path: root/include/linux/projid.h
2013-11-26userns: userns: Remove UIDGID_STRICT_TYPE_CHECKSEric W. Biederman
Removing UIDGID_STRICT_TYPE_CHECKS simplifies the code and always generates a compile error if the uids and kuids or gids and kgids are mixed by accident. Now that the appropriate conversions have been placed throughout the kernel there is no longer a need for a mode where we don't detect them as compile errors. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-18userns: Add kprojid_t and associated infrastructure in projid.hEric W. Biederman
Implement kprojid_t a cousin of the kuid_t and kgid_t. The per user namespace mapping of project id values can be set with /proc/<pid>/projid_map. A full compliment of helpers is provided: make_kprojid, from_kprojid, from_kprojid_munged, kporjid_has_mapping, projid_valid, projid_eq, projid_eq, projid_lt. Project identifiers are part of the generic disk quota interface, although it appears only xfs implements project identifiers currently. The xfs code allows anyone who has permission to set the project identifier on a file to use any project identifier so when setting up the user namespace project identifier mappings I do not require a capability. Cc: Dave Chinner <david@fromorbit.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
