path: root/include/linux/tee_drv.h
2018-01-11Merge tag 'tee-drv-dynamic-shm+fixes-for-v4.16' of ↵Olof Johansson
https://git.linaro.org/people/jens.wiklander/linux-tee into next/drivers This pull request updates the previous tee-drv-dynamic-shm-for-v4.16 pull request with five new patches fixing review comments and errors. Apart from three small fixes there's two larger patches that in the end checks that memory to be registered really is normal cached memory. * tag 'tee-drv-dynamic-shm+fixes-for-v4.16' of https://git.linaro.org/people/jens.wiklander/linux-tee: tee: shm: Potential NULL dereference calling tee_shm_register() tee: shm: don't put_page on null shm->pages tee: shm: make function __tee_shm_alloc static tee: optee: check type of registered shared memory tee: add start argument to shm_register callback Signed-off-by: Olof Johansson <olof@lixom.net>
2017-12-28tee: add start argument to shm_register callbackJens Wiklander
Adds a start argument to the shm_register callback to allow the callback to check memory type of the passed pages. Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-12-21Merge tag 'tee-drv-dynamic-shm-for-v4.16' of ↵Arnd Bergmann
https://git.linaro.org/people/jens.wiklander/linux-tee into next/drivers Pull "tee dynamic shm for v4.16" from Jens Wiklander: This pull request enables dynamic shared memory support in the TEE subsystem as a whole and in OP-TEE in particular. Global Platform TEE specification [1] allows client applications to register part of own memory as a shared buffer between application and TEE. This allows fast zero-copy communication between TEE and REE. But current implementation of TEE in Linux does not support this feature. Also, current implementation of OP-TEE transport uses fixed size pre-shared buffer for all communications with OP-TEE OS. This is okay in the most use cases. But this prevents use of OP-TEE in virtualized environments, because: a) We can't share the same buffer between different virtual machines b) Physically contiguous memory as seen by VM can be non-contiguous in reality (and as seen by OP-TEE OS) due to second stage of MMU translation. c) Size of this pre-shared buffer is limited. So, first part of this pull request adds generic register/unregister interface to tee subsystem. The second part adds necessary features into OP-TEE driver, so it can use not only static pre-shared buffer, but whole RAM to communicate with OP-TEE OS. This change is backwards compatible allowing older secure world or user space to work with newer kernels and vice versa. [1] https://www.globalplatform.org/specificationsdevice.asp * tag 'tee-drv-dynamic-shm-for-v4.16' of https://git.linaro.org/people/jens.wiklander/linux-tee: tee: shm: inline tee_shm_get_id() tee: use reference counting for tee_context tee: optee: enable dynamic SHM support tee: optee: add optee-specific shared pool implementation tee: optee: store OP-TEE capabilities in private data tee: optee: add registered buffers handling into RPC calls tee: optee: add registered shared parameters handling tee: optee: add shared buffer registration functions tee: optee: add page list manipulation functions tee: optee: Update protocol definitions tee: shm: add page accessor functions tee: shm: add accessors for buffer size and page offset tee: add register user memory tee: flexible shared memory pool creation
2017-12-15tee: shm: inline tee_shm_get_id()Volodymyr Babchuk
Now, when struct tee_shm is defined in public header, we can inline small getter functions like this one. Signed-off-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-12-15tee: use reference counting for tee_contextVolodymyr Babchuk
We need to ensure that tee_context is present until last shared buffer will be freed. Signed-off-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-12-15tee: shm: add page accessor functionsVolodymyr Babchuk
In order to register a shared buffer in TEE, we need accessor function that return list of pages for that buffer. Signed-off-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-12-15tee: shm: add accessors for buffer size and page offsetVolodymyr Babchuk
These two function will be needed for shared memory registration in OP-TEE Signed-off-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-12-15tee: add register user memoryJens Wiklander
Added new ioctl to allow users register own buffers as a shared memory. Signed-off-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> [jw: moved tee_shm_is_registered() declaration] [jw: added space after __tee_shm_alloc() implementation] Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-12-15tee: flexible shared memory pool creationJens Wiklander
Makes creation of shm pools more flexible by adding new more primitive functions to allocate a shm pool. This makes it easier to add driver specific shm pool management. Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org> Signed-off-by: Volodymyr Babchuk <vlad.babchuk@gmail.com>
2017-11-29tee: add tee_param_is_memref() for driver useJens Wiklander
Reviewed-by: Etienne Carriere <etienne.carriere@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-08-04tee: add forward declaration for struct deviceJerome Forissier
tee_drv.h references struct device, but does not include device.h nor platform_device.h. Therefore, if tee_drv.h is included by some file that does not pull device.h nor platform_device.h beforehand, we have a compile warning. Fix this by adding a forward declaration. Signed-off-by: Jerome Forissier <jerome.forissier@linaro.org> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
2017-03-09tee: generic TEE subsystemJens Wiklander
Initial patch for generic TEE subsystem. This subsystem provides: * Registration/un-registration of TEE drivers. * Shared memory between normal world and secure world. * Ioctl interface for interaction with user space. * Sysfs implementation_id of TEE driver A TEE (Trusted Execution Environment) driver is a driver that interfaces with a trusted OS running in some secure environment, for example, TrustZone on ARM cpus, or a separate secure co-processor etc. The TEE subsystem can serve a TEE driver for a Global Platform compliant TEE, but it's not limited to only Global Platform TEEs. This patch builds on other similar implementations trying to solve the same problem: * "optee_linuxdriver" by among others Jean-michel DELORME<jean-michel.delorme@st.com> and Emmanuel MICHEL <emmanuel.michel@st.com> * "Generic TrustZone Driver" by Javier González <javier@javigon.com> Acked-by: Andreas Dannenberg <dannenberg@ti.com> Tested-by: Jerome Forissier <jerome.forissier@linaro.org> (HiKey) Tested-by: Volodymyr Babchuk <vlad.babchuk@gmail.com> (RCAR H3) Tested-by: Scott Branden <scott.branden@broadcom.com> Reviewed-by: Javier González <javier@javigon.com> Signed-off-by: Jens Wiklander <jens.wiklander@linaro.org>
