path: root/include/linux/preempt.h
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-03sched/headers: Move the PREEMPT_COUNT defines from <linux/sched.h> to ↵Ingo Molnar
<linux/preempt.h> These defines are not really part of the scheduler's driver API, but are related to the preempt count - so move them to <linux/preempt.h>. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-12-06x86/uaccess, sched/preempt: Verify access_ok() contextPeter Zijlstra
I recently encountered wreckage because access_ok() was used where it should not be, add an explicit WARN when access_ok() is used wrongly. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06sched/core: Kill PREEMPT_ACTIVEPeter Zijlstra
Its unused, kill the definition. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06sched/core: Simplify preempt_count testsPeter Zijlstra
Since we stopped setting PREEMPT_ACTIVE, there is no need to mask it out of preempt_count() tests. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-06sched/core: Stop setting PREEMPT_ACTIVEPeter Zijlstra
Now that nothing tests for PREEMPT_ACTIVE anymore, stop setting it. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-03sched/preempt: Fix cond_resched_lock() and cond_resched_softirq()Konstantin Khlebnikov
These functions check should_resched() before unlocking spinlock/bh-enable: preempt_count always non-zero => should_resched() always returns false. cond_resched_lock() worked iff spin_needbreak is set. This patch adds argument "preempt_offset" to should_resched(). preempt_count offset constants for that: PREEMPT_DISABLE_OFFSET - offset after preempt_disable() PREEMPT_LOCK_OFFSET - offset after spin_lock() SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable() SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh() Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Graf <agraf@suse.de> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers") Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-03sched, preempt_notifier: separate notifier registration from static_key inc/decPeter Zijlstra
Commit 1cde2930e154 ("sched/preempt: Add static_key() to preempt_notifiers") had two problems. First, the preempt-notifier API needs to sleep with the addition of the static_key, we do however need to hold off preemption while modifying the preempt notifier list, otherwise a preemption could observe an inconsistent list state. KVM correctly registers and unregisters preempt notifiers with preemption disabled, so the sleep caused dmesg splats. Second, KVM registers and unregisters preemption notifiers very often (in vcpu_load/vcpu_put). With a single uniprocessor guest the static key would move between 0 and 1 continuously, hitting the slow path on every userspace exit. To fix this, wrap the static_key inc/dec in a new API, and call it from KVM. Fixes: 1cde2930e154 ("sched/preempt: Add static_key() to preempt_notifiers") Reported-by: Pontus Fuchs <pontus.fuchs@gmail.com> Reported-by: Takashi Iwai <tiwai@suse.de> Tested-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-06-07preempt: Reorganize the notrace definitions a bitFrederic Weisbecker
preempt.h has two seperate "#ifdef CONFIG_PREEMPT" sections: one to define preempt_enable() and another to define preempt_enable_notrace(). Lets gather both. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1433432349-1021-4-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-07preempt: Use preempt_schedule_context() as the official tracing preemption pointFrederic Weisbecker
preempt_schedule_context() is a tracing safe preemption point but it's only used when CONFIG_CONTEXT_TRACKING=y. Other configs have tracing recursion issues since commit: b30f0e3ffedf ("sched/preempt: Optimize preemption operations on __schedule() callers") introduced function based preemp_count_*() ops. Lets make it available on all configs and give it a more appropriate name for its new position. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1433432349-1021-3-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt: Remove PREEMPT_ACTIVE unmasking off in_atomic()Frederic Weisbecker
Now that PREEMPT_ACTIVE implies PREEMPT_DISABLE_OFFSET, ignoring PREEMPT_ACTIVE from in_atomic() check isn't useful anymore. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1431441711-29753-7-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt: Fix out of date commentFrederic Weisbecker
Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1431441711-29753-6-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt: Optimize preemption operations on __schedule() callersFrederic Weisbecker
__schedule() disables preemption and some of its callers (the preempt_schedule*() family) also set PREEMPT_ACTIVE. So we have two preempt_count() modifications that could be performed at once. Lets remove the preemption disablement from __schedule() and pull this responsibility to its callers in order to optimize preempt_count() operations in a single place. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1431441711-29753-5-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt: Rename PREEMPT_CHECK_OFFSET to PREEMPT_DISABLE_OFFSETFrederic Weisbecker
"CHECK" suggests it's only used as a comparison mask. But now it's used further as a config-conditional preempt disabler offset. Lets disambiguate this name. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1431441711-29753-4-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt: Rearrange a few symbols after headers mergeFrederic Weisbecker
Adjust a few comments, and further integrate a few definitions after the dumb headers copy. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1431441711-29753-3-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt: Merge preempt_mask.h into preempt.hFrederic Weisbecker
preempt_mask.h defines all the preempt_count semantics and related symbols: preempt, softirq, hardirq, nmi, preempt active, need resched, etc... preempt.h defines the accessors and mutators of preempt_count. But there is a messy dependency game around those two header files: * preempt_mask.h includes preempt.h in order to access preempt_count() * preempt_mask.h defines all preempt_count semantic and symbols except PREEMPT_NEED_RESCHED that is needed by asm/preempt.h Thus we need to define it from preempt.h, right before including asm/preempt.h, instead of defining it to preempt_mask.h with the other preempt_count symbols. Therefore the preempt_count semantics happen to be spread out. * We plan to introduce preempt_active_[enter,exit]() to consolidate preempt_schedule*() code. But we'll need to access both preempt_count mutators (preempt_count_add()) and preempt_count symbols (PREEMPT_ACTIVE, PREEMPT_OFFSET). The usual place to define preempt operations is in preempt.h but then we'll need symbols in preempt_mask.h which already includes preempt.h. So we end up with a ressource circle dependency. Lets merge preempt_mask.h into preempt.h to solve these dependency issues. This way we gather semantic symbols and operation definition of preempt_count in a single file. This is a dumb copy-paste merge. Further merge re-arrangments are performed in a subsequent patch to ease review. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1431441711-29753-2-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-23sched/preempt/x86: Fix voluntary preempt for x86Peter Zijlstra
The #ifdef CONFIG_PREEMPT is both not needed and wrong. Its not required because asm/preempt.h should provide {set,clear}_preempt_need_resched() regardless and its wrong because for voluntary preempt we still rely on PREEMPT_NEED_RESCHED. Reported-and-Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de> Fixes: 8cb75e0c4ec9 ("sched/preempt: Fix up missed PREEMPT_NEED_RESCHED folding") Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/20140122102435.GH31570@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13sched/preempt: Fix up missed PREEMPT_NEED_RESCHED foldingPeter Zijlstra
With various drivers wanting to inject idle time; we get people calling idle routines outside of the idle loop proper. Therefore we need to be extra careful about not missing TIF_NEED_RESCHED -> PREEMPT_NEED_RESCHED propagations. While looking at this, I also realized there's a small window in the existing idle loop where we can miss TIF_NEED_RESCHED; when it hits right after the tif_need_resched() test at the end of the loop but right before the need_resched() test at the start of the loop. So move preempt_fold_need_resched() out of the loop where we're guaranteed to have TIF_NEED_RESCHED set. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-x9jgh45oeayzajz2mjt0y7d6@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13sched/preempt: Take away preempt_enable_no_resched() from modulesPeter Zijlstra
Discourage drivers/modules to be creative with preemption. Sadly all is implemented in macros and inline so if they want to do evil they still can, but at least try and discourage some. Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Eliezer Tamir <eliezer.tamir@linux.intel.com> Cc: rui.zhang@intel.com Cc: jacob.jun.pan@linux.intel.com Cc: Mike Galbraith <bitbucket@online.de> Cc: hpa@zytor.com Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: lenb@kernel.org Cc: rjw@rjwysocki.net Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-fn7h6vu8wtgxk0ih402qcijx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, x86: Optimize the preempt_schedule() callPeter Zijlstra
Remove the bloat of the C calling convention out of the preempt_enable() sites by creating an ASM wrapper which allows us to do an asm("call ___preempt_schedule") instead. calling.h bits by Andi Kleen Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-tk7xdi1cvvxewixzke8t8le1@git.kernel.org [ Fixed build error. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched: Extract the basic add/sub preempt_count modifiersPeter Zijlstra
Rewrite the preempt_count macros in order to extract the 3 basic preempt_count value modifiers: __preempt_count_add() __preempt_count_sub() and the new: __preempt_count_dec_and_test() And since we're at it anyway, replace the unconventional $op_preempt_count names with the more conventional preempt_count_$op. Since these basic operators are equivalent to the previous _notrace() variants, do away with the _notrace() versions. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-ewbpdbupy9xpsjhg960zwbv8@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched, arch: Create asm/preempt.hPeter Zijlstra
In order to prepare to per-arch implementations of preempt_count move the required bits into an asm-generic header and use this for all archs. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-h5j0c1r3e3fk015m30h8f1zx@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched: Add NEED_RESCHED to the preempt_countPeter Zijlstra
In order to combine the preemption and need_resched test we need to fold the need_resched information into the preempt_count value. Since the NEED_RESCHED flag is set across CPUs this needs to be an atomic operation, however we very much want to avoid making preempt_count atomic, therefore we keep the existing TIF_NEED_RESCHED infrastructure in place but at 3 sites test it and fold its value into preempt_count; namely: - resched_task() when setting TIF_NEED_RESCHED on the current task - scheduler_ipi() when resched_task() sets TIF_NEED_RESCHED on a remote task it follows it up with a reschedule IPI and we can modify the cpu local preempt_count from there. - cpu_idle_loop() for when resched_task() found tsk_is_polling(). We use an inverted bitmask to indicate need_resched so that a 0 means both need_resched and !atomic. Also remove the barrier() in preempt_enable() between preempt_enable_no_resched() and preempt_check_resched() to avoid having to reload the preemption value and allow the compiler to use the flags of the previuos decrement. I couldn't come up with any sane reason for this barrier() to be there as preempt_enable_no_resched() already has a barrier() before doing the decrement. Suggested-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-7a7m5qqbn5pmwnd4wko9u6da@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched: Introduce preempt_count accessor functionsPeter Zijlstra
Replace the single preempt_count() 'function' that's an lvalue with two proper functions: preempt_count() - returns the preempt_count value as rvalue preempt_count_set() - Allows setting the preempt-count value Also provide preempt_count_ptr() as a convenience wrapper to implement all modifying operations. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-orxrbycjozopqfhb4dxdkdvb@git.kernel.org [ Fixed build failure. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-19tracing/context-tracking: Add preempt_schedule_context() for tracingSteven Rostedt
Dave Jones hit the following bug report: =============================== [ INFO: suspicious RCU usage. ] 3.10.0-rc2+ #1 Not tainted ------------------------------- include/linux/rcupdate.h:771 rcu_read_lock() used illegally while idle! other info that might help us debug this: RCU used illegally from idle CPU! rcu_scheduler_active = 1, debug_locks = 0 RCU used illegally from extended quiescent state! 2 locks held by cc1/63645: #0: (&rq->lock){-.-.-.}, at: [<ffffffff816b39fd>] __schedule+0xed/0x9b0 #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8109d645>] cpuacct_charge+0x5/0x1f0 CPU: 1 PID: 63645 Comm: cc1 Not tainted 3.10.0-rc2+ #1 [loadavg: 40.57 27.55 13.39 25/277 64369] Hardware name: Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H, BIOS F12a 04/23/2010 0000000000000000 ffff88010f78fcf8 ffffffff816ae383 ffff88010f78fd28 ffffffff810b698d ffff88011c092548 000000000023d073 ffff88011c092500 0000000000000001 ffff88010f78fd60 ffffffff8109d7c5 ffffffff8109d645 Call Trace: [<ffffffff816ae383>] dump_stack+0x19/0x1b [<ffffffff810b698d>] lockdep_rcu_suspicious+0xfd/0x130 [<ffffffff8109d7c5>] cpuacct_charge+0x185/0x1f0 [<ffffffff8109d645>] ? cpuacct_charge+0x5/0x1f0 [<ffffffff8108dffc>] update_curr+0xec/0x240 [<ffffffff8108f528>] put_prev_task_fair+0x228/0x480 [<ffffffff816b3a71>] __schedule+0x161/0x9b0 [<ffffffff816b4721>] preempt_schedule+0x51/0x80 [<ffffffff816b4800>] ? __cond_resched_softirq+0x60/0x60 [<ffffffff816b6824>] ? retint_careful+0x12/0x2e [<ffffffff810ff3cc>] ftrace_ops_control_func+0x1dc/0x210 [<ffffffff816be280>] ftrace_call+0x5/0x2f [<ffffffff816b681d>] ? retint_careful+0xb/0x2e [<ffffffff816b4805>] ? schedule_user+0x5/0x70 [<ffffffff816b4805>] ? schedule_user+0x5/0x70 [<ffffffff816b6824>] ? retint_careful+0x12/0x2e ------------[ cut here ]------------ What happened was that the function tracer traced the schedule_user() code that tells RCU that the system is coming back from userspace, and to add the CPU back to the RCU monitoring. Because the function tracer does a preempt_disable/enable_notrace() calls the preempt_enable_notrace() checks the NEED_RESCHED flag. If it is set, then preempt_schedule() is called. But this is called before the user_exit() function can inform the kernel that the CPU is no longer in user mode and needs to be accounted for by RCU. The fix is to create a new preempt_schedule_context() that checks if the kernel is still in user mode and if so to switch it to kernel mode before calling schedule. It also switches back to user mode coming back from schedule in need be. The only user of this currently is the preempt_enable_notrace(), which is only used by the tracing subsystem. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1369423420.6828.226.camel@gandalf.local.home Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-04-09spinlocks and preemption points need to be at least compiler barriersLinus Torvalds
In UP and non-preempt respectively, the spinlocks and preemption disable/enable points are stubbed out entirely, because there is no regular code that can ever hit the kind of concurrency they are meant to protect against. However, while there is no regular code that can cause scheduling, we _do_ end up having some exceptional (literally!) code that can do so, and that we need to make sure does not ever get moved into the critical region by the compiler. In particular, get_user() and put_user() is generally implemented as inline asm statements (even if the inline asm may then make a call instruction to call out-of-line), and can obviously cause a page fault and IO as a result. If that inline asm has been scheduled into the middle of a preemption-safe (or spinlock-protected) code region, we obviously lose. Now, admittedly this is *very* unlikely to actually ever happen, and we've not seen examples of actual bugs related to this. But partly exactly because it's so hard to trigger and the resulting bug is so subtle, we should be extra careful to get this right. So make sure that even when preemption is disabled, and we don't have to generate any actual *code* to explicitly tell the system that we are in a preemption-disabled region, we need to at least tell the compiler not to move things around the critical region. This patch grew out of the same discussion that caused commits 79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq* functions") and 3e2e0d2c222b ("tile: comment assumption about __insn_mtspr for <asm/irqflags.h>") to come about. Note for stable: use discretion when/if applying this. As mentioned, this bug may never have actually bitten anybody, and gcc may never have done the required code motion for it to possibly ever trigger in practice. Cc: stable@vger.kernel.org Cc: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-01sched/rt: Document scheduler related skip-resched-check sitesThomas Gleixner
Create a distinction between scheduler related preempt_enable_no_resched() calls and the nearly one hundred other places in the kernel that do not want to reschedule, for one reason or another. This distinction matters for -rt, where the scheduler and the non-scheduler preempt models (and checks) are different. For upstream it's purely documentational. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-gs88fvx2mdv5psnzxnv575ke@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-10sched: Isolate preempt counting in its own config optionFrederic Weisbecker
Create a new CONFIG_PREEMPT_COUNT that handles the inc/dec of preempt count offset independently. So that the offset can be updated by preempt_disable() and preempt_enable() even without the need for CONFIG_PREEMPT beeing set. This prepares to make CONFIG_DEBUG_SPINLOCK_SLEEP working with !CONFIG_PREEMPT where it currently doesn't detect code that sleeps inside explicit preemption disabled sections. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl>
2009-12-02sched: Revert 498657a478c60be092208422fefa9c7b248729c2Tejun Heo
498657a478c60be092208422fefa9c7b248729c2 incorrectly assumed that preempt wasn't disabled around context_switch() and thus was fixing imaginary problem. It also broke KVM because it depended on ->sched_in() to be called with irq enabled so that it can do smp calls from there. Revert the incorrect commit and add comment describing different contexts under with the two callbacks are invoked. Avi: spotted transposed in/out in the added comment. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Avi Kivity <avi@redhat.com> Cc: peterz@infradead.org Cc: efault@gmx.de Cc: rusty@rustcorp.com.au LKML-Reference: <1259726212-30259-2-git-send-email-tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-23ftrace: trace preempt off critical timingsSteven Rostedt
Add preempt off timings. A lot of kernel core code is taken from the RT patch latency trace that was written by Ingo Molnar. This adds "preemptoff" and "preemptirqsoff" to /debugfs/tracing/available_tracers Now instead of just tracing irqs off, preemption off can be selected to be recorded. When this is selected, it shares the same files as irqs off timings. One can either trace preemption off, irqs off, or one or the other off. By echoing "preemptoff" into /debugfs/tracing/current_tracer, recording of preempt off only is performed. "irqsoff" will only record the time irqs are disabled, but "preemptirqsoff" will take the total time irqs or preemption are disabled. Runtime switching of these options is now supported by simpling echoing in the appropriate trace name into /debugfs/tracing/current_tracer. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: add preempt_enable/disable notrace macrosSteven Rostedt
The tracer may need to call preempt_enable and disable functions for time keeping and such. The trace gets ugly when we see these functions show up for all traces. To make the output cleaner this patch adds preempt_enable_notrace and preempt_disable_notrace to be used by tracer (and debugging) functions. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08Remove fastcall from linux/includeHarvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26[PATCH] sched: arch preempt notifier mechanismAvi Kivity
This adds a general mechanism whereby a task can request the scheduler to notify it whenever it is preempted or scheduled back in. This allows the task to swap any special-purpose registers like the fpu or Intel's VT registers. Signed-off-by: Avi Kivity <avi@qumranet.com> [ mingo@elte.hu: fixes, cleanups ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-12-22[PATCH] fix race with preempt_enable()Nicolas Pitre
Currently a simple void foo(void) { preempt_enable(); } produces the following code on ARM: foo: bic r3, sp, #8128 bic r3, r3, #63 ldr r2, [r3, #4] ldr r1, [r3, #0] sub r2, r2, #1 tst r1, #4 str r2, [r3, #4] blne preempt_schedule mov pc, lr The problem is that the TIF_NEED_RESCHED flag is loaded _before_ the preemption count is stored back, hence any interrupt coming within that 3 instruction window causing TIF_NEED_RESCHED to be set won't be seen and scheduling won't happen as it should. Nothing currently prevents gcc from performing that reordering. There is already a barrier() before the decrement of the preemption count, but another one is needed between this and the TIF_NEED_RESCHED flag test for proper code ordering. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] m68k: thread_info header cleanupAl Viro
a) in smp_lock.h #include of sched.h and spinlock.h moved under #ifdef CONFIG_LOCK_KERNEL. b) interrupt.h now explicitly pulls sched.h (not via smp_lock.h from hardirq.h as it used to) c) in three more places we need changes to compensate for (a) - one place in arch/sparc needs string.h now, hardirq.h needs forward declaration of task_struct and preempt.h needs direct include of thread_info.h. d) thread_info-related helpers in sched.h and thread_info.h put under ifndef __HAVE_THREAD_FUNCTIONS. Obviously safe. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
