path: root/include/linux/pm_runtime.h
2013-02-23pm / runtime: introduce pm_runtime_set_memalloc_noio()Ming Lei
Introduce the flag memalloc_noio in 'struct dev_pm_info' to help PM core to teach mm not allocating memory with GFP_KERNEL flag for avoiding probable deadlock. As explained in the comment, any GFP_KERNEL allocation inside runtime_resume() or runtime_suspend() on any one of device in the path from one block or network device to the root device in the device tree may cause deadlock, the introduced pm_runtime_set_memalloc_noio() sets or clears the flag on device in the path recursively. Signed-off-by: Ming Lei <ming.lei@canonical.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Oliver Neukum <oneukum@suse.de> Cc: Jiri Kosina <jiri.kosina@suse.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: Ingo Molnar <mingo@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David Decotigny <david.decotigny@google.com> Cc: Tom Herbert <therbert@google.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-26PM / Runtime: Add new helper function: pm_runtime_active()ShuoX Liu
This boolean function simply returns whether or not the runtime status of the device is 'active'. The typical scenario is driver calls pm_runtime_get firstly, then check pm_runtime_active in atomic environment. Also add entry to Documentation/power/runtime.txt Signed-off-by: Yanmin Zhang <yanmin.zhang@intel.com> Signed-off-by: ShuoX Liu <shuox.liu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-05-01PM / Runtime: Remove device fields related to suspend time, v2Rafael J. Wysocki
After the previous changes in default_stop_ok() and default_power_down_ok() for PM domains, there are two fields in struct dev_pm_info that aren't necessary any more, suspend_time and max_time_suspended_ns. Remove those fields along with all of the code that accesses them, which simplifies the runtime PM framework quite a bit. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-12-01PM / Runtime: Use device PM QoS constraints (v2)Rafael J. Wysocki
Make the runtime PM core use device PM QoS constraints to check if it is allowed to suspend a given device, so that an error code is returned if the device's own PM QoS constraint is negative or one of its children has already been suspended for too long. If this is not the case, the maximum estimated time the device is allowed to be suspended, computed as the minimum of the device's PM QoS constraint and the PM QoS constraints of its children (reduced by the difference between the current time and their suspend times) is stored in a new device's PM field power.max_time_suspended_ns that can be used by the device's subsystem or PM domain to decide whether or not to put the device into lower-power (and presumably higher-latency) states later (if the constraint is 0, which means "no constraint", the power.max_time_suspended_ns is set to -1). Additionally, the time of execution of the subsystem-level .runtime_suspend() callback for the device is recorded in the new power.suspend_time field for later use by the device's subsystem or PM domain along with power.max_time_suspended_ns (it also is used by the core code when the device's parent is suspended). Introduce a new helper function, pm_runtime_update_max_time_suspended(), allowing subsystems and PM domains (or device drivers) to update the power.max_time_suspended_ns field, for example after changing the power state of a suspended device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-11-17PM Sleep: Do not extend wakeup paths to devices with ignore_children setRafael J. Wysocki
Commit 4ca46ff3e0d8c234cb40ebb6457653b59584426c (PM / Sleep: Mark devices involved in wakeup signaling during suspend) introduced the power.wakeup_path field in struct dev_pm_info to mark devices whose children are enabled to wake up the system from sleep states, so that power domains containing the parents that provide their children with wakeup power and/or relay their wakeup signals are not turned off. Unfortunately, that introduced a PM regression on SH7372 whose power consumption in the system "memory sleep" state increased as a result of it, because it prevented the power domain containing the I2C controller from being turned off when some children of that controller were enabled to wake up the system, although the controller was not necessary for them to signal wakeup. To fix this issue use the observation that devices whose power.ignore_children flag is set for runtime PM should be treated analogously during system suspend. Namely, they shouldn't be included in wakeup paths going through their children. Since the SH7372 I2C controller's power.ignore_children flag is set, doing so will restore the previous behavior of that SOC. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-31pm_runtime.h: explicitly requires notifier.hPaul Gortmaker
This file was getting notifier.h via device.h --> module.h but the module.h inclusion is going away, so add notifier.h directly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-25PM: Move clock-related definitions and headers to separate fileRafael J. Wysocki
Since the PM clock management code in drivers/base/power/clock_ops.c is used for both runtime PM and system suspend/hibernation, the definitions of data structures and headers related to it should not be located in include/linux/pm_rumtime.h. Move them to a separate header file. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-08-25PM / Domains: Use power.sybsys_data to reduce overheadRafael J. Wysocki
Currently pm_genpd_runtime_resume() has to walk the list of devices from the device's PM domain to find the corresponding device list object containing the need_restore field to check if the driver's .runtime_resume() callback should be executed for the device. This is suboptimal and can be simplified by using power.sybsys_data to store device information used by the generic PM domains code. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-08-25PM: Introduce struct pm_subsys_dataRafael J. Wysocki
Introduce struct pm_subsys_data that may be subclassed by subsystems to store subsystem-specific information related to the device. Move the clock management fields accessed through the power.subsys_data pointer in struct device to the new strucutre. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-12PM / Runtime: Add new helper function: pm_runtime_status_suspended()Kevin Hilman
This boolean function simply returns whether or not the runtime status of the device is 'suspended'. Unlike pm_runtime_suspended(), this function returns the runtime status whether or not runtime PM for the device has been disabled or not. Also add entry to Documentation/power/runtime.txt Signed-off-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-07-02PM: Rename clock management functionsRafael J. Wysocki
The common PM clock management functions may be used for system suspend/resume as well as for runtime PM, so rename them accordingly. Modify kerneldoc comments describing these functions and kernel messages printed by them, so that they refer to power management in general rather that to runtime PM. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-07-02PM: Allow the clocks management code to be used during system suspendRafael J. Wysocki
The common clocks management code in drivers/base/power/clock_ops.c is going to be used during system-wide power transitions as well as for runtime PM, so it shouldn't depend on CONFIG_PM_RUNTIME. However, the suspend/resume functions provided by it for CONFIG_PM_RUNTIME unset, to be used during system-wide power transitions, should not behave in the same way as their counterparts defined for CONFIG_PM_RUNTIME set, because in that case the clocks are managed differently at run time. The names of the functions still contain the word "runtime" after this change, but that is going to be modified by a separate patch later. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Kevin Hilman <khilman@ti.com>
2011-07-02PM / Domains: Rename struct dev_power_domain to struct dev_pm_domainRafael J. Wysocki
The naming convention used by commit 7538e3db6e015e890825fbd9f86599b (PM: Add support for device power domains), which introduced the struct dev_power_domain type for representing device power domains, evidently confuses some developers who tend to think that objects of this type must correspond to "power domains" as defined by hardware, which is not the case. Namely, at the kernel level, a struct dev_power_domain object can represent arbitrary set of devices that are mutually dependent power management-wise and need not belong to one hardware power domain. To avoid that confusion, rename struct dev_power_domain to struct dev_pm_domain and rename the related pointers in struct device and struct pm_clk_notifier_block from pwr_domain to pm_domain. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Kevin Hilman <khilman@ti.com>
2011-04-30PM / Runtime: Generic clock manipulation rountines for runtime PM (v6)Rafael J. Wysocki
Many different platforms and subsystems may want to disable device clocks during suspend and enable them during resume which is going to be done in a very similar way in all those cases. For this reason, provide generic routines for the manipulation of device clocks during suspend and resume. Convert the ARM shmobile platform to using the new routines. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-03-15PM: Do not create wakeup sysfs files for devices that cannot wake upRafael J. Wysocki
Currently, wakeup sysfs attributes are created for all devices, regardless of whether or not they are wakeup-capable. This is excessive and complicates wakeup device identification from user space (i.e. to identify wakeup-capable devices user space has to read /sys/devices/.../power/wakeup for all devices and see if they are not empty). Fix this issue by avoiding to create wakeup sysfs files for devices that cannot wake up the system from sleep states (i.e. whose power.can_wakeup flags are unset during registration) and modify device_set_wakeup_capable() so that it adds (or removes) the relevant sysfs attributes if a device's wakeup capability status is changed. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM / Runtime: Generic resume shouldn't set RPM_ACTIVE unconditionallyRafael J. Wysocki
The __pm_generic_resume() function changes the given device's runtime PM status to RPM_ACTIVE if its driver's callback returns 0, but it only should do that if the rumtime PM is enabled for the device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-24PM / Runtime: Add synchronous runtime interface for interrupt handlers (v3)Alan Stern
This patch (as1431c) makes the synchronous runtime-PM interface suitable for use in interrupt handlers. Subsystems can call the new pm_runtime_irq_safe() function to tell the PM core that a device's runtime_suspend and runtime_resume callbacks should be invoked with interrupts disabled and the spinlock held. This permits the pm_runtime_get_sync() and the new pm_runtime_put_sync_suspend() routines to be called from within interrupt handlers. When a device is declared irq-safe in this way, the PM core increments the parent's usage count, so the parent will never be runtime suspended. This prevents difficult situations in which an irq-safe device can't resume because it is forced to wait for its non-irq-safe parent. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-12-16PM / Runtime: Fix pm_runtime_suspended()Rafael J. Wysocki
There are some situations (e.g. in __pm_generic_call()), where pm_runtime_suspended() is used to decide whether or not to execute a device's (system) ->suspend() callback. The callback is not executed if pm_runtime_suspended() returns true, but it does so for devices that don't even support runtime PM, because the power.disable_depth device field is ignored by it. This leads to problems (i.e. devices are not suspened when they should), so rework pm_runtime_suspended() so that it returns false if the device's power.disable_depth field is different from zero. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: stable@kernel.org
2010-10-17PM: runtime: add missed pm_request_autosuspendMing Lei
The patch "PM / Runtime: Implement autosuspend support" introduces "autosuspend" facility for runtime PM, but misses helper function of pm_request_autosuspend, so add it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM / Runtime: Implement autosuspend supportAlan Stern
This patch (as1427) implements the "autosuspend" facility for runtime PM. A few new fields are added to the dev_pm_info structure and several new PM helper functions are defined, for telling the PM core whether or not a device uses autosuspend, for setting the autosuspend delay, and for marking periods of device activity. Drivers that do not want to use autosuspend can continue using the same helper functions as before; their behavior will not change. In addition, drivers supporting autosuspend can also call the old helper functions to get the old behavior. The details are all explained in Documentation/power/runtime_pm.txt and Documentation/ABI/testing/sysfs-devices-power. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM / Runtime: Add no_callbacks flagAlan Stern
Some devices, such as USB interfaces, cannot be power-managed independently of their parents, i.e., they cannot be put in low power while the parent remains at full power. This patch (as1425) creates a new "no_callbacks" flag, which tells the PM core not to invoke the runtime-PM callback routines for the such devices but instead to assume that the callbacks always succeed. In addition, the non-debugging runtime-PM sysfs attributes for the devices are removed, since they are pretty much meaningless. The advantage of this scheme comes not so much from avoiding the callbacks themselves, but rather from the fact that without the need for a process context in which to run the callbacks, more work can be done in interrupt context. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM / Runtime: Combine runtime PM entry pointsAlan Stern
This patch (as1424) combines the various public entry points for the runtime PM routines into three simple functions: one for idle, one for suspend, and one for resume. A new bitflag specifies whether or not to increment or decrement the usage_count field. The new entry points are named __pm_runtime_idle, __pm_runtime_suspend, and __pm_runtime_resume, to reflect that they are trampolines. Simultaneously, the corresponding internal routines are renamed to rpm_idle, rpm_suspend, and rpm_resume. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM / Runtime: Replace boolean arguments with bitflagsAlan Stern
The "from_wq" argument in __pm_runtime_suspend() and __pm_runtime_resume() supposedly indicates whether or not the function was called by the PM workqueue thread, but in fact it isn't always used this way. It really indicates whether or not the function should return early if the requested operation is already in progress. Along with this badly-named boolean argument, later patches in this series will add several other boolean arguments to these functions and others. Therefore this patch (as1422) begins the conversion process by replacing from_wq with a bitflag argument. The same bitflags are also used in __pm_runtime_get() and __pm_runtime_put(), where they indicate whether or not the operation should be asynchronous. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10i2c: Fix bus-level power management callbacksRafael J. Wysocki
There are three issues with the i2c bus type's power management callbacks at the moment. First, they don't include any hibernate callbacks, although they should at least include the .restore() callback (there's no guarantee that the driver will be present in memory before loading the image kernel and we must restore the pre-hibernation state of the device). Second, the "legacy" callbacks are not going to be invoked by the PM core since the bus type's pm object is not NULL. Finally, the system sleep PM (ie. suspend/resume) callbacks don't check if the device has been already suspended at run time, in which case they should skip suspending it. Also, it looks like the i2c bus type can use the generic subsystem-level runtime PM callbacks. For these reasons, rework the system sleep PM callbacks provided by the i2c bus type to handle hibernation correctly and to invoke the "legacy" callbacks for drivers that provide them. In addition to that make the i2c bus type use the generic subsystem-level runtime PM callbacks. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2010-03-06PM: Provide generic subsystem-level callbacksRafael J. Wysocki
There are subsystems whose power management callbacks only need to invoke the callbacks provided by device drivers. Still, their system sleep PM callbacks should play well with the runtime PM callbacks, so that devices suspended at run time can be left in that state for a system sleep transition. Provide a set of generic PM callbacks for such subsystems and define convenience macros for populating dev_pm_ops structures. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-26PM / Runtime: Add sysfs switch for disabling device run-time PMRafael J. Wysocki
Add new device sysfs attribute, power/control, allowing the user space to block the run-time power management of the devices. If this attribute is set to "on", the driver of the device won't be able to power manage it at run time (without breaking the rules) and the device will always be in the full power state (except when the entire system goes into a sleep state). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Alan Stern <stern@rowland.harvard.edu>
2009-12-06PM: Add flag for devices capable of generating run-time wake-up eventsRafael J. Wysocki
Apparently, there are devices that can wake up the system from sleep states and yet are incapable of generating wake-up events at run time. Thus, introduce a flag indicating if given device is capable of generating run-time wake-up events. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-08-23PM: Introduce core framework for run-time PM of I/O devices (rev. 17)Rafael J. Wysocki
Introduce a core framework for run-time power management of I/O devices. Add device run-time PM fields to 'struct dev_pm_info' and device run-time PM callbacks to 'struct dev_pm_ops'. Introduce a run-time PM workqueue and define some device run-time PM helper functions at the core level. Document all these things. Special thanks to Alan Stern for his help with the design and multiple detailed reviews of the pereceding versions of this patch and to Magnus Damm for testing feedback. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Magnus Damm <damm@igel.co.jp>
