path: root/include/linux/videodev2.h
2011-05-20[media] v4l: Add M420 format definitionHans de Goede
M420 is a hybrid YUV 4:2:0 packet/planar format. Two Y lines are followed by an interleaved U/V line. Signed-off-by: Hans de Goede <hdegoede@redhat.com> [laurent.pinchart@ideasonboard.com: split into v4l/uvcvideo patches] [laurent.pinchart@ideasonboard.com: add documentation] Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-20[media] Add Y10B, a 10 bpp bit-packed greyscale formatAntonio Ospite
Add a 10 bits per pixel greyscale format in a bit-packed array representation, naming it Y10B. Such pixel format is supplied for instance by the Kinect sensor device. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] v4l: add V4L2_PIX_FMT_Y12 formatMichael Jones
Y12 is a grey-scale format with a depth of 12 bits per pixel stored in 16-bit words. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] gspca - nw80x: New subdriver for Divio based webcamsJean-François Moine
[mchehab@redhat.com: Fix a few CodingStyle issues] Tested-by: Kjell Claesson <kjell.claesson@epost.tidanet.se> Tested-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-22[media] v4l: Add 12 bits bayer pixel formatsLaurent Pinchart
Add FCCs for the following pixel formats: - V4L2_PIX_FMT_SBGGR12 - V4L2_PIX_FMT_SGBRG12 - V4L2_PIX_FMT_SGRBG12 - V4L2_PIX_FMT_SRGGB12 Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: removal of old, obsolete ioctlsHans Verkuil
Some ioctl's were defined wrong on 2.6.2 and 2.6.6, using the wrong type of R/W arguments. They were fixed, but the old ioctl names are still there, maintained to avoid breaking binary compatibility: There's no sense on preserving those forever, as it is very doubtful that someone would try to use a such old binary with a modern kernel. Removing them will allow us to remove some magic done at the V4L ioctl handler. Note that any application compiled with a videodev2.h from 2.6.7 or later will be using the correct ioctls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: Add multiplanar format fourccs for s5p-fimc driverSylwester Nawrocki
Add definitions for format with color planes non-contiguous in physical memory. These formats apply only if the V4L2 multiplane extension is used. V4L2_PIX_FMT_NV12M - 2-plane Y/CbCr V4L2_PIX_FMT_NV12MT - 2-plane Y/CbCr tiled (64x32 pixel macroblocks) V4L2_PIX_FMT_YUV420M - 3-plane Y/Cb/Cr Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: Add multi-planar API definitions to the V4L2 APIPawel Osciak
Multi-planar API is as a backwards-compatible extension of the V4L2 API, which allows video buffers to consist of one or more planes. Planes are separate memory buffers; each has its own mapping, backed by usually separate physical memory buffers. Many different uses for the multi-planar API are possible, examples include: - embedded devices requiring video components to be placed in physically separate buffers, e.g. for Samsung S3C/S5P SoC series' video codec, Y and interleaved Cb/Cr components reside in buffers in different memory banks; - applications may receive (or choose to store) video data of one video buffer in separate memory buffers; such data would have to be temporarily copied together into one buffer before passing it to a V4L2 device; - applications or drivers may want to pass metadata related to a buffer and it may not be possible to place it in the same buffer, together with video data. [mchehab@redhat.com: CodingStyle fixes] Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21[media] V4L2: Add seek spacing and RDS CAP bitsMatti Aaltonen
Add spacing field to v4l2_hw_freq_seek. Add V4L2_TUNER_CAP_RDS_BLOCK_IO, which indicates that the tuner/ transmitter if capable of transmitting/receiving RDS blocks. Add V4L2_TUNER_CAP_RDS_CONTROLS capability, which indicates that the RDS data is handled as values of predefined controls like radio text, program ID and so on. Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l2-common: Move v4l2_find_nearest_format from videodev2.h to ↵Hans Verkuil
v4l2-common.h This function is an internal API and belongs in v4l2-common.h, not videodev.h. The return pointer and probe argument should be const as well. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: V4L2: add a generic function to find the nearest discrete format to ↵Guennadi Liakhovetski
the required one Many video drivers implement a fixed set of frame formats and thus face a task of finding the best match for a user-requested format. Implementing this in a generic function has also an advantage, that different drivers with similar supported format sets will select the same format for the user, which improves consistency across drivers. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: v4l2: Add illuminator controlsJean-François Moine
Some media devices (microscopes) may have one or many illuminators. This patch makes them controlable by the applications. Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Acked-by: Andy Walls <awalls@md.metrocast.net> Signed-off-by: Jean-François Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: gspca_konica: New gspca subdriver for konica chipset using camsHans de Goede
This new driver replaces the (known to not work / crash) usbvideo konicawc driver. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: gspca_xirlink_cit: New gspca subdriver replacing v4l1 usbvideo/ibmcam.cHans de Goede
The old usbvideo ibmcam driver needs to be replaced with a v4l2 driver preferably using the gspca webcam framework rather then the old usbvideo framework. This new gspca sub driver sets a first step in that direction. The ibmcam driver supports 4 different model webcams. This new driver (for now) only supports Model 3 cameras, as my test cam is a Model 3 cam, or so I thought. Upon reading: http://www.linux-usb.org/ibmcam/ I learned that the IBM Netcamera Pro I have even though having the same usb id and the same bcd version is different from the Model 3 cameras supported by the ibmcam driver. So this new gscpa subdriver supports Model 3 cameras (untested), and the IBM Netcamera Pro. Currently use with the IBM Netcamera Pro requires a module parameter. I hope to be able to autodetect which is which in the future. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-08V4L/DVB: v4l: Add driver for Samsung S5P SoC video postprocessorSylwester Nawrocki
This driver exports a video device node per each camera interface/ video postprocessor (FIMC) device contained in Samsung S5P SoC series. The driver is based on v4l2-mem2mem framework. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: Add a new ERROR flag for DQBUF after recoverable streaming errorsPawel Osciak
This flag is intended to indicate streaming errors, which might have resulted in corrupted video data in the buffer, but the buffer can still be reused and streaming may continue. Setting this flag and returning 0 is different from returning EIO. The latter should now indicate more serious (unrecoverable) errors. This patch also solves a problem with the ioctl handling code in vl42-ioctl.c, which does not copy buffer identification data back to the userspace when EIO is returned, so there is no way for applications to discover on which buffer the operation failed in such cases. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: v4l: add VSYNC and EOS events for use with ivtvHans Verkuil
2010-05-19V4L/DVB: V4L: Events: Add new ioctls for eventsSakari Ailus
This patch adds a set of new ioctls to the V4L2 API. The ioctls conform to V4L2 Events RFC version 2.3: <URL:http://www.spinics.net/lists/linux-media/msg12033.html> Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: core: add support for more color effectsXiaolin Zhang
Add support for more color effects (negative, sketch, emboss, etc) by extending the v4l2_colorfx enum items. Signed-off-by: Xiaolin Zhang <xiaolin.zhang@intel.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: videodev2.h: move definition of enum v4l2_ctrl_type to the other ↵Hans Verkuil
control types For some reason the definition of enum v4l2_ctrl_type is far from the place where it is actually needed. This makes it hard to work with this header. Move it to just before struct v4l2_queryctrl, which is the one that actually uses it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: v4l: Add V4L2_CID_IRIS_ABSOLUTE and V4L2_CID_IRIS_RELATIVE controlsLaurent Pinchart
Those control, as their names imply, control the camera aperture settings. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: v4l: add V4L2_PIX_FMT_Y4 and V4L2_PIX_FMT_Y6 pixelformatsHans Verkuil
Old 4 and 6 bit greyscale pixel formats for the old bw-qcam webcam. This is needed to convert it to V4L2. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB: videodev2: introduce a common control for chroma gainDevin Heitmueller
Introduce a new control for modifying the chroma gain. This allows for user intervention in abnormal signal conditions cases where the decoder's chroma AGC cannot compensate and the value needs to be adjusted manually. This work was sponsored by EyeMagnet Limited. Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-18V4L/DVB (12770): Add tm6000 driver to staging treeMauro Carvalho Chehab
Adds a driver for Trident TV Master tm5600/tm6000 chips. Those USB devices are usually found with a Xceive xc2028/xc3028 tuner, although the firmware seems to be modified to work with those chips on some older devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (14003): gspca_cpai1: New gspca subdriver for CPIA CPiA version 1 camsHans de Goede
This new driver supports USB PIA CPiA version 1 cams, replacing the old v4l1 driver. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB (13992): gspca_sn9c2028: New gspca subdriverTheodore Kilgore
New gspca subdriver adding support for SN9C2028 dual-mode cameras. Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13647): v4l: Add a 10-bit monochrome and missing 8- and 10-bit ↵Guennadi Liakhovetski
Bayer fourcc codes The 16-bit monochrome fourcc code has been previously abused for a 10-bit format, add a new 10-bit code instead. Also add missing 8- and 10-bit Bayer fourcc codes for completeness. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13571): v4l: Adding Digital Video Timings APIsMuralidharan Karicheri
This adds the above APIs to the v4l2 core. This is based on version v1.2 of the RFC titled "V4L - Support for video timings at the input/output interface" Following new ioctls are added:- - VIDIOC_ENUM_DV_PRESETS - VIDIOC_S_DV_PRESET - VIDIOC_G_DV_PRESET - VIDIOC_QUERY_DV_PRESET - VIDIOC_S_DV_TIMINGS - VIDIOC_G_DV_TIMINGS Please refer to the RFC for the details. This code was tested using vpfe capture driver on TI's DM365. Following is the test configuration used :- Blu-Ray HD DVD source -> TVP7002 -> DM365 (VPFE) ->DDR A draft version of the TVP7002 driver (currently being reviewed in the mailing list) was used that supports V4L2_DV_1080I60 & V4L2_DV_720P60 presets. A loopback video capture application was used for testing these APIs. This calls following IOCTLS :- - verify the new v4l2_input capabilities flag added - Enumerate available presets using VIDIOC_ENUM_DV_PRESETS - Set one of the supported preset using VIDIOC_S_DV_PRESET - Get current preset using VIDIOC_G_DV_PRESET - Detect current preset using VIDIOC_QUERY_DV_PRESET - Using stub functions in tvp7002, verify VIDIOC_S_DV_TIMINGS and VIDIOC_G_DV_TIMINGS ioctls are received at the sub device. - Tested on 64bit platform by Hans Verkuil Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-09Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (345 commits) V4L/DVB (13542): ir-keytable: Allow dynamic table change V4L/DVB (13541): atbm8830: replace 64-bit division and floating point usage V4L/DVB (13540): ir-common: Cleanup get key evdev code V4L/DVB (13539): ir-common: add __func__ for debug messages V4L/DVB (13538): ir-common: Use a dynamic keycode table V4L/DVB (13537): ir: Prepare the code for dynamic keycode table allocation V4L/DVB (13536): em28xx: Use the full RC5 code on HVR-950 Remote Controller V4L/DVB (13535): ir-common: Add a hauppauge new table with the complete RC5 code V4L/DVB (13534): ir-common: Remove some unused fields/structs V4L/DVB (13533): ir: use dynamic tables, instead of static ones V4L/DVB (13532): ir-common: Add infrastructure to use a dynamic keycode table V4L/DVB (13531): ir-common: rename the debug routine to allow exporting it V4L/DVB (13458): go7007: subdev conversion V4L/DVB (13457): s2250: subdev conversion V4L/DVB (13456): s2250: Change module structure V4L/DVB (13528): em28xx: add support for em2800 VC211A card em28xx: don't reduce scale to half size for em2800 em28xx: don't load audio modules when AC97 is mis-detected em28xx: em2800 chips support max width of 640 V4L/DVB (13523): dvb-bt8xx: fix compile warning ... Fix up trivial conflicts due to spelling fixes from the trivial tree in Documentation/video4linux/gspca.txt drivers/media/video/cx18/cx18-mailbox.h
2009-12-05V4L/DVB (13470): V4L2: Add Capability and Flag field for Chroma KeyVaibhav Hiremath
Signed-off-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-05V4L/DVB (13467): V4L2: Added CID's V4L2_CID_ROTATE/BG_COLORVaibhav Hiremath
2009-12-05V4L/DVB (13183): gspca: add stv0680 subdriverHans de Goede
This patch adds a new subdriver to gspca supporting cams with the stv0680 bridge (replacing the old in kernel v4l1 driver). Many thanks to Hans Verkuil for providing me with one of the 2 cams used in testing this new sub driver. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19V4L/DVB (12511): V4L2: add a new V4L2_CID_BAND_STOP_FILTER integer controlGuennadi Liakhovetski
Add a new V4L2_CID_BAND_STOP_FILTER integer control, which either switches the band-stop filter off, or sets it to a certain strength. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12625): Add new V4L2_FMT_FLAG_EMULATED flag to videodev2.hHans de Goede
V4L2_FMT_FLAG_EMULATED 0x0002 This format is not native to the device but emulated through software (usually libv4l2), where possible try to use a native format instead for better performance. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12548): v4l2: video device: Add V4L2_CTRL_CLASS_FM_TX controlsEduardo Valentin
This patch adds a new class of extended controls. This class is intended to support FM Radio Modulators properties such as: rds, audio limiters, audio compression, pilot tone generation, tuning power levels and preemphasis properties. Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12543): v4l: introduce string control support.Hans Verkuil
The upcoming RDS encoder needs support for string controls. This patch implements the core implementation. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12316): v4l: add V4L2_CAP_RDS_OUTPUT and V4L2_CAP_MODULATOR capsHans Verkuil
Add capabilities to describe an FM transmitter device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12212): v4l2: add RDS API to videodev2.hHans Verkuil
2009-09-12V4L/DVB (12149): videodev2.h: Reorganize fourcc tableMauro Carvalho Chehab
With the changes this file suffered along the time, things got a little disorganized. In particular, V4L2_PIX_FMT_YVYU were shown as a device-specific format, instead of yet another variant of YUV. There's no functional change on this patch. It just adds some comments and reorder fourcc formats to their proper places. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-24V4L/DVB (12283): gspca - sn9c20x: New subdriver for sn9c201 and sn9c202 bridges.Brian Johnson
Signed-off-by: Brian Johnson <brijohn@gmail.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-07-05V4L/DVB (12148): move V4L2_PIX_FMT_SGRBG8 to the proper placeMauro Carvalho Chehab
Instead of defining a new pif format on an internal header, move it to the V4L2 API header. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-23V4L/DVB (12079): gspca_ov519: add support for the ov511 bridgeHans de Goede
gspca_ov519: add support for the ov511 bridge Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-23V4L/DVB (12072): gspca-ov519: add extra controlsHans de Goede
This patch adds autobrightness (so that it can be turned off to make the already present brightness control work) and light frequency filtering controls. The lightfreq control needed 2 different entries in the ctrls array, as the number of options differs depending on the sensor. Always one of the 2 entires is disabled ofcourse. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-06-16V4L/DVB (11970): gspca - ov519: Add support for the ov518 bridge.Hans de Goede
Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11387): Sensor orientation reportingAdam Baker
Add support to the SQ-905 driver to pass back to user space the sensor orientation information obtained from the camera during init. Modifies gspca and the videodev2.h header to create the necessary API. [mchehab@redhat.com: Changed "Output is" to "Frames are" at the comments, as suggested at LMML] Signed-off-by: Adam Baker <linux@baker-net.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11213): gspca - sq905c: New subdriver.Theodore Kilgore
The code in the new sq905c.c is based upon the structure of the code in gspca/sq905.c, and upon the code in libgphoto2/camlibs/digigr8, which supports the same set of cameras in stillcam mode. I am a co-author of gspca/sq905.c and I am the sole author of libgphoto2/camlibs/digigr8, which is licensed under the LGPL. I hereby give myself permission to use my own code from libgphoto2 in gspca/sq905c.c. Signed-off-by: Theodore Kilgore <kilgota@auburn.edu> Signed-off-by: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11042): v4l2-api: Add definitions for V4L2_MPEG_STREAM_VBI_FMT_IVTV ↵Andy Walls
payloads This addition to the v4l2-api add definitions for the constants and data structures used for sliced VBI data insertion into MPEG streams triggered by V4L2_MPEG_STREAM_VBI_FMT_IVTV. This simply declares what the ivtv and cx18 drivers and MythTV have already been doing and provides a proper data structure definition to user space. Signed-off-by: Andy Walls <awalls@radix.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10910): videodev2.h: remove deprecated VIDIOC_G_CHIP_IDENT_OLDHans Verkuil
As announced VIDIOC_G_CHIP_IDENT_OLD is now removed for 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10686): v4l2: add V4L2_CTRL_FLAG_WRITE_ONLY flag.Hans Verkuil
