This patch implements reserved allocation from the first chunk. When
setting up the first chunk, arch can ask to set aside certain number
of bytes right after the core static area which is available only
through a separate reserved allocator. This will be used primarily
for module static percpu variables on architectures with limited
relocation range to ensure that the module perpcu symbols are inside
If reserved area is requested, the first chunk becomes reserved and
isn't available for regular allocation. If the first chunk also
includes piggy-back dynamic allocation area, a separate chunk mapping
the same region is created to serve dynamic allocation. The first one
is called static first chunk and the second dynamic first chunk.
Although they share the page map, their different area map
initializations guarantee they serve disjoint areas according to their
purposes.
If arch doesn't setup reserved area, reserved allocation is handled
like any other allocation.
Impact: argument semantic cleanup
In pcpu_setup_first_chunk(), zero @unit_size and @dyn_size meant
auto-sizing. It's okay for @unit_size as 0 doesn't make sense but 0
dynamic reserve size is valid. Alos, if arch @dyn_size is calculated
from other parameters, it might end up passing in 0 @dyn_size and
malfunction when the size is automatically adjusted.
This patch makes both @unit_size and @dyn_size ssize_t and use -1 for
auto sizing.
Impact: cosmetic, preparation for future changes
Make the following renames in pcpur_setup_first_chunk() in preparation
for future changes.
* s/free_size/dyn_size/
* s/static_vm/first_vm/
* s/static_chunk/schunk/
Impact: cleaup
Make the following cleanups.
* There isn't much arch-specific about PERCPU_MODULE_RESERVE. Always
define it whether arch overrides PERCPU_ENOUGH_ROOM or not.
* blackfin overrides PERCPU_ENOUGH_ROOM to align static area size. Do
it by default.
* percpu allocation sizes doesn't have much to do with the page size.
Don't use PAGE_SHIFT in their definition.
Cc: Bryan Wu <cooloney@kernel.org>
UP __alloc_percpu() triggered WARN_ON_ONCE() if the requested
alignment is larger than that of unsigned long long, which is too
small for all the cacheline aligned allocations. Bump it up to
SMP_CACHE_BYTES which kmalloc allocations generally guarantee.
Reported-by: Ingo Molnar <mingo@elte.hu>
Impact: build fix
the !SMP branch had a 'gfp' leftover:
include/linux/percpu.h: In function '__alloc_percpu':
include/linux/percpu.h:160: error: 'gfp' undeclared (first use in this function)
include/linux/percpu.h:160: error: (Each undeclared identifier is reported only once
include/linux/percpu.h:160: error: for each function it appears in.)
Use GFP_KERNEL like the SMP version does.
Cc: Tejun Heo <tj@kernel.org>
Impact: more latitude for first percpu chunk allocation
The first percpu chunk serves the kernel static percpu area and may or
may not contain extra room for further dynamic allocation.
Initialization of the first chunk needs to be done before normal
memory allocation service is up, so it has its own init path -
pcpu_setup_static().
It seems archs need more latitude while initializing the first chunk
for example to take advantage of large page mapping. This patch makes
the following changes to allow this.
* Define PERCPU_DYNAMIC_RESERVE to give arch hint about how much space
to reserve in the first chunk for further dynamic allocation.
* Rename pcpu_setup_static() to pcpu_setup_first_chunk().
* Make pcpu_setup_first_chunk() much more flexible by fetching page
pointer by callback and adding optional @unit_size, @free_size and
@base_addr arguments which allow archs to selectively part of chunk
initialization to their likings.
Impact: new scalable dynamic percpu allocator which allows dynamic
percpu areas to be accessed the same way as static ones
Implement scalable dynamic percpu allocator which can be used for both
static and dynamic percpu areas. This will allow static and dynamic
areas to share faster direct access methods. This feature is optional
and enabled only when CONFIG_HAVE_DYNAMIC_PER_CPU_AREA is defined by
arch. Please read comment on top of mm/percpu.c for details.
Impact: kill unused functions
percpu_alloc() and its friends never saw much action. It was supposed
to replace the cpu-mask unaware __alloc_percpu() but it never happened
and in fact __percpu_alloc_mask() itself never really grew proper
up/down handling interface either (no exported interface for
populate/depopulate).
percpu allocation is about to go through major reimplementation and
there's no reason to carry this unused interface around. Replace it
with __alloc_percpu() and free_percpu().
This prepares for a real __alloc_percpu, by adding an alignment argument.
Only one place uses __alloc_percpu directly, and that's for a string.
tj: af_inet also uses __alloc_percpu(), update it.
Impact: cleanup
There are two allocated per-cpu accessor macros with almost identical
spelling. The original and far more popular is per_cpu_ptr (44
files), so change over the other 4 files.
tj: kill percpu_ptr() and update UP too
Cc: mingo@redhat.com
Cc: lenb@kernel.org
Cc: cpufreq@vger.kernel.org
Impact: bug fix
IA-64 needs to put percpu data in the seperate section even on UP.
Fixes regression caused by "percpu: refactor percpu.h"
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Tony Luck <tony.luck@intel.com>
Impact: cleanup
Refactor the DEFINE_PER_CPU_* macros and add .data.percpu.first
section.
"percpu: introduce DEFINE_PER_CPU_PAGE_ALIGNED() macro"
into x86/core
arch/x86/kernel/cpu/common.c
This patch makes the following needlessly global functions static:
- percpu_depopulate()
- __percpu_depopulate_mask()
- percpu_populate()
- __percpu_populate_mask()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
While examining holes in percpu section I found this :
c05f5000 D per_cpu__current_task
c05f5000 D __per_cpu_start
c05f5004 D per_cpu__cpu_number
c05f5008 D per_cpu__irq_regs
c05f500c d per_cpu__cpu_devices
c05f5040 D per_cpu__cyc2ns
<Big Hole of about 4000 bytes>
c05f6000 d per_cpu__cpuid4_info
c05f6004 d per_cpu__cache_kobject
c05f6008 d per_cpu__index_kobject
c05f7000 D per_cpu__gdt_page
This is because gdt_page is a percpu variable, defined with
a page alignement, and linker is doing its job, two times because of .o
nesting in the build process.
I introduced a new macro DEFINE_PER_CPU_PAGE_ALIGNED() to avoid
wasting this space. All page aligned variables (only one at this time)
are put in a separate
subsection .data.percpu.page_aligned, at the very begining of percpu zone.
Before patch , on a x86_32 machine :
.data.percpu 30232 3227471872
.data.percpu 22168 3227471872
Thats 8064 bytes saved for each CPU.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Current module loader lookups ".data.percpu" ELF section to perform
per_cpu relocation. But DEFINE_PER_CPU_SHARED_ALIGNED() uses another
section (".data.percpu.shared_aligned"), currently only handled in
vmlinux.lds, not by module loader.
To correct this problem, instead of adding logic into module loader, or
using at build time a module.lds file for all arches to group
".data.percpu.shared_aligned" into ".data.percpu", just use ".data.percpu"
for modules.
Alignment requirements are correctly handled by ld and module loader.
There's nothing in percpu.h that requires an explicit inclusion of
string.h.
Instead of allocating a fix sized array of NR_CPUS pointers for percpu_data,
we can use nr_cpu_ids, which is generally < NR_CPUS.
Cc: Christoph Lameter <clameter@sgi.com>
ia64 has a special processor specific mapping that can be used to locate the
offset for the current per cpu area.
Cc: linux-ia64@vger.kernel.org
Signed-off-by: Mike Travis <travis@sgi.com>
- Special consideration for IA64: Add the ability to specify
arch specific per cpu flags
- remove .data.percpu attribute from DEFINE_PER_CPU for non-smp case.
The arch definitions are all the same. So move them into linux/percpu.h.
We cannot move DECLARE_PER_CPU since some include files just include
asm/percpu.h to avoid include recursion problems.
Cc: Andi Kleen <ak@suse.de>
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Remove the obviously unnecessary includes of <linux/spinlock.h> under the
include/linux/ directory, and fix the couple errors that are introduced as
a result of that.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Rather than using a single constant PERCPU_ENOUGH_ROOM, compute it as
the sum of kernel_percpu + PERCPU_MODULE_RESERVE. This is now common
to all architectures; if an architecture wants to set
PERCPU_ENOUGH_ROOM to something special, then it may do so (ia64 is
the only one which does).
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Signed-off-by: Andi Kleen <ak@suse.de>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Trivial typo fix in the "syntax error if percpu macros are incorrectly
used" patch. I misspelled "identifier" in all places. D'Oh!
Thanks to Dirk Mueller to point this out.
Signed-off-by: Jan Blunck <jblunck@suse.de>
... or we'll end up with cpu_online_map being evaluated on UP. In
modules. cpumask.h is very careful to avoid that, and for a very good
reason. So should we...
PS: yes, it really triggers (on alpha).
This patch splits alloc_percpu() up into two phases. Likewise for
free_percpu(). This allows clients to limit initial allocations to online
cpu's, and to populate or depopulate per-cpu data at run time as needed:
struct my_struct *obj;
/* initial allocation for online cpu's */
obj = percpu_alloc(sizeof(struct my_struct), GFP_KERNEL);
/* populate per-cpu data for cpu coming online */
ptr = percpu_populate(obj, sizeof(struct my_struct), GFP_KERNEL, cpu);
/* access per-cpu object */
ptr = percpu_ptr(obj, smp_processor_id());
/* depopulate per-cpu data for cpu going offline */
percpu_depopulate(obj, cpu);
/* final removal */
percpu_free(obj);
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
Cc: Paul Jackson <pj@sgi.com>
get_cpu_var()/per_cpu()/__get_cpu_var() arguments must be simple
identifiers. Otherwise the arch dependent implementations might break.
This patch enforces the correct usage of the macros by producing a syntax
error if the variable is not a simple identifier.
I found that blkp field was not used in kernel tree.
As most of the times NR_CPUS is a power of two and kmalloc() memory blocks
too, this extra field basically doubles the memory space allocated in
__alloc_percpu() to store the 'struct percpu_data'
(for example, if NR_CPUS=8 on i386, kmalloc(4*8+4) returns a 64 bytes block
instead of a 32 bytes block after this patch)
__alloc_percpu and alloc_percpu both take an 'align' argument which is
completely ignored. snmp6_mib_init() in net/ipv6/af_inet6.c attempts to use
it, but it will be ignored. Therefore, remove the 'align' argument and fixup
the lone caller.
Signed-off-by: Matthew Dobson <colpatch@us.ibm.com>
Acked-by: Manfred Spraul <manfred@colorfullife.com>
Currently per_cpu_ptr() doesn't really do anything with 'cpu' in the UP
case. This is problematic in the cases where this is the only place the
variable is referenced:
CC kernel/workqueue.o
kernel/workqueue.c: In function `current_is_keventd':
kernel/workqueue.c:460: warning: unused variable `cpu'
infrastructure for it.
Let it rip!
