path: root/include/linux/sysctl.h
2008-04-29sysctl: add the ->permissions callback on the ctl_table_rootPavel Emelyanov
When reading from/writing to some table, a root, which this table came from, may affect this table's permissions, depending on who is working with the table. The core hunk is at the bottom of this patch. All the rest is just pushing the ctl_table_root argument up to the sysctl_perm() function. This will be mostly (only?) used in the net sysctls. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: Denis V. Lunev <den@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29sysctl: clean from unneeded extern and forward declarationsPavel Emelyanov
The do_sysctl_strategy isn't used outside kernel/sysctl.c, so this can be static and without a prototype in header. Besides, move this one and parse_table() above their callers and drop the forward declarations of the latter call. One more "besides" - fix two checkpatch warnings: space before a ( and an extra space at the end of a line. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Cc: Denis V. Lunev <den@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29include/linux/sysctl.h: remove empty #elseAdrian Bunk
Remove an empty #else. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05capabilities: introduce per-process capability bounding setSerge E. Hallyn
The capability bounding set is a set beyond which capabilities cannot grow. Currently cap_bset is per-system. It can be manipulated through sysctl, but only init can add capabilities. Root can remove capabilities. By default it includes all caps except CAP_SETPCAP. This patch makes the bounding set per-process when file capabilities are enabled. It is inherited at fork from parent. Noone can add elements, CAP_SETPCAP is required to remove them. One example use of this is to start a safer container. For instance, until device namespaces or per-container device whitelists are introduced, it is best to take CAP_MKNOD away from a container. The bounding set will not affect pP and pE immediately. It will only affect pP' and pE' after subsequent exec()s. It also does not affect pI, and exec() does not constrain pI'. So to really start a shell with no way of regain CAP_MKNOD, you would do prctl(PR_CAPBSET_DROP, CAP_MKNOD); cap_t cap = cap_get_proc(); cap_value_t caparray[1]; caparray[0] = CAP_MKNOD; cap_set_flag(cap, CAP_INHERITABLE, 1, caparray, CAP_DROP); cap_set_proc(cap); cap_free(cap); The following test program will get and set the bounding set (but not pI). For instance ./bset get (lists capabilities in bset) ./bset drop cap_net_raw (starts shell with new bset) (use capset, setuid binary, or binary with file capabilities to try to increase caps) ************************************************************ cap_bound.c ************************************************************ #include <sys/prctl.h> #include <linux/capability.h> #include <sys/types.h> #include <unistd.h> #include <stdio.h> #include <stdlib.h> #include <string.h> #ifndef PR_CAPBSET_READ #define PR_CAPBSET_READ 23 #endif #ifndef PR_CAPBSET_DROP #define PR_CAPBSET_DROP 24 #endif int usage(char *me) { printf("Usage: %s get\n", me); printf(" %s drop <capability>\n", me); return 1; } #define numcaps 32 char *captable[numcaps] = { "cap_chown", "cap_dac_override", "cap_dac_read_search", "cap_fowner", "cap_fsetid", "cap_kill", "cap_setgid", "cap_setuid", "cap_setpcap", "cap_linux_immutable", "cap_net_bind_service", "cap_net_broadcast", "cap_net_admin", "cap_net_raw", "cap_ipc_lock", "cap_ipc_owner", "cap_sys_module", "cap_sys_rawio", "cap_sys_chroot", "cap_sys_ptrace", "cap_sys_pacct", "cap_sys_admin", "cap_sys_boot", "cap_sys_nice", "cap_sys_resource", "cap_sys_time", "cap_sys_tty_config", "cap_mknod", "cap_lease", "cap_audit_write", "cap_audit_control", "cap_setfcap" }; int getbcap(void) { int comma=0; unsigned long i; int ret; printf("i know of %d capabilities\n", numcaps); printf("capability bounding set:"); for (i=0; i<numcaps; i++) { ret = prctl(PR_CAPBSET_READ, i); if (ret < 0) perror("prctl"); else if (ret==1) printf("%s%s", (comma++) ? ", " : " ", captable[i]); } printf("\n"); return 0; } int capdrop(char *str) { unsigned long i; int found=0; for (i=0; i<numcaps; i++) { if (strcmp(captable[i], str) == 0) { found=1; break; } } if (!found) return 1; if (prctl(PR_CAPBSET_DROP, i)) { perror("prctl"); return 1; } return 0; } int main(int argc, char *argv[]) { if (argc<2) return usage(argv[0]); if (strcmp(argv[1], "get")==0) return getbcap(); if (strcmp(argv[1], "drop")!=0 || argc<3) return usage(argv[0]); if (capdrop(argv[2])) { printf("unknown capability\n"); return 1; } return execl("/bin/bash", "/bin/bash", NULL); } ************************************************************ [serue@us.ibm.com: fix typo] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Casey Schaufler <casey@schaufler-ca.com>a Signed-off-by: "Serge E. Hallyn" <serue@us.ibm.com> Tested-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[IPV4] route cache: Introduce rt_genid for smooth cache invalidationEric Dumazet
Current ip route cache implementation is not suited to large caches. We can consume a lot of CPU when cache must be invalidated, since we currently need to evict all cache entries, and this eviction is sometimes asynchronous. min_delay & max_delay can somewhat control this asynchronism behavior, but whole thing is a kludge, regularly triggering infamous soft lockup messages. When entries are still in use, this also consumes a lot of ram, filling dst_garbage.list. A better scheme is to use a generation identifier on each entry, so that cache invalidation can be performed by changing the table identifier, without having to scan all entries. No more delayed flushing, no more stalling when secret_interval expires. Invalidated entries will then be freed at GC time (controled by ip_rt_gc_timeout or stress), or when an invalidated entry is found in a chain when an insert is done. Thus we keep a normal equilibrium. This patch : - renames rt_hash_rnd to rt_genid (and makes it an atomic_t) - Adds a new rt_genid field to 'struct rtable' (filling a hole on 64bit) - Checks entry->rt_genid at appropriate places :
2008-01-28sysctl: Infrastructure for per namespace sysctlsEric W. Biederman
This patch implements the basic infrastructure for per namespace sysctls. A list of lists of sysctl headers is added, allowing each namespace to have it's own list of sysctl headers. Each list of sysctl headers has a lookup function to find the first sysctl header in the list, allowing the lists to have a per namespace instance. register_sysct_root is added to tell sysctl.c about additional lists of sysctl_headers. As all of the users are expected to be in kernel no unregister function is provided. sysctl_head_next is updated to walk through the list of lists. __register_sysctl_paths is added to add a new sysctl table on a non-default sysctl list. The only intrusive part of this patch is propagating the information to decided which list of sysctls to use for sysctl_check_table. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sysctl: Remember the ctl_table we passed to register_sysctl_pathsEric W. Biederman
By doing this we allow users of register_sysctl_paths that build and dynamically allocate their ctl_table to be simpler. This allows them to just remember the ctl_table_header returned from register_sysctl_paths from which they can now find the ctl_table array they need to free. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28sysctl: Add register_sysctl_paths functionEric W. Biederman
There are a number of modules that register a sysctl table somewhere deeply nested in the sysctl hierarchy, such as fs/nfs, fs/xfs, dev/cdrom, etc. They all specify several dummy ctl_tables for the path name. This patch implements register_sysctl_path that takes an additional path name, and makes up dummy sysctl nodes for each component. This patch was originally written by Olaf Kirch and brought to my attention and reworked some by Olaf Hering. I have changed a few additional things so the bugs are mine. After converting all of the easy callers Olaf Hering observed allyesconfig ARCH=i386, the patch reduces the final binary size by 9369 bytes. .text +897 .data -7008 text data bss dec hex filename 26959310 4045899 4718592 35723801 2211a19 ../vmlinux-vanilla 26960207 4038891 4718592 35717690 221023a ../O-allyesconfig/vmlinux So this change is both a space savings and a code simplification. CC: Olaf Kirch <okir@suse.de> CC: Olaf Hering <olaf@aepfle.de> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-20[S390] appldata: remove unused binary sysctls.Heiko Carstens
Remove binary sysctls that never worked due to missing strategy functions. Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-11-20[S390] cmm: remove unused binary sysctls.Heiko Carstens
Remove binary sysctls that never worked due to missing strategy functions. Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-18sysctl: Error on bad sysctl tablesEric W. Biederman
After going through the kernels sysctl tables several times it has become clear that code review and testing is just not effective in prevent problematic sysctl tables from being used in the stable kernel. I certainly can't seem to fix the problems as fast as they are introduced. Therefore this patch adds sysctl_check_table which is called when a sysctl table is registered and checks to see if we have a problematic sysctl table. The biggest part of the code is the table of valid binary sysctl entries, but since we have frozen our set of binary sysctls this table should not need to change, and it makes it much easier to detect when someone unintentionally adds a new binary sysctl value. As best as I can determine all of the several hundred errors spewed on boot up now are legitimate. [bunk@kernel.org: kernel/sysctl_check.c must #include <linux/string.h>] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: properly register the irda binary sysctl numbersEric W. Biederman
Grumble. These numbers should have been in sysctl.h from the beginning if we ever expected anyone to use them. Oh well put them there now so we can find them and make maintenance easier. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: Factor out sysctl_data.Eric W. Biederman
There as been no easy way to wrap the default sysctl strategy routine except for returning 0. Which is not always what we want. The few instances I have seen that want different behaviour have written their own version of sysctl_data. While not too hard it is unnecessary code and has the potential for extra bugs. So to make these situations easier and make that part of sysctl more symetric I have factord sysctl_data out of do_sysctl_strategy and exported as a function everyone can use. Further having sysctl_data be an explicit function makes checking for badly formed sysctl tables much easier. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl core: Stop using the unnecessary ctl_table typedefEric W. Biederman
In sysctl.h the typedef struct ctl_table ctl_table violates coding style isn't needed and is a bit of a nuisance because it makes it harder to recognize ctl_table is a type name. So this patch removes it from the generic sysctl code. Hopefully I will have enough energy to send the rest of my patches will follow and to remove it from the rest of the kernel. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31Add CTL_PROC backAlexey Dobriyan
commit eab03ac7bd3e0da99eb9dc068772a85a5e3f3577 aka "[PATCH] Get rid of /proc/sys/proc" was good commit except strace(1) compile breakage it introduced: system.c:1581: error: 'CTL_PROC' undeclared here (not in a function) So, add dummy enum back. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-25[NETFILTER]: bridge-nf: filter bridged IPv4/IPv6 encapsulated in pppoe trafficMichael Milner
The attached patch by Michael Milner adds support for using iptables and ip6tables on bridged traffic encapsulated in ppoe frames, similar to what's already supported for vlan. Signed-off-by: Michael Milner <milner@blissisland.ca> Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Replace CONFIG_NET_DEBUG with sysctl.Stephen Hemminger
Covert network warning messages from a compile time to runtime choice. Removes kernel config option and replaces it with new /proc/sys/net/core/warnings. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Add two new spurious RTO responses to FRTOIlpo Järvinen
New sysctl tcp_frto_response is added to select amongst these responses: - Rate halving based; reuses CA_CWR state (default) - Very conservative; used to be the only one available (=1) - Undo cwr; undoes ssthresh and cwnd reductions (=2) The response with rate halving requires a new parameter to tcp_enter_cwr because FRTO has already reduced ssthresh and doing a second reduction there has to be prevented. In addition, to keep things nice on 80 cols screen, a local variable was added. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[TCP]: Add RFC3742 Limited Slow-Start, controlled by variable ↵John Heffner
sysctl_tcp_max_ssthresh. Signed-off-by: John Heffner <jheffner@psc.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-24[IPV6]: Disallow RH0 by default.YOSHIFUJI Hideaki
A security issue is emerging. Disallow Routing Header Type 0 by default as we have been doing for IPv4. Note: We allow RH2 by default because it is harmless. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-14[PATCH] sysctl: remove the proc_dir_entry member for the sysctl tablesEric W. Biederman
It isn't needed anymore, all of the users are gone, and all of the ctl_table initializers have been converted to use explicit names of the fields they are initializing. [akpm@osdl.org: NTFS fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: add a parent entry to ctl_table and set the parent entryEric W. Biederman
Add a parent entry into the ctl_table so you can walk the list of parents and find the entire path to a ctl_table entry. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: reimplement the sysctl proc supportEric W. Biederman
With this change the sysctl inodes can be cached and nothing needs to be done when removing a sysctl table. For a cost of 2K code we will save about 4K of static tables (when we remove de from ctl_table) and 70K in proc_dir_entries that we will not allocate, or about half that on a 32bit arch. The speed feels about the same, even though we can now cache the sysctl dentries :( We get the core advantage that we don't need to have a 1 to 1 mapping between ctl table entries and proc files. Making it possible to have /proc/sys vary depending on the namespace you are in. The currently merged namespaces don't have an issue here but the network namespace under /proc/sys/net needs to have different directories depending on which network adapters are visible. By simply being a cache different directories being visible depending on who you are is trivial to implement. [akpm@osdl.org: fix uninitialised var] [akpm@osdl.org: fix ARM build] [bunk@stusta.de: make things static] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: allow sysctl_perm to be called from outside of sysctl.cEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: factor out sysctl_head_next from do_sysctlEric W. Biederman
The current logic to walk through the list of sysctl table headers is slightly painful and implement in a way it cannot be used by code outside sysctl.c I am in the process of implementing a version of the sysctl proc support that instead of using the proc generic non-caching monster, just uses the existing sysctl data structure as backing store for building the dcache entries and for doing directory reads. To use the existing data structures however I need a way to get at them. [akpm@osdl.org: warning fix] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: remove support for CTL_ANYEric W. Biederman
There are currently no users in the kernel for CTL_ANY and it only has effect on the binary interface which is practically unused. So this complicates sysctl lookups for no good reason so just remove it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: register the ocfs2 sysctl numbersEric W. Biederman
ocfs2 was did not have the binary number it uses under CTL_FS registered in sysctl.h. Register it to avoid future conflicts, and change the name of the definition to be in line with the rest of the sysctl numbers. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: register the sysctl number used by the arlan driverEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: "John W. Linville" <linville@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: s390: move sysctl definitions to sysctl.hEric W. Biederman
We need to have the the definition of all top level sysctl directories registers in sysctl.h so we don't conflict by accident and cause abi problems. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move CTL_FRV into sysctl.h where it belongsEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] sysctl: move CTL_PM into sysctl.h where it belongsEric W. Biederman
2007-02-14[PATCH] sysctl: move CTL_SUNRPC to sysctl.h where it belongsEric W. Biederman
Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-08[X.25]: Adds /proc/sys/net/x25/x25_forward to control forwarding.Andrew Hendry
echo "1" > /proc/sys/net/x25/x25_forward To turn on x25_forwarding, defaults to off Requires the previous patch. Signed-off-by: Andrew Hendry <andrew.hendry@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-12Remove duplicate "have to" in commentRolf Eike Beer
Introduced in commit 7cc13edc139108bb527b692f0548dce6bc648572. Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-10[PATCH] sysctl: remove unused "context" paramAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andi Kleen <ak@suse.de> Cc: "David S. Miller" <davem@davemloft.net> Cc: David Howells <dhowells@redhat.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-02[DCCP]: Remove allocation of sysctl numbersGerrit Renker
This is in response to a request sent earlier by Eric W. Biederman and replaces all sysctl numbers for net.dccp.default with CTL_UNNUMBERED. It has been tested to compile and to work. Commiter note: I've removed the use of CTL_UNNUMBERED, not setting .ctl_name sets it to 0, that is the what CTL_UNNUMBERED is, reason is to avoid unneeded source code cluttering. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Adds the tx buffer sysctlsIan McDonald
This one got lost on the way from Ian to Gerrit to me, fix it. Signed-off-by: Ian McDonald <ian.mcdonald@jandi.co.nz> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[DCCP]: Add sysctls to control retransmission behaviourGerrit Renker
This adds 3 sysctls which govern the retransmission behaviour of DCCP control packets (3way handshake, feature negotiation). It removes 4 FIXMEs from the code. The close resemblance of sysctl variables to their TCP analogues is emphasised not only by their name, but also by giving them the same initial values. This is useful since there is not much practical experience with DCCP yet. Furthermore, with regard to the previous patch, it is now possible to limit the number of keepalive-Responses by setting net.dccp.default.request_retries (also a bit like in TCP). Lastly, added documentation of all existing DCCP sysctls. Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2006-12-02[TCP]: Restrict congestion control choices.Stephen Hemminger
Allow normal users to only choose among a restricted set of congestion control choices. The default is reno and what ever has been configured as default. But the policy can be changed by administrator at any time. For example, to allow any choice: cp /proc/sys/net/ipv4/tcp_available_congestion_control \ /proc/sys/net/ipv4/tcp_allowed_congestion_control Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[TCP]: Add tcp_available_congestion_control sysctl.Stephen Hemminger
Create /proc/sys/net/ipv4/tcp_available_congestion_control that reflects currently available TCP choices. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-11-06[PATCH] sysctl: implement CTL_UNNUMBEREDEric W. Biederman
This patch takes the CTL_UNNUMBERD concept from NFS and makes it available to all new sysctl users. At the same time the sysctl binary interface maintenance documentation is updated to mention and to describe what is needed to successfully maintain the sysctl binary interface. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-06[PATCH] sysctl: allow a zero ctl_name in the middle of a sysctl tableEric W. Biederman
Since it is becoming clear that there are just enough users of the binary sysctl interface that completely removing the binary interface from the kernel will not be an option for foreseeable future, we need to find a way to address the sysctl maintenance issues. The basic problem is that sysctl requires one central authority to allocate sysctl numbers, or else conflicts and ABI breakage occur. The proc interface to sysctl does not have that problem, as names are not densely allocated. By not terminating a sysctl table until I have neither a ctl_name nor a procname, it becomes simple to add sysctl entries that don't show up in the binary sysctl interface. Which allows people to avoid allocating a binary sysctl value when not needed. I have audited the kernel code and in my reading I have not found a single sysctl table that wasn't terminated by a completely zero filled entry. So this change in behavior should not affect anything. I think this mechanism eases the pain enough that combined with a little disciple we can solve the reoccurring sysctl ABI breakage. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (225 commits) [PATCH] Don't set calgary iommu as default y [PATCH] i386/x86-64: New Intel feature flags [PATCH] x86: Add a cumulative thermal throttle event counter. [PATCH] i386: Make the jiffies compares use the 64bit safe macros. [PATCH] x86: Refactor thermal throttle processing [PATCH] Add 64bit jiffies compares (for use with get_jiffies_64) [PATCH] Fix unwinder warning in traps.c [PATCH] x86: Allow disabling early pci scans with pci=noearly or disallowing conf1 [PATCH] x86: Move direct PCI scanning functions out of line [PATCH] i386/x86-64: Make all early PCI scans dependent on CONFIG_PCI [PATCH] Don't leak NT bit into next task [PATCH] i386/x86-64: Work around gcc bug with noreturn functions in unwinder [PATCH] Fix some broken white space in ia32_signal.c [PATCH] Initialize argument registers for 32bit signal handlers. [PATCH] Remove all traces of signal number conversion [PATCH] Don't synchronize time reading on single core AMD systems [PATCH] Remove outdated comment in x86-64 mmconfig code [PATCH] Use string instructions for Core2 copy/clear [PATCH] x86: - restore i8259A eoi status on resume [PATCH] i386: Split multi-line printk in oops output. ...
2006-09-26[PATCH] zone_reclaim: dynamic slab reclaimChristoph Lameter
Currently one can enable slab reclaim by setting an explicit option in /proc/sys/vm/zone_reclaim_mode. Slab reclaim is then used as a final option if the freeing of unmapped file backed pages is not enough to free enough pages to allow a local allocation. However, that means that the slab can grow excessively and that most memory of a node may be used by slabs. We have had a case where a machine with 46GB of memory was using 40-42GB for slab. Zone reclaim was effective in dealing with pagecache pages. However, slab reclaim was only done during global reclaim (which is a bit rare on NUMA systems). This patch implements slab reclaim during zone reclaim. Zone reclaim occurs if there is a danger of an off node allocation. At that point we 1. Shrink the per node page cache if the number of pagecache pages is more than min_unmapped_ratio percent of pages in a zone. 2. Shrink the slab cache if the number of the nodes reclaimable slab pages (patch depends on earlier one that implements that counter) are more than min_slab_ratio (a new /proc/sys/vm tunable). The shrinking of the slab cache is a bit problematic since it is not node specific. So we simply calculate what point in the slab we want to reach (current per node slab use minus the number of pages that neeed to be allocated) and then repeately run the global reclaim until that is unsuccessful or we have reached the limit. I hope we will have zone based slab reclaim at some point which will make that easier. The default for the min_slab_ratio is 5% Also remove the slab option from /proc/sys/vm/zone_reclaim_mode. [akpm@osdl.org: cleanups] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] x86: Allow users to force a panic on NMIDon Zickus
To quote Alan Cox: The default Linux behaviour on an NMI of either memory or unknown is to continue operation. For many environments such as scientific computing it is preferable that the box is taken out and the error dealt with than an uncorrected parity/ECC error get propogated. A small number of systems do generate NMI's for bizarre random reasons such as power management so the default is unchanged. In other respects the new proc/sys entry works like the existing panic controls already in that directory. This is separate to the edac support - EDAC allows supported chipsets to handle ECC errors well, this change allows unsupported cases to at least panic rather than cause problems further down the line. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-26[PATCH] x86: Add abilty to enable/disable nmi watchdog with sysctlDon Zickus
Adds a new /proc/sys/kernel/nmi call that will enable/disable the nmi watchdog. Signed-off-by: Don Zickus <dzickus@redhat.com> Signed-off-by: Andi Kleen <ak@suse.de>
2006-09-22[IPV6] NDISC: Add proxy_ndp sysctl.YOSHIFUJI Hideaki
We do not always need proxy NDP functionality even we enable forwarding. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NetLabel]: CIPSOv4 enginePaul Moore
Add support for the Commercial IP Security Option (CIPSO) to the IPv4 network stack. CIPSO has become a de-facto standard for trusted/labeled networking amongst existing Trusted Operating Systems such as Trusted Solaris, HP-UX CMW, etc. This implementation is designed to be used with the NetLabel subsystem to provide explicit packet labeling to LSM developers. The CIPSO/IPv4 packet labeling works by the LSM calling a NetLabel API function which attaches a CIPSO label (IPv4 option) to a given socket; this in turn attaches the CIPSO label to every packet leaving the socket without any extra processing on the outbound side. On the inbound side the individual packet's sk_buff is examined through a call to a NetLabel API function to determine if a CIPSO/IPv4 label is present and if so the security attributes of the CIPSO label are returned to the caller of the NetLabel API function. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-03[PATCH] ZVC/zone_reclaim: Leave 1% of unmapped pagecache pages for file I/OChristoph Lameter
It turns out that it is advantageous to leave a small portion of unmapped file backed pages if all of a zone's pages (or almost all pages) are allocated and so the page allocator has to go off-node. This allows recently used file I/O buffers to stay on the node and reduces the times that zone reclaim is invoked if file I/O occurs when we run out of memory in a zone. The problem is that zone reclaim runs too frequently when the page cache is used for file I/O (read write and therefore unmapped pages!) alone and we have almost all pages of the zone allocated. Zone reclaim may remove 32 unmapped pages. File I/O will use these pages for the next read/write requests and the unmapped pages increase. After the zone has filled up again zone reclaim will remove it again after only 32 pages. This cycle is too inefficient and there are potentially too many zone reclaim cycles. With the 1% boundary we may still remove all unmapped pages for file I/O in zone reclaim pass. However. it will take a large number of read and writes to get back to 1% again where we trigger zone reclaim again. The zone reclaim 2.6.16/17 does not show this behavior because we have a 30 second timeout. [akpm@osdl.org: rename the /proc file and the variable] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
