path: root/include/linux/udp.h
2008-03-23[NET]: include/linux/udp.h - remove duplicate includeJoe Perches
Remove duplicate #include <linux/types.h> Combine #ifdef __KERNEL__ blocks Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[UDP]: Revert udplite and code split.David S. Miller
This reverts commit db1ed684f6c430c4cdad67d058688b8a1b5e607c ("[IPV6] UDP: Rename IPv6 UDP files."), commit 8be8af8fa4405652e6c0797db5465a4be8afb998 ("[IPV4] UDP: Move IPv4-specific bits to other file.") and commit e898d4db2749c6052072e9bc4448e396cbdeb06a ("[UDP]: Allow users to configure UDP-Lite."). First, udplite is of such small cost, and it is a core protocol just like TCP and normal UDP are. We spent enormous amounts of effort to make udplite share as much code with core UDP as possible. All of that work is less valuable if we're just going to slap a config option on udplite support. It is also causing build failures, as reported on linux-next, showing that the changeset was not tested very well. In fact, this is the second build failure resulting from the udplite change. Finally, the config options provided was a bool, instead of a modular option. Meaning the udplite code does not even get build tested by allmodconfig builds, and furthermore the user is not presented with a reasonable modular build option which is particularly needed by distribution vendors. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[UDP]: Allow users to configure UDP-Lite.YOSHIFUJI Hideaki
Let's give users an option for disabling UDP-Lite (~4K). old: | text data bss dec hex filename | 286498 12432 6072 305002 4a76a net/ipv4/built-in.o | 193830 8192 3204 205226 321aa net/ipv6/ipv6.o new (without UDP-Lite): | text data bss dec hex filename | 284086 12136 5432 301654 49a56 net/ipv4/built-in.o | 191835 7832 3076 202743 317f7 net/ipv6/ipv6.o Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-07-10[UDP]: Introduce UDP encapsulation type for L2TPJames Chapman
This patch adds a new UDP_ENCAP_L2TPINUDP encapsulation type for UDP sockets. When a UDP socket's encap_type is UDP_ENCAP_L2TPINUDP, the skb is delivered to a function pointed to by the udp_sock's encap_rcv funcptr. If the skb isn't wanted by L2TP, it returns >0, which causes it to be passed through to UDP. Include padding to put the new encap_rcv field on a 4-byte boundary. Previously, the only user of UDP encap sockets was ESP, so when CONFIG_XFRM was not defined, some of the encap code was compiled out. This patch changes that. As a result, udp_encap_rcv() will now do a little more work when CONFIG_XFRM is not defined. Signed-off-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_transport_header(skb)Arnaldo Carvalho de Melo
For the places where we need a pointer to the transport header, it is still legal to touch skb->h.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce udp_hdr(), remove skb->h.uhArnaldo Carvalho de Melo
2006-12-02[NET]: Annotate checksums in on-the-wire packets.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NET]: Supporting UDP-Lite (RFC 3828) in LinuxGerrit Renker
This is a revision of the previously submitted patch, which alters the way files are organized and compiled in the following manner: * UDP and UDP-Lite now use separate object files * source file dependencies resolved via header files net/ipv{4,6}/udp_impl.h * order of inclusion files in udp.c/udplite.c adapted accordingly [NET/IPv4]: Support for the UDP-Lite protocol (RFC 3828) This patch adds support for UDP-Lite to the IPv4 stack, provided as an extension to the existing UDPv4 code: * generic routines are all located in net/ipv4/udp.c * UDP-Lite specific routines are in net/ipv4/udplite.c * MIB/statistics support in /proc/net/snmp and /proc/net/udplite * shared API with extensions for partial checksum coverage [NET/IPv6]: Extension for UDP-Lite over IPv6 It extends the existing UDPv6 code base with support for UDP-Lite in the same manner as per UDPv4. In particular, * UDPv6 generic and shared code is in net/ipv6/udp.c * UDP-Litev6 specific extensions are in net/ipv6/udplite.c * MIB/statistics support in /proc/net/snmp6 and /proc/net/udplite6 * support for IPV6_ADDRFORM * aligned the coding style of protocol initialisation with af_inet6.c * made the error handling in udpv6_queue_rcv_skb consistent; to return `-1' on error on all error cases * consolidation of shared code [NET]: UDP-Lite Documentation and basic XFRM/Netfilter support The UDP-Lite patch further provides * API documentation for UDP-Lite * basic xfrm support * basic netfilter support for IPv4 and IPv6 (LOG target) Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-28[IPV4]: UDP header annotationsAl Viro
2006-06-30typo fixes: infomation -> informationAdrian Bunk
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
