path: root/include/linux/synclink.h
2008-04-28synclink drivers bool conversionJoe Perches
Remove more TRUE/FALSE defines and uses Remove == TRUE tests Convert BOOLEAN to bool Convert int to bool where appropriate Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11synclink_gt: add compat_ioctlPaul Fulghum
Add support for 32 bit ioctl on 64 bit systems for synclink_gt Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-01[PATCH] synclink_gt: add bisync and monosync modesPaul Fulghum
Add bisync and monosync serial protocol support to the synclink_gt driver. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] synclink_gt: add GT2 adapter supportPaul Fulghum
Add support for SyncLink GT2 adapter to driver. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] add synclink_gt custom hdlc idlePaul Fulghum
Add custom HDLC idle pattern feature. It allows the user to specify an arbitrary 8 or 16 bit repeating pattern on the transmit data pin between HDLC frames. In most cases the idle pattern is continuous ones or flags as supported by off the shelf synchronous controllers and defined in the ISO3309 standard. Some applications (radio/satellite modems, connections to legacy military hardware) require non-standard patterns. Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] synclink_gt add gpio featurePaul Fulghum
Add driver support for general purpose I/O feature of the Synclink GT adapters. Signed-off-by: Paul Fulghum <paulkf@micrgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] new driver synclink_gtPaul Fulghum
New character device driver for the SyncLink GT and SyncLink AC families of synchronous and asynchronous serial adapters Signed-off-by: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
