path: root/include/linux/spinlock.h
2008-04-17locking: remove unused double_spin_lock()Oleg Nesterov
double_spin_lock() has no callers, and it can't be used without additional lockdep annotations, remove it. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-11Spell out behavior of atomic_dec_and_lock() in kerneldocJ. Bruce Fields
A little more detail here wouldn't hurt. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-02-08Remove fastcall from linux/includeHarvey Harrison
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30spinlock: lockbreak cleanupNick Piggin
The break_lock data structure and code for spinlocks is quite nasty. Not only does it double the size of a spinlock but it changes locking to a potentially less optimal trylock. Put all of that under CONFIG_GENERIC_LOCKBREAK, and introduce a __raw_spin_is_contended that uses the lock data itself to determine whether there are waiters on the lock, to be used if CONFIG_GENERIC_LOCKBREAK is not set. Rename need_lockbreak to spin_needbreak, make it use spin_is_contended to decouple it from the spinlock implementation, and make it typesafe (rwlocks do not have any need_lockbreak sites -- why do they even get bloated up with that break_lock then?). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-16introduce write_trylock_irqsave()Satyam Sharma
Introduce a write_trylock_irqsave() implementation. Similar in style to the implementation of spin_trylock_irqsave() in mainline. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Sripathi Kodi <sripathik@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] timer/hrtimer: take per cpu locks in sane orderHeiko Carstens
Doing something like this on a two cpu system # echo 0 > /sys/devices/system/cpu/cpu0/online # echo 1 > /sys/devices/system/cpu/cpu0/online # echo 0 > /sys/devices/system/cpu/cpu1/online will give me this: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.21-rc2-g562aa1d4-dirty #7 ------------------------------------------------------- bash/1282 is trying to acquire lock: (&cpu_base->lock_key){.+..}, at: [<000000000005f17e>] hrtimer_cpu_notify+0xc6/0x240 but task is already holding lock: (&cpu_base->lock_key#2){.+..}, at: [<000000000005f174>] hrtimer_cpu_notify+0xbc/0x240 which lock already depends on the new lock. This happens because we have the following code in kernel/hrtimer.c: migrate_hrtimers(int cpu) [...] old_base = &per_cpu(hrtimer_bases, cpu); new_base = &get_cpu_var(hrtimer_bases); [...] spin_lock(&new_base->lock); spin_lock(&old_base->lock); Which means the spinlocks are taken in an order which depends on which cpu gets shut down from which other cpu. Therefore lockdep complains that there might be an ABBA deadlock. Since migrate_hrtimers() gets only called on cpu hotplug it's safe to assume that it isn't executed concurrently on a The same problem exists in kernel/timer.c: migrate_timers(). As pointed out by Christian Borntraeger one possible solution to avoid the locking order complaints would be to make sure that the locks are always taken in the same order. E.g. by taking the lock of the cpu with the lower number first. To achieve this we introduce two new spinlock functions double_spin_lock and double_spin_unlock which lock or unlock two locks in a given order. Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: John Stultz <johnstul@us.ibm.com> Cc: Christian Borntraeger <cborntra@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Fix sparse annotation of spin unlock macros in one casePavel Roskin
SMP systems without premption and spinlock debugging enabled use unlock macros that don't tell sparse that the lock is being released. Add sparse annotations in this case. Signed-off-by: Pavel Roskin <proski@gnu.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] add bottom_half.hAndrew Morton
With CONFIG_SMP=n: drivers/input/ff-memless.c:384: warning: implicit declaration of function 'local_bh_disable' drivers/input/ff-memless.c:393: warning: implicit declaration of function 'local_bh_enable' Really linux/spinlock.h should include linux/interrupt.h. But interrupt.h includes sched.h which will need spinlock.h. So the patch breaks the _bh declarations out into a separate header and includes it in both interrupt.h and spinlock.h. Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Andi Kleen <ak@suse.de> Cc: <stable@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-26Revert "[PATCH] Enforce "unsigned long flags;" when spinlocking"Linus Torvalds
This reverts commit ee3ce191e8eaa4cc15c51a28b34143b36404c4f5, since it broke on at least ARM, MIPS and PA-RISC due to complicated header file dependencies. Conflicts in include/linux/spinlock.h (due to the "nested" variety fixes) fixed up by hand. Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Russell King <rmk+lkml@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] lockdep: spin_lock_irqsave_nested()Arjan van de Ven
Introduce spin_lock_irqsave_nested(); implementation from: http://lkml.org/lkml/2006/6/1/122 Patch from: http://lkml.org/lkml/2006/9/13/258 [akpm@osdl.org: two compile fixes] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Jiri Kosina <jikos@jikos.cz> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-25[PATCH] Enforce "unsigned long flags;" when spinlockingAlexey Dobriyan
Make it break or warn if you pass to spin_lock_irqsave() and friends something different from "unsigned long flags;". Suprisingly large amount of these was caught by recent commit c53421b18f205c5f97c604ae55c6a921f034b0f6 and others. Idea is largely from FRV typechecking. Suggestions from Andrew Morton. All stupid typos in first version fixed. Passes allmodconfig on i386, x86_64, alpha, arm as well as my usual config. Note #1: checking with sparse is still needed, because a driver can save and pass around flags or something. So far patch is very intrusive. Note #2: techically, we should break only if sizeof(flags) < sizeof(unsigned long), however, the more pain for getting suspicious code into kernel, the better. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Pass a lock expression to __cond_lock, like __acquire and __releaseJosh Triplett
Currently, __acquire and __release take a lock expression, but __cond_lock takes only a condition, not the lock acquired if the expression evaluates to true. Change __cond_lock to accept a lock expression, and change all the callers to pass in a lock expression. Signed-off-by: Josh Triplett <josh@freedesktop.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Replace _spin_trylock with spin_trylock in the IRQ variants to use ↵Josh Triplett
__cond_lock spin_trylock_irq and spin_trylock_irqsave use _spin_trylock, which does not use the __cond_lock wrapper annotation and thus does not affect the lock context; change them to use spin_trylock instead, which does use __cond_lock. Signed-off-by: Josh Triplett <josh@freedesktop.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: prove spinlock rwlock locking correctnessIngo Molnar
Use the lock validator framework to prove spinlock and rwlock locking correctness. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2005-12-26kbuild: set correct KBUILD_MODNAME when using well known kernel symbols as ↵Ustyugov Roman
module names This patch fixes a problem when we use well known kernel symbols as module names. For example, if module source name is current.c, idle_stack.c or etc., we have a bad KBUILD_MODNAME value. For example, KBUILD_MODNAME will be "get_current()" instead of "current", or "(init_thread_union.stack)" instead of "idle_task". The trick is to define a stringify macro on the commandline - named KBUILD_STR for namespace reasons - and then to stringify the module name. There are a few uses of KBUILD_MODNAME throughout the tree but the usage is for debug and will not be harmed by this change so left untouched for now. While at it KBUILD_BASENAME was changed too. Any spinlock usage in the unix module would have created wrong section names without it. Usage in spinlock.h fixed so it no longer stringify KBUILD_BASENAME. Original patch from Ustyogov Roman - all bugs introduced by me. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-10-30[PATCH] x86: inline spin_unlock if !CONFIG_DEBUG_SPINLOCK and !CONFIG_PREEMPTIngo Molnar
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-21[PATCH] spin_unlock_bh() and preempt_check_resched()Samuel Thibault
In _spin_unlock_bh(lock): do { \ _raw_spin_unlock(lock); \ preempt_enable(); \ local_bh_enable(); \ __release(lock); \ } while (0) there is no reason for using preempt_enable() instead of a simple preempt_enable_no_resched() Since we know bottom halves are disabled, preempt_schedule() will always return at once (preempt_count!=0), and hence preempt_check_resched() is useless here... This fixes it by using "preempt_enable_no_resched()" instead of the "preempt_enable()", and thus avoids the useless preempt_check_resched() just before re-enabling bottom halves. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
