path: root/include/linux/writeback.h
2008-04-30mm: bdi: export BDI attributes in sysfsPeter Zijlstra
Provide a place in sysfs (/sys/class/bdi) for the backing_dev_info object. This allows us to see and set the various BDI specific variables. In particular this properly exposes the read-ahead window for all relevant users and /sys/block/<block>/queue/read_ahead_kb should be deprecated. With patient help from Kay Sievers and Greg KH [mszeredi@suse.cz] - split off NFS and FUSE changes into separate patches - document new sysfs attributes under Documentation/ABI - do bdi_class_init as a core_initcall, otherwise the "default" BDI won't be initialized - remove bdi_init_fmt macro, it's not used very much [akpm@linux-foundation.org: fix ia64 warning] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kay Sievers <kay.sievers@vrfy.org> Acked-by: Greg KH <greg@kroah.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05writeback: speed up writeback of big dirty filesFengguang Wu
After making dirty a 100M file, the normal behavior is to start the writeback for all data after 30s delays. But sometimes the following happens instead: - after 30s: ~4M - after 5s: ~4M - after 5s: all remaining 92M Some analyze shows that the internal io dispatch queues goes like this: s_io s_more_io ------------------------- 1) 100M,1K 0 2) 1K 96M 3) 0 96M 1) initial state with a 100M file and a 1K file 2) 4M written, nr_to_write <= 0, so write more 3) 1K written, nr_to_write > 0, no more writes(BUG) nr_to_write > 0 in (3) fools the upper layer to think that data have all been written out. The big dirty file is actually still sitting in s_more_io. We cannot simply splice s_more_io back to s_io as soon as s_io becomes empty, and let the loop in generic_sync_sb_inodes() continue: this may starve newly expired inodes in s_dirty. It is also not an option to draw inodes from both s_more_io and s_dirty, an let the loop go on: this might lead to live locks, and might also starve other superblocks in sync time(well kupdate may still starve some superblocks, that's another bug). We have to return when a full scan of s_io completes. So nr_to_write > 0 does not necessarily mean that "all data are written". This patch introduces a flag writeback_control.more_io to indicate that more io should be done. With it the big dirty file no longer has to wait for the next kupdate invokation 5s later. In sync_sb_inodes() we only set more_io on super_blocks we actually visited. This avoids the interaction between two pdflush deamons. Also in __sync_single_inode() we don't blindly keep requeuing the io if the filesystem cannot progress. Failing to do so may lead to 100% iowait. Tested-by: Mike Snitzer <snitzer@gmail.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Michael Rubin <mrubin@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm/page-writeback: highmem_is_dirtyable optionBron Gondwana
Add vm.highmem_is_dirtyable toggle A 32 bit machine with HIGHMEM64 enabled running DCC has an MMAPed file of approximately 2Gb size which contains a hash format that is written randomly by the dbclean process. On 2.6.16 this process took a few minutes. With lowmem only accounting of dirty ratios, this takes about 12 hours of 100% disk IO, all random writes. Include a toggle in /proc/sys/vm/highmem_is_dirtyable which can be set to 1 to add the highmem back to the total available memory count. [akpm@linux-foundation.org: Fix the CONFIG_DETECT_SOFTLOCKUP=y build] Signed-off-by: Bron Gondwana <brong@fastmail.fm> Cc: Ethan Solomita <solo@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-14Revert "writeback: introduce writeback_control.more_io to indicate more io"Linus Torvalds
This reverts commit 2e6883bdf49abd0e7f0d9b6297fc3be7ebb2250b, as requested by Fengguang Wu. It's not quite fully baked yet, and while there are patches around to fix the problems it caused, they should get more testing. Says Fengguang: "I'll resend them both for -mm later on, in a more complete patchset". See http://bugzilla.kernel.org/show_bug.cgi?id=9738 for some of this discussion. Requested-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17introduce I_SYNCJoern Engel
I_LOCK was used for several unrelated purposes, which caused deadlock situations in certain filesystems as a side effect. One of the purposes now uses the new I_SYNC bit. Also document the various bits and change their order from historical to logical. [bunk@stusta.de: make fs/inode.c:wake_up_inode() static] Signed-off-by: Joern Engel <joern@wohnheim.fh-wedel.de> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: David Chinner <dgc@sgi.com> Cc: Anton Altaparmakov <aia21@cam.ac.uk> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17writeback: introduce writeback_control.more_io to indicate more ioFengguang Wu
After making dirty a 100M file, the normal behavior is to start the writeback for all data after 30s delays. But sometimes the following happens instead: - after 30s: ~4M - after 5s: ~4M - after 5s: all remaining 92M Some analyze shows that the internal io dispatch queues goes like this: s_io s_more_io ------------------------- 1) 100M,1K 0 2) 1K 96M 3) 0 96M 1) initial state with a 100M file and a 1K file 2) 4M written, nr_to_write <= 0, so write more 3) 1K written, nr_to_write > 0, no more writes(BUG) nr_to_write > 0 in (3) fools the upper layer to think that data have all been written out. The big dirty file is actually still sitting in s_more_io. We cannot simply splice s_more_io back to s_io as soon as s_io becomes empty, and let the loop in generic_sync_sb_inodes() continue: this may starve newly expired inodes in s_dirty. It is also not an option to draw inodes from both s_more_io and s_dirty, an let the loop go on: this might lead to live locks, and might also starve other superblocks in sync time(well kupdate may still starve some superblocks, that's another bug). We have to return when a full scan of s_io completes. So nr_to_write > 0 does not necessarily mean that "all data are written". This patch introduces a flag writeback_control.more_io to indicate this situation. With it the big dirty file no longer has to wait for the next kupdate invocation 5s later. Cc: David Chinner <dgc@sgi.com> Cc: Ken Chen <kenchen@google.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: per device dirty thresholdPeter Zijlstra
Scale writeback cache per backing device, proportional to its writeout speed. By decoupling the BDI dirty thresholds a number of problems we currently have will go away, namely: - mutual interference starvation (for any number of BDIs); - deadlocks with stacked BDIs (loop, FUSE and local NFS mounts). It might be that all dirty pages are for a single BDI while other BDIs are idling. By giving each BDI a 'fair' share of the dirty limit, each one can have dirty pages outstanding and make progress. A global threshold also creates a deadlock for stacked BDIs; when A writes to B, and A generates enough dirty pages to get throttled, B will never start writeback until the dirty pages go away. Again, by giving each BDI its own 'independent' dirty limit, this problem is avoided. So the problem is to determine how to distribute the total dirty limit across the BDIs fairly and efficiently. A DBI that has a large dirty limit but does not have any dirty pages outstanding is a waste. What is done is to keep a floating proportion between the DBIs based on writeback completions. This way faster/more active devices get a larger share than slower/idle devices. [akpm@linux-foundation.org: fix warnings] [hugh@veritas.com: Fix occasional hang when a task couldn't get out of balance_dirty_pages] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-10Fix warnings with !CONFIG_BLOCKJens Axboe
Hide everything in blkdev.h with CONFIG_BLOCK isn't set, and fixup the (few) files that fail to build because they were relying on blkdev.h pulling in extra includes for them. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-09VFS: Remove writeback_control->fs_privateTrond Myklebust
The only user of this field was NFS. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-08mm: set_page_dirty_balance() vs ->page_mkwrite()Peter Zijlstra
All the current page_mkwrite() implementations also set the page dirty. Which results in the set_page_dirty_balance() call to _not_ call balance, because the page is already found dirty. This allows us to dirty a _lot_ of pages without ever hitting balance_dirty_pages(). Not good (tm). Force a balance call if ->page_mkwrite() was successful. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11consolidate generic_writepages and mpage_writepagesMiklos Szeredi
Clean up massive code duplication between mpage_writepages() and generic_writepages(). The new generic function, write_cache_pages() takes a function pointer argument, which will be called for each page to be written. Maybe cifs_writepages() too can use this infrastructure, but I'm not touching that with a ten-foot pole. The upcoming page writeback support in fuse will also want this. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30NFS: Fix a race when doing NFS write coalescingTrond Myklebust
Currently we do write coalescing in a very inefficient manner: one pass in generic_writepages() in order to lock the pages for writing, then one pass in nfs_flush_mapping() and/or nfs_sync_mapping_wait() in order to gather the locked pages for coalescing into RPC requests of size "wsize". In fact, it turns out there is actually a deadlock possible here since we only start I/O on the second pass. If the user signals the process while we're in nfs_sync_mapping_wait(), for instance, then we may exit before starting I/O on all the requests that have been queued up. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-03-01[PATCH] throttle_vm_writeout(): don't loop on GFP_NOFS and GFP_NOIO allocationsAndrew Morton
throttle_vm_writeout() is designed to wait for the dirty levels to subside. But if the caller holds IO or FS locks, we might be holding up that writeout. So change it to take a single nap to give other devices a chance to clean some memory, then return. Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-20[PATCH] separate bdi congestion functions from queue congestion functionsAndrew Morton
Separate out the concept of "queue congestion" from "backing-dev congestion". Congestion is a backing-dev concept, not a queue concept. The blk_* congestion functions are retained, as wrappers around the core backing-dev congestion functions. This proper layering is needed so that NFS can cleanly use the congestion functions, and so that CONFIG_BLOCK=n actually links. Cc: "Thomas Maier" <balagi@justmail.de> Cc: "Jens Axboe" <jens.axboe@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: David Howells <dhowells@redhat.com> Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-30[PATCH] BLOCK: Dissociate generic_writepages() from mpage stuff [try #6]David Howells
Dissociate the generic_writepages() function from the mpage stuff, moving its declaration to linux/mm.h and actually emitting a full implementation into mm/page-writeback.c. The implementation is a partial duplicate of mpage_writepages() with all BIO references removed. It is used by NFS to do writeback. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] call mm/page-writeback.c:set_ratelimit() when new pages are hot-addedChandra Seetharaman
ratelimit_pages in page-writeback.c is recalculated (in set_ratelimit()) every time a CPU is hot-added/removed. But this value is not recalculated when new pages are hot-added. This patch fixes that problem by calling set_ratelimit() when new pages are hot-added. [akpm@osdl.org: cleanups] Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] mm: balance dirty pagesPeter Zijlstra
Now that we can detect writers of shared mappings, throttle them. Avoids OOM by surprise. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-22Add a real API for dealing with blk_congestion_wait()Trond Myklebust
2006-06-23[PATCH] writeback: fix range handlingOGAWA Hirofumi
When a writeback_control's `start' and `end' fields are used to indicate a one-byte-range starting at file offset zero, the required values of .start=0,.end=0 mean that the ->writepages() implementation has no way of telling that it is being asked to perform a range request. Because we're currently overloading (start == 0 && end == 0) to mean "this is not a write-a-range request". To make all this sane, the patch changes range of writeback_control. So caller does: If it is calling ->writepages() to write pages, it sets range (range_start/end or range_cyclic) always. And if range_cyclic is true, ->writepages() thinks the range is cyclic, otherwise it just uses range_start and range_end. This patch does, - Add LLONG_MAX, LLONG_MIN, ULLONG_MAX to include/linux/kernel.h -1 is usually ok for range_end (type is long long). But, if someone did, range_end += val; range_end is "val - 1" u64val = range_end >> bits; u64val is "~(0ULL)" or something, they are wrong. So, this adds LLONG_MAX to avoid nasty things, and uses LLONG_MAX for range_end. - All callers of ->writepages() sets range_start/end or range_cyclic. - Fix updates of ->writeback_index. It seems already bit strange. If it starts at 0 and ended by check of nr_to_write, this last index may reduce chance to scan end of file. So, this updates ->writeback_index only if range_cyclic is true or whole-file is scanned. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Nathan Scott <nathans@sgi.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Steven French <sfrench@us.ibm.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] balance_dirty_pages_ratelimited: take nr_pages argAndrew Morton
Modify balance_dirty_pages_ratelimited() so that it can take a number-of-pages-which-I-just-dirtied argument. For msync(). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] Represent dirty_*_centisecs as jiffies internallyBart Samwel
Make that the internal values for: /proc/sys/vm/dirty_writeback_centisecs /proc/sys/vm/dirty_expire_centisecs are stored as jiffies instead of centiseconds. Let the sysctl interface do the conversions with full precision using clock_t_to_jiffies, instead of doing overflow-sensitive on-the-fly conversions every time the values are used. Cons: apparent precision loss if HZ is not a multiple of 100, because of conversion back and forth. This is a common problem for all sysctl values that use proc_dointvec_userhz_jiffies. (There is only one other in-tree use, in net/core/neighbour.c.) Signed-off-by: Bart Samwel <bart@samwel.tk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] export/change sync_page_range/_nolock()OGAWA Hirofumi
This exports/changes the sync_page_range/_nolock(). The fatfs needs sync_page_range/_nolock() for expanding truncate, and changes "size_t count" to "loff_t count". Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06identify multipage ->writepages() callsAndrew Morton
NFS needs to be able to distinguish between single-page ->writepage() calls and multipage ->writepages() calls. For the single-page writepage calls NFS can kick off the I/O within the context of ->writepage(). For multipage ->writepages calls, nfs_writepage() will leave the I/O pending and nfs_writepages() will kick off the I/O when it all has been queued up within NFS. Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-01-03[PATCH] add AOP_TRUNCATED_PAGE, prepend AOP_ to WRITEPAGE_ACTIVATEZach Brown
readpage(), prepare_write(), and commit_write() callers are updated to understand the special return code AOP_TRUNCATED_PAGE in the style of writepage() and WRITEPAGE_ACTIVATE. AOP_TRUNCATED_PAGE tells the caller that the callee has unlocked the page and that the operation should be tried again with a new page. OCFS2 uses this to detect and work around a lock inversion in its aop methods. There should be no change in behaviour for methods that don't return AOP_TRUNCATED_PAGE. WRITEPAGE_ACTIVATE is also prepended with AOP_ for consistency and they are made enums so that kerneldoc can be used to document their semantics. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2005-09-10[PATCH] mm/filemap.c: make two functions staticAdrian Bunk
With Nick Piggin <npiggin@suse.de> Give some things static scope. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] rename wakeup_bdflush to wakeup_pdflushPekka J Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
