path: root/include/linux/usb/usbnet.h
2011-04-28usbnet: Resubmit interrupt URB if device is openPaul Stewart
Resubmit interrupt URB if device is open. Use a flag set in usbnet_open() to determine this state. Also kill and free interrupt URB in usbnet_disconnect(). [Rebased off git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6.git] Signed-off-by: Paul Stewart <pstew@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14usbnet: Fix up 'FLAG_POINTTOPOINT' and 'FLAG_MULTI_PACKET' overlaps.huajun li
USB tethering does not work anymore since 2.6.39-rc2, but it's okay in -rc1. The root cause is the new added mask code 'FLAG_POINTTOPOINT' overlaps 'FLAG_MULTI_PACKET' in include/linux/usb/usbnet.h, this causes logic issue in rx_process(). This patch cleans up the overlap. Reported-and-Tested-by: Gottfried Haider <gottfried.haider@gmail.com> Signed-off-by: Huajun Li <huajun.li.lee@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-01usbnet: use eth%d name for known ethernet devicesArnd Bergmann
The documentation for the USB ethernet devices suggests that only some devices are supposed to use usb0 as the network interface name instead of eth0. The logic used there, and documented in Kconfig for CDC is that eth0 will be used when the mac address is a globally assigned one, but usb0 is used for the locally managed range that is typically used on point-to-point links. Unfortunately, this has caused a lot of pain on the smsc95xx device that is used on the popular pandaboard without an EEPROM to store the MAC address, which causes the driver to call random_ether_address(). Obviously, there should be a proper MAC addressed assigned to the device, and discussions are ongoing about how to solve this, but this patch at least makes sure that the default interface naming gets a little saner and matches what the user can expect based on the documentation, including for new devices. The approach taken here is to flag whether a device might be a point-to-point link with the new FLAG_POINTTOPOINT setting in the usbnet driver_info. A driver can set both FLAG_POINTTOPOINT and FLAG_ETHER if it is not sure (e.g. cdc_ether), or just one of the two. The usbnet framework only looks at the MAC address for device naming if both flags are set, otherwise it trusts the flag. Signed-off-by: Arnd Bergmann <arnd.bergmann@linaro.org> Tested-by: Andy Green <andy.green@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-30net/usb: Ethernet quirks for the LG-VL600 4G modemAndrzej Zaborowski
This adds a driver for the CDC Ethernet part of this modem. The device's ID is blacklisted in cdc_ether.c and is white-listed in this new driver because of the quirks needed to make it useful. The modem's firmware exposes a CDC ACM port for modem control and a CDC Ethernet port for network data. The descriptors look fine but both ports actually are some sort of multiplexers requiring non- standard headers added/removed from every packet or they get ignored. All information is based on a usb traffic log from a Windows machine. On the Verizon 4G network I've seen speeds up to 1.1MB/s so far with this driver, a speed-o-meter site reports 16.2Mbps/10.5Mbps. Userspace scripts are required to talk to the CDC ACM port. Signed-off-by: Andrzej Zaborowski <balrogg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-06usbnet: changes for upcoming cdc_ncm driverAlexey Orishko
Changes: include/linux/usb/usbnet.h: - a new flag to indicate driver's capability to accumulate IP packets in Tx direction and extract several packets from single skb in Rx direction. drivers/net/usb/usbnet.c: - the procedure of counting packets in usbnet was updated due to the accumulating of IP packets in the driver - no short packets are sent if indicated by the flag in driver_info structure Signed-off-by: Alexey Orishko <alexey.orishko@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-20USB: include/usb/*.h checkpatch cleanupGreg Kroah-Hartman
Lots of minor formatting cleanups in includes/usb/ to make checkpatch happier. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-17usbnet: Convert dev(dbg|err|warn|info) macros to netdev_<level>Joe Perches
These macros are too similar to the dev_<level> equivalents but take a usbnet * argument. Convert them to the recently introduced netdev_<level> macros and remove the old macros. The old macros had "\n" appended to the format string. Add the "\n" to the converted uses. Some existing uses of the dev<foo> macros in cdc_eem.c probably mistakenly had trailing "\n". No "\n" added there. Fix net1080 this/other log message inversion. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-03usbnet & cdc-ether: Autosuspend for online devicesOliver Neukum
Using remote wakeup and delayed transmission to allow online device to go into usb autosuspend. Minimal alternate support for devices that don't support remote wakeup. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10usbnet: Set link down initially for drivers that update link stateBen Hutchings
Some usbnet drivers update link state while others do not due to hardware limitations. Add a flag to distinguish those that do, and set the link down initially for their devices. This is intended to fix this bug: http://bugs.debian.org/444043 Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05usbnet: Use wwan%d interface name for mobile broadband devicesMarcel Holtmann
Add support for usbnet based devices like CDC-Ether to indicate that they are actually mobile broadband devices. In that case use wwan%d as default interface name. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22smsc95xx: fix transmission where ZLP is expectedSteve Glendinning
Usbnet framework assumes USB hardware doesn't handle zero length packets, but SMSC LAN95xx requires these to be sent for correct operation. This patch fixes an easily reproducible tx lockup when sending a frame that results in exactly 512 bytes in a USB transmission (e.g. a UDP frame with 458 data bytes, due to IP headers and our USB headers). It adds an extra flag to usbnet for the hardware driver to indicate that it can handle and requires the zero length packets. This patch should not affect other usbnet users, please also consider for -stable. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01usbnet: convert to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-14usbnet: add rx queue pausingJussi Kivilinna
Add rx queue pausing to usbnet. This is needed by rndis_wlan so that it can control rx queue and prevent received packets from being send forward before rndis_wlan receives and handles 'media connect'-indication. Without this establishing WPA connections is hard and fail often. [v2] - removed unneeded use of skb_clone Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04rndis_host: allow rndis_wlan to see all indicationsJussi Kivilinna
Allow rndis_wlan to see all indications. Currently rndis_host lets rndis_wlan to know about link state changes only, but there is whole set of other 802.11-specific indications that rndis_wlan should handle properly. So rename link_change() to indication() and convert rndis_wlan to use it. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04usbnet: allow "minidriver" to prevent urb unlinking on usbnet_stopJussi Kivilinna
rndis_wlan devices freeze after running usbnet_stop several times. It appears that firmware freezes in state where it does not respond to any RNDIS commands and device have to be physically unplugged/replugged. This patch lets minidrivers to disable unlink_urbs on usbnet_stop through new info flag. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Cc: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10usbnet: Add stop function pointer to 'struct rndis_data'.Jussi Kivilinna
Allow minidriver to know that netdev has stopped. This is to let wireless turn off radio when usbnet dev is stopped. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-30usbnet: Remove private stats structureHerbert Xu
Now that nothing uses the private stats structure we can remove it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-21export usbnet_get_ethernet_addr from usbnet and fixed cdc_ether.cPeter Holik
because of using the same function get_ethernet_addr as cdc_ether.c i export usbnet_get_ethernet_addr from usbnet and fixed cdc_ether (suggested by Oliver Neukum). Signed-off-by: Peter Holik <peter@holik.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21usbnet: support net_device_opsStephen Hemminger
Use net_device_ops for usbnet device, and export for use by other derived drivers. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21usbnet: allow type check of devdbg arguments in non-debug buildSteve Glendinning
Improve usbnet's devdbg to always type-check diagnostic arguments, like dev_dbg (device.h). This makes no change to the resulting size of usbnet modules. This patch also removes an #ifdef DEBUG directive from rndis_wlan so it's devdbg statements are always type-checked at compile time. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24USB: Standardize inclusion protection and add where missing.Robert P. J. Day
For the header files in include/linux/usb, add missing multiple inclusion protection and standardize what's already there. The apparent standards: * macro name of __LINUX_USB_headerfile_H * inclusion protection placed after leading comment block * macro name added as a comment on the final #endif * any obvious trivial whitespace cleanup associated with the above Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-31Move usbnet.h and rndis_host.h to include/linux/usbJussi Kivilinna
Move headers usbnet.h and rndis_host.h to include/linux/usb and fix includes for drivers/net/usb modules. Headers are moved because rndis_wlan will be outside drivers/net/usb in drivers/net/wireless and yet need these headers. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
