commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82 upstream.
Cleanup and preparation for the next change.
signal_wake_up(resume => true) is overused. None of ptrace/jctl callers
actually want to wakeup a TASK_WAKEKILL task, but they can't specify the
necessary mask.
Turn signal_wake_up() into signal_wake_up_state(state), reintroduce
signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up()
which adds __TASK_TRACED.
This way ptrace_signal_wake_up() can work "inside" ptrace_request()
even if the tracee doesn't have the TASK_WAKEKILL bit set.
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull generic execve() changes from Al Viro:
"This introduces the generic kernel_thread() and kernel_execve()
functions, and switches x86, arm, alpha, um and s390 over to them."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (26 commits)
s390: convert to generic kernel_execve()
s390: switch to generic kernel_thread()
s390: fold kernel_thread_helper() into ret_from_fork()
s390: fold execve_tail() into start_thread(), convert to generic sys_execve()
um: switch to generic kernel_thread()
x86, um/x86: switch to generic sys_execve and kernel_execve
x86: split ret_from_fork
alpha: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
alpha: switch to generic kernel_thread()
alpha: switch to generic sys_execve()
arm: get rid of execve wrapper, switch to generic execve() implementation
arm: optimized current_pt_regs()
arm: introduce ret_from_kernel_execve(), switch to generic kernel_execve()
arm: split ret_from_fork, simplify kernel_thread() [based on patch by rmk]
new helper: current_pt_regs()
preparation for generic kernel_thread()
um: kill thread->forking
um: let signal_delivered() do SIGTRAP on singlestepping into handler
The deprecated /proc/<pid>/oom_adj is scheduled for removal this month.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
Acked-by: David Rientjes <rientjes@google.com>
Create a new header file, fs/coredump.h, which contains functions only
used by the new coredump.c. It also moves do_coredump to the
include/linux/coredump.h header file, for consistency.
Signed-off-by: Alex Kelly <alex.page.kelly@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
This prepares for making core dump functionality optional.
The variable "suid_dumpable" and associated functions are left in fs/exec.c
because they're used elsewhere, such as in ptrace.
Pull networking changes from David Miller:
1) GRE now works over ipv6, from Dmitry Kozlov.
2) Make SCTP more network namespace aware, from Eric Biederman.
3) TEAM driver now works with non-ethernet devices, from Jiri Pirko.
4) Make openvswitch network namespace aware, from Pravin B Shelar.
5) IPV6 NAT implementation, from Patrick McHardy.
6) Server side support for TCP Fast Open, from Jerry Chu and others.
7) Packet BPF filter supports MOD and XOR, from Eric Dumazet and Daniel
Borkmann.
8) Increate the loopback default MTU to 64K, from Eric Dumazet.
9) Use a per-task rather than per-socket page fragment allocator for
outgoing networking traffic. This benefits processes that have very
many mostly idle sockets, which is quite common.
From Eric Dumazet.
10) Use up to 32K for page fragment allocations, with fallbacks to
smaller sizes when higher order page allocations fail. Benefits are
a) less segments for driver to process b) less calls to page
allocator c) less waste of space.
From Eric Dumazet.
11) Allow GRO to be used on GRE tunnels, from Eric Dumazet.
12) VXLAN device driver, one way to handle VLAN issues such as the
limitation of 4096 VLAN IDs yet still have some level of isolation.
From Stephen Hemminger.
13) As usual there is a large boatload of driver changes, with the scale
perhaps tilted towards the wireless side this time around.
Fix up various fairly trivial conflicts, mostly caused by the user
namespace changes.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1012 commits)
hyperv: Add buffer for extended info after the RNDIS response message.
hyperv: Report actual status in receive completion packet
hyperv: Remove extra allocated space for recv_pkt_list elements
hyperv: Fix page buffer handling in rndis_filter_send_request()
hyperv: Fix the missing return value in rndis_filter_set_packet_filter()
hyperv: Fix the max_xfer_size in RNDIS initialization
vxlan: put UDP socket in correct namespace
vxlan: Depend on CONFIG_INET
sfc: Fix the reported priorities of different filter types
sfc: Remove EFX_FILTER_FLAG_RX_OVERRIDE_IP
sfc: Fix loopback self-test with separate_tx_channels=1
sfc: Fix MCDI structure field lookup
sfc: Add parentheses around use of bitfield macro arguments
sfc: Fix null function pointer in efx_sriov_channel_type
vxlan: virtual extensible lan
igmp: export symbol ip_mc_leave_group
netlink: add attributes to fdb interface
tg3: unconditionally select HWMON support when tg3 is enabled.
Revert "net: ti cpsw ethernet: allow reading phy interface mode from DT"
gre: fix sparse warning
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
Pull scheduler changes from Ingo Molnar:
"Continued quest to clean up and enhance the cputime code by Frederic
Weisbecker, in preparation for future tickless kernel features.
Other than that, smallish changes."
Fix up trivial conflicts due to additions next to each other in arch/{x86/}Kconfig
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits)
cputime: Make finegrained irqtime accounting generally available
cputime: Gather time/stats accounting config options into a single menu
ia64: Reuse system and user vtime accounting functions on task switch
ia64: Consolidate user vtime accounting
vtime: Consolidate system/idle context detection
cputime: Use a proper subsystem naming for vtime related APIs
sched: cpu_power: enable ARCH_POWER
sched/nohz: Clean up select_nohz_load_balancer()
sched: Fix load avg vs. cpu-hotplug
sched: Remove __ARCH_WANT_INTERRUPTS_ON_CTXSW
sched: Fix nohz_idle_balance()
sched: Remove useless code in yield_to()
sched: Add time unit suffix to sched sysctl knobs
sched/debug: Limit sd->*_idx range on sysctl
sched: Remove AFFINE_WAKEUPS feature flag
s390: Remove leftover account_tick_vtime() header
cputime: Consolidate vtime handling on context switch
sched: Move cputime code to its own file
cputime: Generalize CONFIG_VIRT_CPU_ACCOUNTING
tile: Remove SD_PREFER_LOCAL leftover
Pull perf update from Ingo Molnar:
"Lots of changes in this cycle as well, with hundreds of commits from
over 30 contributors. Most of the activity was on the tooling side.
Higher level changes:
- New 'perf kvm' analysis tool, from Xiao Guangrong.
- New 'perf trace' system-wide tracing tool
- uprobes fixes + cleanups from Oleg Nesterov.
- Lots of patches to make perf build on Android out of box, from
Irina Tirdea
- Extend ftrace function tracing utility to be more dynamic for its
users. It allows for data passing to the callback functions, as
well as reading regs as if a breakpoint were to trigger at function
entry.
The main goal of this patch series was to allow kprobes to use
ftrace as an optimized probe point when a probe is placed on an
ftrace nop. With lots of help from Masami Hiramatsu, and going
through lots of iterations, we finally came up with a good
solution.
- Add cpumask for uncore pmu, use it in 'stat', from Yan, Zheng.
- Various tracing updates from Steve Rostedt
- Clean up and improve 'perf sched' performance by elliminating lots
of needless calls to libtraceevent.
- Event group parsing support, from Jiri Olsa
- UI/gtk refactorings and improvements from Namhyung Kim
- Add support for non-tracepoint events in perf script python, from
Feng Tang
- Add --symbols to 'script', similar to the one in 'report', from
Feng Tang.
Infrastructure enhancements and fixes:
- Convert the trace builtins to use the growing evsel/evlist
tracepoint infrastructure, removing several open coded constructs
like switch like series of strcmp to dispatch events, etc.
Basically what had already been showcased in 'perf sched'.
- Add evsel constructor for tracepoints, that uses libtraceevent just
to parse the /format events file, use it in a new 'perf test' to
make sure the libtraceevent format parsing regressions can be more
readily caught.
- Some strange errors were happening in some builds, but not on the
next, reported by several people, problem was some parser related
files, generated during the build, didn't had proper make deps, fix
from Eric Sandeen.
- Introduce struct and cache information about the environment where
a perf.data file was captured, from Namhyung Kim.
- Fix handling of unresolved samples when --symbols is used in
'report', from Feng Tang.
- Add union member access support to 'probe', from Hyeoncheol Lee.
- Fixups to die() removal, from Namhyung Kim.
- Render fixes for the TUI, from Namhyung Kim.
- Don't enable annotation in non symbolic view, from Namhyung Kim.
- Fix pipe mode in 'report', from Namhyung Kim.
- Move related stats code from stat to util/, will be used by the
'stat' kvm tool, from Xiao Guangrong.
- Remove die()/exit() calls from several tools.
- Resolve vdso callchains, from Jiri Olsa
- Don't pass const char pointers to basename, so that we can
unconditionally use libgen.h and thus avoid ifdef BIONIC lines,
from David Ahern
- Refactor hist formatting so that it can be reused with the GTK
browser, From Namhyung Kim
- Fix build for another rbtree.c change, from Adrian Hunter.
- Make 'perf diff' command work with evsel hists, from Jiri Olsa.
- Use the only field_sep var that is set up: symbol_conf.field_sep,
fix from Jiri Olsa.
- .gitignore compiled python binaries, from Namhyung Kim.
- Get rid of die() in more libtraceevent places, from Namhyung Kim.
- Rename libtraceevent 'private' struct member to 'priv' so that it
works in C++, from Steven Rostedt
- Remove lots of exit()/die() calls from tools so that the main perf
exit routine can take place, from David Ahern
- Fix x86 build on x86-64, from David Ahern.
- {int,str,rb}list fixes from Suzuki K Poulose
- perf.data header fixes from Namhyung Kim
- Allow user to indicate objdump path, needed in cross environments,
from Maciek Borzecki
- Fix hardware cache event name generation, fix from Jiri Olsa
- Add round trip test for sw, hw and cache event names, catching the
problem Jiri fixed, after Jiri's patch, the test passes
successfully.
- Clean target should do clean for lib/traceevent too, fix from David
Ahern
- Check the right variable for allocation failure, fix from Namhyung
Kim
- Set up evsel->tp_format regardless of evsel->name being set
already, fix from Namhyung Kim
- Oprofile fixes from Robert Richter.
- Remove perf_event_attr needless version inflation, from Jiri Olsa
- Introduce libtraceevent strerror like error reporting facility,
from Namhyung Kim
- Add pmu mappings to perf.data header and use event names from cmd
line, from Robert Richter
- Fix include order for bison/flex-generated C files, from Ben
Hutchings
- Build fixes and documentation corrections from David Ahern
- Assorted cleanups from Robert Richter
- Let O= makes handle relative paths, from Steven Rostedt
- perf script python fixes, from Feng Tang.
- Initial bash completion support, from Frederic Weisbecker
- Allow building without libelf, from Namhyung Kim.
- Support DWARF CFI based unwind to have callchains when %bp based
unwinding is not possible, from Jiri Olsa.
- Symbol resolution fixes, while fixing support PPC64 files with an
.opt ELF section was the end goal, several fixes for code that
handles all architectures and cleanups are included, from Cody
Schafer.
- Assorted fixes for Documentation and build in 32 bit, from Robert
Richter
- Cache the libtraceevent event_format associated to each evsel
early, so that we avoid relookups, i.e. calling pevent_find_event
repeatedly when processing tracepoint events.
[ This is to reduce the surface contact with libtraceevents and
make clear what is that the perf tools needs from that lib: so
far parsing the common and per event fields. ]
- Don't stop the build if the audit libraries are not installed, fix
from Namhyung Kim.
- Fix bfd.h/libbfd detection with recent binutils, from Markus
Trippelsdorf.
- Improve warning message when libunwind devel packages not present,
from Jiri Olsa"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (282 commits)
perf trace: Add aliases for some syscalls
perf probe: Print an enum type variable in "enum variable-name" format when showing accessible variables
perf tools: Check libaudit availability for perf-trace builtin
perf hists: Add missing period_* fields when collapsing a hist entry
perf trace: New tool
perf evsel: Export the event_format constructor
perf evsel: Introduce rawptr() method
perf tools: Use perf_evsel__newtp in the event parser
perf evsel: The tracepoint constructor should store sys:name
perf evlist: Introduce set_filter() method
perf evlist: Renane set_filters method to apply_filters
perf test: Add test to check we correctly parse and match syscall open parms
perf evsel: Handle endianity in intval method
perf evsel: Know if byte swap is needed
perf tools: Allow handling a NULL cpu_map as meaning "all cpus"
perf evsel: Improve tracepoint constructor setup
tools lib traceevent: Fix error path on pevent_parse_event
perf test: Fix build failure
trace: Move trace event enable from fs_initcall to core_initcall
tracing: Add an option for disabling markers
Let architectures select GENERIC_KERNEL_THREAD and have their copy_thread()
treat NULL regs as "it came from kernel_thread(), sp argument contains
the function new thread will be calling and stack_size - the argument for
that function". Switching the architectures begins shortly...
drivers/net/team/team.c
drivers/net/usb/qmi_wwan.c
net/batman-adv/bat_iv_ogm.c
net/ipv4/fib_frontend.c
net/ipv4/route.c
net/l2tp/l2tp_netlink.c
The team, fib_frontend, route, and l2tp_netlink conflicts were simply
overlapping changes.
qmi_wwan and bat_iv_ogm were of the "use HEAD" variety.
With help from Antonio Quartulli.
Clear the syscalls hook of a task when it's scheduled out so that if
the task migrates, it doesn't run the syscall slow path on a CPU
that might not need it.
Also set the syscalls hook on the next task if needed.
Cc: Alessio Igor Bogani <abogani@kernel.org>
Cc: Avi Kivity <avi@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Gilad Ben Yossef <gilad@benyossef.com>
Cc: Hakan Akkan <hakanakkan@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Kevin Hilman <khilman@ti.com>
Cc: Max Krasnyansky <maxk@qualcomm.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com>
We currently use a per socket order-0 page cache for tcp_sendmsg()
operations.
This page is used to build fragments for skbs.
Its done to increase probability of coalescing small write() into
single segments in skbs still in write queue (not yet sent)
But it wastes a lot of memory for applications handling many mostly
idle sockets, since each socket holds one page in sk->sk_sndmsg_page
Its also quite inefficient to build TSO 64KB packets, because we need
about 16 pages per skb on arches where PAGE_SIZE = 4096, so we hit
page allocator more than wanted.
This patch adds a per task frag allocator and uses bigger pages,
if available. An automatic fallback is done in case of memory pressure.
(up to 32768 bytes per frag, thats order-3 pages on x86)
This increases TCP stream performance by 20% on loopback device,
but also benefits on other network devices, since 8x less frags are
mapped on transmit and unmapped on tx completion. Alexander Duyck
mentioned a probable performance win on systems with IOMMU enabled.
Its possible some SG enabled hardware cant cope with bigger fragments,
but their ndo_start_xmit() should already handle this, splitting a
fragment in sub fragments, since some arches have PAGE_SIZE=65536
Successfully tested on various ethernet devices.
(ixgbe, igb, bnx2x, tg3, mellanox mlx4)
Cc: Ben Hutchings <bhutchings@solarflare.com>
Cc: Vijay Subramanian <subramanian.vijay@gmail.com>
Cc: Alexander Duyck <alexander.h.duyck@intel.com>
Tested-by: Vijay Subramanian <subramanian.vijay@gmail.com>
Always store audit loginuids in type kuid_t.
Print loginuids by converting them into uids in the appropriate user
namespace, and then printing the resulting uid.
Modify audit_get_loginuid to return a kuid_t.
Modify audit_set_loginuid to take a kuid_t.
Modify /proc/<pid>/loginuid on read to convert the loginuid into the
user namespace of the opener of the file.
Modify /proc/<pid>/loginud on write to convert the loginuid
rom the user namespace of the opener of the file.
Cc: Eric Paris <eparis@redhat.com>
Cc: Paul Moore <paul@paul-moore.com> ?
perturbations"
This reverts commit 970e178985cadbca660feb02f4d2ee3a09f7fdda.
Nikolay Ulyanitsky reported thatthe 3.6-rc5 kernel has a 15-20%
performance drop on PostgreSQL 9.2 on his machine (running "pgbench").
Borislav Petkov was able to reproduce this, and bisected it to this
commit 970e178985ca ("sched: Improve scalability via 'CPU buddies' ...")
apparently because the new single-idle-buddy model simply doesn't find
idle CPU's to reschedule on aggressively enough.
Mike Galbraith suspects that it is likely due to the user-mode spinlocks
in PostgreSQL not reacting well to preemption, but we don't really know
the details - I'll just revert the commit for now.
There are hopefully other approaches to improve scheduler scalability
without it causing these kinds of downsides.
Reported-by: Nikolay Ulyanitsky <lystor@gmail.com>
Bisected-by: Borislav Petkov <bp@alien8.de>
Acked-by: Mike Galbraith <efault@gmx.de>
Add the new MMF_RECALC_UPROBES flag, it means that MMF_HAS_UPROBES
can be false positive after remove_breakpoint() or uprobe_munmap().
It is also set by uprobe_dup_mmap(), this is not optimal but simple.
We could add the new hook, uprobe_dup_vma(), to set MMF_HAS_UPROBES
only if the new mm actually has uprobes, but I don't think this
makes sense.
The next patch will use this flag to clear MMF_HAS_UPROBES.
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
There is no load_balancer to be selected now. It just sets the
state of the nohz tick to stop.
So rename the function, pass the 'cpu' as a parameter and then
remove the useless call from tick_nohz_restart_sched_tick().
[ s/set_nohz_tick_stopped/nohz_balance_enter_idle/g
s/clear_nohz_tick_stopped/nohz_balance_exit_idle/g ]
Signed-off-by: Alex Shi <alex.shi@intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Link: http://lkml.kernel.org/r/1347261059-24747-1-git-send-email-alex.shi@intel.com
Now that the last architecture to use this has stopped doing so (ARM,
thanks Catalin!) we can remove this complexity from the scheduler
core.
Link: http://lkml.kernel.org/n/tip-g9p2a1w81xxbrze25v9zpzbf@git.kernel.org
Add the new MMF_HAS_UPROBES flag. It is set by install_breakpoint()
and it is copied by dup_mmap(), uprobe_pre_sstep_notifier() checks
it to avoid the slow path if the task was never probed. Perhaps it
makes sense to check it in valid_vma(is_register => false) as well.
This needs the new dup_mmap()->uprobe_dup_mmap() hook. We can't use
uprobe_reset_state() or put MMF_HAS_UPROBES into MMF_INIT_MASK, we
need oldmm->mmap_sem to avoid the race with uprobe_register() or
mmap() from another thread.
Currently we never clear this bit, it can be false-positive after
uprobe_unregister() or uprobe_munmap() or if dup_mmap() hits the
probed VM_DONTCOPY vma. But this is fine correctness-wise and has
no effect unless the task hits the non-uprobe breakpoint.
Since power saving code was removed from sched now, the implement
code is out of service in this function, and even pollute other logical.
like, 'want_sd' never has chance to be set '0', that remove the effect
of SD_WAKE_AFFINE here.
So, clean up the obsolete code, includes SD_PREFER_LOCAL.
Link: http://lkml.kernel.org/r/5028F431.6000306@intel.com
Revert commit 45226e9 (NMI watchdog: fix for lockup detector breakage
on resume) which breaks resume from system suspend on my SH7372
Mackerel board (by causing a NULL pointer dereference to happen) and
is generally wrong, because it abuses the CPU hotplug functionality
in a shamelessly blatant way.
The original issue should be addressed through appropriate syscore
resume callback instead.
This is needed to allow network softirq packet processing to make use of
PF_MEMALLOC.
Currently softirq context cannot use PF_MEMALLOC due to it not being
associated with a task, and therefore not having task flags to fiddle with
- thus the gfp to alloc flag mapping ignores the task flags when in
interrupts (hard or soft) context.
Allowing softirqs to make use of PF_MEMALLOC therefore requires some
trickery. This patch borrows the task flags from whatever process happens
to be preempted by the softirq. It then modifies the gfp to alloc flags
mapping to not exclude task flags in softirq context, and modify the
softirq code to save, clear and restore the PF_MEMALLOC flag.
The save and clear, ensures the preempted task's PF_MEMALLOC flag doesn't
leak into the softirq. The restore ensures a softirq's PF_MEMALLOC flag
cannot leak back into the preempted process. This should be safe due to
the following reasons
Softirqs can run on multiple CPUs sure but the same task should not be
executing the same softirq code. Neither should the softirq
handler be preempted by any other softirq handler so the flags
should not leak to an unrelated softirq.
Softirqs re-enable hardware interrupts in __do_softirq() so can be
preempted by hardware interrupts so PF_MEMALLOC is inherited
by the hard IRQ. However, this is similar to a process in
reclaim being preempted by a hardirq. While PF_MEMALLOC is
set, gfp_to_alloc_flags() distinguishes between hard and
soft irqs and avoids giving a hardirq the ALLOC_NO_WATERMARKS
flag.
If the softirq is deferred to ksoftirq then its flags may be used
instead of a normal tasks but as the softirq cannot be preempted,
the PF_MEMALLOC flag does not leak to other code by accident.
[davem@davemloft.net: Document why PF_MEMALLOC is safe]
Cc: Neil Brown <neilb@suse.de>
Cc: Mike Christie <michaelc@cs.wisc.edu>
Cc: Eric B Munson <emunson@mgebm.net>
Cc: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Sanity:
CONFIG_CGROUP_MEM_RES_CTLR -> CONFIG_MEMCG
CONFIG_CGROUP_MEM_RES_CTLR_SWAP -> CONFIG_MEMCG_SWAP
CONFIG_CGROUP_MEM_RES_CTLR_SWAP_ENABLED -> CONFIG_MEMCG_SWAP_ENABLED
CONFIG_CGROUP_MEM_RES_CTLR_KMEM -> CONFIG_MEMCG_KMEM
[mhocko@suse.cz: fix missed bits]
Cc: Glauber Costa <glommer@parallels.com>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: Tejun Heo <tj@kernel.org>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
On the suspend/resume path the boot CPU does not go though an
offline->online transition. This breaks the NMI detector post-resume
since it depends on PMU state that is lost when the system gets
suspended.
Fix this by forcing a CPU offline->online transition for the lockup
detector on the boot CPU during resume.
To provide more context, we enable NMI watchdog on Chrome OS. We have
seen several reports of systems freezing up completely which indicated
that the NMI watchdog was not firing for some reason.
Debugging further, we found a simple way of repro'ing system freezes --
issuing the command 'tasket 1 sh -c "echo nmilockup > /proc/breakme"'
after the system has been suspended/resumed one or more times.
With this patch in place, the system freeze result in panics, as
expected.
These panics provide a nice stack trace for us to debug the actual issue
causing the freeze.
[akpm@linux-foundation.org: fiddle with code comment]
[akpm@linux-foundation.org: make lockup_detector_bootcpu_resume() conditional on CONFIG_SUSPEND]
[akpm@linux-foundation.org: fix section errors]
Signed-off-by: Sameer Nanda <snanda@chromium.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Mandeep Singh Baines <msb@chromium.org>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
When suid_dumpable=2, detect unsafe core_pattern settings and warn when
they are seen.
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Alan Cox <alan@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Doug Ledford <dledford@redhat.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: James Morris <james.l.morris@oracle.com>
"The biggest change is a performance improvement on SMP systems:
| 4 socket 40 core + SMT Westmere box, single 30 sec tbench
| runs, higher is better:
| clients 1 2 4 8 16 32 64 128
| pre 30 41 118 645 3769 6214 12233 14312
| post 299 603 1211 2418 4697 6847 11606 14557
| A nice increase in performance.
which speedup is particularly noticeable on heavily interacting
few-tasks workloads, so the changes should help desktop-style Xorg
workloads and interactivity as well, on multi-core CPUs.
There are also cpuset suspend behavior fixes/restructuring and various
smaller tweaks."
sched: Fix race in task_group()
sched: Improve balance_cpu() to consider other cpus in its group as target of (pinned) task
sched: Reset loop counters if all tasks are pinned and we need to redo load balance
sched: Reorder 'struct lb_env' members to reduce its size
sched: Improve scalability via 'CPU buddies', which withstand random perturbations
cpusets: Remove/update outdated comments
cpusets, hotplug: Restructure functions that are invoked during hotplug
cpusets, hotplug: Implement cpuset tree traversal in a helper function
CPU hotplug, cpusets, suspend: Don't modify cpusets during suspend/resume
sched/x86: Remove broken power estimation
Stefan reported a crash on a kernel before a3e5d1091c1 ("sched:
Don't call task_group() too many times in set_task_rq()"), he
found the reason to be that the multiple task_group()
invocations in set_task_rq() returned different values.
Looking at all that I found a lack of serialization and plain
wrong comments.
The below tries to fix it using an extra pointer which is
updated under the appropriate scheduler locks. Its not pretty,
but I can't really see another way given how all the cgroup
stuff works.
Reported-and-tested-by: Stefan Bader <stefan.bader@canonical.com>
Link: http://lkml.kernel.org/r/1340364965.18025.71.camel@twins
perturbations
Traversing an entire package is not only expensive, it also leads to tasks
bouncing all over a partially idle and possible quite large package. Fix
that up by assigning a 'buddy' CPU to try to motivate. Each buddy may try
to motivate that one other CPU, if it's busy, tough, it may then try its
SMT sibling, but that's all this optimization is allowed to cost.
Sibling cache buddies are cross-wired to prevent bouncing.
4 socket 40 core + SMT Westmere box, single 30 sec tbench runs, higher is better:
Signed-off-by: Mike Galbraith <efault@gmx.de>
Link: http://lkml.kernel.org/r/1339471112.7352.32.camel@marge.simpson.net
Pull the big VFS changes from Al Viro:
"This one is *big* and changes quite a few things around VFS. What's in there:
- the first of two really major architecture changes - death to open
intents.
The former is finally there; it was very long in making, but with
Miklos getting through really hard and messy final push in
fs/namei.c, we finally have it. Unlike his variant, this one
doesn't introduce struct opendata; what we have instead is
->atomic_open() taking preallocated struct file * and passing
everything via its fields.
Instead of returning struct file *, it returns -E... on error, 0
on success and 1 in "deal with it yourself" case (e.g. symlink
found on server, etc.).
See comments before fs/namei.c:atomic_open(). That made a lot of
goodies finally possible and quite a few are in that pile:
->lookup(), ->d_revalidate() and ->create() do not get struct
nameidata * anymore; ->lookup() and ->d_revalidate() get lookup
flags instead, ->create() gets "do we want it exclusive" flag.
With the introduction of new helper (kern_path_locked()) we are rid
of all struct nameidata instances outside of fs/namei.c; it's still
visible in namei.h, but not for long. Come the next cycle,
declaration will move either to fs/internal.h or to fs/namei.c
itself. [me, miklos, hch]
- The second major change: behaviour of final fput(). Now we have
__fput() done without any locks held by caller *and* not from deep
in call stack.
That obviously lifts a lot of constraints on the locking in there.
Moreover, it's legal now to call fput() from atomic contexts (which
has immediately simplified life for aio.c). We also don't need
anti-recursion logics in __scm_destroy() anymore.
There is a price, though - the damn thing has become partially
asynchronous. For fput() from normal process we are guaranteed
that pending __fput() will be done before the caller returns to
userland, exits or gets stopped for ptrace.
For kernel threads and atomic contexts it's done via
schedule_work(), so theoretically we might need a way to make sure
it's finished; so far only one such place had been found, but there
might be more.
There's flush_delayed_fput() (do all pending __fput()) and there's
__fput_sync() (fput() analog doing __fput() immediately). I hope
we won't need them often; see warnings in fs/file_table.c for
details. [me, based on task_work series from Oleg merged last
cycle]
- sync series from Jan
- large part of "death to sync_supers()" work from Artem; the only
bits missing here are exofs and ext4 ones. As far as I understand,
those are going via the exofs and ext4 trees resp.; once they are
in, we can put ->write_super() to the rest, along with the thread
calling it.
- preparatory bits from unionmount series (from dhowells).
- assorted cleanups and fixes all over the place, as usual.
This is not the last pile for this cycle; there's at least jlayton's
ESTALE work and fsfreeze series (the latter - in dire need of fixes,
so I'm not sure it'll make the cut this cycle). I'll probably throw
symlink/hardlink restrictions stuff from Kees into the next pile, too.
Plus there's a lot of misc patches I hadn't thrown into that one -
it's large enough as it is..."
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits)
ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file()
btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file()
switch dentry_open() to struct path, make it grab references itself
spufs: shift dget/mntget towards dentry_open()
zoran: don't bother with struct file * in zoran_map
ecryptfs: don't reinvent the wheels, please - use struct completion
don't expose I_NEW inodes via dentry->d_inode
tidy up namei.c a bit
unobfuscate follow_up() a bit
ext3: pass custom EOF to generic_file_llseek_size()
ext4: use core vfs llseek code for dir seeks
vfs: allow custom EOF in generic_file_llseek code
vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes
vfs: Remove unnecessary flushing of block devices
vfs: Make sys_sync writeout also block device inodes
vfs: Create function for iterating over block devices
vfs: Reorder operations during sys_sync
quota: Move quota syncing to ->sync_fs method
quota: Split dquot_quota_sync() to writeback and cache flushing part
vfs: Move noop_backing_dev_info check from sync into writeback
recursion in __scm_destroy() will be cut by delaying final fput()
task_work and rcu_head are identical now; merge them (calling the result
struct callback_head, rcu_head #define'd to it), kill separate allocation
in security/keys since we can just use cred->rcu now.
layout based on Oleg's suggestion; single-linked list,
task->task_works points to the last element, forward pointer
from said last element points to head. I'd still prefer
much more regular scheme with two pointers in task_work,
but...
Pick up the latest ring-buffer fixes, before applying a new fix.
'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
Pull RCU, perf, and scheduler fixes from Ingo Molnar.
The RCU fix is a revert for an optimization that could cause deadlocks.
One of the scheduler commits (164c33c6adee "sched: Fix fork() error path
to not crash") is correct but not complete (some architectures like Tile
are not covered yet) - the resulting additional fixes are still WIP and
Ingo did not want to delay these pending fixes. See this thread on
lkml:
[PATCH] fork: fix error handling in dup_task()
The perf fixes are just trivial oneliners.
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
Revert "rcu: Move PREEMPT_RCU preemption to switch_to() invocation"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf kvm: Fix segfault with report and mixed guestmount use
perf kvm: Fix regression with guest machine creation
perf script: Fix format regression due to libtraceevent merge
ring-buffer: Fix accounting of entries when removing pages
ring-buffer: Fix crash due to uninitialized new_pages list head
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
MAINTAINERS/sched: Update scheduler file pattern
sched/nohz: Rewrite and fix load-avg computation -- again
sched: Fix fork() error path to not crash
Thanks to Charles Wang for spotting the defects in the current code:
- If we go idle during the sample window -- after sampling, we get a
negative bias because we can negate our own sample.
- If we wake up during the sample window we get a positive bias
because we push the sample to a known active period.
So rewrite the entire nohz load-avg muck once again, now adding
copious documentation to the code.
Reported-and-tested-by: Doug Smythies <dsmythies@telus.net>
Reported-and-tested-by: Charles Wang <muming.wq@gmail.com>
Cc: stable@kernel.org
Link: http://lkml.kernel.org/r/1340373782.18025.74.camel@twins
[ minor edits ]
This reverts commit 616c310e83b872024271c915c1b9ab505b9efad9.
(Move PREEMPT_RCU preemption to switch_to() invocation).
Testing by Sasha Levin <levinsasha928@gmail.com> showed that this
can result in deadlock due to invoking the scheduler when one of
the runqueue locks is held. Because this commit was simply a
performance optimization, revert it.
Reported-by: Sasha Levin <levinsasha928@gmail.com>
Tested-by: Sasha Levin <levinsasha928@gmail.com>
Merge in Linux 3.5-rc2 - to pick up fixes.
Pull scheduler fixes from Ingo Molnar.
sched: Fix the relax_domain_level boot parameter
sched: Validate assumptions in sched_init_numa()
sched: Always initialize cpu-power
sched: Fix domain iteration
sched/rt: Fix lockdep annotation within find_lock_lowest_rq()
sched/numa: Load balance between remote nodes
sched/x86: Calculate booted cores after construction of sibling_mask
A fix for commit b32dfe377102 ("c/r: prctl: add ability to set new
mm_struct::exe_file").
After removing mm->num_exe_file_vmas kernel keeps mm->exe_file until
final mmput(), it never becomes NULL while task is alive.
We can check for other mapped files in mm instead of checking
mm->num_exe_file_vmas, and mark mm with flag MMF_EXE_FILE_CHANGED in
order to forbid second changing of mm->exe_file.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Kill the no longer needed uprobes_srcu/uprobe_srcu_id code.
It doesn't really work anyway. synchronize_srcu() can only
synchronize with the code "inside" the
srcu_read_lock/srcu_read_unlock section, while
uprobe_pre_sstep_notifier() does srcu_read_lock() _after_ we
already hit the breakpoint.
I guess this probably works "in practice". synchronize_srcu() is
slow and it implies synchronize_sched(), and the probed task
enters the non- preemptible section at the start of exception
handler. Still this is not right at least in theory, and
task->uprobe_srcu_id blows task_struct.
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anton Arapov <anton@redhat.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20120529193008.GG8057@redhat.com
Weird topologies can lead to asymmetric domain setups. This needs
further consideration since these setups are typically non-minimal
too.
For now, make it work by adding an extra mask selecting which CPUs
are allowed to iterate up.
The topology that triggered it is the one from David Rientjes:
10 20 20 30
20 10 20 20
20 20 10 20
30 20 20 10
resulting in boxes that wouldn't even boot.
Reported-by: David Rientjes <rientjes@google.com>
Link: http://lkml.kernel.org/n/tip-3p86l9cuaqnxz7uxsojmz5rm@git.kernel.org
sched: Remove NULL assignment of dattr_cur
sched: Remove the last NULL entry from sched_feat_names
sched: Make sched_feat_names const
sched/rt: Fix SCHED_RR across cgroups
sched: Move nr_cpus_allowed out of 'struct sched_rt_entity'
sched: Make sure to not re-read variables after validation
sched: Fix SD_OVERLAP
sched: Don't try allocating memory from offline nodes
sched/nohz: Fix rq->cpu_load calculations some more
sched/x86: Use cpu_llc_shared_mask(cpu) for coregroup_mask
Only 3 out of 63 do not. Renamed the current variant to __set_current_blocked(),
added set_current_blocked() that will exclude unblockable signals, switched
open-coded instances to it.
replace boilerplate "should we use ->saved_sigmask or ->blocked?"
with calls of obvious inlined helper...
first fruits of ..._restore_sigmask() helpers: now we can take
boilerplate "signal didn't have a handler, clear RESTORE_SIGMASK
and restore the blocked mask from ->saved_mask" into a common
helper. Open-coded instances switched...
Pull second pile of signal handling patches from Al Viro:
"This one is just task_work_add() series + remaining prereqs for it.
There probably will be another pull request from that tree this
cycle - at least for helpers, to get them out of the way for per-arch
fixes remaining in the tree."
Fix trivial conflict in kernel/irq/manage.c: the merge of Andrew's pile
had brought in commit 97fd75b7b8e0 ("kernel/irq/manage.c: use the
pr_foo() infrastructure to prefix printks") which changed one of the
pr_err() calls that this merge moves around.
keys: kill task_struct->replacement_session_keyring
keys: kill the dummy key_replace_session_keyring()
keys: change keyctl_session_to_parent() to use task_work_add()
genirq: reimplement exit_irq_thread() hook via task_work_add()
task_work_add: generic process-context callbacks
avr32: missed _TIF_NOTIFY_RESUME on one of do_notify_resume callers
parisc: need to check NOTIFY_RESUME when exiting from syscall
move key_repace_session_keyring() into tracehook_notify_resume()
TIF_NOTIFY_RESUME is defined on all targets now
Since nr_cpus_allowed is used outside of sched/rt.c and wants to be
used outside of there more, move it to a more natural site.
Link: http://lkml.kernel.org/n/tip-kr61f02y9brwzkh6x53pdptm@git.kernel.org
Follow up on commit 556061b00 ("sched/nohz: Fix rq->cpu_load[]
calculations") since while that fixed the busy case it regressed the
mostly idle case.
Add a callback from the nohz exit to also age the rq->cpu_load[]
array. This closes the hole where either there was no nohz load
balance pass during the nohz, or there was a 'significant' amount of
idle time between the last nohz balance and the nohz exit.
So we'll update unconditionally from the tick to not insert any
accidental 0 load periods while busy, and we try and catch up from
nohz idle balance and nohz exit. Both these are still prone to missing
a jiffy, but that has always been the case.
Cc: pjt@google.com
Link: http://lkml.kernel.org/n/tip-kt0trz0apodbf84ucjfdbr1a@git.kernel.org
