path: root/include/linux/virtio.h
2010-05-19virtio: add_buf_gfpMichael S. Tsirkin
Add an add_buf variant that gets gfp parameter. Use that to allocate indirect buffers. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio_ring: remove a level of indirectionMichael S. Tsirkin
We have a single virtqueue_ops implementation, and it seems unlikely we'll get another one at this point. So let's remove an unnecessary level of indirection: it would be very easy to re-add it if another implementation surfaces. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-05-19virtio: add virtqueue_ vq_ops wrappersMichael S. Tsirkin
Add inline functions that wrap vq->vq_ops-> calls Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-03-13net/9p: Add sysfs mount_tag file for virtio 9P deviceAneesh Kumar K.V
This adds a new file for virtio 9P device. The file contain details of the mount device name that should be used to mount the 9P file system. Ex: /sys/devices/virtio-pci/virtio1/mount_tag file now contian the tag name to be used to mount the 9P file system. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-02-24virtio: Add ability to detach unused buffers from vringsShirley Ma
There's currently no way for a virtio driver to ask for unused buffers, so it has to keep a list itself to reclaim them at shutdown. This is redundant, since virtio_ring stores that information. So add a new hook to do this. Signed-off-by: Shirley Ma <xma@us.ibm.com> Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: make add_buf return capacity remainingRusty Russell
This API change means that virtio_net can tell how much capacity remains for buffers. It's necessarily fuzzy, since VIRTIO_RING_F_INDIRECT_DESC means we can fit any number of descriptors in one, *if* we can kmalloc. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dinesh Subhraveti <dineshs@us.ibm.com>
2009-06-12virtio: add names to virtqueue struct, mapping from devices to queues.Rusty Russell
Add a linked list of all virtqueues for a virtio device: this helps for debugging and is also needed for upcoming interface change. Also, add a "name" field for clearer debug messages. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-06-12virtio: fix obsolete documentation on probe functionRusty Russell
2008-05-02virtio: explicit advertisement of driver featuresRusty Russell
A recent proposed feature addition to the virtio block driver revealed some flaws in the API: in particular, we assume that feature negotiation is complete once a driver's probe function returns. There is nothing in the API to require this, however, and even I didn't notice when it was violated. So instead, we require the driver to specify what features it supports in a table, we can then move the feature negotiation into the virtio core. The intersection of device and driver features are presented in a new 'features' bitmap in the struct virtio_device. Note that this highlights the difference between Linux unsigned-long bitmaps where each unsigned long is in native endian, and a straight-forward little-endian array of bytes. Drivers can still remove feature bits in their probe routine if they really have to. API changes: - dev->config->feature() no longer gets and acks a feature. - drivers should advertise their features in the 'feature_table' field - use virtio_has_feature() for extra sanity when checking feature bits Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-04-07virtio: remove overzealous BUG_ON.Rusty Russell
The 'disable_cb' callback is designed as an optimization to tell the host we don't need callbacks now. As it is not reliable, the debug check is overzealous: it can happen on two CPUs at the same time. Document this. Even if it were reliable, the virtio_net driver doesn't disable callbacks on transmit so the START_USE/END_USE debugging reentrance protection can be easily tripped even on UP. Thanks to Balaji Rao for the bug report and testing. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> CC: Balaji Rao <balajirrao@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-17virtio: fix race in enable_cbChristian Borntraeger
There is a race in virtio_net, dealing with disabling/enabling the callback. I saw the following oops: kernel BUG at /space/kvm/drivers/virtio/virtio_ring.c:218! illegal operation: 0001 [#1] SMP Modules linked in: sunrpc dm_mod CPU: 2 Not tainted 2.6.25-rc1zlive-host-10623-gd358142-dirty #99 Process swapper (pid: 0, task: 000000000f85a610, ksp: 000000000f873c60) Krnl PSW : 0404300180000000 00000000002b81a6 (vring_disable_cb+0x16/0x20) R:0 T:1 IO:0 EX:0 Key:0 M:1 W:0 P:0 AS:0 CC:3 PM:0 EA:3 Krnl GPRS: 0000000000000001 0000000000000001 0000000010005800 0000000000000001 000000000f3a0900 000000000f85a610 0000000000000000 0000000000000000 0000000000000000 000000000f870000 0000000000000000 0000000000001237 000000000f3a0920 000000000010ff74 00000000002846f6 000000000fa0bcd8 Krnl Code: 00000000002b819a: a7110001 tmll %r1,1 00000000002b819e: a7840004 brc 8,2b81a6 00000000002b81a2: a7f40001 brc 15,2b81a4 >00000000002b81a6: a51b0001 oill %r1,1 00000000002b81aa: 40102000 sth %r1,0(%r2) 00000000002b81ae: 07fe bcr 15,%r14 00000000002b81b0: eb7ff0380024 stmg %r7,%r15,56(%r15) 00000000002b81b6: a7f13e00 tmll %r15,15872 Call Trace: ([<000000000fa0bcd0>] 0xfa0bcd0) [<00000000002b8350>] vring_interrupt+0x5c/0x6c [<000000000010ab08>] do_extint+0xb8/0xf0 [<0000000000110716>] ext_no_vtime+0x16/0x1a [<0000000000107e72>] cpu_idle+0x1c2/0x1e0 The problem can be triggered with a high amount of host->guest traffic. I think its the following race: poll says netif_rx_complete poll calls enable_cb enable_cb opens the interrupt mask a new packet comes, an interrupt is triggered----\ enable_cb sees that there is more work | enable_cb disables the interrupt | . V . interrupt is delivered . skb_recv_done does atomic napi test, ok some waiting disable_cb is called->check fails->bang! . poll would do napi check poll would do disable_cb The fix is to let enable_cb not disable the interrupt again, but expect the caller to do the cleanup if it returns false. In that case, the interrupt is only disabled, if the napi test_set_bit was successful. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (cleaned up doco)
2008-02-04virtio: reset functionRusty Russell
A reset function solves three problems: 1) It allows us to renegotiate features, eg. if we want to upgrade a guest driver without rebooting the guest. 2) It gives us a clean way of shutting down virtqueues: after a reset, we know that the buffers won't be used by the host, and 3) It helps the guest recover from messed-up drivers. So we remove the ->shutdown hook, and the only way we now remove feature bits is via reset. We leave it to the driver to do the reset before it deletes queues: the balloon driver, for example, needs to chat to the host in its remove function. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: configuration change callbackRusty Russell
Various drivers want to know when their configuration information changes: the balloon driver is the immediate user, but the network driver may one day have a "carrier" status as well. This introduces that callback (lguest doesn't use it yet). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: explicit enable_cb/disable_cb rather than callback return.Rusty Russell
It seems that virtio_net wants to disable callbacks (interrupts) before calling netif_rx_schedule(), so we can't use the return value to do so. Rename "restart" to "cb_enable" and introduce "cb_disable" hook: callback now returns void, rather than a boolean. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Virtio interfaceRusty Russell
This attempts to implement a "virtual I/O" layer which should allow common drivers to be efficiently used across most virtual I/O mechanisms. It will no-doubt need further enhancement. The virtio drivers add buffers to virtio queues; as the buffers are consumed the driver "interrupt" callbacks are invoked. There is also a generic implementation of config space which drivers can query to get setup information from the host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dor Laor <dor.laor@qumranet.com> Cc: Arnd Bergmann <arnd@arndb.de>
