It acts exactly like a regular 'cond_resched()', but will not get
optimized away when CONFIG_PREEMPT is set.
Normal kernel code is already preemptable in the presense of
CONFIG_PREEMPT, so cond_resched() is optimized away (see commit
02b67cc3ba36bdba351d6c3a00593f4ec550d9d3 "sched: do not do
cond_resched() when CONFIG_PREEMPT").
But when wanting to conditionally reschedule while holding a lock, you
need to use "cond_sched_lock(lock)", and the new function is the BKL
equivalent of that.
Also make fs/locks.c use it.
this replaces the rq->clock stuff (and possibly cpu_clock()).
- architectures that have an 'imperfect' hardware clock can set
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK
- the 'jiffie' window might be superfulous when we update tick_gtod
before the __update_sched_clock() call in sched_clock_tick()
- cpu_clock() might be implemented as:
sched_clock_cpu(smp_processor_id())
if the accuracy proves good enough - how far can TSC drift in a
single jiffie when considering the filtering and idle hooks?
[ mingo@elte.hu: various fixes and cleanups ]
make time_sync_thresh tunable to architecture code.
Dmitry Adamushko pointed out a logic error in task_wake_up_rt() where we
will always evaluate to "true". You can find the thread here:
http://lkml.org/lkml/2008/4/22/296
In reality, we only want to try to push tasks away when a wake up request is
not going to preempt the current task. So lets fix it.
Note: We introduce test_tsk_need_resched() instead of open-coding the flag
check so that the merge-conflict with -rt should help remind us that we
may need to support NEEDS_RESCHED_DELAYED in the future, too.
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
CC: Dmitry Adamushko <dmitry.adamushko@gmail.com>
CC: Steven Rostedt <rostedt@goodmis.org>
There are some places that are known to operate on tasks'
global pids only:
* the rest_init() call (called on boot)
* the kgdb's getthread
* the create_kthread() (since the kthread is run in init ns)
So use the find_task_by_pid_ns(..., &init_pid_ns) there
and schedule the find_task_by_pid for removal.
[sukadev@us.ibm.com: Fix warning in kernel/pid.c]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Change all the #ifdef TIF_RESTORE_SIGMASK conditionals in non-arch code to
#ifdef HAVE_SET_RESTORE_SIGMASK. If arch code defines it first, the generic
set_restore_sigmask() using TIF_RESTORE_SIGMASK is not defined.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: "Luck, Tony" <tony.luck@intel.com>
The global init has a lot of long standing problems with the unhandled fatal
signals.
- The "is_global_init(current)" check in get_signal_to_deliver()
protects only the main thread. Sub-thread can dequee the fatal
signal and shutdown the whole thread group except the main thread.
If it dequeues SIGSTOP /sbin/init will be stopped, this is not
right too. Note that we can't use is_global_init(->group_leader),
this breaks exec and this can't solve other problems we have.
- Even if afterwards ignored, the fatal signals sets SIGNAL_GROUP_EXIT
on delivery. This breaks exec, has other bad implications, and this
is just wrong.
Introduce the new SIGNAL_UNKILLABLE flag to fix these problems. It also helps
to solve some other problems addressed by the subsequent patches.
Currently we use this flag for the global init only, but it could also be used
by kthreads and (perhaps) by the sub-namespace inits.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Roland McGrath <roland@redhat.com>
We export send_sigqueue() and send_group_sigqueue() for the only user,
posix_timer_event(). This is a bit silly, because both are just trivial
helpers on top of do_send_sigqueue() and because the we pass the unused
.si_signo parameter.
Kill them both, rename do_send_sigqueue() to send_sigqueue(), and export it.
Based on discussion with Jiri and Roland.
In short: currently handle_stop_signal(SIGCONT, p) sends the notification to
p->parent, with this patch p itself notifies its parent when it becomes
running.
handle_stop_signal(SIGCONT) has to drop ->siglock temporary in order to notify
the parent with do_notify_parent_cldstop(). This leads to multiple problems:
- as Jiri Kosina pointed out, the stopped task can resume without
actually seeing SIGCONT which may have a handler.
- we race with another sig_kernel_stop() signal which may come in
that window.
- we race with sig_fatal() signals which may set SIGNAL_GROUP_EXIT
in that window.
- we can't avoid taking tasklist_lock() while sending SIGCONT.
With this patch handle_stop_signal() just sets the new SIGNAL_CLD_CONTINUED
flag in p->signal->flags and returns. The notification is sent by the first
task which returns from finish_stop() (there should be at least one) or any
other signalled thread from get_signal_to_deliver().
This is a user-visible change. Say, currently kill(SIGCONT, stopped_child)
can't return without seeing SIGCHLD, with this patch SIGCHLD can be delayed
unpredictably. Another difference is that if the child is ptraced by another
process, CLD_CONTINUED may be delivered to ->real_parent after ptrace_detach()
while currently it always goes to the tracer which doesn't actually need this
notification. Hopefully not a problem.
The patch asks for the futher obvious cleanups, I'll send them separately.
Cc: Jiri Kosina <jkosina@suse.cz>
Remove the mem_cgroup member from mm_struct and instead adds an owner.
This approach was suggested by Paul Menage. The advantage of this approach
is that, once the mm->owner is known, using the subsystem id, the cgroup
can be determined. It also allows several control groups that are
virtually grouped by mm_struct, to exist independent of the memory
controller i.e., without adding mem_cgroup's for each controller, to
mm_struct.
A new config option CONFIG_MM_OWNER is added and the memory resource
controller selects this config option.
This patch also adds cgroup callbacks to notify subsystems when mm->owner
changes. The mm_cgroup_changed callback is called with the task_lock() of
the new task held and is called just prior to changing the mm->owner.
I am indebted to Paul Menage for the several reviews of this patchset and
helping me make it lighter and simpler.
This patch was tested on a powerpc box, it was compiled with both the
MM_OWNER config turned on and off.
After the thread group leader exits, it's moved to init_css_state by
cgroup_exit(), thus all future charges from runnings threads would be
redirected to the init_css_set's subsystem.
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Pavel Emelianov <xemul@openvz.org>
Cc: Hugh Dickins <hugh@veritas.com>
Cc: Sudhir Kumar <skumar@linux.vnet.ibm.com>
Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Cc: Hirokazu Takahashi <taka@valinux.co.jp>
Cc: David Rientjes <rientjes@google.com>,
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Reviewed-by: Paul Menage <menage@google.com>
Filesystem capability support makes it possible to do away with (set)uid-0
based privilege and use capabilities instead. That is, with filesystem
support for capabilities but without this present patch, it is (conceptually)
possible to manage a system with capabilities alone and never need to obtain
privilege via (set)uid-0.
Of course, conceptually isn't quite the same as currently possible since few
user applications, certainly not enough to run a viable system, are currently
prepared to leverage capabilities to exercise privilege. Further, many
applications exist that may never get upgraded in this way, and the kernel
will continue to want to support their setuid-0 base privilege needs.
Where pure-capability applications evolve and replace setuid-0 binaries, it is
desirable that there be a mechanisms by which they can contain their
privilege. In addition to leveraging the per-process bounding and inheritable
sets, this should include suppressing the privilege of the uid-0 superuser
from the process' tree of children.
The feature added by this patch can be leveraged to suppress the privilege
associated with (set)uid-0. This suppression requires CAP_SETPCAP to
initiate, and only immediately affects the 'current' process (it is inherited
through fork()/exec()). This reimplementation differs significantly from the
historical support for securebits which was system-wide, unwieldy and which
has ultimately withered to a dead relic in the source of the modern kernel.
With this patch applied a process, that is capable(CAP_SETPCAP), can now drop
all legacy privilege (through uid=0) for itself and all subsequently
fork()'d/exec()'d children with:
prctl(PR_SET_SECUREBITS, 0x2f);
This patch represents a no-op unless CONFIG_SECURITY_FILE_CAPABILITIES is
enabled at configure time.
[akpm@linux-foundation.org: fix uninitialised var warning]
[serue@us.ibm.com: capabilities: use cap_task_prctl when !CONFIG_SECURITY]
Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Reviewed-by: James Morris <jmorris@namei.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Paul Moore <paul.moore@hp.com>
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
The SIE instruction on s390 uses the 2nd half of the page table page to
virtualize the storage keys of a guest. This patch offers the s390_enable_sie
function, which reorganizes the page tables of a single-threaded process to
reserve space in the page table:
s390_enable_sie makes sure that the process is single threaded and then uses
dup_mm to create a new mm with reorganized page tables. The old mm is freed
and the process has now a page status extended field after every page table.
Code that wants to exploit pgstes should SELECT CONFIG_PGSTE.
This patch has a small common code hit, namely making dup_mm non-static.
Edit (Carsten): I've modified Martin's patch, following Jeremy Fitzhardinge's
review feedback. Now we do have the prototype for dup_mm in
include/linux/sched.h. Following Martin's suggestion, s390_enable_sie() does now
call task_lock() to prevent race against ptrace modification of mm_users.
Signed-off-by: Carsten Otte <cotte@de.ibm.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Some architectures need to maintain a kmem cache for thread info
structures. The next commit adds that to powerpc to fix an alignment
problem.
There is no good arch callback to use to initialize that cache
that I can find, so this adds a new one in the form of a weak
function whose default is empty.
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc
* 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc:
Deprecate the asm/semaphore.h files in feature-removal-schedule.
Convert asm/semaphore.h users to linux/semaphore.h
security: Remove unnecessary inclusions of asm/semaphore.h
lib: Remove unnecessary inclusions of asm/semaphore.h
kernel: Remove unnecessary inclusions of asm/semaphore.h
include: Remove unnecessary inclusions of asm/semaphore.h
fs: Remove unnecessary inclusions of asm/semaphore.h
drivers: Remove unnecessary inclusions of asm/semaphore.h
net: Remove unnecessary inclusions of asm/semaphore.h
arch: Remove unnecessary inclusions of asm/semaphore.h
De-couple load-balancing from the rb-trees, so that I can change their
organization.
Now that the group hierarchy can have an arbitrary depth the O(n^2) nature
of RT task dequeues will really hurt. Optimize this by providing space to
store the tree path, so we can walk it the other way.
Implement SMP nice support for the full group hierarchy.
On each load-balance action, compile a sched_domain wide view of the full
task_group tree. We compute the domain wide view when walking down the
hierarchy, and readjust the weights when walking back up.
After collecting and readjusting the domain wide view, we try to balance the
tasks within the task_groups. The current approach is a naively balance each
task group until we've moved the targeted amount of load.
Inspired by Srivatsa Vaddsgiri's previous code and Abhishek Chandra's H-SMP
paper.
XXX: there will be some numerical issues due to the limited nature of
SCHED_LOAD_SCALE wrt to representing a task_groups influence on the
total weight. When the tree is deep enough, or the task weight small
enough, we'll run out of bits.
CC: Abhishek Chandra <chandra@cs.umn.edu>
CC: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
[rebased for sched-devel/latest]
- Add a new cpuset file, having levels:
sched_relax_domain_level
- Modify partition_sched_domains() and build_sched_domains()
to take attributes parameter passed from cpuset.
- Fill newidle_idx for node domains which currently unused but
might be required if sched_relax_domain_level become higher.
- We can change the default level by boot option 'relax_domain_level='.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
UID grouping doesn't actually have a task_group representing the root of
the task_group tree. Add one.
This patch makes the group scheduler multi hierarchy aware.
[a.p.zijlstra@chello.nl: rt-parts and assorted fixes]
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Add a new function that accepts a pointer to the "newly allowed cpus"
cpumask argument.
int set_cpus_allowed_ptr(struct task_struct *p, const cpumask_t *new_mask)
The current set_cpus_allowed() function is modified to use the above
but this does not result in an ABI change. And with some compiler
optimization help, it may not introduce any additional overhead.
Additionally, to enforce the read only nature of the new_mask arg, the
"const" property is migrated to sub-functions called by set_cpus_allowed.
This silences compiler warnings.
Signed-off-by: Mike Travis <travis@sgi.com>
* Modify sched_affinity functions to pass cpumask_t variables by reference
instead of by value.
* Use new set_cpus_allowed_ptr function.
Depends on:
[sched-devel]: sched: add new set_cpus_allowed_ptr function
Cc: Paul Jackson <pj@sgi.com>
Cc: Cliff Wickman <cpw@sgi.com>
Various SMP balancing algorithms require that the bandwidth period
run in sync.
Possible improvements are moving the rt_bandwidth thing into root_domain
and keeping a span per rt_bandwidth which marks throttled cpus.
it's unused.
None of these files use any of the functionality promised by
asm/semaphore.h. It's possible that they (or some user of them) rely
on it dragging in some unrelated header file, but I can't build all
these files, so we'll have to fix any build failures as they come up.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
add_timer_on() can add a timer on a CPU which is currently in a long
idle sleep, but the timer wheel is not reevaluated by the nohz code on
that CPU. So a timer can be delayed for quite a long time. This
triggered a false positive in the clocksource watchdog code.
To avoid this we need to wake up the idle CPU and enforce the
reevaluation of the timer wheel for the next timer event.
Add a function, which checks a given CPU for idle state, marks the
idle task with NEED_RESCHED and sends a reschedule IPI to notify the
other CPU of the change in the timer wheel.
Call this function from add_timer_on().
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: stable@kernel.org
include/linux/sched.h | 6 ++++++
kernel/sched.c | 43 +++++++++++++++++++++++++++++++++++++++++++
kernel/timer.c | 10 +++++++++-
3 files changed, 58 insertions(+), 1 deletion(-)
Needed so it can be called from outside of sched.c.
improve affine wakeups. Maintain the 'overlap' metric based on CFS's
sum_exec_runtime - which means the amount of time a task executes
after it wakes up some other task.
Use the 'overlap' for the wakeup decisions: if the 'overlap' is short,
it means there's strong workload coupling between this task and the
woken up task. If the 'overlap' is large then the workload is decoupled
and the scheduler will move them to separate CPUs more easily.
( Also slightly move the preempt_check within try_to_wake_up() - this has
no effect on functionality but allows 'early wakeups' (for still-on-rq
tasks) to be correctly accounted as well.)
Kei Tokunaga reported an interactivity problem when moving tasks
between control groups.
Tasks would retain their old vruntime when moved between groups, this
can cause funny lags. Re-set the vruntime on group move to fit within
the new tree.
Reported-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com>
The following commits cause a number of regressions:
commit 58e2d4ca581167c2a079f4ee02be2f0bc52e8729
Author: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Date: Fri Jan 25 21:08:00 2008 +0100
sched: group scheduling, change how cpu load is calculated
commit 6b2d7700266b9402e12824e11e0099ae6a4a6a79
sched: group scheduler, fix fairness of cpu bandwidth allocation for task groups
Namely:
- very frequent wakeups on SMP, reported by PowerTop users.
- cacheline trashing on (large) SMP
- some latencies larger than 500ms
While there is a mergeable patch to fix the latter, the former issues
are not fixable in a manner suitable for .25 (we're at -rc3 now).
Hence we revert them and try again in v2.6.26.
Tested-by: Alexey Zaytsev <alexey.zaytsev@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep
* 'v2.6.25-rc3-lockdep' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep:
Subject: lockdep: include all lock classes in all_lock_classes
lockdep: increase MAX_LOCK_DEPTH
Some code paths exceed the current max lock depth (XFS), so increase
this limit a bit. I looked at making this a dynamic allocated array,
but we should not advocate insane lock depths, so stay with this as
long as it works...
Avoids sparse warnings:
kernel/sched.c:2170:17: warning: symbol 'schedule_tail' was not declared. Should it be static?
Avoids the need for an external declaration in arch/um/process.c
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
FASTCALL() is always expanded to empty, remove it.
Make the rt group scheduler compile time configurable.
Keep it experimental for now.
Change the rt_ratio interface to rt_runtime_us, to match rt_period_us.
This avoids picking a granularity for the ratio.
Extend the /sys/kernel/uids/<uid>/ interface to allow setting
the group's rt_runtime.
There's only one caller left - the kill_pgrp one - so merge these two
functions and forget the kill_pgrp_info one.
Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru>
signal_struct->tsk points to the ->group_leader and thus we have the nasty
code in de_thread() which has to change it and restart ->real_timer if the
leader is changed.
Use "struct pid *leader_pid" instead. This also allows us to kill now
unneeded send_group_sig_info().
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Roland McGrath <roland@redhat.com>
pid_vnr returns the user space pid with respect to the pid namespace the
struct pid was allocated in. What we want before we return a pid to user
space is the user space pid with respect to the pid namespace of current.
pid_vnr is a very nice optimization but because it isn't quite what we want
it is easy to use pid_vnr at times when we aren't certain the struct pid
was allocated in our pid namespace.
Currently this describes at least tiocgpgrp and tiocgsid in ttyio.c the
parent process reported in the core dumps and the parent process in
get_signal_to_deliver.
So unless the performance impact is huge having an interface that does what
we want instead of always what we want should be much more reliable and
much less error prone.
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Change set_special_pids() to work with struct pid, not pid_t from global name
space. This again speedups and imho cleanups the code, also a preparation for
the next patch.
Basic setup routines, the mm_struct has a pointer to the cgroup that
it belongs to and the the page has a page_cgroup associated with it.
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Cc: Paul Menage <menage@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Herbert Poetzl <herbert@13thfloor.at>
groups_sort() can be quite long if user loads a large gid table.
This is because GROUP_AT(group_info, some_integer) uses an integer divide.
So having to do XXX thousand divides during one syscall can lead to very
high latencies. (NGROUPS_MAX=65536)
In the past (25 Mar 2006), an analog problem was found in groups_search()
(commit d74beb9f33a5f16d2965f11b275e401f225c949d ) and at that time I
changed some variables to unsigned int.
I believe that a more generic fix is to make sure NGROUPS_PER_BLOCK is
unsigned.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
The capability bounding set is a set beyond which capabilities cannot grow.
Currently cap_bset is per-system. It can be manipulated through sysctl,
but only init can add capabilities. Root can remove capabilities. By
default it includes all caps except CAP_SETPCAP.
This patch makes the bounding set per-process when file capabilities are
enabled. It is inherited at fork from parent. Noone can add elements,
CAP_SETPCAP is required to remove them.
One example use of this is to start a safer container. For instance, until
device namespaces or per-container device whitelists are introduced, it is
best to take CAP_MKNOD away from a container.
The bounding set will not affect pP and pE immediately. It will only
affect pP' and pE' after subsequent exec()s. It also does not affect pI,
and exec() does not constrain pI'. So to really start a shell with no way
of regain CAP_MKNOD, you would do
prctl(PR_CAPBSET_DROP, CAP_MKNOD);
cap_t cap = cap_get_proc();
cap_value_t caparray[1];
caparray[0] = CAP_MKNOD;
cap_set_flag(cap, CAP_INHERITABLE, 1, caparray, CAP_DROP);
cap_set_proc(cap);
cap_free(cap);
The following test program will get and set the bounding
set (but not pI). For instance
./bset get
(lists capabilities in bset)
./bset drop cap_net_raw
(starts shell with new bset)
(use capset, setuid binary, or binary with
file capabilities to try to increase caps)
cap_bound.c
#include <sys/prctl.h>
#include <linux/capability.h>
#include <sys/types.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#ifndef PR_CAPBSET_READ
#define PR_CAPBSET_READ 23
#endif
#ifndef PR_CAPBSET_DROP
#define PR_CAPBSET_DROP 24
#endif
int usage(char *me)
printf("Usage: %s get\n", me);
printf(" %s drop <capability>\n", me);
return 1;
#define numcaps 32
char *captable[numcaps] = {
"cap_chown",
"cap_dac_override",
"cap_dac_read_search",
"cap_fowner",
"cap_fsetid",
"cap_kill",
"cap_setgid",
"cap_setuid",
"cap_setpcap",
"cap_linux_immutable",
"cap_net_bind_service",
"cap_net_broadcast",
"cap_net_admin",
"cap_net_raw",
"cap_ipc_lock",
"cap_ipc_owner",
"cap_sys_module",
"cap_sys_rawio",
"cap_sys_chroot",
"cap_sys_ptrace",
"cap_sys_pacct",
"cap_sys_admin",
"cap_sys_boot",
"cap_sys_nice",
"cap_sys_resource",
"cap_sys_time",
"cap_sys_tty_config",
"cap_mknod",
"cap_lease",
"cap_audit_write",
"cap_audit_control",
"cap_setfcap"
int getbcap(void)
int comma=0;
unsigned long i;
int ret;
printf("i know of %d capabilities\n", numcaps);
printf("capability bounding set:");
for (i=0; i<numcaps; i++) {
ret = prctl(PR_CAPBSET_READ, i);
if (ret < 0)
perror("prctl");
else if (ret==1)
printf("%s%s", (comma++) ? ", " : " ", captable[i]);
printf("\n");
return 0;
int capdrop(char *str)
unsigned long i;
int found=0;
if (strcmp(captable[i], str) == 0) {
found=1;
break;
if (!found)
return 1;
if (prctl(PR_CAPBSET_DROP, i)) {
perror("prctl");
return 1;
return 0;
int main(int argc, char *argv[])
if (argc<2)
return usage(argv[0]);
if (strcmp(argv[1], "get")==0)
return getbcap();
if (strcmp(argv[1], "drop")!=0 || argc<3)
if (capdrop(argv[2])) {
printf("unknown capability\n");
return 1;
return execl("/bin/bash", "/bin/bash", NULL);
[serue@us.ibm.com: fix typo]
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Casey Schaufler <casey@schaufler-ca.com>a
Signed-off-by: "Serge E. Hallyn" <serue@us.ibm.com>
Tested-by: Jiri Slaby <jirislaby@gmail.com>
The following replaces the earlier patches sent. It should address
David Rientjes's comments, and has been compile tested on all the
architectures that it touches, save for parisc.
For the /proc/<pid>/pagemap code[1], we need to able to query how
much virtual address space a particular task has. The trick is
that we do it through /proc and can't use TASK_SIZE since it
references "current" on some arches. The process opening the
/proc file might be a 32-bit process opening a 64-bit process's
pagemap file.
x86_64 already has a TASK_SIZE_OF() macro:
#define TASK_SIZE_OF(child) ((test_tsk_thread_flag(child, TIF_IA32)) ? IA32_PAGE_OFFSET : TASK_SIZE64)
I'd like to have that for other architectures. So, add it
for all the architectures that actually use "current" in
their TASK_SIZE. For the others, just add a quick #define
in sched.h to use plain old TASK_SIZE.
1. http://www.linuxworld.com/news/2007/042407-kernel.html
- MIPS portion from Ralf Baechle <ralf@linux-mips.org>
[akpm@linux-foundation.org: fix mips build]
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
Signed-off-by: Matt Mackall <mpm@selenic.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
As Roland pointed out, we have the very old problem with exec. de_thread()
sets SIGNAL_GROUP_EXIT, kills other threads, changes ->group_leader and then
clears signal->flags. All signals (even fatal ones) sent in this window
(which is not too small) will be lost.
With this patch exec doesn't abuse SIGNAL_GROUP_EXIT. signal_group_exit(),
the new helper, should be used to detect exit_group() or exec() in progress.
It can have more users, but this patch does only strictly necessary changes.
Cc: Robin Holt <holt@sgi.com>
It was dumb to make get_task_comm() return void. Change it to return a
pointer to the resulting output for caller convenience.
Cc: Ulrich Drepper <drepper@redhat.com>
In order to correlate audit records to an individual login add a session
id. This is incremented every time a user logs in and is included in
almost all messages which currently output the auid. The field is
labeled ses= or oses=
Signed-off-by: Eric Paris <eparis@redhat.com>
Keeping loginuid in audit_context is racy and results in messier
code. Taken to task_struct, out of the way of ->audit_context
changes.
* 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits)
Remove commented-out code copied from NFS
NFS: Switch from intr mount option to TASK_KILLABLE
Add wait_for_completion_killable
Add wait_event_killable
Add schedule_timeout_killable
Use mutex_lock_killable in vfs_readdir
Add mutex_lock_killable
Use lock_page_killable
Add lock_page_killable
Add fatal_signal_pending
Add TASK_WAKEKILL
exit: Use task_is_*
signal: Use task_is_*
sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL
ptrace: Use task_is_*
power: Use task_is_*
wait: Use TASK_NORMAL
proc/base.c: Use task_is_*
proc/array.c: Use TASK_REPORT
perfmon: Use task_is_*
Fixed up conflicts in NFS/sunrpc manually..
The break_lock data structure and code for spinlocks is quite nasty.
Not only does it double the size of a spinlock but it changes locking to
a potentially less optimal trylock.
Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a
__raw_spin_is_contended that uses the lock data itself to determine whether
there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is
not set.
Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to
decouple it from the spinlock implementation, and make it typesafe (rwlocks
do not have any need_lockbreak sites -- why do they even get bloated up
with that break_lock then?).
Signed-off-by: Nick Piggin <npiggin@suse.de>
