path: root/include/linux/tc_act
2009-01-30headers_check fix: tc_act/tc_pedit.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/tc_act/tc_pedit.h:19: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-01-30headers_check fix: tc_act/tc_mirred.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/tc_act/tc_mirred.h:16: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-01-30headers_check fix: tc_act/tc_gact.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/tc_act/tc_gact.h:19: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2008-09-12pkt_action: add new action skbeditAlexander Duyck
This new action will have the ability to change the priority and/or queue_mapping fields on an sk_buff. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-26[NET] tc_nat: header installStephen Hemminger
iproute2 build needs tc_nat.h header from kernel make install_headers. Signed-off-by: Stephen Hemminger <stephen.hemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[PKT_SCHED]: Add stateless NATHerbert Xu
Stateless NAT is useful in controlled environments where restrictions are placed on through traffic such that we don't need connection tracking to correctly NAT protocol-specific data. In particular, this is of interest when the number of flows or the number of addresses being NATed is large, or if connection tracking information has to be replicated and where it is not practical to do so. Previously we had stateless NAT functionality which was integrated into the IPv4 routing subsystem. This was a great solution as long as the NAT worked on a subnet to subnet basis such that the number of NAT rules was relatively small. The reason is that for SNAT the routing based system had to perform a linear scan through the rules. If the number of rules is large then major renovations would have take place in the routing subsystem to make this practical. For the time being, the least intrusive way of achieving this is to use the u32 classifier written by Alexey Kuznetsov along with the actions infrastructure implemented by Jamal Hadi Salim. The following patch is an attempt at this problem by creating a new nat action that can be invoked from u32 hash tables which would allow large number of stateless NAT rules that can be used/updated in constant time. The actual NAT code is mostly based on the previous stateless NAT code written by Alexey. In future we might be able to utilise the protocol NAT code from netfilter to improve support for other protocols. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-19[HEADERS] One line per header in Kbuild files to reduce conflictsDavid Woodhouse
2006-06-18Add generic Kbuild files for 'make headers_install'David Woodhouse
This adds the Kbuild files listing the files which are to be installed by the 'headers_install' make target, in generic directories. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-04-24[PKT_SCHED]: Introduce simple actions.Jamal Hadi Salim
And provide an example simply action in order to demonstrate usage. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
