path: root/include/linux/timerqueue.h
2011-04-26timers: Add rb_init_node() to allow for stack allocated rb nodesJohn Stultz
In cases where a timerqueue_node or some structure that utilizes a timerqueue_node is allocated on the stack, gcc would give warnings caused by the timerqueue_init()'s calling RB_CLEAR_NODE, which self-references the nodes uninitialized data. The solution is to create an rb_init_node() function that zeros the rb_node structure out and then calls RB_CLEAR_NODE(), and then call the new init function from timerqueue_init(). CC: Thomas Gleixner <tglx@linutronix.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-12-11timerqueue: Make timerqueue_getnext() static inlineThomas Gleixner
No point in calling a function just to dereference a pointer. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org>
2010-12-10timers: Rename timerlist infrastructure to timerqueueJohn Stultz
Thomas pointed out a namespace collision between the new timerlist infrastructure I introduced and the existing timer_list.c So to avoid confusion, I've renamed the timerlist infrastructure to timerqueue. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
