path: root/include/linux/ptrace.h
2008-04-30ptrace: introduce ptrace_reparented() helperOleg Nesterov
Add another trivial helper for the sake of grep. It also auto-documents the fact that ->parent != real_parent implies ->ptrace. No functional changes. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08kill PT_ATTACHEDOleg Nesterov
Since the patch "Fix ptrace_attach()/ptrace_traceme()/de_thread() race" commit f5b40e363ad6041a96e3da32281d8faa191597b9 we set PT_ATTACHED and change child->parent "atomically" wrt task_list lock. This means we can remove the checks like "PT_ATTACHED && ->parent != ptracer" which were needed to catch the "ptrace attach is in progress" case. We can also remove the flag itself since nobody else uses it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Roland McGrath <roland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06Add arch_ptrace_stopRoland McGrath
This adds support to allow asm/ptrace.h to define two new macros, arch_ptrace_stop_needed and arch_ptrace_stop. These control special machine-specific actions to be done before a ptrace stop. The new code compiles away to nothing when the new macros are not defined. This is the case on all machines to begin with. On ia64, these macros will be defined to solve the long-standing issue of ptrace vs register backing store. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Petr Tesarik <ptesarik@suse.cz> Cc: Tony Luck <tony.luck@intel.com> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30ptrace: generic PTRACE_SINGLEBLOCKRoland McGrath
This makes ptrace_request handle PTRACE_SINGLEBLOCK along with PTRACE_CONT et al. The new generic code makes use of the arch_has_block_step macro and generic entry points on machines that define them. [ mingo@elte.hu: bugfix ] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30ptrace: arch_has_block_stepRoland McGrath
This defines the new macro arch_has_block_step() in linux/ptrace.h, a default for when asm/ptrace.h does not define it. This is the analog of arch_has_single_step() for step-until-branch on machines that have it. It declares the new user_enable_block_step function, which goes with the existing user_enable_single_step and user_disable_single_step. This is not used yet, but paves the way to harmonize on this interface for the arch-specific calls on all machines. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30ptrace: arch_has_single_stepRoland McGrath
This defines the new macro arch_has_single_step() in linux/ptrace.h, a default for when asm/ptrace.h does not define it. It declares the new user_enable_single_step and user_disable_single_step functions. This is not used yet, but paves the way to harmonize on this interface for the arch-specific calls on all machines. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-02restrict reading from /proc/<pid>/maps to those who share ->mm or can ptrace pidAl Viro
Contents of /proc/*/maps is sensitive and may become sensitive after open() (e.g. if target originally shares our ->mm and later does exec on suid-root binary). Check at read() (actually, ->start() of iterator) time that mm_struct we'd grabbed and locked is - still the ->mm of target - equal to reader's ->mm or the target is ptracable by reader. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_POKEDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_POKEDATA go into generic_ptrace_pokedata() function. AFAICS, fix bug on xtensa where successful PTRACE_POKEDATA will nevertheless return EPERM. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17PTRACE_PEEKDATA consolidationAlexey Dobriyan
Identical implementations of PTRACE_PEEKDATA go into generic_ptrace_peekdata() function. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-29[PATCH] Use decimal for PTRACE_ATTACH and PTRACE_DETACH.Roland McGrath
It is sure confusing that linux/ptrace.h has: #define PTRACE_SINGLESTEP 9 #define PTRACE_ATTACH 0x10 #define PTRACE_DETACH 0x11 #define PTRACE_SYSCALL 24 All the low-numbered constants are in decimal, but the last two in hex. It sure makes it likely that someone will look at this and think that 9, 10, 11 are used, and that 16 and 17 are not used. How about we use the same notation for all the numbers [0,24] in the same short list? Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] coredump: kill ptrace related stuffOleg Nesterov
With this patch zap_process() sets SIGNAL_GROUP_EXIT while sending SIGKILL to the thread group. This means that a TASK_TRACED task 1. Will be awakened by signal_wake_up(1) 2. Can't sleep again via ptrace_notify() 3. Can't go to do_signal_stop() after return from ptrace_stop() in get_signal_to_deliver() So we can remove all ptrace related stuff from coredump path. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] ptrace: document the locking rulesEric W. Biederman
After a lot of reading the code and thinking about how it behaves I have managed to figure out what the current ptrace locking rules are. The current code is in much better that it appears at first glance. The troublesome code paths are actually the code paths that violate the current rules. ptrace uses simple exclusive access as it's locking. You can only touch task->ptrace if the task is stopped and you are the ptracer, or if the task is running and are the task itself. Very simple, very easy to maintain. It just needs to be documented so people know not to touch ptrace from elsewhere. Currently we do have a few pieces of code that are in violation of this rule. Particularly the core dump code, and ptrace_attach. But so far the code looks fixable. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15[PATCH] fix zap_thread's ptrace related problemsOleg Nesterov
1. The tracee can go from ptrace_stop() to do_signal_stop() after __ptrace_unlink(p). 2. It is unsafe to __ptrace_unlink(p) while p->parent may wait for tasklist_lock in ptrace_detach(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Christoph Hellwig <hch@lst.de> Cc: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] PTRACE_SYSEMU is only for i386 and clashes with other ptrace codes ↵Paolo 'Blaisorblade' Giarrusso
of other archs PTRACE_SYSEMU{,_SINGLESTEP} is actually arch specific, for now, and the current allocated number clashes with a ptrace code of frv, i.e. PTRACE_GETFDPIC. I should have submitted this much earlier, anyway we get no breakage for this. CC: Daniel Jacobowitz <dan@debian.org> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] use ptrace_get_task_struct in various placesChristoph Hellwig
The ptrace_get_task_struct() helper that I added as part of the ptrace consolidation is useful in variety of places that currently opencode it. Switch them to the common helpers. Add a ptrace_traceme() helper that needs to be explicitly called, and simplify the ptrace_get_task_struct() interface. We don't need the request argument now, and we return the task_struct directly, using ERR_PTR() for error returns. It's a bit more code in the callers, but we have two sane routines that do one thing well now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove duplicated code from proc and ptraceMiklos Szeredi
Extract common code used by ptrace_attach() and may_ptrace_attach() into a separate function. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] Uml support: add PTRACE_SYSEMU_SINGLESTEP option to i386Bodo Stroesser
This patch implements the new ptrace option PTRACE_SYSEMU_SINGLESTEP, which can be used by UML to singlestep a process: it will receive SINGLESTEP interceptions for normal instructions and syscalls, but syscall execution will be skipped just like with PTRACE_SYSEMU. Signed-off-by: Bodo Stroesser <bstroesser@fujitsu-siemens.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] UML Support - Ptrace: adds the host SYSEMU support, for UML and ↵Laurent Vivier
general usage Jeff Dike <jdike@addtoit.com>, Paolo 'Blaisorblade' Giarrusso <blaisorblade_spam@yahoo.it>, Bodo Stroesser <bstroesser@fujitsu-siemens.com> Adds a new ptrace(2) mode, called PTRACE_SYSEMU, resembling PTRACE_SYSCALL except that the kernel does not execute the requested syscall; this is useful to improve performance for virtual environments, like UML, which want to run the syscall on their own. In fact, using PTRACE_SYSCALL means stopping child execution twice, on entry and on exit, and each time you also have two context switches; with SYSEMU you avoid the 2nd stop and so save two context switches per syscall. Also, some architectures don't have support in the host for changing the syscall number via ptrace(), which is currently needed to skip syscall execution (UML turns any syscall into getpid() to avoid it being executed on the host). Fixing that is hard, while SYSEMU is easier to implement. * This version of the patch includes some suggestions of Jeff Dike to avoid adding any instructions to the syscall fast path, plus some other little changes, by myself, to make it work even when the syscall is executed with SYSENTER (but I'm unsure about them). It has been widely tested for quite a lot of time. * Various fixed were included to handle the various switches between various states, i.e. when for instance a syscall entry is traced with one of PT_SYSCALL / _SYSEMU / _SINGLESTEP and another one is used on exit. Basically, this is done by remembering which one of them was used even after the call to ptrace_notify(). * We're combining TIF_SYSCALL_EMU with TIF_SYSCALL_TRACE or TIF_SINGLESTEP to make do_syscall_trace() notice that the current syscall was started with SYSEMU on entry, so that no notification ought to be done in the exit path; this is a bit of a hack, so this problem is solved in another way in next patches. * Also, the effects of the patch: "Ptrace - i386: fix Syscall Audit interaction with singlestep" are cancelled; they are restored back in the last patch of this series. Detailed descriptions of the patches doing this kind of processing follow (but I've already summed everything up). * Fix behaviour when changing interception kind #1. In do_syscall_trace(), we check the status of the TIF_SYSCALL_EMU flag only after doing the debugger notification; but the debugger might have changed the status of this flag because he continued execution with PTRACE_SYSCALL, so this is wrong. This patch fixes it by saving the flag status before calling ptrace_notify(). * Fix behaviour when changing interception kind #2: avoid intercepting syscall on return when using SYSCALL again. A guest process switching from using PTRACE_SYSEMU to PTRACE_SYSCALL crashes. The problem is in arch/i386/kernel/entry.S. The current SYSEMU patch inhibits the syscall-handler to be called, but does not prevent do_syscall_trace() to be called after this for syscall completion interception. The appended patch fixes this. It reuses the flag TIF_SYSCALL_EMU to remember "we come from PTRACE_SYSEMU and now are in PTRACE_SYSCALL", since the flag is unused in the depicted situation. * Fix behaviour when changing interception kind #3: avoid intercepting syscall on return when using SINGLESTEP. When testing 2.6.9 and the skas3.v6 patch, with my latest patch and had problems with singlestepping on UML in SKAS with SYSEMU. It looped receiving SIGTRAPs without moving forward. EIP of the traced process was the same for all SIGTRAPs. What's missing is to handle switching from PTRACE_SYSCALL_EMU to PTRACE_SINGLESTEP in a way very similar to what is done for the change from PTRACE_SYSCALL_EMU to PTRACE_SYSCALL_TRACE. I.e., after calling ptrace(PTRACE_SYSEMU), on the return path, the debugger is notified and then wake ups the process; the syscall is executed (or skipped, when do_syscall_trace() returns 0, i.e. when using PTRACE_SYSEMU), and do_syscall_trace() is called again. Since we are on the return path of a SYSEMU'd syscall, if the wake up is performed through ptrace(PTRACE_SYSCALL), we must still avoid notifying the parent of the syscall exit. Now, this behaviour is extended even to resuming with PTRACE_SINGLESTEP. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
