Currently the rtc_class_op's set_mmss() function takes a 32-bit
second value (on 32-bit systems), which is problematic for dates
past y2038.
This patch provides a safe version named set_mmss64() using
y2038 safe time64_t.
After this patch, set_mmss() is deprecated and all its users
will be fixed to use set_mmss64(), it can be removed when having
no users.
Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org>
[jstultz: Add whitespace fix for checkpatch]
Signed-off-by: John Stultz <john.stultz@linaro.org>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Link: http://lkml.kernel.org/r/1427945681-29972-8-git-send-email-john.stultz@linaro.org
rtc_set_ntp_time() uses timespec which is y2038-unsafe,
so modify to use timespec64 which is y2038-safe, then
replace rtc_time_to_tm() with rtc_time64_to_tm().
Also adjust all its call sites(only NTP uses it) accordingly.
Cc: pang.xunlei <pang.xunlei@linaro.org>
Cc: Arnd Bergmann <arnd.bergmann@linaro.org>
As part of addressing "y2038 problem" for in-kernel uses, this patch
adds safe rtc_tm_to_time64()/rtc_time64_to_tm() respectively using
time64_t.
After this patch, rtc_tm_to_time() is deprecated and all its call
sites will be fixed using corresponding safe versions, it can be
removed when having no users. Also change rtc_tm_to_time64() to
return time64_t directly instead of just as a parameter like
rtc_tm_to_time() does.
After this patch, rtc_time_to_tm() is deprecated and all its call
In addition, change rtc_tm_to_ktime() and rtc_ktime_to_tm() to use
the safe version in passing.
Signed-off-by: pang.xunlei <pang.xunlei@linaro.org>
devm_rtc_device_register()
Other devm_* APIs use 'struct device *dev' as the first argument. Thus,
in order to sync with other devm_* functions, struct device is used as
the first argument for devm_rtc_device_register().
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
These functions allow the driver core to automatically clean up any
allocation made by rtc drivers. Thus it simplifies the error paths.
Acked-by: Tejun Heo <tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
All in-kernel users of class_find_device() don't really need mutable
data for match callback.
In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c)
this patch changes match callbacks to use const search data.
The const is propagated to rtc_class_open() and power_supply_get_by_name()
parameters.
Note that there's a dev reference leak in suspend_test.c that's not
touched in this patch.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
The purpose of this option is to allow ARM/etc systems that rely on the
class RTC subsystem to have the same kind of automatic NTP based
synchronization that we have on PC platforms. Today ARM does not
implement update_persistent_clock and makes extensive use of the class
RTC system.
When enabled CONFIG_RTC_SYSTOHC will provide a generic
rtc_update_persistent_clock that stores the current time in the RTC and
is intended complement the existing CONFIG_RTC_HCTOSYS option that loads
the RTC at boot.
Like with RTC_HCTOSYS the platform's update_persistent_clock is used
first, if it works. Platforms with mixed class RTC and non-RTC drivers
need to return ENODEV when class RTC should be used. Such an update for
PPC is included in this patch.
Long term, implementations of update_persistent_clock should migrate to
proper class RTC drivers and use CONFIG_RTC_SYSTOHC instead.
Tested on ARM kirkwood and PPC405
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Without this patch /sys/class/rtc/$CONFIG_RTC_HCTOSYS_DEVICE/hctosys
contains a 1 (meaning "This rtc was used to initialize the system
clock") even if setting the time by do_settimeofday() at bootup failed.
The RTC can also be used to set the clock on resume, if it did 1,
otherwise 0. Previously there was no indication if the RTC was used
to set the clock in resume.
This uses only CONFIG_RTC_HCTOSYS_DEVICE for conditional compilation
instead of it and CONFIG_RTC_HCTOSYS to be more consistent.
rtc_hctosys_ret was moved to class.c so class.c no longer depends on
hctosys.c.
[sfr@canb.auug.org.au: fix build]
Signed-off-by: David Fries <David@Fries.net>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Currently there is no generic way to get the RTC battery status within an
application. So add an ioctl to read the status bit. The idea is that
the bit is set once a low voltage is detected. It stays there until it is
reset using the RTC_VL_CLR ioctl.
Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com>
Richard Weinberger noticed that on some RTC hardware that
doesn't support UIE mode, due to coarse granular alarms
(like 1minute resolution), the current virtualized RTC
support doesn't properly error out when UIE is enabled.
Instead the current code queues an alarm for the next second,
but it won't fire until up to a miniute later.
This patch provides a generic way to flag this sort of hardware
and fixes the issue on the mpc5121 where Richard noticed the
problem.
CC: stable@vger.kernel.org
Reported-by: Richard Weinberger <richard@nod.at>
Tested-by: Richard Weinberger <richard@nod.at>
The RTC pie hrtimer is self rearming. We really need to limit the
frequency to something sensible. Thus limit it to the 8192Hz max
value from the rtc man documentation
Cc: Willy Tarreau <w@1wt.eu>
Cc: stable@kernel.org
[jstultz: slightly reworked to use RTC_MAX_FREQ value]
[akpm@linux-foundation.org: retain the code comments]
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
When we register an rtc device at boot, we read the alarm value
in hardware and set the rtc device's aie_timer to that value.
The initial method to do this was to simply call rtc_set_alarm()
with the value read from hardware. However, this may cause problems
as rtc_set_alarm may enable interupts, and the RTC alarm might fire,
which can cause invalid pointer dereferencing since the RTC registration
is not complete.
This patch solves the issue by initializing the rtc_device.aie_timer
y hand via rtc_initialize_alarm(). This avoids any calls to the RTC
hardware which might enable interrupts too early.
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Alessandro Zummo <a.zummo@towertech.it>
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Now that the generic code handles UIE mode irqs via periodic
alarm interrupts, no one calls the
rtc_class_ops->update_irq_enable() method anymore.
This patch removes the driver hooks and implementations of
update_irq_enable if no one else is calling it.
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
With the generic rtc code now emulating PIE mode irqs via an
hrtimer, no one calls the rtc_class_ops->irq_set_freq call.
This patch removes the hook and deletes the driver functions
if no one else calls them.
With PIE mode interrupts now emulated in generic code via an hrtimer,
no one calls rtc_class_ops->irq_set_state(), so this patch removes it
along with driver implementations.
Mark Brown pointed out a corner case: that RTC alarms should
be allowed to be persistent across reboots if the hardware
supported it.
The rework of the generic layer to virtualize the RTC alarm
virtualized much of the alarm handling, and removed the
code used to read the alarm time from the hardware.
Mark noted if we want the alarm to be persistent across
reboots, we need to re-read the alarm value into the
virtualized generic layer at boot up, so that the generic
layer properly exposes that value.
This patch restores much of the earlier removed
rtc_read_alarm code and wires it in so that we
set the kernel's alarm value to what we find in the
hardware at boot time.
NOTE: Not all hardware supports persistent RTC alarm state across
system reset. rtc-cmos for example will keep the alarm time, but
disables the AIE mode irq. Applications should not expect the RTC
alarm to be valid after a system reset. We will preserve what
we can, to represent the hardware state at boot, but its not
guarenteed.
Further, in the future, with multiplexed RTC alarms, the
soonest alarm to fire may not be the one set via the /dev/rt
ioctls. So an application may set the alarm with RTC_ALM_SET,
but after a reset find that RTC_ALM_READ returns an earlier
time. Again, we preserve what we can, but applications should
not expect the RTC alarm state to persist across a system reset.
Big thanks to Mark for pointing out the issue!
Thanks also to Marcelo for helping think through the solution.
CC: Mark Brown <broonie@opensource.wolfsonmicro.com>
Reported-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch re-enables UIE timer/polling emulation for rtc devices
that do not support alarm irqs.
CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Uwe pointed out that my alarm based UIE emulation is not sufficient
to replace the older timer/polling based UIE emulation on devices
where there is no alarm irq. This causes rtc devices without alarms
to return -EINVAL to UIE ioctls. The fix is to re-instate the old
timer/polling method for devices without alarm irqs.
This patch reverts the following commits:
042620a018afcfba1d678062b62e46 - Remove UIE emulation
1daeddd5962acad1bea55e524fc0fa - Cleanup removed UIE emulation declaration
b5cc8ca1c9c3a37eaddf709b2fd3e1 - Remove Kconfig symbol for UIE emulation
The emulation mode will still need to be wired-in with a following
patch before it will work.
In cases where RTC hardware does not support alarms, the virtualized
RTC interfaces did not have a way to propagate the error up to userland.
This patch extends rtc_timer_enqueue so it catches errors from the hardware
and returns them upwards to the virtualized interfaces. To simplify error
handling, it also internalizes the management of the timer->enabled bit
into rtc_timer_enqueue and rtc_timer_remove.
Also makes rtc_timer_enqueue and rtc_timer_remove static.
Reported-by: David Daney <ddaney@caviumnetworks.com>
Reported-by: Andreas Schwab <schwab@linux-m68k.org>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Diagnosed-by: David Daney <ddaney@caviumnetworks.com>
Tested-by: David Daney <ddaney@caviumnetworks.com>
LKML-Reference: <1295565973-14358-1-git-send-email-john.stultz@linaro.org>
rtc_dev_update_irq_enable_emul was removed in commit
042620a018afcfba1d678062b62e463b9e43a68d (UIE emulation is
now handled via hrtimer), but the declaration was missed.
This patch cleans it up.
LKML-Reference: <1294939849-20608-1-git-send-email-john.stultz@linaro.org>
rtctimer_* is already occupied by sound/core/rtctimer.c. Instead of
fiddling with that, rename the new functions to rtc_timer_* which
reads nicer anyway.
Cc: John Stultz <johnstul@us.ibm.com>
Since we provide UIE interrupts via a rtc_timer, the old
emulation code can be removed.
LKML Reference: <1290136329-18291-5-git-send-email-john.stultz@linaro.org>
CC: Richard Cochran <richardcochran@gmail.com>
This patch reworks a large portion of the generic RTC code
to in-effect virtualize the rtc interrupt code.
The current RTC interface is very much a raw hardware interface.
Via the proc, /dev/, or sysfs interfaces, applciations can set
the hardware to trigger interrupts in one of three modes:
AIE: Alarm interrupt
UIE: Update interrupt (ie: once per second)
PIE: Periodic interrupt (sub-second irqs)
The problem with this interface is that it limits the RTC hardware
so it can only be used by one application at a time.
The purpose of this patch is to extend the RTC code so that we can
multiplex multiple applications event needs onto a single RTC device.
This is done by utilizing the timerqueue infrastructure to manage
a list of events, which cause the RTC hardware to be programmed
to fire an interrupt for the next event in the list.
In order to preserve the functionality of the exsting proc,/dev/ and
sysfs interfaces, we emulate the different interrupt modes as follows:
AIE: We create a rtc_timer dedicated to AIE mode interrupts. There is
only one per device, so we don't change existing interface semantics.
UIE: Again, a dedicated rtc_timer, set for periodic mode, is used
to emulate UIE interrupts. Again, only one per device.
PIE: Since PIE mode interrupts fire faster then the RTC's clock read
granularity, we emulate PIE mode interrupts using a hrtimer. Again,
one per device.
With this patch, the rtctest.c application in Documentation/rtc.txt
passes fine on x86 hardware. However, there may very well still be
bugs, so greatly I'd appreciate any feedback or testing!
LKML Reference: <1290136329-18291-4-git-send-email-john.stultz@linaro.org>
contains a 1 (meaning "This rtc was used to initialize the system clock")
even if reading the time at bootup failed.
Moreover change error handling in rtc_hctosys() to use goto and so reduce
the indention level.
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
- the LEAP_YEAR macro is buggy - it references its arg multiple times.
Fix this by turning it into a C function.
- give it a more approriate name
- Move it to rtc.h so that other .c files can use it, instead of copying it.
Cc: dann frazier <dannf@hp.com>
Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
Cc: stephane eranian <eranian@googlemail.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: David Brownell <david-b@pacbell.net>
Add standard interfaces for alarm/update irqs enabling. Drivers are no
more required to implement equivalent ioctl code as rtc-dev will provide
it.
UIE emulation should now be handled correctly and will work even for those
RTC drivers who cannot be configured to do both UIE and AIE.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
The following functions can now become static:
- rtc_interrupt()
- rtc_get_rtc_time()
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Bernhard Walle <bwalle@suse.de>
Acked-by: Paul Gortmaker <p_gortmaker@yahoo.com>
Remove implicit use of BKL in ioctl() from the RTC framework.
Instead, the rtc->ops_lock is used. That's the same lock that already
protects the RTC operations when they're issued through the exported
rtc_*() calls in drivers/rtc/interface.c ... making this a bugfix, not
just a cleanup, since both ioctl calls and set_alarm() need to update IRQ
enable flags and that implies a common lock (which RTC drivers as a rule
do not provide on their own).
A new comment at the declaration of "struct rtc_class_ops" summarizes
current locking rules. It's not clear to me that the exceptions listed
there should exist ... if not, those are pre-existing problems which can
be fixed in a patch that doesn't relate to BKL removal.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jonathan Corbet <corbet@lwn.net>
RTC code is using mutex to assure exclusive access to /dev/rtc. This is
however wrong usage, as it leaves the mutex locked when returning into
userspace, which is unacceptable.
Convert rtc->char_lock into bit operation.
David says "884b4aaaa242a2db8c8252796f0118164a680ab5 should be reverted. It
added an rtc_merge_alarm() call to the 2.6.20 kernel, which hasn't yet been
used by any in-tree driver; this patch obviates the need for that call, and
uses a more robust approach."
Cc: Scott Wood <scottwood@freescale.com>
Finish converting the RTC framework so it no longer uses class_device.
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
This patch removes class_device from the programming interface that the RTC
framework exposes to the rest of the kernel. Now an rtc_device is passed,
which is more type-safe and streamlines all the relevant code.
This simplifies the /dev support by removing a superfluous class_device (the
/sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc
core. Accordingly, if it's configured then /dev support is now part of the
RTC core, and is never a separate module.
It's another step towards being able to remove "struct class_device".
[bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"]
Add rtc_merge_alarm(), which can be used by rtc drivers to turn a partially
specified alarm expiry (i.e. most significant fields set to -1, as with the
RTC_ALM_SET ioctl()) into a fully specified expiry.
If the most significant specified field is earlier than the current time, the
least significant unspecified field is incremented.
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Update RTC framework so that drivers can constify their method tables, moving
them from ".data" to ".rodata". Then update the drivers.
This corrects the comments describing the 'enabled' and 'pending' flags in
struct rtc_wkalrm of include/linux/rtc.h.
Signed-off-by: Andrew Victor <andrew@sanpeople.com>
RTC: Add exported function rtc_year_days() to calculate the tm_yday value.
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in
the drivers.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Import genrtc's RTC UIE emulation (CONFIG_GEN_RTC_X) to rtc-dev driver with
slight adjustments/refinements. This makes UIE-less rtc drivers work
better with programs doing read/poll on /dev/rtc, such as hwclock. This
emulation should not harm rtc drivers with UIE support, since
rtc_dev_ioctl() calls underlaying rtc driver's ioctl() first.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Add the basic RTC subsystem infrastructure to the kernel.
rtc/class.c - registration facilities for RTC drivers
rtc/interface.c - kernel/rtc interface functions
rtc/hctosys.c - snippet of code that copies hw clock to sw clock
at bootup, if configured to do so.
RTC and date/time related functions.
Git patch 52dfa9a64cfb3dd01fa1ee1150d589481e54e28e
[PATCH] move rtc_interrupt() prototype to rtc.h
broke strace(1) builds. The below moves the kernel-only additions lower,
under the already provided #ifdef __KERNEL__ statement.
Cc: <stable@kernel.org>
This patch moves the rtc_interrupt() prototype to rtc.h and removes the
prototypes from C files.
It also renames static rtc_interrupt() functions in
arch/arm/mach-integrator/time.c and arch/sh64/kernel/time.c to avoid compile
problems.
Signed-off-by: Paul Gortmaker <p_gortmaker@yahoo.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
infrastructure for it.
Let it rip!
