path: root/include/linux/rcupdate.h
2011-05-05rcu: introduce kfree_rcu()Lai Jiangshan
Many rcu callbacks functions just call kfree() on the base structure. These functions are trivial, but their size adds up, and furthermore when they are used in a kernel module, that module must invoke the high-latency rcu_barrier() function at module-unload time. The kfree_rcu() function introduced by this commit addresses this issue. Rather than encoding a function address in the embedded rcu_head structure, kfree_rcu() instead encodes the offset of the rcu_head structure within the base structure. Because the functions are not allowed in the low-order 4096 bytes of kernel virtual memory, offsets up to 4095 bytes can be accommodated. If the offset is larger than 4095 bytes, a compile-time error will be generated in __kfree_rcu(). If this error is triggered, you can either fall back to use of call_rcu() or rearrange the structure to position the rcu_head structure into the first 4096 bytes. Note that the allowable offset might decrease in the future, for example, to allow something like kmem_cache_free_rcu(). The new kfree_rcu() function can replace code as follows: call_rcu(&p->rcu, simple_kfree_callback); where "simple_kfree_callback()" might be defined as follows: void simple_kfree_callback(struct rcu_head *p) { struct foo *q = container_of(p, struct foo, rcu); kfree(q); } with the following: kfree_rcu(&p->rcu, rcu); Note that the "rcu" is the name of a field in the structure being freed. The reason for using this rather than passing in a pointer to the base structure is that the above approach allows better type checking. This commit is based on earlier work by Lai Jiangshan and Manfred Spraul: Lai's V1 patch: http://lkml.org/lkml/2008/9/18/1 Manfred's patch: http://lkml.org/lkml/2009/1/2/115 Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: add DEBUG_OBJECTS_RCU_HEAD check for alignmentPaul E. McKenney
Verify that rcu_head structures are aligned to a four-byte boundary. This check is enabled by CONFIG_DEBUG_OBJECTS_RCU_HEAD. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: make rcutorture version numbers available through debugfsPaul E. McKenney
It is not possible to accurately correlate rcutorture output with that of debugfs. This patch therefore adds a debugfs file that prints out the rcutorture version number, permitting easy correlation. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-01rcu: create new rcu_access_index() and use in mcePaul E. McKenney
The MCE subsystem needs to sample an RCU-protected index outside of any protection for that index. If this was a pointer, we would use rcu_access_pointer(), but there is no corresponding rcu_access_index(). This commit therefore creates an rcu_access_index() and applies it to MCE. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Zdenek Kabelac <zkabelac@redhat.com>
2010-12-17rcu: increase synchronize_sched_expedited() batchingTejun Heo
The fix in commit #6a0cc49 requires more than three concurrent instances of synchronize_sched_expedited() before batching is possible. This patch uses a ticket-counter-like approach that is also not unrelated to Lai Jiangshan's Ring RCU to allow sharing of expedited grace periods even when there are only two concurrent instances of synchronize_sched_expedited(). This commit builds on Tejun's original posting, which may be found at http://lkml.org/lkml/2010/11/9/204, adding memory barriers, avoiding overflow of signed integers (other than via atomic_t), and fixing the detection of batching. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu,cleanup: move synchronize_sched_expedited() out of sched.cLai Jiangshan
The first version of synchronize_sched_expedited() used the migration code in the scheduler, and was therefore implemented in kernel/sched.c. However, the more recent version of this code no longer uses the migration code, so this commit moves it to the main RCU source files. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-17rcu: move TINY_RCU from softirq to kthreadPaul E. McKenney
If RCU priority boosting is to be meaningful, callback invocation must be boosted in addition to preempted RCU readers. Otherwise, in presence of CPU real-time threads, the grace period ends, but the callbacks don't get invoked. If the callbacks don't get invoked, the associated memory doesn't get freed, so the system is still subject to OOM. But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit moves the callback invocations to a kthread, which can be boosted easily. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-09-23rcu: only one evaluation of arg in rcu_dereference_check() unless sparsePaul E. McKenney
The current version of the __rcu_access_pointer(), __rcu_dereference_check(), and __rcu_dereference_protected() macros evaluate their "p" argument three times, not counting typeof()s. This is bad news if that argument contains a side effect. This commit therefore evaluates this argument only once in normal kernel builds. However, the straightforward approach defeats sparse's RCU-pointer checking, so when __CHECKER__ is defined, the additional pair of evaluations of the "p" argument are performed in order to permit sparse to detect misuse of RCU-protected pointers. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de>
2010-08-20rcu: combine duplicate code, courtesy of CONFIG_PREEMPT_RCUPaul E. McKenney
The CONFIG_PREEMPT_RCU kernel configuration parameter was recently re-introduced, but as an indication of the type of RCU (preemptible vs. non-preemptible) instead of as selecting a given implementation. This commit uses CONFIG_PREEMPT_RCU to combine duplicate code from include/linux/rcutiny.h and include/linux/rcutree.h into include/linux/rcupdate.h. This commit also combines a few other pieces of duplicate code that have accumulated. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-20rcu: repair code-duplication FIXMEsPaul E. McKenney
Combine the duplicate definitions of ULONG_CMP_GE(), ULONG_CMP_LT(), and rcu_preempt_depth() into include/linux/rcupdate.h. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-20rcu: update obsolete rcu_read_lock() comment.Paul E. McKenney
The comment says that blocking is illegal in rcu_read_lock()-style RCU read-side critical sections, which is no longer entirely true given preemptible RCU. This commit provides a fix. Suggested-by: David Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-20rcu: Add a TINY_PREEMPT_RCUPaul E. McKenney
Implement a small-memory-footprint uniprocessor-only implementation of preemptible RCU. This implementation uses but a single blocked-tasks list rather than the combinatorial number used per leaf rcu_node by TREE_PREEMPT_RCU, which reduces memory consumption and greatly simplifies processing. This version also takes advantage of uniprocessor execution to accelerate grace periods in the case where there are no readers. The general design is otherwise broadly similar to that of TREE_PREEMPT_RCU. This implementation is a step towards having RCU implementation driven off of the SMP and PREEMPT kernel configuration variables, which can happen once this implementation has accumulated sufficient experience. Removed ACCESS_ONCE() from __rcu_read_unlock() and added barrier() as suggested by Steve Rostedt in order to avoid the compiler-reordering issue noted by Mathieu Desnoyers (http://lkml.org/lkml/2010/8/16/183). As can be seen below, CONFIG_TINY_PREEMPT_RCU represents almost 5Kbyte savings compared to CONFIG_TREE_PREEMPT_RCU. Of course, for non-real-time workloads, CONFIG_TINY_RCU is even better. CONFIG_TREE_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 6170 825 28 7023 kernel/rcutree.o ---- 7026 Total CONFIG_TINY_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 2081 81 8 2170 kernel/rcutiny.o ---- 2183 Total CONFIG_TINY_RCU (non-preemptible) text data bss dec filename 13 0 0 13 kernel/rcupdate.o 719 25 0 744 kernel/rcutiny.o --- 757 Total Requested-by: Loïc Minier <loic.minier@canonical.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-19rcu head remove initMathieu Desnoyers
RCU heads really don't need to be initialized. Their state before call_rcu() really does not matter. We need to keep init/destroy_rcu_head_on_stack() though, since we want debugobjects to be able to keep track of these objects. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> CC: David S. Miller <davem@davemloft.net> CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> CC: akpm@linux-foundation.org CC: mingo@elte.hu CC: laijs@cn.fujitsu.com CC: dipankar@in.ibm.com CC: josh@joshtriplett.org CC: dvhltc@us.ibm.com CC: niv@us.ibm.com CC: tglx@linutronix.de CC: peterz@infradead.org CC: rostedt@goodmis.org CC: Valdis.Kletnieks@vt.edu CC: dhowells@redhat.com CC: eric.dumazet@gmail.com CC: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-19rcu: improve kerneldoc for rcu_read_lock(), call_rcu(), and synchronize_rcu()Paul E. McKenney
Make it explicit that new RCU read-side critical sections that start after call_rcu() and synchronize_rcu() start might still be running after the end of the relevant grace period. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-19Add RCU check for find_task_by_vpid().Tetsuo Handa
find_task_by_vpid() says "Must be called under rcu_read_lock().". But due to commit 3120438 "rcu: Disable lockdep checking in RCU list-traversal primitives", we are currently unable to catch "find_task_by_vpid() with tasklist_lock held but RCU lock not held" errors due to the RCU-lockdep checks being suppressed in the RCU variants of the struct list_head traversals. This commit therefore places an explicit check for being in an RCU read-side critical section in find_task_by_pid_ns(). =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- kernel/pid.c:386 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 1 1 lock held by rc.sysinit/1102: #0: (tasklist_lock){.+.+..}, at: [<c1048340>] sys_setpgid+0x40/0x160 stack backtrace: Pid: 1102, comm: rc.sysinit Not tainted 2.6.35-rc3-dirty #1 Call Trace: [<c105e714>] lockdep_rcu_dereference+0x94/0xb0 [<c104b4cd>] find_task_by_pid_ns+0x6d/0x70 [<c104b4e8>] find_task_by_vpid+0x18/0x20 [<c1048347>] sys_setpgid+0x47/0x160 [<c1002b50>] sysenter_do_call+0x12/0x36 Commit updated to use a new rcu_lockdep_assert() exported API rather than the old internal __do_rcu_dereference(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-08-19rcu: define __rcu address space modifier for sparsePaul E. McKenney
This commit provides definitions for the __rcu annotation defined earlier. This annotation permits sparse to check for correct use of RCU-protected pointers. If a pointer that is annotated with __rcu is accessed directly (as opposed to via rcu_dereference(), rcu_assign_pointer(), or one of their variants), sparse can be made to complain. To enable such complaints, use the new default-disabled CONFIG_SPARSE_RCU_POINTER kernel configuration option. Please note that these sparse complaints are intended to be a debugging aid, -not- a code-style-enforcement mechanism. There are special rcu_dereference_protected() and rcu_access_pointer() accessors for use when RCU read-side protection is not required, for example, when no other CPU has access to the data structure in question or while the current CPU hold the update-side lock. This patch also updates a number of docbook comments that were showing their age. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Christopher Li <sparse@chrisli.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-06-14rcu: add an rcu_dereference_index_check()Paul E. McKenney
The sparse RCU-pointer checking relies on type magic that dereferences the pointer in question. This does not work if the pointer is in fact an array index. This commit therefore supplies a new RCU API that omits the sparse checking to continue to support rcu_dereference() on integers. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-06-14tree/tiny rcu: Add debug RCU head objectsMathieu Desnoyers
Helps finding racy users of call_rcu(), which results in hangs because list entries are overwritten and/or skipped. Changelog since v4: - Bissectability is now OK - Now generate a WARN_ON_ONCE() for non-initialized rcu_head passed to call_rcu(). Statically initialized objects are detected with object_is_static(). - Rename rcu_head_init_on_stack to init_rcu_head_on_stack. - Remove init_rcu_head() completely. Changelog since v3: - Include comments from Lai Jiangshan This new patch version is based on the debugobjects with the newly introduced "active state" tracker. Non-initialized entries are all considered as "statically initialized". An activation fixup (triggered by call_rcu()) takes care of performing the debug object initialization without issuing any warning. Since we cannot increase the size of struct rcu_head, I don't see much room to put an identifier for statically initialized rcu_head structures. So for now, we have to live without "activation without explicit init" detection. But the main purpose of this debug option is to detect double-activations (double call_rcu() use of a rcu_head before the callback is executed), which is correctly addressed here. This also detects potential internal RCU callback corruption, which would cause the callbacks to be executed twice. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> CC: David S. Miller <davem@davemloft.net> CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> CC: akpm@linux-foundation.org CC: mingo@elte.hu CC: laijs@cn.fujitsu.com CC: dipankar@in.ibm.com CC: josh@joshtriplett.org CC: dvhltc@us.ibm.com CC: niv@us.ibm.com CC: tglx@linutronix.de CC: peterz@infradead.org CC: rostedt@goodmis.org CC: Valdis.Kletnieks@vt.edu CC: dhowells@redhat.com CC: eric.dumazet@gmail.com CC: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2010-05-10rcu head introduce rcu head init on stackMathieu Desnoyers
PEM: o Would it be possible to make this bisectable as follows? a. Insert a new patch after current patch 4/6 that defines destroy_rcu_head_on_stack(), init_rcu_head_on_stack(), and init_rcu_head() with their !CONFIG_DEBUG_OBJECTS_RCU_HEAD definitions. This patch performs this transition. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> CC: David S. Miller <davem@davemloft.net> CC: akpm@linux-foundation.org CC: mingo@elte.hu CC: laijs@cn.fujitsu.com CC: dipankar@in.ibm.com CC: josh@joshtriplett.org CC: dvhltc@us.ibm.com CC: niv@us.ibm.com CC: tglx@linutronix.de CC: peterz@infradead.org CC: rostedt@goodmis.org CC: Valdis.Kletnieks@vt.edu CC: dhowells@redhat.com CC: eric.dumazet@gmail.com CC: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: slim down rcutiny by removing rcu_scheduler_active and friendsPaul E. McKenney
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC. So conditionally compile rcu_scheduler_active in order to slim down rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is responsible for most of the slimming. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: shrink rcutiny by making synchronize_rcu_bh() be inlinePaul E. McKenney
Because synchronize_rcu_bh() is identical to synchronize_sched(), make the former a static inline invoking the latter, saving the overhead of an EXPORT_SYMBOL_GPL() and the duplicate code. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: fix now-bogus rcu_scheduler_active comments.Paul E. McKenney
The rcu_scheduler_active check has been wrapped into the new debug_lockdep_rcu_enabled() function, so update the comments to reflect this new reality. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: Fix bogus CONFIG_PROVE_LOCKING in comments to reflect reality.Paul E. McKenney
It is CONFIG_DEBUG_LOCK_ALLOC rather than CONFIG_PROVE_LOCKING, so fix it. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: optionally leave lockdep enabled after RCU lockdep splatLai Jiangshan
There is no need to disable lockdep after an RCU lockdep splat, so remove the debug_lockdeps_off() from lockdep_rcu_dereference(). To avoid repeated lockdep splats, use a static variable in the inlined rcu_dereference_check() and rcu_dereference_protected() macros so that a given instance splats only once, but so that multiple instances can be detected per boot. This is controlled by a new config variable CONFIG_PROVE_RCU_REPEATEDLY, which is disabled by default. This provides the normal lockdep behavior by default, but permits people who want to find multiple RCU-lockdep splats per boot to easily do so. Requested-by: Eric Paris <eparis@redhat.com> Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Tested-by: Eric Paris <eparis@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-06rcu: create rcu_my_thread_group_empty() wrapperPaul E. McKenney
Some RCU-lockdep splat repairs need to know whether they are running in a single-threaded process. Unfortunately, the thread_group_empty() primitive is defined in sched.h, and can induce #include hell. This commit therefore introduces a rcu_my_thread_group_empty() wrapper that is defined in rcupdate.c, thus avoiding the need to include sched.h everywhere. Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
2010-04-19rcu: Make RCU lockdep check the lockdep_recursion variablePaul E. McKenney
The lockdep facility temporarily disables lockdep checking by incrementing the current->lockdep_recursion variable. Such disabling happens in NMIs and in other situations where lockdep might expect to recurse on itself. This patch therefore checks current->lockdep_recursion, disabling RCU lockdep splats when this variable is non-zero. In addition, this patch removes the "likely()", as suggested by Lai Jiangshan. Reported-by: Frederic Weisbecker <fweisbec@gmail.com> Reported-by: David Miller <davem@davemloft.net> Tested-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: eric.dumazet@gmail.com LKML-Reference: <20100415195039.GA22623@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-14rcu: Better explain the condition parameter of rcu_dereference_check()David Howells
Better explain the condition parameter of rcu_dereference_check() that describes the conditions under which the dereference is permitted to take place (and incorporate Yong Zhang's suggestion). This condition is only checked under lockdep proving. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: eric.dumazet@gmail.com LKML-Reference: <1270852752-25278-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-14rcu: Add rcu_access_pointer and rcu_dereference_protectedPaul E. McKenney
This patch adds variants of rcu_dereference() that handle situations where the RCU-protected data structure cannot change, perhaps due to our holding the update-side lock, or where the RCU-protected pointer is only to be fetched, not dereferenced. These are needed due to some performance concerns with using rcu_dereference() where it is not required, aside from the need for lockdep/sparse checking. The new rcu_access_pointer() primitive is for the case where the pointer is be fetch and not dereferenced. This primitive may be used without protection, RCU or otherwise, due to the fact that it uses ACCESS_ONCE(). The new rcu_dereference_protected() primitive is for the case where updates are prevented, for example, due to holding the update-side lock. This primitive does neither ACCESS_ONCE() nor smp_read_barrier_depends(), so can only be used when updates are somehow prevented. Suggested-by: David Howells <dhowells@redhat.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: eric.dumazet@gmail.com LKML-Reference: <1270852752-25278-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-18rcu: Fix local_irq_disable() CONFIG_PROVE_RCU=y false positivesLai Jiangshan
It is documented that local_irq_disable() also delimits RCU_SCHED read-site critical sections. See the document of synchronize_sched() or Documentation/RCU/whatisRCU.txt. So we have to test irqs_disabled() in rcu_read_lock_sched_held(). Otherwise rcu-lockdep brings incorrect complaint. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: eric.dumazet@gmail.com LKML-Reference: <1268940334-10892-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-16rcu: Make rcu_read_lock_bh_held() allow for disabled BHPaul E. McKenney
Disabling BH can stand in for rcu_read_lock_bh(), and this patch updates rcu_read_lock_bh_held() to allow for this. In order to avoid include-file hell, this function is moved out of line to kernel/rcupdate.c. This fixes a false positive RCU warning. Reported-by: Arnd Bergmann <arnd@arndb.de> Reported-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <20100316000343.GA25857@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-13Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: locking: Make sparse work with inline spinlocks and rwlocks x86/mce: Fix RCU lockdep splats rcu: Increase RCU CPU stall timeouts if PROVE_RCU ftrace: Replace read_barrier_depends() with rcu_dereference_raw() rcu: Suppress RCU lockdep warnings during early boot rcu, ftrace: Fix RCU lockdep splat in ftrace_perf_buf_prepare() rcu: Suppress __mpol_dup() false positive from RCU lockdep rcu: Make rcu_read_lock_sched_held() handle !PREEMPT rcu: Add control variables to lockdep_rcu_dereference() diagnostics rcu, cgroup: Relax the check in task_subsys_state() as early boot is now handled by lockdep-RCU rcu: Use wrapper function instead of exporting tasklist_lock sched, rcu: Fix rcu_dereference() for RCU-lockdep rcu: Make task_subsys_state() RCU-lockdep checks handle boot-time use rcu: Fix holdoff for accelerated GPs for last non-dynticked CPU x86/gart: Unexport gart_iommu_aperture Fix trivial conflicts in kernel/trace/ftrace.c
2010-03-12sysctl extern cleanup: rcuDave Young
Extern declarations in sysctl.c should be moved to their own header file, and then include them in relavant .c files. Move rcutorture_runnable extern declaration to linux/rcupdate.h Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-04rcu: Suppress RCU lockdep warnings during early bootPaul E. McKenney
RCU is used during very early boot, before RCU and lockdep have been initialized. So make the underlying primitives (rcu_read_lock_held(), rcu_read_lock_bh_held(), rcu_read_lock_sched_held(), and rcu_dereference_check()) check for early boot via the rcu_scheduler_active flag. This will suppress false positives. Also introduce a debug_lockdep_rcu_enabled() static inline helper function, which tags the CONTINUE_PROVE_RCU case as likely(), as suggested by Ingo Molnar. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267631219-8713-2-git-send-email-paulmck@linux.vnet.ibm.com> [ v2: removed incomplete debug_lockdep_rcu_update() bits ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-04rcu: Make rcu_read_lock_sched_held() handle !PREEMPTPaul E. McKenney
The rcu_read_lock_sched_held() needs to unconditionally return the value "1" in a !PREEMPT kernel, because under !PREEMPT, -all- kernel code is implicitly preempt-disabled. This patch makes this happen. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267667418-32233-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-27rcu: Make non-RCU_PROVE_LOCKING rcu_read_lock_sched_held() understand bootPaul E. McKenney
Before the scheduler starts, all tasks are non-preemptible by definition. So, during that time, rcu_read_lock_sched_held() needs to always return "true". This patch makes that be so for RCU_PROVE_LOCKING=n. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267231138-27856-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-26rcu: Make rcu_read_lock_sched_held() take boot time into accountPaul E. McKenney
Before the scheduler starts, all tasks are non-preemptible by definition. So, during that time, rcu_read_lock_sched_held() needs to always return "true". This patch makes that be so. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1267135607-7056-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Integrate rcu_dereference_check() message into lockdepPaul E. McKenney
Make rcu_dereference_check() print the list of held locks in addition to the stack dump to ease debugging. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-3-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Add lockdep-enabled variants of rcu_dereference()Paul E. McKenney
Make rcu_dereference() check for being in an RCU read-side critical section, and create rcu_dereference_bh(), rcu_dereference_sched(), and srcu_dereference() to check for the other flavors of RCU. Also create rcu_dereference_raw() to avoid checking, and make rcu_dereference_check() use rcu_dereference_raw(). Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-2-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Introduce lockdep-based checking to RCU read-side primitivesPaul E. McKenney
Inspection is proving insufficient to catch all RCU misuses, which is understandable given that rcu_dereference() might be protected by any of four different flavors of RCU (RCU, RCU-bh, RCU-sched, and SRCU), and might also/instead be protected by any of a number of locking primitives. It is therefore time to enlist the aid of lockdep. This set of patches is inspired by earlier work by Peter Zijlstra and Thomas Gleixner, and takes the following approach: o Set up separate lockdep classes for RCU, RCU-bh, and RCU-sched. o Set up separate lockdep classes for each instance of SRCU. o Create primitives that check for being in an RCU read-side critical section. These return exact answers if lockdep is fully enabled, but if unsure, report being in an RCU read-side critical section. (We want to avoid false positives!) The primitives are: For RCU: rcu_read_lock_held(void) For RCU-bh: rcu_read_lock_bh_held(void) For RCU-sched: rcu_read_lock_sched_held(void) For SRCU: srcu_read_lock_held(struct srcu_struct *sp) o Add rcu_dereference_check(), which takes a second argument in which one places a boolean expression based on the above primitives and/or lockdep_is_held(). o A new kernel configuration parameter, CONFIG_PROVE_RCU, enables rcu_dereference_check(). This depends on CONFIG_PROVE_LOCKING, and should be quite helpful during the transition period while CONFIG_PROVE_RCU-unaware patches are in flight. The existing rcu_dereference() primitive does no checking, but upcoming patches will change that. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-22rcu: Re-arrange code to reduce #ifdef painPaul E. McKenney
Remove #ifdefs from kernel/rcupdate.c and include/linux/rcupdate.h by moving code to include/linux/rcutiny.h, include/linux/rcutree.h, and kernel/rcutree.c. Also remove some definitions that are no longer used. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1258908830885-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-27rcu: Fix TINY_RCU #elif conditionPaul E. McKenney
Some compilers are happy with "#elif CONFIG_RCU_TINY", while others strongly prefer "#elif defined(CONFIG_RCU_TINY)". Change to the latter to make more compilers happy. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12565906642768-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: "Tiny RCU", The Bloatwatch EditionPaul E. McKenney
This patch is a version of RCU designed for !SMP provided for a small-footprint RCU implementation. In particular, the implementation of synchronize_rcu() is extremely lightweight and high performance. It passes rcutorture testing in each of the four relevant configurations (combinations of NO_HZ and PREEMPT) on x86. This saves about 1K bytes compared to old Classic RCU (which is no longer in mainline), and more than three kilobytes compared to Hierarchical RCU (updated to 2.6.30): CONFIG_TREE_RCU: text data bss dec filename 183 4 0 187 kernel/rcupdate.o 2783 520 36 3339 kernel/rcutree.o 3526 Total (vs 4565 for v7) CONFIG_TREE_PREEMPT_RCU: text data bss dec filename 263 4 0 267 kernel/rcupdate.o 4594 776 52 5422 kernel/rcutree.o 5689 Total (6155 for v7) CONFIG_TINY_RCU: text data bss dec filename 96 4 0 100 kernel/rcupdate.o 734 24 0 758 kernel/rcutiny.o 858 Total (vs 848 for v7) The above is for x86. Your mileage may vary on other platforms. Further compression is possible, but is being procrastinated. Changes from v7 (http://lkml.org/lkml/2009/10/9/388) o Apply Lai Jiangshan's review comments (aside from might_sleep() in synchronize_sched(), which is covered by SMP builds). o Fix up expedited primitives. Changes from v6 (http://lkml.org/lkml/2009/9/23/293). o Forward ported to put it into the 2.6.33 stream. o Added lockdep support. o Make lightweight rcu_barrier. Changes from v5 (http://lkml.org/lkml/2009/6/23/12). o Ported to latest pre-2.6.32 merge window kernel. - Renamed rcu_qsctr_inc() to rcu_sched_qs(). - Renamed rcu_bh_qsctr_inc() to rcu_bh_qs(). - Provided trivial rcu_cpu_notify(). - Provided trivial exit_rcu(). - Provided trivial rcu_needs_cpu(). - Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h. o Removed the dependence on EMBEDDED, with a view to making TINY_RCU default for !SMP at some time in the future. o Added (trivial) support for expedited grace periods. Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include: o Squeeze the size down a bit further by removing the ->completed field from struct rcu_ctrlblk. o This permits synchronize_rcu() to become the empty function. Previous concerns about rcutorture were unfounded, as rcutorture correctly handles a constant value from rcu_batches_completed() and rcu_batches_completed_bh(). Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include: o Changed rcu_batches_completed(), rcu_batches_completed_bh() rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and rcu_nmi_exit(), to be static inlines, as suggested by David Howells. Doing this saves about 100 bytes from rcutiny.o. (The numbers between v3 and this v4 of the patch are not directly comparable, since they are against different versions of Linux.) Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include: o Fix whitespace issues. o Change short-circuit "||" operator to instead be "+" in order to fix performance bug noted by "kraai" on LWN. (http://lwn.net/Articles/324348/) Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include: o This version depends on EMBEDDED as well as !SMP, as suggested by Ingo. o Updated rcu_needs_cpu() to unconditionally return zero, permitting the CPU to enter dynticks-idle mode at any time. This works because callbacks can be invoked upon entry to dynticks-idle mode. o Paul is now OK with this being included, based on a poll at the Kernel Miniconf at linux.conf.au, where about ten people said that they cared about saving 900 bytes on single-CPU systems. o Applies to both mainline and tip/core/rcu. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-05rcu: Clean up code based on review feedback from Josh Triplett, part 3Paul E. McKenney
Whitespace fixes, updated comments, and trivial code movement. o Fix whitespace error in RCU_HEAD_INIT() o Move "So where is rcu_write_lock()" comment so that it does not come between the rcu_read_unlock() header comment and the rcu_read_unlock() definition. o Move the module_param statements for blimit, qhimark, and qlowmark to immediately follow the corresponding definitions. o In __rcu_offline_cpu(), move the assignment to rdp_me inside the "if" statement, given that rdp_me is not used outside of that "if" statement. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12541491931164-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23rcu: Clean up code based on review feedback from Josh Triplett, part 2Paul E. McKenney
These issues identified during an old-fashioned face-to-face code review extending over many hours. o Add comments for tricky parts of code, and correct comments that have passed their sell-by date. o Get rid of the vestiges of rcu_init_sched(), which is no longer needed now that PREEMPT_RCU is gone. o Move the #include of rcutree_plugin.h to the end of rcutree.c, which means that, rather than having a random collection of forward declarations, the new set of forward declarations document the set of plugins. The new home for this #include also allows __rcu_init_preempt() to move into rcutree_plugin.h. o Fix rcu_preempt_check_callbacks() to be static. Suggested-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246443924-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu> Peter Zijlstra <peterz@infradead.org>
2009-09-19rcu: Fix whitespace inconsistenciesPaul E. McKenney
Fix a number of whitespace ^Ierrors in the include/linux/rcu* and the kernel/rcu* files. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com> [ did more checkpatch fixlets ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcu: Fix synchronize_rcu() for TREE_PREEMPT_RCUPaul E. McKenney
The redirection of synchronize_sched() to synchronize_rcu() was appropriate for TREE_RCU, but not for TREE_PREEMPT_RCU. Fix this by creating an underlying synchronize_sched(). TREE_RCU then redirects synchronize_rcu() to synchronize_sched(), while TREE_PREEMPT_RCU has its own version of synchronize_rcu(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <12528585111916-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-26rcu: Remove lockdep annotations from RCU's _notrace() API membersPaul E. McKenney
The lockdep annotations rcu_read_acquire() and rcu_read_release() might lead to infinite looping if called from lockdep. So this patch removes them. Formal repost of http://lkml.org/lkml/2009/8/25/309 on the strength of Lai Jiangshan's review. Suggested-by: Lai Jiangshan <laijs@cn.fujitsu.com> Suggested-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <20090826015337.GA18904@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-24rcu: Add "notrace" to RCU function headers used by ftracePaul E. McKenney
Both rcu_read_lock_sched_notrace() and rcu_read_unlock_sched_notrace() are used by ftrace, and thus need to be marked "notrace". Unfortunately, my naive assumption that gcc would see the inner "notrace" does not hold. Kudos to Lai Jiangshan for noting this. Reported-by: Ingo Molnar <mingo@elte.hu> Bug-spotted-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12511321213243-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Remove CONFIG_PREEMPT_RCUPaul E. McKenney
Now that CONFIG_TREE_PREEMPT_RCU is in place, there is no further need for CONFIG_PREEMPT_RCU. Remove it, along with whatever subtle bugs it may (or may not) contain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <125097461396-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-23rcu: Merge preemptable-RCU functionality into hierarchical RCUPaul E. McKenney
Create a kernel/rcutree_plugin.h file that contains definitions for preemptable RCU (or, under the #else branch of the #ifdef, empty definitions for the classic non-preemptable semantics). These definitions fit into plugins defined in kernel/rcutree.c for this purpose. This variant of preemptable RCU uses a new algorithm whose read-side expense is roughly that of classic hierarchical RCU under CONFIG_PREEMPT. This new algorithm's update-side expense is similar to that of classic hierarchical RCU, and, in absence of read-side preemption or blocking, is exactly that of classic hierarchical RCU. Perhaps more important, this new algorithm has a much simpler implementation, saving well over 1,000 lines of code compared to mainline's implementation of preemptable RCU, which will hopefully be retired in favor of this new algorithm. The simplifications are obtained by maintaining per-task nesting state for running tasks, and using a simple lock-protected algorithm to handle accounting when tasks block within RCU read-side critical sections, making use of lessons learned while creating numerous user-level RCU implementations over the past 18 months. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org LKML-Reference: <12509746134003-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
