path: root/include/linux/raid/bitmap.h
2009-03-31md: move headers out of include/linux/raid/Christoph Hellwig
Move the headers with the local structures for the disciplines and bitmap.h into drivers/md/ so that they are more easily grepable for hacking and not far away. md.h is left where it is for now as there are some uses from the outside. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: NeilBrown <neilb@suse.de>
2008-06-28Improve setting of "events_cleared" for write-intent bitmaps.Neil Brown
When an array is degraded, bits in the write-intent bitmap are not cleared, so that if the missing device is re-added, it can be synced by only updated those parts of the device that have changed since it was removed. The enable this a 'events_cleared' value is stored. It is the event counter for the array the last time that any bits were cleared. Sometimes - if a device disappears from an array while it is 'clean' - the events_cleared value gets updated incorrectly (there are subtle ordering issues between updateing events in the main metadata and the bitmap metadata) resulting in the missing device appearing to require a full resync when it is re-added. With this patch, we update events_cleared precisely when we are about to clear a bit in the bitmap. We record events_cleared when we clear the bit internally, and copy that to the superblock which is written out before the bit on storage. This makes it more "obviously correct". We also need to update events_cleared when the event_count is going backwards (as happens on a dirty->clean transition of a non-degraded array). Thanks to Mike Snitzer for identifying this problem and testing early "fixes". Cc: "Mike Snitzer" <snitzer@gmail.com> Signed-off-by: Neil Brown <neilb@suse.de>
2008-05-24md: kill file_path wrapperChristoph Hellwig
Kill the trivial and rather pointless file_path wrapper around d_path. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04md: reduce CPU wastage on idle md array with a write-intent bitmapNeilBrown
On an md array with a write-intent bitmap, a thread wakes up every few seconds and scans the bitmap looking for work to do. If the array is idle, there will be no work to do, but a lot of scanning is done to discover this. So cache the fact that the bitmap is completely clean, and avoid scanning the whole bitmap when the cache is known to be clean. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06md: Update md bitmap during resync.NeilBrown
Currently an md array with a write-intent bitmap does not updated that bitmap to reflect successful partial resync. Rather the entire bitmap is updated when the resync completes. This is because there is no guarentee that resync requests will complete in order, and tracking each request individually is unnecessarily burdensome. However there is value in regularly updating the bitmap, so add code to periodically pause while all pending sync requests complete, then update the bitmap. Doing this only every few seconds (the same as the bitmap update time) does not notciably affect resync performance. [snitzer@gmail.com: export bitmap_cond_end_sync] Signed-off-by: Neil Brown <neilb@suse.de> Cc: "Mike Snitzer" <snitzer@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17bitmap.h: remove dead artifactsAdrian Bunk
bitmap_active() no longer exists and BITMAP_ACTIVE is no longer used. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17md: change bitmap_unplug and others to void functionsNeilBrown
bitmap_unplug only ever returns 0, so it may as well be void. Two callers try to print a message if it returns non-zero, but that message is already printed by bitmap_file_kick. write_page returns an error which is not consistently checked. It always causes BITMAP_WRITE_ERROR to be set on an error, and that can more conveniently be checked. When the return of write_page is checked, an error causes bitmap_file_kick to be called - so move that call into write_page - and protect against recursive calls into bitmap_file_kick. bitmap_update_sb returns an error that is never checked. So make these 'void' and be consistent about checking the bit. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23md: don't write more than is required of the last page of a bitmapNeilBrown
It is possible that real data or metadata follows the bitmap without full page alignment. So limit the last write to be only the required number of bytes, rounded up to the hard sector size of the device. Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-09[PATCH] md: avoid possible BUG_ON in md bitmap handlingNeil Brown
md/bitmap tracks how many active write requests are pending on blocks associated with each bit in the bitmap, so that it knows when it can clear the bit (when count hits zero). The counter has 14 bits of space, so if there are ever more than 16383, we cannot cope. Currently the code just calles BUG_ON as "all" drivers have request queue limits much smaller than this. However is seems that some don't. Apparently some multipath configurations can allow more than 16383 concurrent write requests. So, in this unlikely situation, instead of calling BUG_ON we now wait for the count to drop down a bit. This requires a new wait_queue_head, some waiting code, and a wakeup call. Tested by limiting the counter to 20 instead of 16383 (writes go a lot slower in that case...). Signed-off-by: Neil Brown <neilb@suse.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-21[PATCH] md: endian annotations for the bitmap superblockNeilBrown
And a couple of bug fixes found by sparse. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] md: new sysfs interface for setting bits in the write-intent-bitmapPaul Clements
Add a new sysfs interface that allows the bitmap of an array to be dirtied. The interface is write-only, and is used as follows: echo "1000" > /sys/block/md2/md/bitmap (dirty the bit for chunk 1000 [offset 0] in the in-memory and on-disk bitmaps of array md2) echo "1000-2000" > /sys/block/md1/md/bitmap (dirty the bits for chunks 1000-2000 in md1's bitmap) This is useful, for example, in cluster environments where you may need to combine two disjoint bitmaps into one (following a server failure, after a secondary server has taken over the array). By combining the bitmaps on the two servers, a full resync can be avoided (This was discussed on the list back on March 18, 2005, "[PATCH 1/2] md bitmap bug fixes" thread). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md/bitmap: change md/bitmap file handling to use bmap to file blocksNeilBrown
If md is asked to store a bitmap in a file, it tries to hold onto the page cache pages for that file, manipulate them directly, and call a cocktail of operations to write the file out. I don't believe this is a supportable approach. This patch changes the approach to use the same approach as swap files. i.e. bmap is used to enumerate all the block address of parts of the file and we write directly to those blocks of the device. swapfile only uses parts of the file that provide a full pages at contiguous addresses. We don't have that luxury so we have to cope with pages that are non-contiguous in storage. To handle this we attach buffers to each page, and store the addresses in those buffers. With this approach the pagecache may contain data which is inconsistent with what is on disk. To alleviate the problems this can cause, md invalidates the pagecache when releasing the file. If the file is to be examined while the array is active (a non-critical but occasionally useful function), O_DIRECT io must be used. And new version of mdadm will have support for this. This approach simplifies a lot of code: - we no longer need to keep a list of pages which we need to wait for, as the b_endio function can keep track of how many outstanding writes there are. This saves a mempool. - -EAGAIN returns from write_page are no longer possible (not sure if they ever were actually). Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] md/bitmap: remove bitmap writeback daemonNeilBrown
md/bitmap currently has a separate thread to wait for writes to the bitmap file to complete (as we cannot get a callback on that action). However this isn't needed as bitmap_unplug is called from process context and waits for the writeback thread to do it's work. The same result can be achieved by doing the waiting directly in bitmap_unplug. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] md: make md on-disk bitmaps not host-endianNeilBrown
Current bitmaps use set_bit et.al and so are host-endian, which means not-portable. Oops. Define a new version number (4) for which bitmaps are little-endian. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] md: add write-behind support for md/raid1NeilBrown
If a device is flagged 'WriteMostly' and the array has a bitmap, and the bitmap superblock indicates that write_behind is allowed, then write_behind is enabled for WriteMostly devices. Write requests will be acknowledges as complete to the caller (via b_end_io) when all non-WriteMostly devices have completed the write, but will not be cleared from the bitmap until all devices complete. This requires memory allocation to make a local copy of the data being written. If there is insufficient memory, then we fall-back on normal write semantics. Signed-Off-By: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-04[PATCH] md: make sure md bitmap updates are flushed when array is stopped.NeilBrown
The recent change to never ignore the bitmap, revealed that the bitmap isn't begin flushed properly when an array is stopped. We call bitmap_daemon_work three times as there is a three-stage pipeline for flushing updates to the bitmap file. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-15[PATCH] md/raid1: clear bitmap when fullsync completesNeilBrown
We need to be careful differentiating between a resync of a complete array, in which we can clear the bitmap, and a resync of a degraded array, in which we cannot. This patch cleans all that up. Cc: Paul Clements <paul.clements@steeleye.com> Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: allow md intent bitmap to be stored near the superblock.NeilBrown
This provides an alternate to storing the bitmap in a separate file. The bitmap can be stored at a given offset from the superblock. Obviously the creator of the array must make sure this doesn't intersect with data.... After is good for version-0.90 superblocks. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: enable the bitmap write-back daemon and wait for it.NeilBrown
Currently we don't wait for updates to the bitmap to be flushed to disk properly. The infrastructure all there, but it isn't being used.... A separate kernel thread (bitmap_writeback_daemon) is needed to wait for each page as we cannot get callbacks when a page write completes. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] md: optimised resync using Bitmap based intent loggingNeilBrown
With this patch, the intent to write to some block in the array can be logged to a bitmap file. Each bit represents some number of sectors and is set before any update happens, and only cleared when all writes relating to all sectors are complete. After an unclean shutdown, information in this bitmap can be used to optimise resync - only sectors which could be out-of-sync need to be updated. Also if a drive is removed and then added back into an array, the recovery can make use of the bitmap to optimise reconstruction. This is not implemented in this patch. Currently the bitmap is stored in a file which must (obviously) be stored on a separate device. The patch only provided infrastructure. It does not update any personalities to bitmap intent logging. Md arrays can still be used with no bitmap file. This patch has minimal impact on such arrays. Signed-off-by: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
