path: root/include/linux/rculist_nulls.h
2010-08-19rculist: avoid __rcu annotationsArnd Bergmann
This avoids warnings from missing __rcu annotations in the rculist implementation, making it possible to use the same lists in both RCU and non-RCU cases. We can add rculist annotations later, together with lockdep support for rculist, which is missing as well, but that may involve changing all the users. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-02-25rcu: Disable lockdep checking in RCU list-traversal primitivesPaul E. McKenney
The theory is that use of bare rcu_dereference() is more prone to error than use of the RCU list-traversal primitives. Therefore, disable lockdep RCU read-side critical-section checking in these primitives for the time being. Once all of the rcu_dereference() uses have been dealt with, it may be time to re-enable lockdep checking for the RCU list-traversal primitives. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-4-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Fix whitespace inconsistenciesPaul E. McKenney
Fix a number of whitespace ^Ierrors in the include/linux/rcu* and the kernel/rcu* files. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com> [ did more checkpatch fixlets ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16rcu: Introduce hlist_nulls variant of hlistEric Dumazet
hlist uses NULL value to finish a chain. hlist_nulls variant use the low order bit set to 1 to signal an end-of-list marker. This allows to store many different end markers, so that some RCU lockless algos (used in TCP/UDP stack for example) can save some memory barriers in fast paths. Two new files are added : include/linux/list_nulls.h - mimics hlist part of include/linux/list.h, derived to hlist_nulls variant include/linux/rculist_nulls.h - mimics hlist part of include/linux/rculist.h, derived to hlist_nulls variant Only four helpers are declared for the moment : hlist_nulls_del_init_rcu(), hlist_nulls_del_rcu(), hlist_nulls_add_head_rcu() and hlist_nulls_for_each_entry_rcu() prefetches() were removed, since an end of list is not anymore NULL value. prefetches() could trigger useless (and possibly dangerous) memory transactions. Example of use (extracted from __udp4_lib_lookup()) struct sock *sk, *result; struct hlist_nulls_node *node; unsigned short hnum = ntohs(dport); unsigned int hash = udp_hashfn(net, hnum); struct udp_hslot *hslot = &udptable->hash[hash]; int score, badness; rcu_read_lock(); begin: result = NULL; badness = -1; sk_nulls_for_each_rcu(sk, node, &hslot->head) { score = compute_score(sk, net, saddr, hnum, sport, daddr, dport, dif); if (score > badness) { result = sk; badness = score; } } /* * if the nulls value we got at the end of this lookup is * not the expected one, we must restart lookup. * We probably met an item that was moved to another chain. */ if (get_nulls_value(node) != hash) goto begin; if (result) { if (unlikely(!atomic_inc_not_zero(&result->sk_refcnt))) result = NULL; else if (unlikely(compute_score(result, net, saddr, hnum, sport, daddr, dport, dif) < badness)) { sock_put(result); goto begin; } } rcu_read_unlock(); return result; Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: David S. Miller <davem@davemloft.net>
