path: root/include/linux/timex.h
2008-05-01ntp: handle leap second via timerRoman Zippel
Remove the leap second handling from second_overflow(), which doesn't have to check for it every second anymore. With CONFIG_NO_HZ this also makes sure the leap second is handled close to the full second. Additionally this makes it possible to abort a leap second properly by resetting the STA_INS/STA_DEL status bits. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: remove current_tick_length()Roman Zippel
current_tick_length used to do a little more, but now it just returns tick_length, which we can also access directly at the few places, where it's needed. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: rename TICK_LENGTH_SHIFT to NTP_SCALE_SHIFTRoman Zippel
As TICK_LENGTH_SHIFT is used for more than just the tick length, the name isn't quite approriate anymore, so this renames it to NTP_SCALE_SHIFT. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: support for TAIRoman Zippel
This adds support for setting the TAI value (International Atomic Time). The value is reported back to userspace via timex (as we don't have a ntp_gettime() syscall). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: increase time_offset resolutionRoman Zippel
time_offset is already a 64bit value but its resolution barely used, so this makes better use of it by replacing SHIFT_UPDATE with TICK_LENGTH_SHIFT. Side note: the SHIFT_HZ in SHIFT_UPDATE was incorrect for CONFIG_NO_HZ and the primary reason for changing time_offset to 64bit to avoid the overflow. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: increase time_freq resolutionRoman Zippel
This changes time_freq to a 64bit value and makes it static (the only outside user had no real need to modify it). Intermediate values were already 64bit, so the change isn't that big, but it saves a little in shifts by replacing SHIFT_NSEC with TICK_LENGTH_SHIFT. PPM_SCALE is then used to convert between user space and kernel space representation. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01ntp: NTP4 user space bits updateRoman Zippel
This adds a few more things from the ntp nanokernel related to user space. It's now possible to select the resolution used of some values via STA_NANO and the kernel reports in which mode it works (pll/fll). If some values for adjtimex() are outside the acceptable range, they are now simply normalized instead of letting the syscall fail. I removed MOD_CLKA/MOD_CLKB as the mapping didn't really makes any sense, the kernel doesn't support setting the clock. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-09time: remove obsolete CLOCK_TICK_ADJUSTRoman Zippel
The first version of the ntp_interval/tick_length inconsistent usage patch was recently merged as bbe4d18ac2e058c56adb0cd71f49d9ed3216a405 http://git.kernel.org/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=bbe4d18ac2e058c56adb0cd71f49d9ed3216a405 While the fix did greatly improve the situation, it was correctly pointed out by Roman that it does have a small bug: If the users change clocksources after the system has been running and NTP has made corrections, the correctoins made against the old clocksource will be applied against the new clocksource, causing error. The second attempt, which corrects the issue in the NTP_INTERVAL_LENGTH definition has also made it up-stream as commit e13a2e61dd5152f5499d2003470acf9c838eab84 http://git.kernel.org/gitweb.cgi?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=e13a2e61dd5152f5499d2003470acf9c838eab84 Roman has correctly pointed out that CLOCK_TICK_ADJUST is calculated based on the PIT's frequency, and isn't really relevant to non-PIT driven clocksources (that is, clocksources other then jiffies and pit). This patch reverts both of those changes, and simply removes CLOCK_TICK_ADJUST. This does remove the granularity error correction for users of PIT and Jiffies clocksource users, but the granularity error but for the majority of users, it should be within the 500ppm range NTP can accommodate for. For systems that have granularity errors greater then 500ppm, the "ntp_tick_adj=" boot option can be used to compensate. [johnstul@us.ibm.com: provided changelog] [mattilinnanvuori@yahoo.com: maek ntp_tick_adj static] Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: john stultz <johnstul@us.ibm.com> Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: mingo@elte.hu Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-10ntp: correct inconsistent interval/tick_length usagejohn stultz
clocksource initialization and error accumulation. This corrects a 280ppm drift seen on some systems using acpi_pm, and affects other clocksources as well (likely to a lesser degree). Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-06read_current_timer() cleanupsAndrew Morton
- All implementations can be __devinit - The function prototypes were in asm/timex.h but they all must be the same, so create a single declaration in linux/timex.h. - uninline the sparc64 version to match the other architectures - Don't bother #defining ARCH_HAS_READ_CURRENT_TIMER to a particular value. [ezk@cs.sunysb.edu: fix build] Cc: "David S. Miller" <davem@davemloft.net> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-26time: add ADJ_OFFSET_SS_READJohn Stultz
Michael Kerrisk reported that a long standing bug in the adjtimex() system call causes glibc's adjtime(3) function to deliver the wrong results if 'delta' is NULL. add the ADJ_OFFSET_SS_READ API detail, which will be used by glibc to fix this API compatibility bug. Also see: http://bugzilla.kernel.org/show_bug.cgi?id=6761 [ mingo@elte.hu: added patch description and made it backwards compatible ] NOTE: the new flag is defined 0xa001 so that it returns -EINVAL on older kernels - this way glibc can use it safely. Suggested by Ulrich Drepper. Acked-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-20[IA64] remove time interpolatorBob Picco
Remove time_interpolator code (This is generic code, but only user was ia64. It has been superseded by the CONFIG_GENERIC_TIME code). Signed-off-by: Bob Picco <bob.picco@hp.com> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Peter Keilty <peter.keilty@hp.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2007-02-16[PATCH] HZ free ntpjohn stultz
Distangle the NTP update from HZ. This is necessary for dynamic tick enabled kernels. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] use cycle_t instead of u64 in struct time_interpolatorHelge Deller
The 32bit and 64bit PARISC Linux kernels suffers from the problem, that the gettimeofday() call sometimes returns non-monotonic times. The easiest way to fix this, is to drop the PARISC-specific implementation and switch over to the generic TIME_INTERPOLATION framework. But in order to make it even compile on 32bit PARISC, the patch below which touches the generic Linux code, is mandatory. More information and the full patch with the parisc-specific changes is included in this thread: http://lists.parisc-linux.org/pipermail/parisc-linux/2006-December/031003.html As far as I could see, this patch does not change anything for the existing architectures which use this framework (IA64 and SPARC64), since "cycles_t" is defined there as unsigned 64bit-integer anyway (which then makes this patch a no-change for them). Signed-off-by: Helge Deller <deller@gmx.de> Cc: <linux-arch@vger.kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-06[PATCH] provide tickadj defineRoman Zippel
Provide a tickadj compatibility define for archs still using it. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kernel/time/ntp.c: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global function static: - ntp_update_frequency() - make the following needlessly global variables static: - time_state - time_offset - time_constant - time_reftime - remove the following read-only global variable: - time_precision Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: cleanup defines and commentsRoman Zippel
Remove a few unused defines and remove obsolete information from comments. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: convert to the NTP4 reference modelRoman Zippel
This converts the kernel ntp model into a model which matches the nanokernel reference implementations. The previous patches already increased the resolution and precision of the computations, so that this conversion becomes quite simple. <linux@horizon.com> explains: The original NTP kernel interface was defined in units of microseconds. That's what Linux implements. As computers have gotten faster and can now split microseconds easily, a new kernel interface using nanosecond units was defined ("the nanokernel", confusing as that name is to OS hackers), and there's an STA_NANO bit in the adjtimex() status field to tell the application which units it's using. The current ntpd supports both, but Linux loses some possible timing resolution because of quantization effects, and the ntpd hackers would really like to be able to drop the backwards compatibility code. Ulrich Windl has been maintaining a patch set to do the conversion for years, but it's hard to keep in sync. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: convert time_freq to nsec valueRoman Zippel
This converts time_freq to a scaled nsec value and adds around 6bit of extra resolution. This pushes the time_freq to its 32bit limits so the calculatons have to be done with 64bit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: remove time_toleranceRoman Zippel
time_tolerance isn't changed at all in the kernel, so simply remove it, this simplifies the next patch, as it avoids a number of conversions. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add time_adjust to tick lengthRoman Zippel
This folds update_ntp_one_tick() into second_overflow() and adds time_adjust to the tick length, this makes time_next_adjust unnecessary. This slightly changes the adjtime() behaviour, instead of applying it to the next tick, it's applied to the next second. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: prescale time_offsetRoman Zippel
This converts time_offset into a scaled per tick value. This avoids now completely the crude compensation in second_overflow(). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add ntp_update_frequencyRoman Zippel
This introduces ntp_update_frequency() and deinlines ntp_clear() (as it's not performance critical). ntp_update_frequency() calculates the base tick length using tick_usec and adds a base adjustment, in case the frequency doesn't divide evenly by HZ. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] NTP: Move all the NTP related code to ntp.cjohn stultz
Move all the NTP related code to ntp.c [akpm@osdl.org: cleanups, build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-13[PATCH] headers_check: remove <asm/timex.h> from user exportDavid Woodhouse
There's useful stuff in <linux/timex.h> but <asm/timex.h> has nothing for userspace. Stop exporting it, and include it only from within the existing #ifdef __KERNEL__ part of <linux/timex.h> This fixes a 'make headers_check' failure on i386 because asm-i386/timex.h includes both asm-i386/tsc.h and asm-i386/processor.h, neither of which are exported to userspace. It's not entirely clear _why_ it includes either of these, but it does. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fix and optimize clock source updateRoman Zippel
This fixes the clock source updates in update_wall_time() to correctly track the time coming in via current_tick_length(). Optimize the fast paths to be as short as possible to keep the overhead low. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Let user request precision from current_tick_length()john stultz
Change the current_tick_length() function so it takes an argument which specifies how much precision to return in shifted nanoseconds. This provides a simple way to convert between NTPs internal nanoseconds shifted by (SHIFT_SCALE - 10) to other shifted nanosecond units that are used by the clocksource abstraction. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-26[PATCH] consolidate sys32/compat_adjtimexStephen Rothwell
Create compat_sys_adjtimex and use it an all appropriate places. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Arnd Bergmann <arnd@arndb.de> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] remove pps supportRoman Zippel
This removes the support for pps. It's completely unused within the kernel and is basically in the way for further cleanups. It should be easier to readd proper support for it after the rest has been converted to NTP4 (where the pps mechanisms are quite different from NTP3 anyway). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-17[PATCH] Provide an interface for getting the current tick lengthPaul Mackerras
This provides an interface for arch code to find out how many nanoseconds are going to be added on to xtime by the next call to do_timer. The value returned is a fixed-point number in 52.12 format in nanoseconds. The reason for this format is that it gives the full precision that the timekeeping code is using internally. The motivation for this is to fix a problem that has arisen on 32-bit powerpc in that the value returned by do_gettimeofday drifts apart from xtime if NTP is being used. PowerPC is now using a lockless do_gettimeofday based on reading the timebase register and performing some simple arithmetic. (This method of getting the time is also exported to userspace via the VDSO.) However, the factor and offset it uses were calculated based on the nominal tick length and weren't being adjusted when NTP varied the tick length. Note that 64-bit powerpc has had the lockless do_gettimeofday for a long time now. It also had an extremely hairy routine that got called from the 32-bit compat routine for adjtimex, which adjusted the factor and offset according to what it thought the timekeeping code was going to do. Not only was this only called if a 32-bit task did adjtimex (i.e. not if a 64-bit task did adjtimex), it was also duplicating computations from kernel/timer.c and it wasn't clear that it was (still) correct. The simple solution is to ask the timekeeping code how long the current jiffy will be on each timer interrupt, after calling do_timer. If this jiffy will be a different length from the last one, we then need to compute new values for the factor and offset used in the lockless do_gettimeofday. In this way we can keep xtime and do_gettimeofday in sync, even when NTP is varying the tick length. Note that when adjtimex varies the tick length, it almost always introduces the variation from the next tick on. The only case I could see where adjtimex would vary the length of the current tick is when an old-style adjtime adjustment is being cancelled. (It's not clear to me why the adjustment has to be cancelled immediately rather than from the next tick on.) Thus I don't see any real need for a hook in adjtimex; the rare case of an old-style adjustment being cancelled can be fixed up at the next tick. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: john stultz <johnstul@us.ibm.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] NTP shift_right cleanupjohn stultz
Create a macro shift_right() that avoids the numerous ugly conditionals in the NTP code that look like: if(a < 0) b = -(-a >> shift); else b = a >> shift; Replacing it with: b = shift_right(a, shift); This should have zero effect on the logic, however it should probably have a bit of testing just to be sure. Also replace open-coded min/max with the macros. Signed-off-by : John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] NTP: ntp-helper functionsjohn stultz
This patch cleans up a commonly repeated set of changes to the NTP state variables by adding two helper inline functions: ntp_clear(): Clears the ntp state variables ntp_synced(): Returns 1 if the system is synced with a time server. This was compile tested for alpha, arm, i386, x86-64, ppc64, s390, sparc, sparc64. Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
