path: root/include/linux/virtio_net.h
2019-02-27net: avoid false positives in untrusted gso validationWillem de Bruijn
commit 9e8db5913264d3967b93c765a6a9e464d9c473db upstream. GSO packets with vnet_hdr must conform to a small set of gso_types. The below commit uses flow dissection to drop packets that do not. But it has false positives when the skb is not fully initialized. Dissection needs skb->protocol and skb->network_header. Infer skb->protocol from gso_type as the two must agree. SKB_GSO_UDP can use both ipv4 and ipv6, so try both. Exclude callers for which network header offset is not known. Fixes: d5be7f632bad ("net: validate untrusted gso packets without csum offload") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-02-27net: validate untrusted gso packets without csum offloadWillem de Bruijn
commit d5be7f632bad0f489879eed0ff4b99bd7fe0b74c upstream. Syzkaller again found a path to a kernel crash through bad gso input. By building an excessively large packet to cause an skb field to wrap. If VIRTIO_NET_HDR_F_NEEDS_CSUM was set this would have been dropped in skb_partial_csum_set. GSO packets that do not set checksum offload are suspicious and rare. Most callers of virtio_net_hdr_to_skb already pass them to skb_probe_transport_header. Move that test forward, change it to detect parse failure and drop packets on failure as those cleary are not one of the legitimate VIRTIO_NET_HDR_GSO types. Fixes: bfd5f4a3d605 ("packet: Add GSO/csum offload support.") Fixes: f43798c27684 ("tun: Allow GSO using virtio_net_hdr") Reported-by: syzbot <syzkaller@googlegroups.com> Signed-off-by: Willem de Bruijn <willemb@google.com> Reviewed-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-10-18net/packet: fix packet drop as of virtio gsoJianfeng Tan
[ Upstream commit 9d2f67e43b73e8af7438be219b66a5de0cfa8bd9 ] When we use raw socket as the vhost backend, a packet from virito with gso offloading information, cannot be sent out in later validaton at xmit path, as we did not set correct skb->protocol which is further used for looking up the gso function. To fix this, we set this field according to virito hdr information. Fixes: e858fae2b0b8f4 ("virtio_net: use common code for virtio_net_hdr and skb GSO conversion") Signed-off-by: Jianfeng Tan <jianfeng.tan@linux.alibaba.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-06-26net: in virtio_net_hdr only add VLAN_HLEN to csum_start if payload holds vlanWillem de Bruijn
[ Upstream commit fd3a88625844907151737fc3b4201676effa6d27 ] Tun, tap, virtio, packet and uml vector all use struct virtio_net_hdr to communicate packet metadata to userspace. For skbuffs with vlan, the first two return the packet as it may have existed on the wire, inserting the VLAN tag in the user buffer. Then virtio_net_hdr.csum_start needs to be adjusted by VLAN_HLEN bytes. Commit f09e2249c4f5 ("macvtap: restore vlan header on user read") added this feature to macvtap. Commit 3ce9b20f1971 ("macvtap: Fix csum_start when VLAN tags are present") then fixed up csum_start. Virtio, packet and uml do not insert the vlan header in the user buffer. When introducing virtio_net_hdr_from_skb to deduplicate filling in the virtio_net_hdr, the variant from macvtap which adds VLAN_HLEN was applied uniformly, breaking csum offset for packets with vlan on virtio and packet. Make insertion of VLAN_HLEN optional. Convert the callers to pass it when needed. Fixes: e858fae2b0b8f4 ("virtio_net: use common code for virtio_net_hdr and skb GSO conversion") Fixes: 1276f24eeef2 ("packet: use common code for virtio_net_hdr and skb GSO conversion") Signed-off-by: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-17net: accept UFO datagrams from tuntap and packetWillem de Bruijn
[ Upstream commit 0c19f846d582af919db66a5914a0189f9f92c936 ] Tuntap and similar devices can inject GSO packets. Accept type VIRTIO_NET_HDR_GSO_UDP, even though not generating UFO natively. Processes are expected to use feature negotiation such as TUNSETOFFLOAD to detect supported offload types and refrain from injecting other packets. This process breaks down with live migration: guest kernels do not renegotiate flags, so destination hosts need to expose all features that the source host does. Partially revert the UFO removal from 182e0b6b5846~1..d9d30adf5677. This patch introduces nearly(*) no new code to simplify verification. It brings back verbatim tuntap UFO negotiation, VIRTIO_NET_HDR_GSO_UDP insertion and software UFO segmentation. It does not reinstate protocol stack support, hardware offload (NETIF_F_UFO), SKB_GSO_UDP tunneling in SKB_GSO_SOFTWARE or reception of VIRTIO_NET_HDR_GSO_UDP packets in tuntap. To support SKB_GSO_UDP reappearing in the stack, also reinstate logic in act_csum and openvswitch. Achieve equivalence with v4.13 HEAD by squashing in commit 939912216fa8 ("net: skb_needs_check() removes CHECKSUM_UNNECESSARY check for tx.") and reverting commit 8d63bee643f1 ("net: avoid skb_warn_bad_offload false positives on UFO"). (*) To avoid having to bring back skb_shinfo(skb)->ip6_frag_id, ipv6_proxy_select_ident is changed to return a __be32 and this is assigned directly to the frag_hdr. Also, SKB_GSO_UDP is inserted at the end of the enum to minimize code churn. Tested Booted a v4.13 guest kernel with QEMU. On a host kernel before this patch `ethtool -k eth0` shows UFO disabled. After the patch, it is enabled, same as on a v4.13 host kernel. A UFO packet sent from the guest appears on the tap device: host: nc -l -p -u 8000 & tcpdump -n -i tap0 guest: dd if=/dev/zero of=payload.txt bs=1 count=2000 nc -u 192.16.1.1 8000 < payload.txt Direct tap to tap transmission of VIRTIO_NET_HDR_GSO_UDP succeeds, packets arriving fragmented: ./with_tap_pair.sh ./tap_send_ufo tap0 tap1 (from https://github.com/wdebruij/kerneltools/tree/master/tests) Changes v1 -> v2 - simplified set_offload change (review comment) - documented test procedure Link: http://lkml.kernel.org/r/<CAF=yD-LuUeDuL9YWPJD9ykOZ0QCjNeznPDr6whqZ9NGMNF12Mw@mail.gmail.com> Fixes: fb652fdfe837 ("macvlan/macvtap: Remove NETIF_F_UFO advertisement.") Reported-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: Willem de Bruijn <willemb@google.com> Acked-by: Jason Wang <jasowang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-07-17net: Remove all references to SKB_GSO_UDP.David S. Miller
Such packets are no longer possible. Signed-off-by: David S. Miller <davem@davemloft.net>
2017-01-20virtio-net: restore VIRTIO_HDR_F_DATA_VALID on receivingJason Wang
Commit 501db511397f ("virtio: don't set VIRTIO_NET_HDR_F_DATA_VALID on xmit") in fact disables VIRTIO_HDR_F_DATA_VALID on receiving path too, fixing this by adding a hint (has_data_valid) and set it only on the receiving path. Cc: Rolf Neugebauer <rolf.neugebauer@docker.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Rolf Neugebauer <rolf.neugebauer@docker.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-01-17virtio: don't set VIRTIO_NET_HDR_F_DATA_VALID on xmitRolf Neugebauer
This patch part reverts fd2a0437dc33 and e858fae2b0b8 which introduced a subtle change in how the virtio_net flags are derived from the SKBs ip_summed field. With the above commits, the flags are set to VIRTIO_NET_HDR_F_DATA_VALID when ip_summed == CHECKSUM_UNNECESSARY, thus treating it differently to ip_summed == CHECKSUM_NONE, which should be the same. Further, the virtio spec 1.0 / CS04 explicitly says that VIRTIO_NET_HDR_F_DATA_VALID must not be set by the driver. Fixes: fd2a0437dc33 ("virtio_net: introduce virtio_net_hdr_{from,to}_skb") Fixes: e858fae2b0b8 (" virtio_net: use common code for virtio_net_hdr and skb GSO conversion") Signed-off-by: Rolf Neugebauer <rolf.neugebauer@docker.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-19virtio_net: Do not clear memory for struct virtio_net_hdr twice.Jarno Rajahalme
virtio_net_hdr_from_skb() clears the memory for the header, so there is no point for the callers to do the same. Signed-off-by: Jarno Rajahalme <jarno@ovn.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-11-19virtio_net.h: Fix comment.Jarno Rajahalme
Fix incorrent comment after the final #endif. Signed-off-by: Jarno Rajahalme <jarno@ovn.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-10virtio_net: introduce virtio_net_hdr_{from,to}_skbMike Rapoport
The code for conversion between virtio_net_hdr and skb GSO info is duplicated at several places. Let's put it to a common place to allow reuse. Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-10-13UAPI: (Scripted) Disintegrate include/linuxDavid Howells
Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Dave Jones <davej@redhat.com>
2012-04-15virtio-net: send gratuitous packets when neededJason Wang
As hypervior does not have the knowledge of guest network configuration, it's better to ask guest to send gratuitous packets when needed. This patch implements VIRTIO_NET_F_GUEST_ANNOUNCE feature: hypervisor would notice the guest when it thinks it's time for guest to announce the link presnece. Guest tests VIRTIO_NET_S_ANNOUNCE bit during config change interrupt and woule send gratuitous packets through netif_notify_peers() and ack the notification through ctrl vq. We need to make sure the atomicy of read and ack in guest otherwise we may ack more times than being notified. This is done through handling the whole config change interrupt in an non-reentrant workqueue. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-11virtio_net: introduce VIRTIO_NET_HDR_F_DATA_VALIDJason Wang
There's no need for the guest to validate the checksum if it have been validated by host nics. So this patch introduces a new flag - VIRTIO_NET_HDR_F_DATA_VALID which is used to bypass the checksum examing in guest. The backend (tap/macvtap) may set this flag when met skbs with CHECKSUM_UNNECESSARY to save cpu utilization. No feature negotiation is needed as old driver just ignore this flag. Iperf shows 12%-30% performance improvement for UDP traffic. For TCP, when gro is on no difference as it produces skb with partial checksum. But when gro is disabled, 20% or even higher improvement could be measured by netperf. Signed-off-by: Jason Wang <jasowang@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-30virtio: add full three-clause BSD text to headers.Rusty Russell
It's unclear to me if it's important, but it's obviously causing my technical colleages some headaches and I'd hate such imprecision to slow virtio adoption. I've emailed this to all non-trivial contributors for approval, too. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Ryan Harper <ryanh@us.ibm.com> Acked-by: Anthony Liguori <aliguori@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com> Acked-by: john cooper <john.cooper@redhat.com> Acked-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
2009-10-22virtio: let header files include virtio_ids.hChristian Borntraeger
Rusty, commit 3ca4f5ca73057a617f9444a91022d7127041970a virtio: add virtio IDs file moved all device IDs into a single file. While the change itself is a very good one, it can break userspace applications. For example if a userspace tool wanted to get the ID of virtio_net it used to include virtio_net.h. This does no longer work, since virtio_net.h does not include virtio_ids.h. This patch moves all "#include <linux/virtio_ids.h>" from the C files into the header files, making the header files compatible with the old ones. In addition, this patch exports virtio_ids.h to userspace. CC: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-09-23virtio: add virtio IDs fileFernando Luis Vazquez Cao
Virtio IDs are spread all over the tree which makes assigning new IDs bothersome. Putting them together should make the process less error-prone. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-07-30lguest and virtio: cleanup struct definitions to Linux style.Rusty Russell
I've been doing this for years, and akpm picked me up on it about 12 months ago. lguest partly serves as example code, so let's do it Right. Also, remove two unused fields in struct vblk_info in the example launcher. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@redhat.com>
2009-07-17virtio_net: Sync header with qemuAlex Williamson
Qemu added support for a few extra RX modes that Linux doesn't currently make use of. Sync the headers to maintain consistency. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-05-01virtio: add missing include to virtio_net.hGrant Likely
virtio_net.h uses the macro ETH_ALEN which is defined in linux/if_ether.h. Discovered when hacking on virtio-over-pci patches. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add support for VLAN filtering in the hypervisorAlex Williamson
VLAN filtering allows the hypervisor to drop packets from VLANs that we're not a part of, further reducing the number of extraneous packets recieved. This makes use of the VLAN virtqueue command class. The CTRL_VLAN feature bit tells us whether the backend supports VLAN filtering. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add a MAC filter tableAlex Williamson
Make use of the MAC control virtqueue class to support a MAC filter table. The filter table is managed by the hypervisor. We consider the table to be available if the CTRL_RX feature bit is set. We leave it to the hypervisor to manage the table and enable promiscuous or all-multi mode as necessary depending on the resources available to it. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add a set_rx_mode interfaceAlex Williamson
Make use of the RX_MODE control virtqueue class to enable the set_rx_mode netdev interface. This allows us to selectively enable/disable promiscuous and allmulti mode so we don't see packets we don't want. For now, we automatically enable these as needed if additional unicast or multicast addresses are requested. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-04virtio_net: Add a virtqueue for outbound control commandsAlex Williamson
This will be used for RX mode, MAC filter table, VLAN filtering, etc... The control transaction consists of one or more "out" sg entries and one or more "in" sg entries. The first out entry contains a header defining the class and command. Additional out entries may provide data for the command. The last in entry provides a status response back from the command. Virtqueues typically run asynchronous, running a callback function when there's data in the channel. We can't readily make use of this in the command paths where we need to use this. Instead, we kick the virtqueue and spin. The kick causes an I/O write, triggering an immediate trap into the hypervisor. Signed-off-by: Alex Williamson <alex.williamson@hp.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-03Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/Kconfig
2009-01-31headers_check fix: linux/virtio_net.hJaswinder Singh Rajput
fix the following 'make headers_check' warning: usr/include/linux/virtio_net.h:28: found __[us]{8,16,32,64} type without #include <linux/types.h> Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
2009-01-21virtio_net: add link status handlingMark McLoughlin
Allow the host to inform us that the link is down by adding a VIRTIO_NET_F_STATUS which indicates that device status is available in virtio_net config. This is currently useful for simulating link down conditions (e.g. using proposed qemu 'set_link' monitor command) but would also be needed if we were to support device assignment via virtio. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (added future masking) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16virtio_net: VIRTIO_NET_F_MSG_RXBUF (imprive rcv buffer allocation)Mark McLoughlin
If segmentation offload is enabled by the host, we currently allocate maximum sized packet buffers and pass them to the host. This uses up 20 ring entries, allowing us to supply only 20 packet buffers to the host with a 256 entry ring. This is a huge overhead when receiving small packets, and is most keenly felt when receiving MTU sized packets from off-host. The VIRTIO_NET_F_MRG_RXBUF feature flag is set by hosts which support using receive buffers which are smaller than the maximum packet size. In order to transfer large packets to the guest, the host merges together multiple receive buffers to form a larger logical buffer. The number of merged buffers is returned to the guest via a field in the virtio_net_hdr. Make use of this support by supplying single page receive buffers to the host. On receive, we extract the virtio_net_hdr, copy 128 bytes of the payload to the skb's linear data buffer and adjust the fragment offset to point to the remaining data. This ensures proper alignment and allows us to not use any paged data for small packets. If the payload occupies multiple pages, we simply append those pages as fragments and free the associated skbs. This scheme allows us to be efficient in our use of ring entries while still supporting large packets. Benchmarking using netperf from an external machine to a guest over a 10Gb/s network shows a 100% improvement from ~1Gb/s to ~2Gb/s. With a local host->guest benchmark with GSO disabled on the host side, throughput was seen to increase from 700Mb/s to 1.7Gb/s. Based on a patch from Herbert Xu. Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (use netdev_priv) Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25virtio: clarify that ABI is usable by any implementationsRusty Russell
We want others to implement and use virtio, so it makes sense to BSD license the non-__KERNEL__ parts of the headers to make this crystal clear. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Ryan Harper <ryanh@us.ibm.com> Acked-by: Eric Van Hensbergen <ericvh@gmail.com> Acked-by: Anthony Liguori <aliguori@us.ibm.com>
2008-06-10virtio: Fix typo in virtio_net_hdr commentsMark McLoughlin
Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-02virtio: finer-grained features for virtio_netRusty Russell
So, we previously had a 'VIRTIO_NET_F_GSO' bit which meant that 'the host can handle csum offload, and any TSO (v4&v6 incl ECN) or UFO packets you might want to send. I thought this was good enough for Linux, but it actually isn't, since we don't do UFO in software. So, add separate feature bits for what the host can handle. Add equivalent ones for the guest to say what it can handle, because LRO is coming too (thanks Herbert!). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: Tweak virtio_net definesRusty Russell
1) Turn GSO on virtio net into an all-or-nothing (keep checksumming separate). Having multiple bits is a pain: if you can't support something you should handle it in software, which is still a performance win. 2) Make VIRTIO_NET_HDR_GSO_ECN a flag in the header, so it can apply to IPv6 or v4. 3) Rename VIRTIO_NET_F_NO_CSUM to VIRTIO_NET_F_CSUM (ie. means we do checksumming). 4) Add csum and gso params to virtio_net to allow more testing. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: Net header needs hdr_lenRusty Russell
It's far easier to deal with packets if we don't have to parse the packet to figure out the header length to know how much to pull into the skb data. Add the field to the virtio_net_hdr struct (and fix the spaces that somehow crept in there). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-02-04virtio: simplify config mechanism.Rusty Russell
Previously we used a type/len pair within the config space, but this seems overkill. We now simply define a structure which represents the layout in the config space: the config space can now only be extended at the end. The main driver-visible changes: 1) We indicate what fields are present with an explicit feature bit. 2) Virtqueues are explicitly numbered, and not in the config space. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-23Net driver using virtioRusty Russell
The network driver uses two virtqueues: one for input packets and one for output packets. This has nice locking properties (ie. we don't do any for recv vs send). TODO: 1) Big packets. 2) Multi-client devices (maybe separate driver?). 3) Resolve freeing of old xmit skbs (Christian Borntraeger) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: netdev@vger.kernel.org
