path: root/include/linux/syslog.h
2010-02-04syslog: use defined constants instead of raw numbersKees Cook
Right now the syslog "type" action are just raw numbers which makes the source difficult to follow. This patch replaces the raw numbers with defined constants for some level of sanity. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: John Johansen <john.johansen@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2010-02-04syslog: distinguish between /proc/kmsg and syscallsKees Cook
This allows the LSM to distinguish between syslog functions originating from /proc/kmsg access and direct syscalls. By default, the commoncaps will now no longer require CAP_SYS_ADMIN to read an opened /proc/kmsg file descriptor. For example the kernel syslog reader can now drop privileges after opening /proc/kmsg, instead of staying privileged with CAP_SYS_ADMIN. MAC systems that implement security_syslog have unchanged behavior. Signed-off-by: Kees Cook <kees.cook@canonical.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: John Johansen <john.johansen@canonical.com> Signed-off-by: James Morris <jmorris@namei.org>
