path: root/include/linux/vmw_vmci_defs.h
2017-02-03vmw_vmci: switch to pci_irq_alloc_vectorsChristoph Hellwig
Cleans up the IRQ management code a lot, including removing a lot of state from the per-device structure. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-07VMCI: Use 32bit atomics for queue headers on X86_32Jorgen Hansen
This change restricts the reading and setting of the head and tail pointers on 32bit X86 to 32bit for both correctness and performance reasons. On uniprocessor X86_32, the atomic64_read may be implemented as a non-locked cmpxchg8b. This may result in updates to the pointers done by the VMCI device being overwritten. On MP systems, there is no such correctness issue, but using 32bit atomics avoids the overhead of the locked 64bit operation. All this is safe because the queue size on 32bit systems will never exceed a 32bit value. Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Jorgen Hansen <jhansen@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-08VMCI: Some header and config files.George Zhang
VMCI head config patch Adds all the necessary files to enable building of the VMCI module with the Linux Makefiles and Kconfig systems. Also adds the header files used for building modules against the driver. Signed-off-by: George Zhang <georgezhang@vmware.com> Acked-by: Andy king <acking@vmware.com> Acked-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
