path: root/include/linux/wl12xx.h
2015-03-24wlcore: remove wl12xx_platform_dataEliad Peller
Now that we have wlcore device-tree bindings in place (for both wl12xx and wl18xx), remove the legacy wl12xx_platform_data struct, and move its members into the platform device data (that is passed to wlcore) Davinci 850 is the only platform that still set the platform data in the legacy way (and doesn't have DT bindings), so remove the relevant code/Kconfig option from the board file (as suggested by Sekhar Nori) Since no one currently uses wlcore_spi, simply remove its platform data support (DT bindings will have to be added if someone actually needs it) Signed-off-by: Luciano Coelho <luca@coelho.fi> Signed-off-by: Eliad Peller <eliad@wizery.com> Tested-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-24wl12xx: use frequency instead of enumerations for pdata clocksLuciano Coelho
Instead of defining an enumeration with the FW specific values for the different clock rates, use the actual frequency instead. Also add a boolean to specify whether the clock is XTAL or not. Change all board files to reflect this. Signed-off-by: Luciano Coelho <luca@coelho.fi> [Eliad - small fixes, update board file changes] Signed-off-by: Eliad Peller <eliad@wizery.com> Tested-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2015-03-19wlcore: set irq_trigger in board files instead of hiding behind a quirkLuciano Coelho
The platform_quirk element in the platform data was used to change the way the IRQ is triggered. When set, the EDGE_IRQ quirk would change the irqflags used and treat edge trigger differently from the rest. Instead of hiding this irq flag setting behind the quirk, have the board files set the irq_trigger explicitly. This will allow us to use standard irq DT definitions later on. Signed-off-by: Luciano Coelho <luca@coelho.fi> [Eliad - rebase, add irq_trigger field and pass it, update board file changes] Signed-off-by: Eliad Peller <eliad@wizery.com> Tested-by: Nikita Kiryanov <nikita@compulab.co.il> Acked-by: Kalle Valo <kvalo@codeaurora.org> Acked-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-02-28wl1251: move power GPIO handling into the driverSebastian Reichel
Move the power GPIO handling from the board code into the driver. This is a dependency for device tree support. Signed-off-by: Sebastian Reichel <sre@debian.org> Reviewed-by: Pavel Machek <pavel@ucw.cz> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2014-02-28wl1251: split wl251 platform data to a separate structureLuciano Coelho
Move the wl1251 part of the wl12xx platform data structure into a new structure specifically for wl1251. Change the platform data built-in block and board files accordingly. Signed-off-by: Luciano Coelho <coelho@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Reviewed-by: Felipe Balbi <balbi@ti.com> Reviewed-by: Sebastian Reichel <sre@debian.org> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2013-02-08wlcore: move wl12xx_platform_data up and make it truly optionalLuciano Coelho
The platform data is used not only by wlcore-based drivers, but also by wl1251. Move it up in the directory hierarchy to reflect this. Additionally, make it truly optional. At the moment, disabling platform data while wl1251_sdio or wlcore_sdio are enabled doesn't work, but it will be necessary when device tree support is implemented. Signed-off-by: Luciano Coelho <coelho@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com>
2013-02-08wlcore: remove if_ops from platform_dataLuciano Coelho
We can't pass pointers from the platform data to the modules, because with DT it cannot be done. Those pointers are not set by the board files anyway. It's the bus modules that set them, so they can be safely removed from the platform data without changing any board files. Create a new structure that the bus modules pass to wlcore. This structure contains the if_ops pointers and a pointer to the actual platform data. Signed-off-by: Luciano Coelho <coelho@ti.com> Reviewed-by: Felipe Balbi <balbi@ti.com>
2011-10-11wl12xx: move common init code from bus modules to mainFelipe Balbi
Move all common parts from sdio.c and spi.c to main.c, since they now can be handled as part of the platform driver. Signed-off-by: Felipe Balbi <balbi@ti.com> [forward-ported, cleaned-up and rephrased commit message] [added a bunch of fixes and a new pdata element] [moved some new code into main.c as well] Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-04-19wl12xx: Handle platforms without level trigger interruptsIdo Yariv
Some platforms are incapable of triggering on level interrupts. Add a platform quirks member in the platform data structure, as well as an edge interrupt quirk which can be set on such platforms. When the interrupt is requested with IRQF_TRIGGER_RISING, IRQF_ONESHOT cannot be used, as we might miss interrupts that occur after the FW status is cleared and before the threaded interrupt handler exits. Moreover, when IRQF_ONESHOT is not set, iterating more than once in the threaded interrupt handler introduces a few race conditions between this handler and the hardirq handler. Currently this is worked around by limiting the loop to one iteration only. This workaround has an impact on performance. To remove to this restriction, the race conditions will need to be addressed. Signed-off-by: Ido Yariv <ido@wizery.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-04-19wl12xx: Clean up and fix the 128x boot sequenceIdo Yariv
Clean up the boot sequence code & fix the following issues: 1. Always read the registers' values and set the relevant bits instead of zeroing all other bits 2. Handle cases where wl1271_top_reg_read returns an error 3. Verify that the HW can detect the selected clock source 4. Remove 128x PG10 initialization code 5. Configure the MCS PLL to work in HP mode Signed-off-by: Ido Yariv <ido@wizery.com> Reviewed-by: Luciano Coelho <coelho@ti.com> Signed-off-by: Luciano Coelho <coelho@ti.com>
2011-04-19wl12xx: add new board_tcxo_clock element to the platform dataLuciano Coelho
This new value is a new type of clock setting that is used by wl128x chipsets. Signed-off-by: Luciano Coelho <coelho@ti.com>
2010-11-15wl1271: ref_clock cosmetic changesGery Kahn
Cosmetic cleanup for ref_clock code while configured by board. Signed-off-by: Gery Kahn <geryk@ti.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-09-30wl12xx: fix non-wl12xx build scenariosOhad Ben-Cohen
Support building wl1271-equipped boards without building the wl1271 driver itself, e.g.: CONFIG_MACH_OMAP_ZOOM3=y CONFIG_WL12XX is not set Reported-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: Luciano Coelho <luciano.coelho@nokia.com>
2010-09-21wl1271: make ref_clock configurable by boardOhad Ben-Cohen
The wl1271 device is using a reference clock that may change between board to board. Make the ref_clock parameter configurable by board settings instead of having a hard coded value in the sources. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-21wl12xx: add platform data passing supportOhad Ben-Cohen
Add a simple mechanism to pass platform data to the SDIO instances of wl12xx. This way there is no confusion over who owns the 'embedded data', typechecking is preserved, and no possibility for the wrong driver to pick up the data. Originally proposed by Russell King. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-09-21wl12xx: make wl12xx.h common to both spi and sdioOhad Ben-Cohen
Move wl12xx.h outside of the spi-specific location, so it can be shared with both spi and sdio solutions. Update all users of spi/wl12xx.h accordingly Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Luciano Coelho <luciano.coelho@nokia.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
