path: root/include/linux/zlib.h
2014-08-08initramfs: support initramfs that is bigger than 2GiBYinghai Lu
Now with 64bit bzImage and kexec tools, we support ramdisk that size is bigger than 2g, as we could put it above 4G. Found compressed initramfs image could not be decompressed properly. It turns out that image length is int during decompress detection, and it will become < 0 when length is more than 2G. Furthermore, during decompressing len as int is used for inbuf count, that has problem too. Change len to long, that should be ok as on 32 bit platform long is 32bits. Tested with following compressed initramfs image as root with kexec. gzip, bzip2, xz, lzma, lzop, lz4. run time for populate_rootfs(): size name Nehalem-EX Westmere-EX Ivybridge-EX 9034400256 root_img : 26s 24s 30s 3561095057 root_img.lz4 : 28s 27s 27s 3459554629 root_img.lzo : 29s 29s 28s 3219399480 root_img.gz : 64s 62s 49s 2251594592 root_img.xz : 262s 260s 183s 2226366598 root_img.lzma: 386s 376s 277s 2901482513 root_img.bz2 : 635s 599s Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Rashika Kheria <rashika.kheria@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: Kyungsik Lee <kyungsik.lee@lge.com> Cc: P J P <ppandit@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tetsuo Handa <penguin-kernel@i-love.sakura.ne.jp> Cc: "Daniel M. Weeks" <dan@danweeks.net> Cc: Alexandre Courbot <acourbot@nvidia.com> Cc: Jan Beulich <JBeulich@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06zlib: clean up some dead codeSergey Senozhatsky
Cleanup unused `if 0'-ed functions, which have been dead since 2006 (commits 87c2ce3b9305 ("lib/zlib*: cleanups") by Adrian Bunk and 4f3865fb57a0 ("zlib_inflate: Upgrade library code to a recent version") by Richard Purdie): - zlib_deflateSetDictionary - zlib_deflateParams - zlib_deflateCopy - zlib_inflateSync - zlib_syncsearch - zlib_inflateSetDictionary - zlib_inflatePrime Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22zlib: slim down zlib_deflate() workspace when possibleJim Keniston
Instead of always creating a huge (268K) deflate_workspace with the maximum compression parameters (windowBits=15, memLevel=8), allow the caller to obtain a smaller workspace by specifying smaller parameter values. For example, when capturing oops and panic reports to a medium with limited capacity, such as NVRAM, compression may be the only way to capture the whole report. In this case, a small workspace (24K works fine) is a win, whether you allocate the workspace when you need it (i.e., during an oops or panic) or at boot time. I've verified that this patch works with all accepted values of windowBits (positive and negative), memLevel, and compression level. Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Miller <davem@davemloft.net> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[ZLIB]: Move bnx2 driver gzip unpacker into zlib.Denys Vlasenko
Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-22[PATCH] zlib_inflate: Upgrade library code to a recent versionRichard Purdie
Upgrade the zlib_inflate implementation in the kernel from a patched version 1.1.3/4 to a patched 1.2.3. The code in the kernel is about seven years old and I noticed that the external zlib library's inflate performance was significantly faster (~50%) than the code in the kernel on ARM (and faster again on x86_32). For comparison the newer deflate code is 20% slower on ARM and 50% slower on x86_32 but gives an approx 1% compression ratio improvement. I don't consider this to be an improvement for kernel use so have no plans to change the zlib_deflate code. Various changes have been made to the zlib code in the kernel, the most significant being the extra functions/flush option used by ppp_deflate. This update reimplements the features PPP needs to ensure it continues to work. This code has been tested on ARM under both JFFS2 (with zlib compression enabled) and ppp_deflate and on x86_32. JFFS2 sees an approx. 10% real world file read speed improvement. This patch also removes ZLIB_VERSION as it no longer has a correct value. We don't need version checks anyway as the kernel's module handling will take care of that for us. This removal is also more in keeping with the zlib author's wishes (http://www.zlib.net/zlib_faq.html#faq24) and I've added something to the zlib.h header to note its a modified version. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Joern Engel <joern@wh.fh-wedel.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] lib/zlib*: cleanupsAdrian Bunk
This patch contains the following possible cleanups: - #if 0 the following unused functions: - zlib_deflate/deflate.c: zlib_deflateSetDictionary - zlib_deflate/deflate.c: zlib_deflateParams - zlib_deflate/deflate.c: zlib_deflateCopy - zlib_inflate/infblock.c: zlib_inflate_set_dictionary - zlib_inflate/infblock.c: zlib_inflate_blocks_sync_point - zlib_inflate/inflate_sync.c: zlib_inflateSync - zlib_inflate/inflate_sync.c: zlib_inflateSyncPoint - remove the following unneeded EXPORT_SYMBOL's: - zlib_deflate/deflate_syms.c: zlib_deflateCopy - zlib_deflate/deflate_syms.c: zlib_deflateParams - zlib_inflate/inflate_syms.c: zlib_inflateSync - zlib_inflate/inflate_syms.c: zlib_inflateSyncPoint Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-06Add fakey 'deflateBound()' function to the in-kernel zlib routinesLinus Torvalds
It's not the real deflateBound() in newer zlib libraries, partly because the upcoming usage of it won't have the "stream" available, so we can't have the same interfaces anyway.
