path: root/include/linux/wait_bit.h
2018-05-03bdi: wake up concurrent wb_shutdown() callers.Tetsuo Handa
syzbot is reporting hung tasks at wait_on_bit(WB_shutting_down) in wb_shutdown() [1]. This seems to be because commit 5318ce7d46866e1d ("bdi: Shutdown writeback on all cgwbs in cgwb_bdi_destroy()") forgot to call wake_up_bit(WB_shutting_down) after clear_bit(WB_shutting_down). Introduce a helper function clear_and_wake_up_bit() and use it, in order to avoid similar errors in future. [1] https://syzkaller.appspot.com/bug?id=b297474817af98d5796bc544e1bb806fc3da0e5e Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Reported-by: syzbot <syzbot+c0cf869505e03bdf1a24@syzkaller.appspotmail.com> Fixes: 5318ce7d46866e1d ("bdi: Shutdown writeback on all cgwbs in cgwb_bdi_destroy()") Cc: Tejun Heo <tj@kernel.org> Reviewed-by: Jan Kara <jack@suse.cz> Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2018-03-20sched/wait: Remove the wait_on_atomic_t() APIPeter Zijlstra
There are no users left (everyone got converted to wait_var_event()), remove it. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2018-03-20sched/wait: Introduce wait_var_event()Peter Zijlstra
As a replacement for the wait_on_atomic_t() API provide the wait_var_event() API. The wait_var_event() API is based on the very same hashed-waitqueue idea, but doesn't care about the type (atomic_t) or the specific condition (atomic_read() == 0). IOW. it's much more widely applicable/flexible. It shares all the benefits/disadvantages of a hashed-waitqueue approach with the existing wait_on_atomic_t/wait_on_bit() APIs. The API is modeled after the existing wait_event() API, but instead of taking a wait_queue_head, it takes an address. This addresses is hashed to obtain a wait_queue_head from the bit_wait_table. Similar to the wait_event() API, it takes a condition expression as second argument and will wait until this expression becomes true. The following are (mostly) identical replacements: wait_on_atomic_t(&my_atomic, atomic_t_wait, TASK_UNINTERRUPTIBLE); wake_up_atomic_t(&my_atomic); wait_var_event(&my_atomic, !atomic_read(&my_atomic)); wake_up_var(&my_atomic); The only difference is that wake_up_var() is an unconditional wakeup and doesn't check the previously hard-coded (atomic_read() == 0) condition here. This is of little concequence, since most callers are already conditional on atomic_dec_and_test() and the ones that are not, are trivial to make so. Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-11-13Pass mode to wait_on_atomic_t() action funcs and provide default actionsDavid Howells
Make wait_on_atomic_t() pass the TASK_* mode onto its action function as an extra argument and make it 'unsigned int throughout. Also, consolidate a bunch of identical action functions into a default function that can do the appropriate thing for the mode. Also, change the argument name in the bit_wait*() function declarations to reflect the fact that it's the mode and not the bit number. [Peter Z gives this a grudging ACK, but thinks that the whole atomic_t wait should be done differently, though he's not immediately sure as to how] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> cc: Ingo Molnar <mingo@kernel.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-20sched/wait: Disambiguate wq_entry->task_list and wq_head->task_list namingIngo Molnar
So I've noticed a number of instances where it was not obvious from the code whether ->task_list was for a wait-queue head or a wait-queue entry. Furthermore, there's a number of wait-queue users where the lists are not for 'tasks' but other entities (poll tables, etc.), in which case the 'task_list' name is actively confusing. To clear this all up, name the wait-queue head and entry list structure fields unambiguously: struct wait_queue_head::task_list => ::head struct wait_queue_entry::task_list => ::entry For example, this code: rqw->wait.task_list.next != &wait->task_list ... is was pretty unclear (to me) what it's doing, while now it's written this way: rqw->wait.head.next != &wait->entry ... which makes it pretty clear that we are iterating a list until we see the head. Other examples are: list_for_each_entry_safe(pos, next, &x->task_list, task_list) { list_for_each_entry(wq, &fence->wait.task_list, task_list) { ... where it's unclear (to me) what we are iterating, and during review it's hard to tell whether it's trying to walk a wait-queue entry (which would be a bug), while now it's written as: list_for_each_entry_safe(pos, next, &x->head, entry) { list_for_each_entry(wq, &fence->wait.head, entry) { Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-06-20sched/wait: Move bit_wait_table[] and related functionality from ↵Ingo Molnar
sched/core.c to sched/wait_bit.c The key hashed waitqueue data structures and their initialization was done in the main scheduler file for no good reason, move them to sched/wait_bit.c instead. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-06-20sched/wait: Split out the wait_bit*() APIs from <linux/wait.h> into ↵Ingo Molnar
<linux/wait_bit.h> The wait_bit*() types and APIs are mixed into wait.h, but they are a pretty orthogonal extension of wait-queues. Furthermore, only about 50 kernel files use these APIs, while over 1000 use the regular wait-queue functionality. So clean up the main wait.h by moving the wait-bit functionality out of it, into a separate .h and .c file: include/linux/wait_bit.h for types and APIs kernel/sched/wait_bit.c for the implementation Update all header dependencies. This reduces the size of wait.h rather significantly, by about 30%. Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
