path: root/include/linux/pm_clock.h
2015-05-12PM / clock_ops: Provide default runtime ops to usersRajendra Nayak
Most users of PM clocks do the extact same things in the runtime suspend/resume callbacks. Provide them USE_PM_CLK_RUNTIME_OPS so as to avoid/remove boilerplate code. Signed-off-by: Rajendra Nayak <rnayak@codeaurora.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Acked-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-07PM / clock_ops: Add pm_clk_add_clk()Geert Uytterhoeven
The existing pm_clk_add() allows to pass a clock by con_id. However, when referring to a specific clock from DT, no con_id is available. Add pm_clk_add_clk(), which allows to specify the struct clk * directly. The will will increment refcount on clock pointer, so the caller has to use clk_put() on clock pointer when done. Reviewed-by: Santosh Shilimkar <santosh.shilimkar@ti.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2011-08-25PM: Move clock-related definitions and headers to separate fileRafael J. Wysocki
Since the PM clock management code in drivers/base/power/clock_ops.c is used for both runtime PM and system suspend/hibernation, the definitions of data structures and headers related to it should not be located in include/linux/pm_rumtime.h. Move them to a separate header file. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
