commit 50b926e439620c469565e8be0f28be78f5fca1ce upstream
SD_PREFER_SIBLING is set at the CPU domain level if power saving isn't
enabled, leading to many cache misses on large machines as we traverse
looking for an idle shared cache to wake to. Change the enabler of
select_idle_sibling() to SD_SHARE_PKG_RESOURCES, and enable same at the
sibling domain level.
Reported-by: Lin Ming <ming.m.lin@intel.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1262612696.15495.15.camel@marge.simson.net>
Yanmin reported that both tbench and hackbench were significantly
hurt by trying to keep tasks local on these domains, esp on small
cache machines.
So disable it in order to promote spreading outside of the cache
domains.
Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com>
CC: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1255083400.8802.15.camel@laptop>
topology_thread_siblings: core
There were replaced by topology_core_cpumask and topology_thread_cpumask.
Sysbench thinks SD_BALANCE_WAKE is too agressive and kbuild doesn't
really mind too much, SD_BALANCE_NEWIDLE picks up most of the
slack.
On a dual socket, quad core, dual thread nehalem system:
sysbench (--num_threads=16):
SD_BALANCE_WAKE-: 13982 tx/s
SD_BALANCE_WAKE+: 15688 tx/s
kbuild (-j16):
SD_BALANCE_WAKE-: 47.648295846 seconds time elapsed ( +- 0.312% )
SD_BALANCE_WAKE+: 47.608607360 seconds time elapsed ( +- 0.026% )
(same within noise)
LKML-Reference: <new-submission>
And turn it on for NUMA and MC domains. This improves
locality in balancing decisions by keeping up to
capacity amount of tasks local before looking for idle
CPUs. (and twice the capacity if SD_POWERSAVINGS_BALANCE
is set.)
If we're looking to place a new task, we might as well find the
idlest position _now_, not 1 tick ago.
Make the idle balancer more agressive, to improve a
x264 encoding workload provided by Jason Garrett-Glaser:
NEXT_BUDDY NO_LB_BIAS
encoded 600 frames, 252.82 fps, 22096.60 kb/s
encoded 600 frames, 250.69 fps, 22096.60 kb/s
encoded 600 frames, 245.76 fps, 22096.60 kb/s
NO_NEXT_BUDDY LB_BIAS
encoded 600 frames, 344.44 fps, 22096.60 kb/s
encoded 600 frames, 346.66 fps, 22096.60 kb/s
encoded 600 frames, 352.59 fps, 22096.60 kb/s
NO_NEXT_BUDDY NO_LB_BIAS
encoded 600 frames, 425.75 fps, 22096.60 kb/s
encoded 600 frames, 425.45 fps, 22096.60 kb/s
encoded 600 frames, 422.49 fps, 22096.60 kb/s
Peter pointed out that this is better done via newidle_idx,
not via LB_BIAS, newidle balancing should look for where
there is load _now_, not where there was load 2 ticks ago.
Worst-case latencies are improved as well as no buddies
means less vruntime spread. (as per prior lkml discussions)
This change improves kbuild-peak parallelism as well.
Reported-by: Jason Garrett-Glaser <darkshikari@gmail.com>
LKML-Reference: <1253011667.9128.16.camel@marge.simson.net>
CPU level should have WAKE_AFFINE, whereas ALLNODES is dubious.
When merging select_task_rq_fair() and sched_balance_self() we lost
the use of wake_idx, restore that and set them to 0 to make wake
balancing more aggressive.
The problem with wake_idle() is that is doesn't respect things like
cpu_power, which means it doesn't deal well with SMT nor the recent
RT interaction.
To cure this, it needs to do what sched_balance_self() does, which
leads to the possibility of merging select_task_rq_fair() and
sched_balance_self().
Modify sched_balance_self() to:
- update_shares() when walking up the domain tree,
(it only called it for the top domain, but it should
have done this anyway), which allows us to remove
this ugly bit from try_to_wake_up().
- do wake_affine() on the smallest domain that contains
both this (the waking) and the prev (the wakee) cpu for
WAKE invocations.
Then use the top-down balance steps it had to replace wake_idle().
This leads to the dissapearance of SD_WAKE_BALANCE and
SD_WAKE_IDLE_FAR, with SD_WAKE_IDLE replaced with SD_BALANCE_WAKE.
SD_WAKE_AFFINE needs SD_BALANCE_WAKE to be effective.
Touch all topology bits to replace the old with new SD flags --
platforms might need re-tuning, enabling SD_BALANCE_WAKE
conditionally on a NUMA distance seems like a good additional
feature, magny-core and small nehalem systems would want this
enabled, systems with slow interconnects would not.
Now that SD_WAKE_IDLE doesn't make pipe-test suck anymore,
enable it by default for MC, CPU and NUMA domains.
Start the re-tuning of the balancer by turning on newidle.
It improves hackbench performance and parallelism on a 4x4 box.
The "perf stat --repeat 10" measurements give us:
domain0 domain1
-SD_BALANCE_NEWIDLE -SD_BALANCE_NEWIDLE:
2041.273208 task-clock-msecs # 9.354 CPUs ( +- 0.363% )
+SD_BALANCE_NEWIDLE -SD_BALANCE_NEWIDLE:
2086.326925 task-clock-msecs # 11.934 CPUs ( +- 0.301% )
+SD_BALANCE_NEWIDLE +SD_BALANCE_NEWIDLE:
2115.289791 task-clock-msecs # 12.158 CPUs ( +- 0.263% )
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Gautham R Shenoy <ego@in.ibm.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Re-organize the flag settings so that it's visible at a glance
which sched-domains flags are set and which not.
With the new balancer code we'll need to re-tune these details
anyway, so make it cleaner to make fewer mistakes down the
road ;-)
The idea is that multi-threading a core yields more work
capacity than a single thread, provide a way to express a
static gain for threads.
Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Acked-by: Gautham R Shenoy <ego@in.ibm.com>
LKML-Reference: <20090901083826.073345955@chello.nl>
Impact: cleanup, potential bugfix
Not sure what changed to expose this, but clearly that numa_node_id()
doesn't belong in mmzone.h (the inline in gfp.h is probably overkill, too).
In file included from include/linux/topology.h:34,
from arch/x86/mm/numa.c:2:
/home/rusty/patches-cpumask/linux-2.6/arch/x86/include/asm/topology.h:64:1: warning: "numa_node_id" redefined
In file included from include/linux/topology.h:32,
include/linux/mmzone.h:770:1: warning: this is the location of the previous definition
Cc: Mike Travis <travis@sgi.com>
LKML-Reference: <200903132343.37661.rusty@rustcorp.com.au>
Impact: cleanup
node_to_cpumask (and the blecherous node_to_cpumask_ptr which
contained a declaration) are replaced now everyone implements
cpumask_of_node.
Impact: reduce stack usage, use new cpumask API.
This actually uses topology_core_cpumask() and
topology_thread_cpumask(), removing the only users of
topology_core_siblings() and topology_thread_siblings()
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: linux-net-drivers@solarflare.com
Impact: change task balancing to save power more agressively
Add SD_BALANCE_NEWIDLE flag at MC level and CPU level
if sched_mc is set. This helps power savings and
will not affect performance when sched_mc=0
Ingo and Mike Galbraith have optimised the SD flags by
removing SD_BALANCE_NEWIDLE at MC and CPU level. This
helps performance but hurts power savings since this
slows down task consolidation by reducing the number
of times load_balance is run.
sched: fine-tune SD_MC_INIT
commit 14800984706bf6936bbec5187f736e928be5c218
Author: Mike Galbraith <efault@gmx.de>
Date: Fri Nov 7 15:26:50 2008 +0100
sched: re-tune balancing -- revert
commit 9fcd18c9e63e325dbd2b4c726623f760788d5aa8
Author: Ingo Molnar <mingo@elte.hu>
Date: Wed Nov 5 16:52:08 2008 +0100
This patch selectively enables SD_BALANCE_NEWIDLE flag
only when sched_mc is set to 1 or 2. This helps power savings
by task consolidation and also does not hurt performance at
sched_mc=0 where all power saving optimisations are turned off.
Signed-off-by: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Impact: cleanup
BALANCE_FOR_MC_POWER and similar macros defined in sched.h are
not constants and have various condition checks and significant
amount of code that is not suitable to be contain in a macro.
Also there could be side effects on the expressions passed to
some of them like test_sd_parent().
This patch converts all complex macros related to power savings
balance to inline functions.
Change arch_update_cpu_topology so it returns 1 if the cpu topology changed
and 0 if it didn't change. This will be useful for the next patch which adds
a call to this function in partition_sched_domains.
fine-tune the HT sched-domains parameters as well.
On a HT capable box, this increases lat_ctx performance from 23.87
usecs to 1.49 usecs:
# before
$ ./lat_ctx -s 0 2
"size=0k ovr=1.89
2 23.87
# after
$ ./lat_ctx -s 0 2
"size=0k ovr=1.84
2 1.49
Tune SD_MC_INIT the same way as SD_CPU_INIT:
unset SD_BALANCE_NEWIDLE, and set SD_WAKE_BALANCE.
This improves vmark by 5%:
vmark 132102 125968 125497 messages/sec avg 127855.66 .984
vmark 139404 131719 131272 messages/sec avg 134131.66 1.033
# *DOCUMENTATION*
Impact: improve wakeup affinity on NUMA systems, tweak SMP systems
Given the fixes+tweaks to the wakeup-buddy code, re-tweak the domain
balancing defaults on NUMA and SMP systems.
Turn on SD_WAKE_AFFINE which was off on x86 NUMA - there's no reason
why we would not want to have wakeup affinity across nodes as well.
(we already do this in the standard NUMA template.)
lat_ctx on a NUMA box is particularly happy about this change:
before:
| phoenix:~/l> ./lat_ctx -s 0 2
| "size=0k ovr=2.60
| 2 5.70
after:
| "size=0k ovr=2.65
| 2 2.07
a 2.75x speedup.
pipe-test is similarly happy about it too:
| phoenix:~/sched-tests> ./pipe-test
| 18.26 usecs/loop.
| 14.70 usecs/loop.
| 14.38 usecs/loop.
| 10.55 usecs/loop. # +WAKE_AFFINE on domain0+domain1
| 8.63 usecs/loop.
| 8.59 usecs/loop.
| 9.03 usecs/loop.
| 8.94 usecs/loop.
| 8.96 usecs/loop.
| 8.63 usecs/loop.
Also:
- disable SD_BALANCE_NEWIDLE on NUMA and SMP domains (keep it for siblings)
- enable SD_WAKE_BALANCE on SMP domains
Sysbench+postgresql improves all around the board, quite significantly:
.28-rc3-11474e2c .28-rc3-11474e2c-tune
1: 571 688 +17.08%
2: 1236 1206 -2.55%
4: 2381 2642 +9.89%
8: 4958 5164 +3.99%
16: 9580 9574 -0.07%
32: 7128 8118 +12.20%
64: 7342 8266 +11.18%
128: 7342 8064 +8.95%
256: 7519 7884 +4.62%
512: 7350 7731 +4.93%
SUM: 55412 59341 +6.62%
So it's a win both for the runup portion, the peak area and the tail.
This can result in an empty topology directory in sysfs, and requires
in-kernel users to protect all uses with #ifdef - see
<http://marc.info/?l=linux-netdev&m=120639033904472&w=2>.
The documentation of CPU topology specifies what the defaults should be if
only partial information is available from the hardware. So we can
provide these defaults as a fallback.
This patch:
- Adds default definitions of the 4 topology macros to <linux/topology.h>
- Changes drivers/base/topology.c to use the topology macros unconditionally
and to cope with definitions that aren't lvalues
- Updates documentation accordingly
[ From: Andrew Morton <akpm@linux-foundation.org>
- fold now-duplicated code
- fix layout
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Chandra Seetharaman <sekharan@us.ibm.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: John Hawkes <hawkes@sgi.com>
Cc: Zhang, Yanmin <yanmin.zhang@intel.com>
improve the sysbench ramp-up phase and its peak throughput on
a 16way NUMA box, by turning on WAKE_AFFINE:
tip/sched tip/sched+wake-affine
1: 700 830 +15.65%
2: 1465 1391 -5.28%
4: 3017 3105 +2.81%
8: 5100 6021 +15.30%
16: 10725 10745 +0.19%
32: 10135 10150 +0.16%
64: 9338 9240 -1.06%
128: 8599 8252 -4.21%
256: 8475 8144 -4.07%
SUM: 57558 57882 +0.56%
this change also improves lat_ctx from 6.69 usecs to 1.11 usec:
$ ./lat_ctx -s 0 2
"size=0k ovr=1.19
2 1.11
$ ./lat_ctx -s 0 2
"size=0k ovr=1.22
2 6.69
in sysbench it's an overall win with some weakness at the lots-of-clients
side. That happens because we now under-balance this workload
a bit. To counter that effect, turn on NEWIDLE:
wake-idle wake-idle+newidle
1: 830 834 +0.43%
2: 1391 1401 +0.65%
4: 3105 3091 -0.43%
8: 6021 6046 +0.42%
16: 10745 10736 -0.08%
32: 10150 10206 +0.55%
64: 9240 9533 +3.08%
128: 8252 8355 +1.24%
256: 8144 8384 +2.87%
SUM: 57882 58591 +1.21%
as a bonus this not only improves the many-clients case but
also improves the (more important) rampup phase.
sysbench is a workload that quickly breaks down if the
scheduler over-balances, so since it showed an improvement
under NEWIDLE this change is definitely good.
* Remove empty cpumask_t (and all non-zero/non-null) variables
in SD_*_INIT macros. Use memset(0) to clear. Also, don't
inline the initializer functions to save on stack space in
build_sched_domains().
* Merge change to include/linux/topology.h that uses the new
node_to_cpumask_ptr function in the nr_cpus_node macro into
this patch.
Depends on:
[mm-patch]: asm-generic-add-node_to_cpumask_ptr-macro.patch
[sched-devel]: sched: add new set_cpus_allowed_ptr function
Will be called each time the scheduling domains are rebuild.
Needed for architectures that don't have a static cpu topology.
WAKE_IDLE is too agressive on multi-core CPUs with the new
wake-affine code, keep it on for SMT/HT balancing alone
(where there's no cache affinity at all between logical CPUs).
whitespace cleanups in topology.h.
reactivate fork balancing.
most multicore CPUs today have shared L2 caches, so tune things so
that the spreading amongst cores is more aggressive.
reintroduce the 2.6.22 topology.h tunings again - they result in
slightly better balancing.
remove the last unused remains of cache_hot_time.
trivial cleanup: LOCAL_DISTANCE and REMOTE_DISTANCE are only used in
topology.h and inside an #ifndef section - limit their existence to
that #ifndef.
the Linux scheduler is starving a number of workloads. So default
to more agressive idle-balancing. This hurts lmbench context-switching
numbers (which was the main reason we sucked at idle-balancing for
such a long time) but the lmbench numbers are fine once the system is
minimally utilized.
Remove the SMT-nice feature which idles sibling cpus on SMT cpus to
facilitiate nice working properly where cpu power is shared. The idling of
cpus in the presence of runnable tasks is considered too fragile, easy to
break with outside code, and the complexity of managing this system if an
architecture comes along with many logical cores sharing cpu power will be
unworkable.
Remove the associated per_cpu_gain variable in sched_domains used only by
this code.
Also:
The reason is that with dynticks enabled, this code breaks without yet
further tweaks so dynticks brought on the rapid demise of this code. So
either we tweak this code or kill it off entirely. It was Ingo's preference
to kill it off. Either way this needs to happen for 2.6.21 since dynticks
has gone in.
Signed-off-by: Con Kolivas <kernel@kolivas.org>
Large sched domains can be very expensive to scan. Add an option SD_SERIALIZE
to the sched domain flags. If that flag is set then we make sure that no
other such domain is being balanced.
[akpm@osdl.org: build fix]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Cc: Peter Williams <pwil3058@bigpond.net.au>
Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com>
Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com>
With SMT, if the logical processor is busy, load balance happens for every
8msec(min)-16msec(max). There is no need to do this often, as this is just
for fairness(to maintain uniform runqueue lengths) and default time slice
anyhow is 100msec.
Appended patch increases this interval to 64msec(min)-128msec(max) when the
logical processor is busy.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Up to now sched group's cpu_power for each sched domain is initialized
independently. This made the setup code ugly as the new sched domains are
getting added.
Make the sched group cpu_power setup code generic, by using domain child
field and new domain flag in sched_domain. For most of the sched
domains(except NUMA), sched group's cpu_power is now computed generically
using the domain properties of itself and of the child domain.
sched groups in NUMA domains are setup little differently and hence they
don't use this generic mechanism.
Acked-by: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Paul Jackson <pj@sgi.com>
Introduce the child field in sched_domain struct and use it in
We will also use this field in cleaning up the sched group cpu_power
setup(done in a different patch) code.
sysfs entries 'sched_mc_power_savings' and 'sched_smt_power_savings' in
/sys/devices/system/cpu/ control the MC/SMT power savings policy for the
scheduler.
Based on the values (1-enable, 0-disable) for these controls, sched groups
cpu power will be determined for different domains. When power savings
policy is enabled and under light load conditions, scheduler will minimize
the physical packages/cpu cores carrying the load and thus conserving
power(with a perf impact based on the workload characteristics... see OLS
2005 CMP kernel scheduler paper for more details..)
Cc: Con Kolivas <kernel@kolivas.org>
Add a new sched domain for representing multi-core with shared caches
between cores. Consider a dual package system, each package containing two
cores and with last level cache shared between cores with in a package. If
there are two runnable processes, with this appended patch those two
processes will be scheduled on different packages.
On such systems, with this patch we have observed 8% perf improvement with
specJBB(2 warehouse) benchmark and 35% improvement with CFP2000 rate(with 2
users).
This new domain will come into play only on multi-core systems with shared
caches. On other systems, this sched domain will be removed by domain
degeneration code. This new domain can be also used for implementing power
savings policy (see OLS 2005 CMP kernel scheduler paper for more details..
I will post another patch for power savings policy soon)
Most of the arch/* file changes are for cpu_coregroup_map() implementation.
Some bits for zone reclaim exists in 2.6.15 but they are not usable. This
patch fixes them up, removes unused code and makes zone reclaim usable.
Zone reclaim allows the reclaiming of pages from a zone if the number of
free pages falls below the watermarks even if other zones still have enough
pages available. Zone reclaim is of particular importance for NUMA
machines. It can be more beneficial to reclaim a page than taking the
performance penalties that come with allocating a page on a remote zone.
Zone reclaim is enabled if the maximum distance to another node is higher
than RECLAIM_DISTANCE, which may be defined by an arch. By default
RECLAIM_DISTANCE is 20. 20 is the distance to another node in the same
component (enclosure or motherboard) on IA64. The meaning of the NUMA
distance information seems to vary by arch.
If zone reclaim is not successful then no further reclaim attempts will
occur for a certain time period (ZONE_RECLAIM_INTERVAL).
This patch was discussed before. See
http://marc.theaimsgroup.com/?l=linux-kernel&m=113519961504207&w=2
http://marc.theaimsgroup.com/?l=linux-kernel&m=113408418232531&w=2
http://marc.theaimsgroup.com/?l=linux-kernel&m=113389027420032&w=2
http://marc.theaimsgroup.com/?l=linux-kernel&m=113380938612205&w=2
This is the latest version of the scheduler cache-hot-auto-tune patch.
The first problem was that detection time scaled with O(N^2), which is
unacceptable on larger SMP and NUMA systems. To solve this:
- I've added a 'domain distance' function, which is used to cache
measurement results. Each distance is only measured once. This means
that e.g. on NUMA distances of 0, 1 and 2 might be measured, on HT
distances 0 and 1, and on SMP distance 0 is measured. The code walks
the domain tree to determine the distance, so it automatically follows
whatever hierarchy an architecture sets up. This cuts down on the boot
time significantly and removes the O(N^2) limit. The only assumption
is that migration costs can be expressed as a function of domain
distance - this covers the overwhelming majority of existing systems,
and is a good guess even for more assymetric systems.
[ People hacking systems that have assymetries that break this
assumption (e.g. different CPU speeds) should experiment a bit with
the cpu_distance() function. Adding a ->migration_distance factor to
the domain structure would be one possible solution - but lets first
see the problem systems, if they exist at all. Lets not overdesign. ]
Another problem was that only a single cache-size was used for measuring
the cost of migration, and most architectures didnt set that variable
up. Furthermore, a single cache-size does not fit NUMA hierarchies with
L3 caches and does not fit HT setups, where different CPUs will often
have different 'effective cache sizes'. To solve this problem:
- Instead of relying on a single cache-size provided by the platform and
sticking to it, the code now auto-detects the 'effective migration
cost' between two measured CPUs, via iterating through a wide range of
cachesizes. The code searches for the maximum migration cost, which
occurs when the working set of the test-workload falls just below the
'effective cache size'. I.e. real-life optimized search is done for
the maximum migration cost, between two real CPUs.
This, amongst other things, has the positive effect hat if e.g. two
CPUs share a L2/L3 cache, a different (and accurate) migration cost
will be found than between two CPUs on the same system that dont share
any caches.
(The reliable measurement of migration costs is tricky - see the source
for details.)
Furthermore i've added various boot-time options to override/tune
migration behavior.
Firstly, there's a blanket override for autodetection:
migration_cost=1000,2000,3000
will override the depth 0/1/2 values with 1msec/2msec/3msec values.
Secondly, there's a global factor that can be used to increase (or
decrease) the autodetected values:
migration_factor=120
will increase the autodetected values by 20%. This option is useful to
tune things in a workload-dependent way - e.g. if a workload is
cache-insensitive then CPU utilization can be maximized by specifying
migration_factor=0.
I've tested the autodetection code quite extensively on x86, on 3
P3/Xeon/2MB, and the autodetected values look pretty good:
Dual Celeron (128K L2 cache):
migration cost matrix (max_cache_size: 131072, cpu: 467 MHz):
[00] [01]
[00]: - 1.7(1)
[01]: 1.7(1) -
cacheflush times [2]: 0.0 (0) 1.7 (1784008)
Here the slow memory subsystem dominates system performance, and even
though caches are small, the migration cost is 1.7 msecs.
Dual HT P4 (512K L2 cache):
migration cost matrix (max_cache_size: 524288, cpu: 2379 MHz):
[00] [01] [02] [03]
[00]: - 0.4(1) 0.0(0) 0.4(1)
[01]: 0.4(1) - 0.4(1) 0.0(0)
[02]: 0.0(0) 0.4(1) - 0.4(1)
[03]: 0.4(1) 0.0(0) 0.4(1) -
cacheflush times [2]: 0.0 (33900) 0.4 (448514)
Here it can be seen that there is no migration cost between two HT
siblings (CPU#0/2 and CPU#1/3 are separate physical CPUs). A fast memory
system makes inter-physical-CPU migration pretty cheap: 0.4 msecs.
8-way P3/Xeon [2MB L2 cache]:
migration cost matrix (max_cache_size: 2097152, cpu: 700 MHz):
[00] [01] [02] [03] [04] [05] [06] [07]
[00]: - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[01]: 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[02]: 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[03]: 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[04]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1)
[05]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1)
[06]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1)
[07]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) -
cacheflush times [2]: 0.0 (0) 19.2 (19281756)
This one has huge caches and a relatively slow memory subsystem - so the
migration cost is 19 msecs.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: <wilder@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
Do some basic initial tuning.
Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au>
Reimplement the balance on exec balancing to be sched-domains aware. Use this
to also do balance on fork balancing. Make x86_64 do balance on fork over the
NUMA domain.
The problem that the non sched domains aware blancing became apparent on dual
core, multi socket opterons. What we want is for the new tasks to be sent to
a different socket, but more often than not, we would first load up our
sibling core, or fill two cores of a single remote socket before selecting a
new one.
This gives large improvements to STREAM on such systems.
Remove the very aggressive idle stuff that has recently gone into 2.6 - it is
going against the direction we are trying to go. Hopefully we can regain
performance through other methods.
Do CPU load averaging over a number of different intervals. Allow each
interval to be chosen by sending a parameter to source_load and target_load.
0 is instantaneous, idx > 0 returns a decaying average with the most recent
sample weighted at 2^(idx-1). To a maximum of 3 (could be easily increased).
So generally a higher number will result in more conservative balancing.
infrastructure for it.
Let it rip!
