path: root/include/linux/sunrpc
2008-05-19svcrdma: Change svc_rdma_send_error return type to voidTom Tucker
The svc_rdma_send_error function is called when an RPCRDMA protocol error is detected. This function attempts to post an error reply message. Since an error posting to a transport in error is ignored, change the return type to void. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Move destroy to kernel threadTom Tucker
Some providers may wait while destroying adapter resources. Since it is possible that the last reference is put on the dto_tasklet, the actual destroy must be scheduled as a work item. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Use standard Linux lists for context cacheTom Tucker
Replace the one-off linked list implementation used to implement the context cache with the standard Linux list_head lists. Add a context counter to catch resource leaks. A WARN_ON will be added later to ensure that we've freed all contexts. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Simplify RDMA_READ deferral buffer managementTom Tucker
An NFS_WRITE requires a set of RDMA_READ requests to fetch the write data from the client. There are two principal pieces of data that need to be tracked: the list of pages that comprise the completed RPC and the SGE of dma mapped pages to refer to this list of pages. Previously this whole bit was managed as a linked list of contexts with the context containing the page list buried in this list. This patch simplifies this processing by not keeping a linked list, but rather only a pionter from the last submitted RDMA_READ's context to the context that maps the set of pages that describe the RPC. This significantly simplifies this code path. SGE contexts are cleaned up inline in the DTO path instead of at read completion time. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-05-19svcrdma: Remove unused READ_DONE context flags bitTom Tucker
The RDMACTXT_F_READ_DONE bit is not longer used. Remove it. Signed-off-by: Tom Tucker <tom@opengridcomputing.com>
2008-04-24Merge git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (80 commits) SUNRPC: Invalidate the RPCSEC_GSS session if the server dropped the request make nfs_automount_list static NFS: remove duplicate flags assignment from nfs_validate_mount_data NFS - fix potential NULL pointer dereference v2 SUNRPC: Don't change the RPCSEC_GSS context on a credential that is in use SUNRPC: Fix a race in gss_refresh_upcall() SUNRPC: Don't disconnect more than once if retransmitting NFSv4 requests SUNRPC: Remove the unused export of xprt_force_disconnect SUNRPC: remove XS_SENDMSG_RETRY SUNRPC: Protect creds against early garbage collection NFSv4: Attempt to use machine credentials in SETCLIENTID calls NFSv4: Reintroduce machine creds NFSv4: Don't use cred->cr_ops->cr_name in nfs4_proc_setclientid() nfs: fix printout of multiword bitfields nfs: return negative error value from nfs{,4}_stat_to_errno NLM/lockd: Ensure client locking calls use correct credentials NFS: Remove the buggy lock-if-signalled case from do_setlk() NLM/lockd: Fix a race when cancelling a blocking lock NLM/lockd: Ensure that nlmclnt_cancel() returns results of the CANCEL call NLM: Remove the signal masking in nlmclnt_proc/nlmclnt_cancel ...
2008-04-23SUNRPC: Update RPC server's TCP record marker decoderChuck Lever
Clean up: Update the RPC server's TCP record marker decoder to match the constructs used by the RPC client's TCP socket transport. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23SUNRPC: remove svc_create_thread()Jeff Layton
Now that the nfs4 callback thread uses the kthread API, there are no more users of svc_create_thread(). Remove it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23gss_krb5: consistently use unsigned for seqnumKevin Coffman
Consistently use unsigned (u32 vs. s32) for seqnum. In get_mic function, send the local copy of seq_send, rather than the context version. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23Remove define for KRB5_CKSUM_LENGTH, which will become enctype-dependentKevin Coffman
cleanup: When adding new encryption types, the checksum length can be different for each enctype. Face the fact that the current code only supports DES which has a checksum length of 8. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23svcrpc: move unused field from cache_deferred_reqJ. Bruce Fields
This field is set once and never used; probably some artifact of an earlier implementation idea. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-23IPv6 support for NFS server export cachesAurélien Charbon
This adds IPv6 support to the interfaces that are used to express nfsd exports. All addressed are stored internally as IPv6; backwards compatibility is maintained using mapped addresses. Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji for comments Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Brian Haley <brian.haley@hp.com> Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-19SUNRPC: Don't disconnect more than once if retransmitting NFSv4 requestsTrond Myklebust
NFSv4 requires us to ensure that we break the TCP connection before we're allowed to retransmit a request. However in the case where we're retransmitting several requests that have been sent on the same connection, we need to ensure that we don't interfere with the attempt to reconnect and/or break the connection again once it has been established. We therefore introduce a 'connection' cookie that is bumped every time a connection is broken. This allows requests to track if they need to force a disconnection. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFSv4: Reintroduce machine credsTrond Myklebust
We need to try to ensure that we always use the same credentials whenever we re-establish the clientid on the server. If not, the server won't recognise that we're the same client, and so may not allow us to recover state. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19NFSv4: Don't use cred->cr_ops->cr_name in nfs4_proc_setclientid()Trond Myklebust
With the recent change to generic creds, we can no longer use cred->cr_ops->cr_name to distinguish between RPCSEC_GSS principals and AUTH_SYS/AUTH_NULL identities. Replace it with the rpc_authops->au_name instead... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-04-19SUNRPC: Fix up xprt_write_space()Trond Myklebust
The rest of the networking layer uses SOCK_ASYNC_NOSPACE to signal whether or not we have someone waiting for buffer memory. Convert the SUNRPC layer to use the same idiom. Remove the unlikely()s in xs_udp_write_space and xs_tcp_write_space. In fact, the most common case will be that there is nobody waiting for buffer space. SOCK_NOSPACE is there to tell the TCP layer whether or not the cwnd was limited by the application window. Ensure that we follow the same idiom as the rest of the networking layer here too. Finally, ensure that we clear SOCK_ASYNC_NOSPACE once we wake up, so that write_space() doesn't keep waking things up on xprt->pending. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Add an rpc_credop callback for binding a credential to an rpc_taskTrond Myklebust
We need the ability to treat 'generic' creds specially, since they want to bind instances of the auth cred instead of binding themselves. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Add a generic RPC credentialTrond Myklebust
Add an rpc credential that is not tied to any particular auth mechanism, but that can be cached by NFS, and later used to look up a cred for whichever auth mechanism that turns out to be valid when the RPC call is being made. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Clean up rpcauth_bindcred()Trond Myklebust
2008-03-14SUNRPC: Fix RPCAUTH_LOOKUP_ROOTCREDSTrond Myklebust
The current RPCAUTH_LOOKUP_ROOTCREDS flag only works for AUTH_SYS authentication, and then only as a special case in the code. This patch removes the auth_sys special casing, and replaces it with generic code. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-03-14SUNRPC: Fix a bug in rpcauth_lookup_credcache()Trond Myklebust
The hash bucket is for some reason always being set to zero. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28Merge branch 'cleanups' into nextTrond Myklebust
2008-02-28SUNRPC: Remove now-redundant RCU-safe rpc_task free pathTrond Myklebust
Now that we've tightened up the locking rules for RPC queue wakeups, we can remove the RCU-safe kfree calls... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28SUNRPC: Eliminate the now-redundant rpc_start_wakeup()Trond Myklebust
2008-02-28SUNRPC: Switch tasks to using the rpc_waitqueue's timer functionTrond Myklebust
2008-02-28SUNRPC: Add a timer function to wait queues.Trond Myklebust
This is designed to replace the timeout timer in the individual rpc_tasks. By putting the timer function in the wait queue, we will eventually be able to reduce the total number of timers in use by the RPC subsystem. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-28SUNRPC: Add a (empty for the moment) destructor for rpc_wait_queuesTrond Myklebust
2008-02-25SUNRPC: Run rpc timeout functions as callbacks instead of in softirqsTrond Myklebust
An audit of the current RPC timeout functions shows that they don't really ever need to run in the softirq context. As long as the softirq is able to signal that the wakeup is due to a timeout (which it can do by setting task->tk_status to -ETIMEDOUT) then the callback functions can just run as standard task->tk_callback functions (in the rpciod/process context). The only possible border-line case would be xprt_timer() for the case of UDP, when the callback is used to reduce the size of the transport congestion window. In testing, however, the effect of moving that update to a callback would appear to be minor. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25SUNRPC: Convert users of rpc_wake_up_task to use rpc_wake_up_queued_taskTrond Myklebust
2008-02-25SUNRPC: Add a new helper rpc_wake_up_queued_task()Trond Myklebust
In all cases where we currently use rpc_wake_up_task(), we almost always know on which waitqueue the rpc_task is actually sleeping. This will allows us to simplify the queue locking in a future patch. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-25SUNRPC: Allow the rpc_release() callback to be run on another workqueueTrond Myklebust
A lot of the work done by the rpc_release() callback is inappropriate for rpciod as it will often involve things like starting a new rpc call in order to clean up state after an interrupted NFSv4 open() call, or calls to mntput(), etc. This patch allows the caller of rpc_run_task() to specify that the rpc_release callback should run on a different workqueue than the default rpciod_workqueue. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-14SUNRPC: Declare as const the rpc_message arguments to rpc_call_sync/asyncTrond Myklebust
2008-02-10nfsd: clean up svc_reserve_auth()J. Bruce Fields
This is a void function attempting to return the return value from another void function, which seems harmless but extremely weird, and apparently makes some compilers complain. While we're there, clean up a little (e.g. the switch statement had a minor style problem and seemed overkill as long as there's only one case). Thanks to Trond for noticing this. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-02-01SUNRPC: spin svc_rqst initialization to its own functionJeff Layton
Move the initialzation in __svc_create_thread that happens prior to thread creation to a new function. Export the function to allow services to have better control over the svc_rqst structs. Also rearrange the rqstp initialization to prevent NULL pointer dereferences in svc_exit_thread in case allocations fail. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01rdma: SVCRMDA Header FileTom Tucker
This file defines the data types used by the SVCRDMA transport module. The principle data structure is the transport specific extension to the svcxprt structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add svc_xprt_names service to replace svc_sock_namesTom Tucker
Create a transport independent version of the svc_sock_names function. The toclose capability of the svc_sock_names service can be implemented using the svc_xprt_find and svc_xprt_close services. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add svc API that queries for a transport instanceTom Tucker
Add a new svc function that allows a service to query whether a transport instance has already been created. This is used in lockd to determine whether or not a transport needs to be created when a lockd instance is brought up. Specifying 0 for the address family or port is effectively a wild-card, and will result in matching the first transport in the service's list that has a matching class name. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add /proc/sys/sunrpc/transport filesTom Tucker
Add a file that when read lists the set of registered svc transports. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Add transport hdr size for defer/revisitTom Tucker
Some transports have a header in front of the RPC header. The current defer/revisit processing considers only the iov_len and arg_len to determine how much to back up when saving the original request to revisit. Add a field to the rqstp structure to save the size of the transport header so svc_defer can correctly compute the start of a request. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the xprt independent code to the svc_xprt.c fileTom Tucker
This functionally trivial patch moves all of the transport independent functions from the svcsock.c file to the transport independent svc_xprt.c file. In addition the following formatting changes were made: - White space cleanup - Function signatures on single line - The inline directive was removed - Lines over 80 columns were reformatted - The term 'socket' was changed to 'transport' in comments - The SMP comment was moved and updated. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Removing remaining references to rq_sock in rqstpTom Tucker
This functionally empty patch removes rq_sock and unamed union from rqstp structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the sockaddr information to svc_xprtTom Tucker
This patch moves the transport sockaddr to the svc_xprt structure. Convenience functions are added to set and get the local and remote addresses of a transport from the transport provider as well as determine the length of a sockaddr. A transport is responsible for setting the xpt_local and xpt_remote addresses in the svc_xprt structure as part of transport creation and xpo_accept processing. This cannot be done in a generic way and in fact varies between TCP, UDP and RDMA. A set of xpo_ functions (e.g. getlocalname, getremotename) could have been added but this would have resulted in additional caching and copying of the addresses around. Note that the xpt_local address should also be set on listening endpoints; for TCP/RDMA this is done as part of endpoint creation. For connected transports like TCP and RDMA, the addresses never change and can be set once and copied into the rqstp structure for each request. For UDP, however, the local and remote addresses may change for each request. In this case, the address information is obtained from the UDP recvmsg info and copied into the rqstp structure from there. A svc_xprt_local_port function was also added that returns the local port given a transport. This is used by svc_create_xprt when returning the port associated with a newly created transport, and later when creating a generic find transport service to check if a service is already listening on a given port. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make deferral processing xprt independentTom Tucker
This patch moves the transport independent sk_deferred list to the svc_xprt structure and updates the svc_deferred_req structure to keep pointers to svc_xprt's directly. The deferral processing code is also moved out of the transport dependent recvfrom functions and into the generic svc_recv path. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move the authinfo cache to svc_xprt.Tom Tucker
Move the authinfo cache to svc_xprt. This allows both the TCP and RDMA transports to share this logic. A flag bit is used to determine if auth information is to be cached or not. Previously, this code looked at the transport protocol. I've also changed the spin_lock/unlock logic so that a lock is not taken for transports that are not caching auth info. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Remove sk_lastrecvTom Tucker
With the implementation of the new mark and sweep algorithm for shutting down old connections, the sk_lastrecv field is no longer needed. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Change svc_sock_received to svc_xprt_received and export itTom Tucker
All fields touched by svc_sock_received are now transport independent. Change it to use svc_xprt directly. This function is called from transport dependent code, so export it. Update the comment to clearly state the rules for calling this function. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make svc_send transport neutralTom Tucker
Move the sk_mutex field to the transport independent svc_xprt structure. Now all the fields that svc_send touches are transport neutral. Change the svc_send function to use the transport independent svc_xprt directly instead of the transport dependent svc_sock structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Move sk_reserved to svc_xprtTom Tucker
This functionally trivial patch moves the sk_reserved field to the transport independent svc_xprt structure. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-02-01svc: Make close transport independentTom Tucker
Move sk_list and sk_ready to svc_xprt. This involves close because these lists are walked by svcs when closing all their transports. So I combined the moving of these lists to svc_xprt with making close transport independent. The svc_force_sock_close has been changed to svc_close_all and takes a list as an argument. This removes some svc internals knowledge from the svcs. This code races with module removal and transport addition. Thanks to Simon Holm Thøgersen for a compile fix. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Cc: Simon Holm Thøgersen <odie@cs.aau.dk>
2008-02-01svc: Move sk_server and sk_pool to svc_xprtTom Tucker
This is another incremental change that moves transport independent fields from svc_sock to the svc_xprt structure. The changes should be functionally null. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Acked-by: Neil Brown <neilb@suse.de> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Reviewed-by: Greg Banks <gnb@sgi.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
