path: root/include/linux/ratelimit.h
2012-10-05tty: Fix bogus "callbacks suppressed" messagesMarkus Trippelsdorf
On the current git tree one sees messages such as: tty_init_dev: 24 callbacks suppressed tty_init_dev: 3 callbacks suppressed To fix this we need to look at condition before calling __ratelimit in the WARN_RATELIMIT macro. While at it remove the superfluous __WARN_RATELIMIT macros. Original patch is from Joe Perches and Jiri Slaby. Signed-off-by: Markus Trippelsdorf <markus@trippelsdorf.de> Acked-and-tested-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-09-13locking, printk: Annotate logbuf_lock as rawThomas Gleixner
The logbuf_lock lock can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [ merged and fixed it ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-26bug.h: Move ratelimit warn interfaces to ratelimit.hDavid S. Miller
As reported by Ingo Molnar, we still have configuration combinations where use of the WARN_RATELIMIT interfaces break the build because dependencies don't get met. Instead of going down the long road of trying to make it so that ratelimit.h can get included by kernel.h or asm-generic/bug.h, just move the interface into ratelimit.h and make users have to include that. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Randy Dunlap <randy.dunlap@oracle.com>
2010-10-26printk: declare printk_ratelimit_state in ratelimit.hNamhyung Kim
Adding declaration of printk_ratelimit_state in ratelimit.h removes potential build breakage and following sparse warning: kernel/printk.c:1426:1: warning: symbol 'printk_ratelimit_state' was not declared. Should it be static? [akpm@linux-foundation.org: remove unneeded ifdef] Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25ratelimit: add ratelimit_state_init()OGAWA Hirofumi
For now, all users of ratelimit_state allocates it statically, so DEFINE_RATELIMIT_STATE() is enough. But, I want to use ratelimit_state for fs, i.e. per super_block to suppress too many error reports. So, this adds ratelimit_state_init() to initialize ratelimite_state which is dynamically allocated, instead of opencoding. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-23ratelimit: Make suppressed output messages more usefulChristian Borntraeger
Today I got: [39648.224782] Registered led device: iwl-phy0::TX [40676.545099] __ratelimit: 246 callbacks suppressed [40676.545103] abcdef[23675]: segfault at 0 ... as you can see the ratelimit message contains a function prefix. Since this is always __ratelimit, this wont help much. This patch changes __ratelimit and printk_ratelimit to print the function name that calls ratelimit. This will pinpoint the responsible function, as long as not several different places call ratelimit with the same ratelimit state at the same time. In that case we catch only one random function that calls ratelimit after the wait period. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> CC: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <200910231458.11832.borntraeger@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22ratelimit: Use per ratelimit context lockingIngo Molnar
I'd like to use printk_ratelimit() in atomic context, but that's not possible right now due to the spinlock usage this commit introduced more than a year ago: 717115e: printk ratelimiting rewrite As a first step push the lock into the ratelimit state structure. This allows us to deal with locking failures to be considered as an event related to that state being too busy. Also clean up the code a bit (without changing functionality): - tidy up the definitions - clean up the code flow This also shrinks the code a tiny bit: text data bss dec hex filename 264 0 4 268 10c ratelimit.o.before 255 0 0 255 ff ratelimit.o.after ( Whole-kernel data size got a bit larger, because we have two ratelimit-state data structures right now. ) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: David S. Miller <davem@davemloft.net> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12remove ratelimt()Andrew Morton
It mistakenly assumes that a static local in an inlined function is a kernel-wide singleton. It also has no callers, so let's remove it. Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25printk ratelimiting rewriteDave Young
All ratelimit user use same jiffies and burst params, so some messages (callbacks) will be lost. For example: a call printk_ratelimit(5 * HZ, 1) b call printk_ratelimit(5 * HZ, 1) before the 5*HZ timeout of a, then b will will be supressed. - rewrite __ratelimit, and use a ratelimit_state as parameter. Thanks for hints from andrew. - Add WARN_ON_RATELIMIT, update rcupreempt.h - remove __printk_ratelimit - use __ratelimit in net_ratelimit Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
