path: root/include/linux/virtio_config.h
2008-05-30virtio: force callback on empty.Rusty Russell
virtio allows drivers to suppress callbacks (ie. interrupts) for efficiency (no locking, it's just an optimization). There's a similar mechanism for the host to suppress notifications coming from the guest: in that case, we ignore the suppression if the ring is completely full. It turns out that life is simpler if the host similarly ignores callback suppression when the ring is completely empty: the network driver wants to free up old packets in a timely manner, and otherwise has to use a timer to poll. We have to remove the code which ignores interrupts when the driver has disabled them (again, it had no locking and hence was unreliable anyway). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-30virtio_config: fix len calculation of config elementsChristian Borntraeger
Rusty, This patch is a prereq for the virtio_blk blocksize patch, please apply it first. Adding an u32 value to the virtio_blk_config unconvered a small bug the config space defintions: v is a pointer, to we have to use sizeof(*v) instead of sizeof(v). Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02virtio: explicit advertisement of driver featuresRusty Russell
A recent proposed feature addition to the virtio block driver revealed some flaws in the API: in particular, we assume that feature negotiation is complete once a driver's probe function returns. There is nothing in the API to require this, however, and even I didn't notice when it was violated. So instead, we require the driver to specify what features it supports in a table, we can then move the feature negotiation into the virtio core. The intersection of device and driver features are presented in a new 'features' bitmap in the struct virtio_device. Note that this highlights the difference between Linux unsigned-long bitmaps where each unsigned long is in native endian, and a straight-forward little-endian array of bytes. Drivers can still remove feature bits in their probe routine if they really have to. API changes: - dev->config->feature() no longer gets and acks a feature. - drivers should advertise their features in the 'feature_table' field - use virtio_has_feature() for extra sanity when checking feature bits Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-05-02virtio: change config to guest endian.Rusty Russell
A recent proposed feature addition to the virtio block driver revealed some flaws in the API, in particular how easy it is to break big endian machines. The virtio config space was originally chosen to be little-endian, because we thought the config might be part of the PCI config space for virtio_pci. It's actually a separate mmio region, so that argument holds little water; as only x86 is currently using the virtio mechanism, we can change this (but must do so now, before the impending s390 merge). API changes: - __virtio_config_val() just becomes a striaght vdev->config_get() call. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: reset functionRusty Russell
A reset function solves three problems: 1) It allows us to renegotiate features, eg. if we want to upgrade a guest driver without rebooting the guest. 2) It gives us a clean way of shutting down virtqueues: after a reset, we know that the buffers won't be used by the host, and 3) It helps the guest recover from messed-up drivers. So we remove the ->shutdown hook, and the only way we now remove feature bits is via reset. We leave it to the driver to do the reset before it deletes queues: the balloon driver, for example, needs to chat to the host in its remove function. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: explicit enable_cb/disable_cb rather than callback return.Rusty Russell
It seems that virtio_net wants to disable callbacks (interrupts) before calling netif_rx_schedule(), so we can't use the return value to do so. Rename "restart" to "cb_enable" and introduce "cb_disable" hook: callback now returns void, rather than a boolean. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Virtio interfaceRusty Russell
This attempts to implement a "virtual I/O" layer which should allow common drivers to be efficiently used across most virtual I/O mechanisms. It will no-doubt need further enhancement. The virtio drivers add buffers to virtio queues; as the buffers are consumed the driver "interrupt" callbacks are invoked. There is also a generic implementation of config space which drivers can query to get setup information from the host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dor Laor <dor.laor@qumranet.com> Cc: Arnd Bergmann <arnd@arndb.de>
