Detach the credentials from task_struct, duplicating them in copy_process()
and releasing them in __put_task_struct().
Acked-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
Constify the kernel_cap_t arguments to the capset LSM hooks.
Take away the ability for sys_capset() to affect processes other than current.
This means that current will not need to lock its own credentials when reading
them against interference by other processes.
This has effectively been the case for a while anyway, since:
(1) Without LSM enabled, sys_capset() is disallowed.
(2) With file-based capabilities, sys_capset() is neutered.
Acked-by: Andrew G. Morgan <morgan@kernel.org>
make an A or B type decision instead of a security decision. Currently
this is the case at least for filesystems when deciding if a process can use
the reserved 'root' blocks and for the case of things like the oom
algorithm determining if processes are root processes and should be less
likely to be killed. These types of security system requests should not be
audited or logged since they are not really security decisions. It would be
possible to solve this problem like the vm_enough_memory security check did
by creating a new LSM interface and moving all of the policy into that
interface but proves the needlessly bloat the LSM and provide complex
indirection.
This merely allows those decisions to be made where they belong and to not
flood logs or printk with denials for thing that are not security decisions.
Signed-off-by: Eric Paris <eparis@redhat.com>
Acked-by: Stephen Smalley <sds@tycho.nsa.gov>
Junjiro R. Okajima reported a problem where knfsd crashes if you are
using it to export shmemfs objects and run strict overcommit. In this
situation the current->mm based modifier to the overcommit goes through a
NULL pointer.
We could simply check for NULL and skip the modifier but we've caught
other real bugs in the past from mm being NULL here - cases where we did
need a valid mm set up (eg the exec bug about a year ago).
To preserve the checks and get the logic we want shuffle the checking
around and add a new helper to the vm_ security wrappers
Also fix a current->mm reference in nommu that should use the passed mm
[akpm@linux-foundation.org: fix build]
Reported-by: Junjiro R. Okajima <hooanon05@yahoo.co.jp>
Signed-off-by: Alan Cox <alan@redhat.com>
Add a new Kconfig option SECURITYFS which will build securityfs support
but does not require CONFIG_SECURITY. The only current user of
securityfs does not depend on CONFIG_SECURITY and there is no reason the
full LSM needs to be built to build this fs.
security.h: fix build failure
include/linux/security.h: In function 'security_ptrace_traceme':
include/linux/security.h:1760: error: 'parent' undeclared (first use in this function)
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Tested-by: Ingo Molnar <mingo@elte.hu>
Fix the setting of PF_SUPERPRIV by __capable() as it could corrupt the flags
the target process if that is not the current process and it is trying to
change its own flags in a different way at the same time.
__capable() is using neither atomic ops nor locking to protect t->flags. This
patch removes __capable() and introduces has_capability() that doesn't set
PF_SUPERPRIV on the process being queried.
This patch further splits security_ptrace() in two:
(1) security_ptrace_may_access(). This passes judgement on whether one
process may access another only (PTRACE_MODE_ATTACH for ptrace() and
PTRACE_MODE_READ for /proc), and takes a pointer to the child process.
current is the parent.
(2) security_ptrace_traceme(). This passes judgement on PTRACE_TRACEME only,
and takes only a pointer to the parent process. current is the child.
In Smack and commoncap, this uses has_capability() to determine whether
the parent will be permitted to use PTRACE_ATTACH if normal checks fail.
This does not set PF_SUPERPRIV.
Two of the instances of __capable() actually only act on current, and so have
been changed to calls to capable().
Of the places that were using __capable():
(1) The OOM killer calls __capable() thrice when weighing the killability of a
process. All of these now use has_capability().
(2) cap_ptrace() and smack_ptrace() were using __capable() to check to see
whether the parent was allowed to trace any process. As mentioned above,
these have been split. For PTRACE_ATTACH and /proc, capable() is now
used, and for PTRACE_TRACEME, has_capability() is used.
(3) cap_safe_nice() only ever saw current, so now uses capable().
(4) smack_setprocattr() rejected accesses to tasks other than current just
after calling __capable(), so the order of these two tests have been
switched and capable() is used instead.
(5) In smack_file_send_sigiotask(), we need to allow privileged processes to
receive SIGIO on files they're manipulating.
(6) In smack_task_wait(), we let a process wait for a privileged process,
whether or not the process doing the waiting is privileged.
I've tested this with the LTP SELinux and syscalls testscripts.
Acked-by: Casey Schaufler <casey@schaufler-ca.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
... and get rid of the last "let's deduce mask from nameidata->flags"
bit.
Why would linux/security.h need forward declarations for nfsctl_arg and
swap_info_struct? It's hard to imagine: remove them.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
The register security hook is no longer required, as the capability
module is always registered. LSMs wishing to stack capability as
a secondary module should do so explicitly.
The sb_get_mnt_opts() hook is unused, and is superseded by the
sb_show_options() hook.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
This patch causes SELinux mount options to show up in /proc/mounts. As
with other code in the area seq_put errors are ignored. Other LSM's
will not have their mount options displayed until they fill in their own
security_sb_show_options() function.
Enable security modules to distinguish reading of process state via
proc from full ptrace access by renaming ptrace_may_attach to
ptrace_may_access and adding a mode argument indicating whether only
read access or full attach access is requested. This allows security
modules to permit access to reading process state without granting
full ptrace access. The base DAC/capability checking remains unchanged.
Read access to /proc/pid/mem continues to apply a full ptrace attach
check since check_mem_permission() already requires the current task
to already be ptracing the target. The other ptrace checks within
proc for elements like environ, maps, and fds are changed to pass the
read mode instead of attach.
In the SELinux case, we model such reading of process state as a
reading of a proc file labeled with the target process' label. This
enables SELinux policy to permit such reading of process state without
permitting control or manipulation of the target process, as there are
a number of cases where programs probe for such information via proc
but do not need to be able to control the target (e.g. procps,
lsof, PolicyKit, ConsoleKit). At present we have to choose between
allowing full ptrace in policy (more permissive than required/desired)
or breaking functionality (or in some cases just silencing the denials
via dontaudit rules but this can hide genuine attacks).
This version of the patch incorporates comments from Casey Schaufler
(change/replace existing ptrace_may_attach interface, pass access
mode), and Chris Wright (provide greater consistency in the checking).
Note that like their predecessors __ptrace_may_attach and
ptrace_may_attach, the __ptrace_may_access and ptrace_may_access
interfaces use different return value conventions from each other (0
or -errno vs. 1 or 0). I retained this difference to avoid any
changes to the caller logic but made the difference clearer by
changing the latter interface to return a bool rather than an int and
by adding a comment about it to ptrace.h for any future callers.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Make secctx_to_secid() take constant secdata.
Add a keyctl() function to get the security label of a key.
The following is added to Documentation/keys.txt:
(*) Get the LSM security context attached to a key.
long keyctl(KEYCTL_GET_SECURITY, key_serial_t key, char *buffer,
size_t buflen)
This function returns a string that represents the LSM security context
attached to a key in the buffer provided.
Unless there's an error, it always returns the amount of data it could
produce, even if that's too big for the buffer, but it won't copy more
than requested to userspace. If the buffer pointer is NULL then no copy
will take place.
A NUL character is included at the end of the string if the buffer is
sufficiently big. This is included in the returned count. If no LSM is
in force then an empty string will be returned.
A process must have view permission on the key for this function to be
successful.
[akpm@linux-foundation.org: declare keyctl_get_security()]
Cc: Paul Moore <paul.moore@hp.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Kevin Coffman <kwc@citi.umich.edu>
Add missing consts to xattr function arguments.
Cc: Andreas Gruenbacher <agruen@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/selinux-2.6:
SELinux: Fix a RCU free problem with the netport cache
SELinux: Made netnode cache adds faster
SELinux: include/security.h whitespace, syntax, and other cleanups
SELinux: policydb.h whitespace, syntax, and other cleanups
SELinux: mls_types.h whitespace, syntax, and other cleanups
SELinux: mls.h whitespace, syntax, and other cleanups
SELinux: hashtab.h whitespace, syntax, and other cleanups
SELinux: context.h whitespace, syntax, and other cleanups
SELinux: ss/conditional.h whitespace, syntax, and other cleanups
SELinux: selinux/include/security.h whitespace, syntax, and other cleanups
SELinux: objsec.h whitespace, syntax, and other cleanups
SELinux: netlabel.h whitespace, syntax, and other cleanups
SELinux: avc_ss.h whitespace, syntax, and other cleanups
Fixed up conflict in include/linux/security.h manually
Filesystem capability support makes it possible to do away with (set)uid-0
based privilege and use capabilities instead. That is, with filesystem
support for capabilities but without this present patch, it is (conceptually)
possible to manage a system with capabilities alone and never need to obtain
privilege via (set)uid-0.
Of course, conceptually isn't quite the same as currently possible since few
user applications, certainly not enough to run a viable system, are currently
prepared to leverage capabilities to exercise privilege. Further, many
applications exist that may never get upgraded in this way, and the kernel
will continue to want to support their setuid-0 base privilege needs.
Where pure-capability applications evolve and replace setuid-0 binaries, it is
desirable that there be a mechanisms by which they can contain their
privilege. In addition to leveraging the per-process bounding and inheritable
sets, this should include suppressing the privilege of the uid-0 superuser
from the process' tree of children.
The feature added by this patch can be leveraged to suppress the privilege
associated with (set)uid-0. This suppression requires CAP_SETPCAP to
initiate, and only immediately affects the 'current' process (it is inherited
through fork()/exec()). This reimplementation differs significantly from the
historical support for securebits which was system-wide, unwieldy and which
has ultimately withered to a dead relic in the source of the modern kernel.
With this patch applied a process, that is capable(CAP_SETPCAP), can now drop
all legacy privilege (through uid=0) for itself and all subsequently
fork()'d/exec()'d children with:
prctl(PR_SET_SECUREBITS, 0x2f);
This patch represents a no-op unless CONFIG_SECURITY_FILE_CAPABILITIES is
enabled at configure time.
[akpm@linux-foundation.org: fix uninitialised var warning]
[serue@us.ibm.com: capabilities: use cap_task_prctl when !CONFIG_SECURITY]
Signed-off-by: Andrew G. Morgan <morgan@kernel.org>
Reviewed-by: James Morris <jmorris@namei.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
This patch changes include/security.h to fix whitespace and syntax issues. Things that
are fixed may include (does not not have to include)
whitespace at end of lines
spaces followed by tabs
spaces used instead of tabs
spacing around parenthesis
location of { around structs and else clauses
location of * in pointer declarations
removal of initialization of static data to keep it in the right section
useless {} in if statemetns
useless checking for NULL before kfree
fixing of the indentation depth of switch statements
no assignments in if statements
include spaces around , in function calls
and any number of other things I forgot to mention
Namely, ones from namespace.c
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6:
security: fix up documentation for security_module_enable
Security: Introduce security= boot parameter
Audit: Final renamings and cleanup
SELinux: use new audit hooks, remove redundant exports
Audit: internally use the new LSM audit hooks
LSM/Audit: Introduce generic Audit LSM hooks
SELinux: remove redundant exports
Netlink: Use generic LSM hook
Audit: use new LSM hooks instead of SELinux exports
SELinux: setup new inode/ipc getsecid hooks
LSM: Introduce inode_getsecid and ipc_getsecid hooks
Add the security= boot parameter. This is done to avoid LSM
registration clashes in case of more than one bult-in module.
User can choose a security module to enable at boot. If no
security= boot parameter is specified, only the first LSM
asking for registration will be loaded. An invalid security
module name will be treated as if no module has been chosen.
LSM modules must check now if they are allowed to register
by calling security_module_enable(ops) first. Modify SELinux
and SMACK to do so.
Do not let SMACK register smackfs if it was not chosen on
boot. Smackfs assumes that smack hooks are registered and
the initial task security setup (swapper->security) is done.
Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com>
Introduce a generic Audit interface for security modules
by adding the following new LSM hooks:
audit_rule_init(field, op, rulestr, lsmrule)
audit_rule_known(krule)
audit_rule_match(secid, field, op, rule, actx)
audit_rule_free(rule)
Those hooks are only available if CONFIG_AUDIT is enabled.
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
Reviewed-by: Paul Moore <paul.moore@hp.com>
Introduce inode_getsecid(inode, secid) and ipc_getsecid(ipcp, secid)
LSM hooks. These hooks will be used instead of similar exported
SELinux interfaces.
Let {inode,ipc,task}_getsecid hooks set the secid to 0 by default
if CONFIG_SECURITY is not defined or if the hook is set to
NULL (dummy). This is done to notify the caller that no valid
secid exists.
The xfrm_get_policy() and xfrm_add_pol_expire() put some rather large structs
on the stack to work around the LSM API. This patch attempts to fix that
problem by changing the LSM API to require only the relevant "security"
pointers instead of the entire SPD entry; we do this for all of the
security_xfrm_policy*() functions to keep things consistent.
Signed-off-by: Paul Moore <paul.moore@hp.com>
The original justification for cap_task_kill() was as follows:
check_kill_permission() does appropriate uid equivalence checks.
However with file capabilities it becomes possible for an
unprivileged user to execute a file with file capabilities
resulting in a more privileged task with the same uid.
However now that cap_task_kill() always returns 0 (permission
granted) when p->uid==current->uid, the whole hook is worthless,
and only likely to create more subtle problems in the corner cases
where it might still be called but return -EPERM. Those cases
are basically when uids are different but euid/suid is equivalent
as per the check in check_kill_permission().
One example of a still-broken application is 'at' for non-root users.
This patch removes cap_task_kill().
Signed-off-by: Serge Hallyn <serge@hallyn.com>
Earlier-version-tested-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br>
Introduce new LSM interfaces to allow an FS to deal with their own mount
options. This includes a new string parsing function exported from the
LSM that an FS can use to get a security data blob and a new security
data blob. This is particularly useful for an FS which uses binary
mount data, like NFS, which does not pass strings into the vfs to be
handled by the loaded LSM. Also fix a BUG() in both SELinux and SMACK
when dealing with binary mount data. If the binary mount data is less
than one page the copy_page() in security_sb_copy_data() can cause an
illegal page fault and boom. Remove all NFSisms from the SELinux code
since they were broken by past NFS changes.
The capability bounding set is a set beyond which capabilities cannot grow.
Currently cap_bset is per-system. It can be manipulated through sysctl,
but only init can add capabilities. Root can remove capabilities. By
default it includes all caps except CAP_SETPCAP.
This patch makes the bounding set per-process when file capabilities are
enabled. It is inherited at fork from parent. Noone can add elements,
CAP_SETPCAP is required to remove them.
One example use of this is to start a safer container. For instance, until
device namespaces or per-container device whitelists are introduced, it is
best to take CAP_MKNOD away from a container.
The bounding set will not affect pP and pE immediately. It will only
affect pP' and pE' after subsequent exec()s. It also does not affect pI,
and exec() does not constrain pI'. So to really start a shell with no way
of regain CAP_MKNOD, you would do
prctl(PR_CAPBSET_DROP, CAP_MKNOD);
cap_t cap = cap_get_proc();
cap_value_t caparray[1];
caparray[0] = CAP_MKNOD;
cap_set_flag(cap, CAP_INHERITABLE, 1, caparray, CAP_DROP);
cap_set_proc(cap);
cap_free(cap);
The following test program will get and set the bounding
set (but not pI). For instance
./bset get
(lists capabilities in bset)
./bset drop cap_net_raw
(starts shell with new bset)
(use capset, setuid binary, or binary with
file capabilities to try to increase caps)
cap_bound.c
#include <sys/prctl.h>
#include <linux/capability.h>
#include <sys/types.h>
#include <unistd.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#ifndef PR_CAPBSET_READ
#define PR_CAPBSET_READ 23
#endif
#ifndef PR_CAPBSET_DROP
#define PR_CAPBSET_DROP 24
#endif
int usage(char *me)
printf("Usage: %s get\n", me);
printf(" %s drop <capability>\n", me);
return 1;
#define numcaps 32
char *captable[numcaps] = {
"cap_chown",
"cap_dac_override",
"cap_dac_read_search",
"cap_fowner",
"cap_fsetid",
"cap_kill",
"cap_setgid",
"cap_setuid",
"cap_setpcap",
"cap_linux_immutable",
"cap_net_bind_service",
"cap_net_broadcast",
"cap_net_admin",
"cap_net_raw",
"cap_ipc_lock",
"cap_ipc_owner",
"cap_sys_module",
"cap_sys_rawio",
"cap_sys_chroot",
"cap_sys_ptrace",
"cap_sys_pacct",
"cap_sys_admin",
"cap_sys_boot",
"cap_sys_nice",
"cap_sys_resource",
"cap_sys_time",
"cap_sys_tty_config",
"cap_mknod",
"cap_lease",
"cap_audit_write",
"cap_audit_control",
"cap_setfcap"
int getbcap(void)
int comma=0;
unsigned long i;
int ret;
printf("i know of %d capabilities\n", numcaps);
printf("capability bounding set:");
for (i=0; i<numcaps; i++) {
ret = prctl(PR_CAPBSET_READ, i);
if (ret < 0)
perror("prctl");
else if (ret==1)
printf("%s%s", (comma++) ? ", " : " ", captable[i]);
printf("\n");
return 0;
int capdrop(char *str)
unsigned long i;
int found=0;
if (strcmp(captable[i], str) == 0) {
found=1;
break;
if (!found)
return 1;
if (prctl(PR_CAPBSET_DROP, i)) {
perror("prctl");
return 1;
return 0;
int main(int argc, char *argv[])
if (argc<2)
return usage(argv[0]);
if (strcmp(argv[1], "get")==0)
return getbcap();
if (strcmp(argv[1], "drop")!=0 || argc<3)
if (capdrop(argv[2])) {
printf("unknown capability\n");
return 1;
return execl("/bin/bash", "/bin/bash", NULL);
[serue@us.ibm.com: fix typo]
Cc: Casey Schaufler <casey@schaufler-ca.com>a
Signed-off-by: "Serge E. Hallyn" <serue@us.ibm.com>
Tested-by: Jiri Slaby <jirislaby@gmail.com>
This patch modifies the interface to inode_getsecurity to have the function
return a buffer containing the security blob and its length via parameters
instead of relying on the calling function to give it an appropriately sized
buffer.
Security blobs obtained with this function should be freed using the
release_secctx LSM hook. This alleviates the problem of the caller having to
guess a length and preallocate a buffer for this function allowing it to be
used elsewhere for Labeled NFS.
The patch also removed the unused err parameter. The conversion is similar to
the one performed by Al Viro for the security_getprocattr hook.
Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov>
Constify function pointer tables and fields.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Add a secctx_to_secid() LSM hook to go along with the existing
secid_to_secctx() LSM hook. This patch also includes the SELinux
implementation for this hook.
The security_sb_post_mountroot() hook is long-since obsolete, and is
fundamentally broken: it is never invoked if someone uses initramfs.
This is particularly damaging, because the existence of this hook has
been used as motivation for not using initramfs.
Stephen Smalley confirmed on 2007-07-19 that this hook was originally
used by SELinux but can now be safely removed:
http://marc.info/?l=linux-kernel&m=118485683612916&w=2
Cc: Eric Paris <eparis@parisplace.org>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Adds security_get_sb_mnt_opts, security_set_sb_mnt_opts, and
security_clont_sb_mnt_opts to the LSM and to SELinux. This will allow
filesystems to directly own and control all of their mount options if they
so choose. This interface deals only with option identifiers and strings so
it should generic enough for any LSM which may come in the future.
Filesystems which pass text mount data around in the kernel (almost all of
them) need not currently make use of this interface when dealing with
SELinux since it will still parse those strings as it always has. I assume
future LSM's would do the same. NFS is the primary FS which does not use
text mount data and thus must make use of this interface.
An LSM would need to implement these functions only if they had mount time
options, such as selinux has context= or fscontext=. If the LSM has no
mount time options they could simply not implement and let the dummy ops
take care of things.
An LSM other than SELinux would need to define new option numbers in
security.h and any FS which decides to own there own security options would
need to be patched to use this new interface for every possible LSM. This
is because it was stated to me very clearly that LSM's should not attempt to
understand FS mount data and the burdon to understand security should be in
the FS which owns the options.
Acked-by: Stephen D. Smalley <sds@tycho.nsa.gov>
Update the security_socket_peersec documentation in
include/linux/security.h. security_socket_peersec has been split
into two functions - _stream and _dgram, with new capabilities.
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
The non-filesystem capability meaning of CAP_SETPCAP is that a process, p1,
can change the capabilities of another process, p2. This is not the
meaning that was intended for this capability at all, and this
implementation came about purely because, without filesystem capabilities,
there was no way to use capabilities without one process bestowing them on
another.
Since we now have a filesystem support for capabilities we can fix the
implementation of CAP_SETPCAP.
The most significant thing about this change is that, with it in effect, no
process can set the capabilities of another process.
The capabilities of a program are set via the capability convolution
rules:
pI(post-exec) = pI(pre-exec)
pP(post-exec) = (X(aka cap_bset) & fP) | (pI(post-exec) & fI)
pE(post-exec) = fE ? pP(post-exec) : 0
at exec() time. As such, the only influence the pre-exec() program can
have on the post-exec() program's capabilities are through the pI
capability set.
The correct implementation for CAP_SETPCAP (and that enabled by this patch)
is that it can be used to add extra pI capabilities to the current process
- to be picked up by subsequent exec()s when the above convolution rules
are applied.
Here is how it works:
Let's say we have a process, p. It has capability sets, pE, pP and pI.
Generally, p, can change the value of its own pI to pI' where
(pI' & ~pI) & ~pP = 0.
That is, the only new things in pI' that were not present in pI need to
be present in pP.
The role of CAP_SETPCAP is basically to permit changes to pI beyond
the above:
if (pE & CAP_SETPCAP) {
pI' = anything; /* ie., even (pI' & ~pI) & ~pP != 0 */
This capability is useful for things like login, which (say, via
pam_cap) might want to raise certain inheritable capabilities for use
by the children of the logged-in user's shell, but those capabilities
are not useful to or needed by the login program itself.
One such use might be to limit who can run ping. You set the
capabilities of the 'ping' program to be "= cap_net_raw+i", and then
only shells that have (pI & CAP_NET_RAW) will be able to run
it. Without CAP_SETPCAP implemented as described above, login(pam_cap)
would have to also have (pP & CAP_NET_RAW) in order to raise this
capability and pass it on through the inheritable set.
Signed-off-by: Andrew Morgan <morgan@kernel.org>
This patch contains the following cleanups that are now possible:
- remove the unused security_operations->inode_xattr_getsuffix
- remove the no longer used security_operations->unregister_security
- remove some no longer required exit code
- remove a bunch of no longer used exports
Cc: Serge Hallyn <serue@us.ibm.com>
Implement file posix capabilities. This allows programs to be given a
subset of root's powers regardless of who runs them, without having to use
setuid and giving the binary all of root's powers.
This version works with Kaigai Kohei's userspace tools, found at
http://www.kaigai.gr.jp/index.php. For more information on how to use this
patch, Chris Friedhoff has posted a nice page at
http://www.friedhoff.org/fscaps.html.
Changelog:
Nov 27:
Incorporate fixes from Andrew Morton
(security-introduce-file-caps-tweaks and
security-introduce-file-caps-warning-fix)
Fix Kconfig dependency.
Fix change signaling behavior when file caps are not compiled in.
Nov 13:
Integrate comments from Alexey: Remove CONFIG_ ifdef from
capability.h, and use %zd for printing a size_t.
Nov 13:
Fix endianness warnings by sparse as suggested by Alexey
Dobriyan.
Nov 09:
Address warnings of unused variables at cap_bprm_set_security
when file capabilities are disabled, and simultaneously clean
up the code a little, by pulling the new code into a helper
function.
Nov 08:
For pointers to required userspace tools and how to use
them, see http://www.friedhoff.org/fscaps.html.
Nov 07:
Fix the calculation of the highest bit checked in
check_cap_sanity().
Nov 07:
Allow file caps to be enabled without CONFIG_SECURITY, since
capabilities are the default.
Hook cap_task_setscheduler when !CONFIG_SECURITY.
Move capable(TASK_KILL) to end of cap_task_kill to reduce
audit messages.
Nov 05:
Add secondary calls in selinux/hooks.c to task_setioprio and
task_setscheduler so that selinux and capabilities with file
cap support can be stacked.
Sep 05:
As Seth Arnold points out, uid checks are out of place
for capability code.
Sep 01:
Define task_setscheduler, task_setioprio, cap_task_kill, and
task_setnice to make sure a user cannot affect a process in which
they called a program with some fscaps.
One remaining question is the note under task_setscheduler: are we
ok with CAP_SYS_NICE being sufficient to confine a process to a
cpuset?
It is a semantic change, as without fsccaps, attach_task doesn't
allow CAP_SYS_NICE to override the uid equivalence check. But since
it uses security_task_setscheduler, which elsewhere is used where
CAP_SYS_NICE can be used to override the uid equivalence check,
fixing it might be tough.
task_setscheduler
note: this also controls cpuset:attach_task. Are we ok with
CAP_SYS_NICE being used to confine to a cpuset?
task_setioprio
task_setnice
sys_setpriority uses this (through set_one_prio) for another
process. Need same checks as setrlimit
Aug 21:
Updated secureexec implementation to reflect the fact that
euid and uid might be the same and nonzero, but the process
might still have elevated caps.
Aug 15:
Handle endianness of xattrs.
Enforce capability version match between kernel and disk.
Enforce that no bits beyond the known max capability are
set, else return -EPERM.
With this extra processing, it may be worth reconsidering
doing all the work at bprm_set_security rather than
d_instantiate.
Aug 10:
Always call getxattr at bprm_set_security, rather than
caching it at d_instantiate.
[morgan@kernel.org: file-caps clean up for linux/capability.h]
[bunk@kernel.org: unexport cap_inode_killpriv]
Cc: Andrew Morgan <morgan@kernel.org>
Convert LSM into a static interface, as the ability to unload a security
module is not required by in-tree users and potentially complicates the
overall security architecture.
Needlessly exported LSM symbols have been unexported, to help reduce API
abuse.
Parameters for the capability and root_plug modules are now specified
at boot.
The SECURITY_FRAMEWORK_VERSION macro has also been removed.
In a nutshell, there is no safe way to unload an LSM. The modular interface
is thus unecessary and broken infrastructure. It is used only by out-of-tree
modules, which are often binary-only, illegal, abusive of the API and
dangerous, e.g. silently re-vectoring SELinux.
[akpm@linux-foundation.org: cleanups]
[akpm@linux-foundation.org: USB Kconfig fix]
[randy.dunlap@oracle.com: fix LSM kernel-doc]
Cc: "Serge E. Hallyn" <serue@us.ibm.com>
Acked-by: Arjan van de Ven <arjan@infradead.org>
It reduces the selinux overhead on read/write by only revalidating
permissions in selinux_file_permission if the task or inode labels have
changed or the policy has changed since the open-time check. A new LSM
hook, security_dentry_open, is added to capture the necessary state at open
time to allow this optimization.
(see http://marc.info/?l=selinux&m=118972995207740&w=2)
Signed-off-by: Yuichi Nakamura<ynakam@hitachisoft.jp>
The new exec code inserts an accounted vma into an mm struct which is not
current->mm. The existing memory check code has a hard coded assumption
that this does not happen as does the security code.
As the correct mm is known we pass the mm to the security method and the
helper function. A new security test is added for the case where we need
to pass the mm and the existing one is modified to pass current->mm to
avoid the need to change large amounts of code.
(Thanks to Tobias for fixing rejects and testing)
Cc: WU Fengguang <wfg@mail.ustc.edu.cn>
Cc: James Morris <jmorris@redhat.com>
Cc: Tobias Diedrich <ranma+kernel@tdiedrich.de>
Add a new security check on mmap operations to see if the user is attempting
to mmap to low area of the address space. The amount of space protected is
indicated by the new proc tunable /proc/sys/vm/mmap_min_addr and defaults to
0, preserving existing behavior.
This patch uses a new SELinux security class "memprotect." Policy already
contains a number of allow rules like a_t self:process * (unconfined_t being
one of them) which mean that putting this check in the process class (its
best current fit) would make it useless as all user processes, which we also
want to protect against, would be allowed. By taking the memprotect name of
the new class it will also make it possible for us to move some of the other
memory protect permissions out of 'process' and into the new class next time
we bump the policy version number (which I also think is a good future idea)
Signed-off-by: Michael Opdenacker <michael@free-electrons.com>
have it return the buffer it had allocated
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Replace a small number of expressions with a call to the "container_of()"
macro.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Acked-by: Paul Mackerras <paulus@samba.org>
Fix the selection of an SA for an outgoing packet to be at the same
context as the originating socket/flow. This eliminates the SELinux
policy's ability to use/sendto SAs with contexts other than the socket's.
With this patch applied, the SELinux policy will require one or more of the
following for a socket to be able to communicate with/without SAs:
1. To enable a socket to communicate without using labeled-IPSec SAs:
allow socket_t unlabeled_t:association { sendto recvfrom }
2. To enable a socket to communicate with labeled-IPSec SAs:
allow socket_t self:association { sendto };
allow socket_t peer_sa_t:association { recvfrom };
Signed-off-by: Venkat Yekkirala <vyekkirala@TrustedCS.com>
Fix SO_PEERSEC for tcp sockets to return the security context of
the peer (as represented by the SA from the peer) as opposed to the
SA used by the local/source socket.
Since the upstreaming of the mlsxfrm modification a few months back,
testing has resulted in the identification of the following issues/bugs that
are resolved in this patch set.
1. Fix the security context used in the IKE negotiation to be the context
of the socket as opposed to the context of the SPD rule.
2. Fix SO_PEERSEC for tcp sockets to return the security context of
the peer as opposed to the source.
3. Fix the selection of an SA for an outgoing packet to be at the same
The following would be the result of applying this patchset:
- SO_PEERSEC will now correctly return the peer's context.
- IKE deamons will receive the context of the source socket/flow
as opposed to the SPD rule's context so that the negotiated SA
will be at the same context as the source socket/flow.
- The SELinux policy will require one or more of the
This Patch: Pass correct security context to IKE for use in negotiation
Fix the security context passed to IKE for use in negotiation to be the
context of the socket as opposed to the context of the SPD rule so that
the SA carries the label of the originating socket/flow.
Currently when an IPSec policy rule doesn't specify a security
context, it is assumed to be "unlabeled" by SELinux, and so
the IPSec policy rule fails to match to a flow that it would
otherwise match to, unless one has explicitly added an SELinux
policy rule allowing the flow to "polmatch" to the "unlabeled"
IPSec policy rules. In the absence of such an explicitly added
SELinux policy rule, the IPSec policy rule fails to match and
so the packet(s) flow in clear text without the otherwise applicable
xfrm(s) applied.
The above SELinux behavior violates the SELinux security notion of
"deny by default" which should actually translate to "encrypt by
default" in the above case.
This was first reported by Evgeniy Polyakov and the way James Morris
was seeing the problem was when connecting via IPsec to a
confined service on an SELinux box (vsftpd), which did not have the
appropriate SELinux policy permissions to send packets via IPsec.
With this patch applied, SELinux "polmatching" of flows Vs. IPSec
policy rules will only come into play when there's a explicit context
specified for the IPSec policy rule (which also means there's corresponding
SELinux policy allowing appropriate domains/flows to polmatch to this context).
Secondly, when a security module is loaded (in this case, SELinux), the
security_xfrm_policy_lookup() hook can return errors other than access denied,
such as -EINVAL. We were not handling that correctly, and in fact
inverting the return logic and propagating a false "ok" back up to
xfrm_lookup(), which then allowed packets to pass as if they were not
associated with an xfrm policy.
The solution for this is to first ensure that errno values are
correctly propagated all the way back up through the various call chains
from security_xfrm_policy_lookup(), and handled correctly.
Then, flow_cache_lookup() is modified, so that if the policy resolver
fails (typically a permission denied via the security module), the flow
cache entry is killed rather than having a null policy assigned (which
indicates that the packet can pass freely). This also forces any future
lookups for the same flow to consult the security module (e.g. SELinux)
for current security policy (rather than, say, caching the error on the
flow cache entry).
This patch: Fix the selinux side of things.
This makes sure SELinux polmatching of flow contexts to IPSec policy
rules comes into play only when an explicit context is associated
with the IPSec policy rule.
Also, this no longer defaults the context of a socket policy to
the context of the socket since the "no explicit context" case
is now handled properly.
