commit df4bb5d128e2c44848aeb36b7ceceba3ac85080d upstream.
There is a race window where quota was redirted once we drop dq_list_lock inside dqput(),
but before we grab dquot->dq_lock inside dquot_release()
TASK1 TASK2 (chowner)
->dqput()
we_slept:
spin_lock(&dq_list_lock)
if (dquot_dirty(dquot)) {
spin_unlock(&dq_list_lock);
dquot->dq_sb->dq_op->write_dquot(dquot);
goto we_slept
if (test_bit(DQ_ACTIVE_B, &dquot->dq_flags)) {
dquot->dq_sb->dq_op->release_dquot(dquot);
dqget()
mark_dquot_dirty()
dqput()
goto we_slept;
So dquot dirty quota will be released by TASK1, but on next we_sleept loop
we detect this and call ->write_dquot() for it.
XFSTEST: https://github.com/dmonakhov/xfstests/commit/440a80d4cbb39e9234df4d7240aee1d551c36107
Link: https://lore.kernel.org/r/20191031103920.3919-2-dmonakhov@openvz.org
CC: stable@vger.kernel.org
Signed-off-by: Dmitry Monakhov <dmtrmonakhov@yandex-team.ru>
commit 6565c182094f69e4ffdece337d395eb7ec760efc upstream.
Quoted from
commit 3da40c7b0898 ("ext4: only call ext4_truncate when size <= isize")
" At LSF we decided that if we truncate up from isize we shouldn't trim
fallocated blocks that were fallocated with KEEP_SIZE and are past the
new i_size. This patch fixes ext4 to do this. "
And generic/092 of fstest have covered this case for long time, however
is_quota_modification() didn't adjust based on that rule, so that in
below condition, we will lose to quota block change:
- fallocate blocks beyond EOF
- remount
- truncate(file_path, file_size)
Fix it.
Link: https://lore.kernel.org/r/20190911093650.35329-1-yuchao0@huawei.com
Fixes: 3da40c7b0898 ("ext4: only call ext4_truncate when size <= isize")
Signed-off-by: Chao Yu <yuchao0@huawei.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
inode_add_rsv_space() and inode_sub_rsv_space() had only one callsite.
Inline them there directly. inode_claim_rsv_space() and
inode_reclaim_rsv_space() had two callsites so inline them there as
well. This will simplify further locking changes.
ext4_xattr_block_set() calls dquot_alloc_block() to charge for an xattr
block when new references are made. However if dquot_initialize() hasn't
been called on an inode, request for charging is effectively ignored
because ext4_inode_info->i_dquot is not initialized yet.
Add dquot_initialize() to call paths that lead to ext4_xattr_block_set().
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Nobody uses them anymore.
Add infrastructure for supporting get_nextdqblk() callback for VFS
quotas. Translate the operation into a callback to appropriate
filesystem and consequently to quota format callback.
Currently when some error happened in ->acquire_dquot(), dqget() just
returned NULL. That was indistinguishable from a case when e.g. someone
run quotaoff and so was generally silently ignored. However
->acquire_dquot() can fail because of ENOSPC or EIO in which case user
should better know. So propagate error up from ->acquire_dquot properly.
Flags in struct quota_state keep flags for each quota type and
some common flags. This patch reorders typed flags:
Before:
0 USRQUOTA DQUOT_USAGE_ENABLED
1 USRQUOTA DQUOT_LIMITS_ENABLED
2 USRQUOTA DQUOT_SUSPENDED
3 GRPQUOTA DQUOT_USAGE_ENABLED
4 GRPQUOTA DQUOT_LIMITS_ENABLED
5 GRPQUOTA DQUOT_SUSPENDED
6 DQUOT_QUOTA_SYS_FILE
7 DQUOT_NEGATIVE_USAGE
After:
1 GRPQUOTA DQUOT_USAGE_ENABLED
2 USRQUOTA DQUOT_LIMITS_ENABLED
3 GRPQUOTA DQUOT_LIMITS_ENABLED
4 USRQUOTA DQUOT_SUSPENDED
Now we can get bitmap of all enabled/suspended quota types without loop.
For example suspended: (flags / DQUOT_SUSPENDED) & ((1 << MAXQUOTAS) - 1).
add/remove: 0/1 grow/shrink: 3/11 up/down: 56/-215 (-159)
function old new delta
__dquot_initialize 423 447 +24
dquot_transfer 181 197 +16
dquot_alloc_inode 286 302 +16
dquot_reclaim_space_nodirty 316 313 -3
dquot_claim_space_nodirty 314 311 -3
dquot_resume 286 281 -5
dquot_free_inode 332 324 -8
__dquot_alloc_space 500 492 -8
dquot_disable 1944 1929 -15
dquot_quota_enable 252 236 -16
__dquot_free_space 750 734 -16
dquot_writeback_dquots 625 608 -17
__dquot_transfer 1186 1154 -32
dquot_quota_sync 299 261 -38
dquot_active.isra 54 - -54
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Change ->set_info to take new qc_info structure which contains all the
necessary information both for XFS and VFS. Convert Q_SETINFO handler
to use this structure.
Create new internal interface for getting information about quota which
contains everything needed for both VFS quotas and XFS quotas. Make VFS
use this and hook it up to Q_GETINFO.
Add functions which translate ->quota_enable / ->quota_disable calls
into appropriate changes in VFS quota. This will enable filesystems
supporting VFS quota files in system inodes to be controlled via
Q_XQUOTA[ON|OFF] quotactls for better userspace compatibility.
Also provide a vector for quotactl using these functions which can be
used by filesystems with quota files stored in hidden system files.
Make Q_QUOTAON / Q_QUOTAOFF quotactl call ->quota_enable /
->quota_disable callback when provided. To match current behavior of
ocfs2 & ext4 we make these quotactls turn on / off quota enforcement for
appropriate quota type.
Currently ->get_dqblk() and ->set_dqblk() use struct fs_disk_quota which
tracks space limits and usage in 512-byte blocks. However VFS quotas
track usage in bytes (as some filesystems require that) and we need to
somehow pass this information. Upto now it wasn't a problem because we
didn't do any unit conversion (thus VFS quota routines happily stuck
number of bytes into d_bcount field of struct fd_disk_quota). Only if
you tried to use Q_XGETQUOTA or Q_XSETQLIM for VFS quotas (or Q_GETQUOTA
/ Q_SETQUOTA for XFS quotas), you got bogus results. Hardly anyone
tried this but reportedly some Samba users hit the problem in practice.
So when we want interfaces compatible we need to fix this.
We bite the bullet and define another quota structure used for passing
information from/to ->get_dqblk()/->set_dqblk. It's somewhat sad we have
to have more conversion routines in fs/quota/quota.c and another copying
of quota structure slows down getting of quota information by about 2%
but it seems cleaner than overloading e.g. units of d_bcount to bytes.
We don't use const through VFS too much so just remove it from quota
function declarations.
Provide dqgrab() function to get quota structure reference when we are
sure it already has at least one active reference. Make use of this
function inside quota code.
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
ext4 needs to convert allocated (metadata) blocks back into blocks
reserved for delayed allocation. Add functions into quota code for
supporting such operation.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Modify dqget to take struct kqid instead of a type and an identifier
pair.
Modify the callers of dqget in ocfs2 and dquot to take generate
a struct kqid so they can continue to call dqget. The conversion
to create struct kqid should all be the final conversions that
are needed in those code paths.
Cc: Jan Kara <jack@suse.cz>
Cc: Mark Fasheh <mfasheh@suse.com>
Update the quotactl user space interface to successfull compile with
user namespaces support enabled and to hand off quota identifiers to
lower layers of the kernel in struct kqid instead of type and qid
pairs.
The quota on function is not converted because while it takes a quota
type and an id. The id is the on disk quota format to use, which
is something completely different.
The signature of two struct quotactl_ops methods were changed to take
struct kqid argumetns get_dqblk and set_dqblk.
The dquot, xfs, and ocfs2 implementations of get_dqblk and set_dqblk
are minimally changed so that the code continues to work with
the change in parameter type.
This is the first in a series of changes to always store quota
identifiers in the kernel in struct kqid and only use raw type and qid
values when interacting with on disk structures or userspace. Always
using struct kqid internally makes it hard to miss places that need
conversion to or from the kernel internal values.
Cc: Ben Myers <bpm@sgi.com>
Cc: Alex Elder <elder@kernel.org>
Split off part of dquot_quota_sync() which writes dquots into a quota file
to a separate function. In the next patch we will use the function from
filesystems and we do not want to abuse ->quota_sync quotactl callback more
than necessary.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Standardize the style for compiler based printf format verification.
Standardized the location of __printf too.
Done via script and a little typing.
$ grep -rPl --include=*.[ch] -w "__attribute__" * | \
grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \
xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }'
[akpm@linux-foundation.org: revert arch bits]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
away the inode_lock from the code.
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
As Al Viro pointed out path resolution during Q_QUOTAON calls to quotactl
is prone to deadlocks. We hold s_umount semaphore for reading during the
path resolution and resolution itself may need to acquire the semaphore
for writing when e. g. autofs mountpoint is passed.
Solve the problem by performing the resolution before we get hold of the
superblock (and thus s_umount semaphore). The whole thing is complicated
by the fact that some filesystems (OCFS2) ignore the path argument. So to
distinguish between filesystem which want the path and which do not we
introduce new .quota_on_meta callback which does not get the path. OCFS2
then uses this callback instead of old .quota_on.
CC: Al Viro <viro@ZenIV.linux.org.uk>
CC: Christoph Hellwig <hch@lst.de>
CC: Ted Ts'o <tytso@mit.edu>
CC: Joel Becker <joel.becker@oracle.com>
fallout
Use %pV in __quota_error so a single printk can not be
interleaved with other logging messages.
Add __attribute__((format (printf, 3, 4))) so format
and arguments can be verified by compiler.
Make sure printk formats and arguments match.
Block # needed a pointer dereference.
Alex Shi found a regression when doing ffsb test. The test has several threads,
and each thread creates a small file, write to it and then delete it. ffsb
reports about 20% regression and Alex bisected it to 43d2932d88e4. The test
will call __mark_inode_dirty 3 times. without this commit, we only take
inode_lock one time, while with it, we take the lock 3 times with flags (
I_DIRTY_SYNC,I_DIRTY_PAGES,I_DIRTY). Perf shows the lock contention increased
too much. Below proposed patch fixes it.
fs is allocating blocks, which usually means file writes and the inode
will be dirtied soon. We fully dirty the inode to reduce some inode_lock
contention in several calls of __mark_inode_dirty.
Jan Kara: Added comment.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Signed-off-by: Alex Shi <alex.shi@intel.com>
Quota code never touches file data. It just modifies i_blocks + i_bytes
of inodes and inode flags of quota files. So use mark_inode_dirty_sync
instead of mark_inode_dirty.
The current quota error message doesn't always print the disk name, so
it is hard to identify the "bad" disk when quota error happens.
This patch changes the standardized quota error message to print out disk name
and function name. It also uses a combination of cpp macro and inline function
to provide better type checking and to lower the text size of the message.
[Jan Kara: Export __quota_error]
Signed-off-by: Jiaying Zhang <jiayingz@google.com>
The various quota operations check for any quota beeing active on
a superblock, and the inode not having the noquota flag.
Merge these two checks into a dquot_active check and move that
into dquot.c as that's the only place where it's needed.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
quota: Convert quota statistics to generic percpu_counter
ext3 uses rb_node = NULL; to zero rb_root.
quota: Fixup dquot_transfer
reiserfs: Fix resuming of quotas on remount read-write
pohmelfs: Remove dead quota code
ufs: Remove dead quota code
udf: Remove dead quota code
quota: rename default quotactl methods to dquot_
quota: explicitly set ->dq_op and ->s_qcop
quota: drop remount argument to ->quota_on and ->quota_off
quota: move unmount handling into the filesystem
quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers
quota: move remount handling into the filesystem
ocfs2: Fix use after free on remount read-only
Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits)
ext4: Make fsync sync new parent directories in no-journal mode
ext4: Drop whitespace at end of lines
ext4: Fix compat EXT4_IOC_ADD_GROUP
ext4: Conditionally define compat ioctl numbers
tracing: Convert more ext4 events to DEFINE_EVENT
ext4: Add new tracepoints to track mballoc's buddy bitmap loads
ext4: Add a missing trace hook
ext4: restart ext4_ext_remove_space() after transaction restart
ext4: Clear the EXT4_EOFBLOCKS_FL flag only when warranted
ext4: Avoid crashing on NULL ptr dereference on a filesystem error
ext4: Use bitops to read/modify i_flags in struct ext4_inode_info
ext4: Convert calls of ext4_error() to EXT4_ERROR_INODE()
ext4: Convert callers of ext4_get_blocks() to use ext4_map_blocks()
ext4: Add new abstraction ext4_map_blocks() underneath ext4_get_blocks()
ext4: Use our own write_cache_pages()
ext4: Show journal_checksum option
ext4: Fix for ext4_mb_collect_stats()
ext4: check for a good block group before loading buddy pages
ext4: Prevent creation of files larger than RLIMIT_FSIZE using fallocate
ext4: Remove extraneous newlines in ext4_msg() calls
Fixed up trivial conflict in fs/ext4/fsync.c
Follow the dquot_* style used elsewhere in dquot.c.
[Jan Kara: Fixed up missing conversion of ext2]
Only set the quota operation vectors if the filesystem actually supports
quota instead of doing it for all filesystems in alloc_super().
[Jan Kara: Export dquot_operations and vfs_quotactl_ops]
Remount handling has fully moved into the filesystem, so all this is
superflous now.
Currently the VFS calls into the quotactl interface for unmounting
filesystems. This means filesystems with their own quota handling
can't easily distinguish between user-space originating quotaoff
and an unount. Instead move the responsibily of the unmount handling
into the filesystem to be consistent with all other dquot handling.
Note that we do call dquot_disable a lot later now, e.g. after
a sync_filesystem. But this is fine as the quota code does all its
writes via blockdev's mapping and that is synced even later.
Instead of having wrappers in the VFS namespace export the dquot_suspend
and dquot_resume helpers directly. Also rename vfs_quota_disable to
dquot_disable while we're at it.
[Jan Kara: Moved dquot_suspend to quotaops.h and made it inline]
Currently, __dquot_transfer() acquires its own references of dquot structures
that will be put into inode. But for OCFS2, this creates a lock inversion
between dq_lock (waited on in dqget) and transaction start (started in
ocfs2_setattr). Currently, deadlock is impossible because dq_lock is acquired
only during dquot_acquire and dquot_release and we already hold a reference to
dquot structures in ocfs2_setattr so neither of these functions can be called
while we call dquot_transfer. But this is rather subtle and it is hard to teach
lockdep about it. So provide __dquot_transfer function that can be passed dquot
references directly. OCFS2 can then pass acquired dquot references directly to
__dquot_transfer with proper locking.
Quota must being initialized if size or uid/git changes requested.
But initialization performed in two different places:
in case of i_size file system is responsible for dquot init
, but in case of uid/gid init will be called internally in
dquot_transfer().
This ambiguity makes code harder to understand.
Let's move this logic to one common helper function.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Pass the larger struct fs_disk_quota to the ->set_dqblk operation so
that the Q_SETQUOTA and Q_XSETQUOTA operations can be implemented
with a single filesystem operation and we can retire the ->set_xquota
operation. The additional information (RT-subvolume accounting and
warn counts) are left zero for the VFS quota implementation.
Add new fieldmask values for setting the numer of blocks and inodes
values which is required for the VFS quota, but wasn't for XFS.
Pass the larger struct fs_disk_quota to the ->get_dqblk operation so
that the Q_GETQUOTA and Q_XGETQUOTA operations can be implemented
with a single filesystem operation and we can retire the ->get_xquota
To simplify metadata tracking for delalloc writes, ext4
will simply claim metadata blocks at allocation time, without
first speculatively reserving the worst case and then freeing
what was not used.
To do this, we need a mechanism to track allocations in
the quota subsystem, but potentially allow that allocation
to actually go over quota.
This patch adds a DQUOT_SPACE_NOFAIL flag and function
variants for this purpose.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Switch __dquot_alloc_space and __dquot_free_space to take flags
to indicate whether to warn and/or to reserve (or free reserve).
This is slightly more readable at the callpoints, and makes it
cleaner to add a "nofail" option in the next patch.
Get rid of the initialize dquot operation - it is now always called from
the filesystem and if a filesystem really needs it's own (which none
currently does) it can just call into it's own routine directly.
Rename the now static low-level dquot_initialize helper to __dquot_initialize
and vfs_dq_init to dquot_initialize to have a consistent namespace.
Currently various places in the VFS call vfs_dq_init directly. This means
we tie the quota code into the VFS. Get rid of that and make the
filesystem responsible for the initialization. For most metadata operations
this is a straight forward move into the methods, but for truncate and
open it's a bit more complicated.
For truncate we currently only call vfs_dq_init for the sys_truncate case
because open already takes care of it for ftruncate and open(O_TRUNC) - the
new code causes an additional vfs_dq_init for those which is harmless.
For open the initialization is moved from do_filp_open into the open method,
which means it happens slightly earlier now, and only for regular files.
The latter is fine because we don't need to initialize it for operations
on special files, and we already do it as part of the namespace operations
for directories.
Add a dquot_file_open helper that filesystems that support generic quotas
can use to fill in ->open.
Get rid of the drop dquot operation - it is now always called from
Rename the now static low-level dquot_drop helper to __dquot_drop
and vfs_dq_drop to dquot_drop to have a consistent namespace.
Get rid of the transfer dquot operation - it is now always called from
Rename the now static low-level dquot_transfer helper to __dquot_transfer
and vfs_dq_transfer to dquot_transfer to have a consistent namespace,
and make the new dquot_transfer return a normal negative errno value
which all callers expect.
Get rid of the alloc_inode and free_inode dquot operations - they are
always called from the filesystem and if a filesystem really needs
their own (which none currently does) it can just call into it's
Also get rid of the vfs_dq_alloc/vfs_dq_free wrappers and always
call the lowlevel dquot_alloc_inode / dqout_free_inode routines
directly, which now lose the number argument which is always 1.
Get rid of the alloc_space, free_space, reserve_space, claim_space and
release_rsv dquot operations - they are always called from the filesystem
and if a filesystem really needs their own (which none currently does)
Move shared logic into the common __dquot_alloc_space,
dquot_claim_space_nodirty and __dquot_free_space low-level methods,
and rationalize the wrappers around it to move as much as possible
code into the common block for CONFIG_QUOTA vs not. Also rename
all these helpers to be named dquot_* instead of vfs_dq_*.
