path: root/include/linux/relay.h
2013-04-30kernel/relay.c: move FIX_SIZE macro into relay.czhangwei(Jovi)
It's better to place FIX_SIZE macro in relay.c, instead of relay.h Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-03switch debugfs to umode_tAl Viro
2009-09-24docs: fix various Documentation/ paths in header filesRandy Dunlap
Fix various Documentation/ paths in include/linux/. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26relay: add buffer-only channels; useful for early loggingEduard - Gabriel Munteanu
Allows one to create and use a channel with no associated files. Files can be initialized later. This is useful in scenarios such as logging in early code, before VFS is up. Therefore, such channels can be created and used as soon as kmem_cache_init() completed. This is needed by kmemtrace to do tracing in early kernel code. [kosaki.motohiro@jp.fujitsu.com: build fix] Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09relay: use plain timer instead of delayed workTom Zanussi
relay doesn't need to use schedule_delayed_work() for waking readers when a simple timer will do. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Cc: Satyam Sharma <satyam.sharma@gmail.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Relay: add CPU hotplug supportMathieu Desnoyers
Mathieu originally needed to add this for tracing Xen, but it's something that's needed for any application that can be tracing while cpus are added. unplug isn't supported by this patch. The thought was that at minumum a new buffer needs to be added when a cpu comes up, but it wasn't worth the effort to remove buffers on cpu down since they'd be freed soon anyway when the channel was closed. [zanussi@us.ibm.com: avoid lock_cpu_hotplug deadlock] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-23[PATCH] relay: migrate from relayfs to a generic relay APIJens Axboe
Original patch from Paul Mundt, sysfs parts removed by me since they were broken. Signed-off-by: Jens Axboe <axboe@suse.de>
