Module example showing how to use the Linux Kernel Markers.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
The marker activation functions sits in kernel/marker.c. A hash table is used
to keep track of the registered probes and armed markers, so the markers
within a newly loaded module that should be active can be activated at module
load time.
marker_query has been removed. marker_get_first, marker_get_next and
marker_release should be used as iterators on the markers.
Acked-by: "Frank Ch. Eigler" <fche@redhat.com>
Cc: Mike Mason <mmlnx@us.ibm.com>
Enable "cgroup" (formerly containers) based fair group scheduling. This
will let administrator create arbitrary groups of tasks (using "cgroup"
pseudo filesystem) and control their cpu bandwidth usage.
[akpm@linux-foundation.org: fix cpp condition]
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Balbir Singh <balbir@in.ibm.com>
Cc: Paul Menage <menage@google.com>
This patch adds a extended crashkernel syntax that makes the value of reserved
system RAM dependent on the system RAM itself:
crashkernel=<range1>:<size1>[,<range2>:<size2>,...][@offset]
range=start-[end]
For example:
crashkernel=512M-2G:64M,2G-:128M
The motivation comes from distributors that configure their crashkernel
command line automatically with some configuration tool (YaST, you know ;)).
Of course that tool knows the value of System RAM, but if the user removes
RAM, then the system becomes unbootable or at least unusable and error
handling is very difficult.
This series implements this change for i386, x86_64, ia64, ppc64 and sh. That
should be all platforms that support kdump in current mainline. I tested all
platforms except sh due to the lack of a sh processor.
This patch:
This is the generic part of the patch. It adds a parse_crashkernel() function
in kernel/kexec.c that is called by the architecture specific code that
actually reserves the memory. That function takes the whole command line and
looks itself for "crashkernel=" in it.
If there are multiple occurrences, then the last one is taken. The advantage
is that if you have a bootloader like lilo or elilo which allows you to append
a command line parameter but not to remove one (like in GRUB), then you can
add another crashkernel value for testing at the boot command line and this
one overwrites the command line in the configuration then.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: Andi Kleen <ak@suse.de>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Virtualization of sysv msg queues is incomplete: msg_hdrs and msg_bytes
variables visible from userspace are global. Let's make them
per-namespace.
Signed-off-by: Alexey Kuznetsov <alexey@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Cc: Pierre Peiffer <pierre.peiffer@bull.net>
Cc: Nadia Derbey <Nadia.Derbey@bull.net>
Cc: Serge Hallyn <serue@us.ibm.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
This patch introduces ipcs storage into IDRs. The main changes are:
. This ipc_ids structure is changed: the entries array is changed into a
root idr structure.
. The grow_ary() routine is removed: it is not needed anymore when adding
an ipc structure, since we are now using the IDR facility.
. The ipc_rmid() routine interface is changed:
. there is no need for this routine to return the pointer passed in as
argument: it is now declared as a void
. since the id is now part of the kern_ipc_perm structure, no need to
have it as an argument to the routine
Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net>
When a cpu is disabled, move_task_off_dead_cpu() is called for tasks that have
been running on that cpu.
Currently, such a task is migrated:
1) to any cpu on the same node as the disabled cpu, which is both online
and among that task's cpus_allowed
2) to any cpu which is both online and among that task's cpus_allowed
It is typical of a multithreaded application running on a large NUMA system to
have its tasks confined to a cpuset so as to cluster them near the memory that
they share. Furthermore, it is typical to explicitly place such a task on a
specific cpu in that cpuset. And in that case the task's cpus_allowed
includes only a single cpu.
This patch would insert a preference to migrate such a task to some cpu within
its cpuset (and set its cpus_allowed to its entire cpuset).
With this patch, migrate the task to:
2) to any online cpu within the task's cpuset
3) to any cpu which is both online and among that task's cpus_allowed
In order to do this, move_task_off_dead_cpu() must make a call to
cpuset_cpus_allowed_locked(), a new subset of cpuset_cpus_allowed(), that will
not block. (name change - per Oleg's suggestion)
Calls are made to cpuset_lock() and cpuset_unlock() in migration_call() to set
the cpuset mutex during the whole migrate_live_tasks() and
migrate_dead_tasks() procedure.
[akpm@linux-foundation.org: build fix]
[pj@sgi.com: Fix indentation and spacing]
Signed-off-by: Cliff Wickman <cpw@sgi.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Paul Jackson <pj@sgi.com>
Signed-off-by: Paul Jackson <pj@sgi.com>
The task_struct->pid member is going to be deprecated, so start
using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in
the kernel.
The first thing to start with is the pid, printed to dmesg - in
this case we may safely use task_pid_nr(). Besides, printks produce
more (much more) than a half of all the explicit pid usage.
[akpm@linux-foundation.org: git-drm went and changed lots of stuff]
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Airlie <airlied@linux.ie>
The pgrp field is not used widely around the kernel so it is now marked as
deprecated with appropriate comment.
The initialization of INIT_SIGNALS is trimmed because
a) they are set to 0 automatically;
b) gcc cannot properly initialize two anonymous (the second one
is the one with the session) unions. In this particular case
to make it compile we'd have to add some field initialized
right before the .pgrp.
This is the same patch as the 1ec320afdc9552c92191d5f89fcd1ebe588334ca one
(from Cedric), but for the pgrp field.
Some progress report:
We have to deprecate the pid, tgid, session and pgrp fields on struct
task_struct and struct signal_struct. The session and pgrp are already
deprecated. The tgid value is close to being such - the worst known usage
in in fs/locks.c and audit code. The pid field deprecation is mainly
blocked by numerous printk-s around the kernel that print the tsk->pid to
log.
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
remove BITS_TO_TYPE macro
I realized, that it is actually the same as DIV_ROUND_UP, use it instead.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
define global BIT macro
move all local BIT defines to the new globally define macro.
Cc: Kumar Gala <galak@gate.crashing.org>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Cc: "John W. Linville" <linville@tuxdriver.com>
get rid of input BIT* duplicate defines
use newly global defined macros for input layer. Also remove includes of
input.h from non-input sources only for BIT macro definiton. Define the
macro temporarily in local manner, all those local definitons will be
removed further in this patchset (to not break bisecting).
BIT macro will be globally defined (1<<x)
Cc: <dtor@mail.ru>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Cc: <lenb@kernel.org>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: <perex@suse.cz>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: <vernux@us.ibm.com>
Cc: <malattia@linux.it>
define first set of BIT* macros
- move BITOP_MASK and BITOP_WORD from asm-generic/bitops/atomic.h to
include/linux/bitops.h and rename it to BIT_MASK and BIT_WORD
- move BITS_TO_LONGS and BITS_PER_BYTE to bitops.h too and allow easily
define another BITS_TO_something (e.g. in event.c) by BITS_TO_TYPE macro
Remaining (and common) BIT macro will be defined after all occurences and
conflicts will be sorted out in the patches.
remove asm/bitops.h includes
including asm/bitops directly may cause compile errors. don't include it
and include linux/bitops instead. next patch will deny including asm header
directly.
Cc: Adrian Bunk <bunk@kernel.org>
This new version guarantees amb_bit switch in small enough intervals, so that
the device won't stop working in the middle of a movement anymore. However it
preserves old (openhaptics) functionality.
Cause writes to cpuset "cpus" file to update cpus_allowed for member tasks:
- collect batches of tasks under tasklist_lock and then call
set_cpus_allowed() on them outside the lock (since this can sleep).
- add a simple generic priority heap type to allow efficient collection
of batches of tasks to be processed without duplicating or missing any
tasks in subsequent batches.
- make "cpus" file update a no-op if the mask hasn't changed
- fix race between update_cpumask() and sched_setaffinity() by making
sched_setaffinity() post-check that it's not running on any cpus outside
cpuset_cpus_allowed().
Signed-off-by: Paul Menage <menage@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Add a new per-cpuset flag called 'sched_load_balance'.
When enabled in a cpuset (the default value) it tells the kernel scheduler
that the scheduler should provide the normal load balancing on the CPUs in
that cpuset, sometimes moving tasks from one CPU to a second CPU if the
second CPU is less loaded and if that task is allowed to run there.
When disabled (write "0" to the file) then it tells the kernel scheduler
that load balancing is not required for the CPUs in that cpuset.
Now even if this flag is disabled for some cpuset, the kernel may still
have to load balance some or all the CPUs in that cpuset, if some
overlapping cpuset has its sched_load_balance flag enabled.
If there are some CPUs that are not in any cpuset whose sched_load_balance
flag is enabled, the kernel scheduler will not load balance tasks to those
CPUs.
Moreover the kernel will partition the 'sched domains' (non-overlapping
sets of CPUs over which load balancing is attempted) into the finest
granularity partition that it can find, while still keeping any two CPUs
that are in the same shed_load_balance enabled cpuset in the same element
of the partition.
This serves two purposes:
1) It provides a mechanism for real time isolation of some CPUs, and
2) it can be used to improve performance on systems with many CPUs
by supporting configurations in which load balancing is not done
across all CPUs at once, but rather only done in several smaller
disjoint sets of CPUs.
This mechanism replaces the earlier overloading of the per-cpuset
flag 'cpu_exclusive', which overloading was removed in an earlier
patch: cpuset-remove-sched-domain-hooks-from-cpusets
See further the Documentation and comments in the code itself.
[akpm@linux-foundation.org: don't be weird]
Since these are expanded into call to pid_nr_ns() anyway, it's OK to move
the whole routine out-of-line. This is a cheap way to save ~100 bytes from
vmlinux. Together with the previous two patches, it saves half-a-kilo from
the vmlinux.
Un-inline other (currently inlined) functions must be done with additional
performance testing.
The find_pid/_vpid/_pid_ns functions are used to find the struct pid by its
id, depending on whic id - global or virtual - is used.
The find_vpid() is a macro that pushes the current->nsproxy->pid_ns on the
stack to call another function - find_pid_ns(). It turned out, that this
dereference together with the push itself cause the kernel text size to
grow too much.
Move all these out-of-line. Together with the previous patch this saves a
bit less that 400 bytes from .text section.
With pid namespaces this field is now dangerous to use explicitly, so hide
it behind the helpers.
Also the pid and pgrp fields o task_struct and signal_struct are to be
deprecated. Unfortunately this patch cannot be sent right now as this
leads to tons of warnings, so start isolating them, and deprecate later.
Actually the p->tgid == pid has to be changed to has_group_leader_pid(),
but Oleg pointed out that in case of posix cpu timers this is the same, and
thread_group_leader() is more preferable.
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Since we've switched from using pid->nr to pid->upids->nr some
fields on struct pid are no longer needed
The find_task_by_something is a set of macros are used to find task by pid
depending on what kind of pid is proposed - global or virtual one. All of
them are wrappers above the most generic one - find_task_by_pid_type_ns() -
and just substitute some args for it.
It turned out, that dereferencing the current->nsproxy->pid_ns construction
and pushing one more argument on the stack inline cause kernel text size to
grow.
This patch moves all this stuff out-of-line into kernel/pid.c. Together
with the next patch it saves a bit less than 400 bytes from the .text
section.
Terminate all processes in a namespace when the reaper of the namespace is
exiting. We do this by walking the pidmap of the namespace and sending
SIGKILL to all processes.
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
The namespace's proc_mnt must be kern_mount-ed to make this pointer always
valid, independently of whether the user space mounted the proc or not. This
solves raced in proc_flush_task, etc. with the proc_mnt switching from NULL
to not-NULL.
The initialization is done after the init's pid is created and hashed to make
proc_get_sb() finr it and get for root inode.
Sice the namespace holds the vfsmnt, vfsmnt holds the superblock and the
superblock holds the namespace we must explicitly break this circle to destroy
all the stuff. This is done after the init of the namespace dies. Running a
few steps forward - when init exits it will kill all its children, so no
proc_mnt will be needed after its death.
When clone() is invoked with CLONE_NEWPID, create a new pid namespace and then
create a new struct pid for the new process. Allocate pid_t's for the new
process in the new pid namespace and all ancestor pid namespaces. Make the
newly cloned process the session and process group leader.
Since the active pid namespace is special and expected to be the first entry
in pid->upid_list, preserve the order of pid namespaces.
The size of 'struct pid' is dependent on the the number of pid namespaces the
process exists in, so we use multiple pid-caches'. Only one pid cache is
created during system startup and this used by processes that exist only in
init_pid_ns.
When a process clones its pid namespace, we create additional pid caches as
necessary and use the pid cache to allocate 'struct pids' for that depth.
Note, that with this patch the newly created namespace won't work, since the
rest of the kernel still uses global pids, but this is to be fixed soon. Init
pid namespace still works.
[oleg@tv-sign.ru: merge fix]
* remove pid.h from pid_namespaces.h;
* rework is_(cgroup|global)_init;
* optimize (get|put)_pid_ns for init_pid_ns;
* declare task_child_reaper to return actual reaper.
Each pid namespace have to be visible through its own proc mount. Thus we
need to have per-namespace proc trees with their own superblocks.
We cannot easily show different pid namespace via one global proc tree, since
each pid refers to different tasks in different namespaces. E.g. pid 1
refers to the init task in the initial namespace and to some other task when
seeing from another namespace. Moreover - pid, exisintg in one namespace may
not exist in the other.
This approach has one move advantage is that the tasks from the init namespace
can see what tasks live in another namespace by reading entries from another
proc tree.
When searching the task by numerical id on may need to find it using global
pid (as it is done now in kernel) or by its virtual id, e.g. when sending a
signal to a task from one namespace the sender will specify the task's virtual
id and we should find the task by this value.
[akpm@linux-foundation.org: fix gfs2 linkage]
When showing pid to user or getting the pid numerical id for in-kernel use the
value of this id may differ depending on the namespace.
This set of helpers is used to get the global pid nr, the virtual (i.e. seen
by task in its namespace) nr and the nr as it is seen from the specified
namespace.
Each struct upid element of struct pid has to be initialized properly, i.e.
its nr mst be allocated from appropriate pidmap and ns set to appropriate
namespace.
When allocating a new pid, we need to know the namespace this pid will live
in, so the additional argument is added to alloc_pid().
On the other hand, the rest of the kernel still uses the pid->nr and
pid->pid_chain fields, so these ones are still initialized, but this will be
removed soon.
Each namespace has a parent and is characterized by its "level". Level is the
number of the namespace generation. E.g. init namespace has level 0, after
cloning new one it will have level 1, the next one - 2 and so on and so forth.
This level is not explicitly limited.
True hierarchy must have some way to find each namespace's children, but it is
not used in the patches, so this ability is not added (yet).
Since task will be visible from different pid namespaces each of them have to
be addressed by multiple pids. struct upid is to store the information about
which id refers to which namespace.
The constuciton looks like this. Each struct pid carried the reference
counter and the list of tasks attached to this pid. At its end it has a
variable length array of struct upid-s. Each struct upid has a numerical id
(pid itself), pointer to the namespace, this ID is valid in and is hashed into
a pid_hash for searching the pids.
The nr and pid_chain fields are kept in struct pid for a while to make kernel
still work (no patch initialize the upids yet), but it will be removed at the
end of this series when we switch to upids completely.
proc trees
The first part is trivial - we just make the proc_flush_task() to operate on
arbitrary vfsmount with arbitrary ids and pass the pid and global proc_mnt to
it.
The other change is more tricky: I moved the proc_flush_task() call in
release_task() higher to address the following problem.
When flushing task from many proc trees we need to know the set of ids (not
just one pid) to find the dentries' names to flush. Thus we need to pass the
task's pid to proc_flush_task() as struct pid is the only object that can
provide all the pid numbers. But after __exit_signal() task has detached all
his pids and this information is lost.
This creates a tiny gap for proc_pid_lookup() to bring some dentries back to
tree and keep them in hash (since pids are still alive before __exit_signal())
till the next shrink, but since proc_flush_task() does not provide a 100%
guarantee that the dentries will be flushed, this is OK to do so.
This flag tells the .get_sb callback that this is a kern_mount() call so that
it can trust *data pointer to be valid in-kernel one. If this flag is passed
from the user process, it is cleared since the *data pointer is not a valid
kernel object.
Running a few steps forward - this will be needed for proc to create the
superblock and store a valid pid namespace on it during the namespace
creation. The reason, why the namespace cannot live without proc mount is
described in the appropriate patch.
In the following scenario:
code path 1:
my_function() -> lock(L1); ...; flush_workqueue(); ...
code path 2:
run_workqueue() -> my_work() -> ...; lock(L1); ...
you can get a deadlock when my_work() is queued or running
but my_function() has acquired L1 already.
This patch adds a pseudo-lock to each workqueue to make lockdep
warn about this scenario.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
When someone wants to deal with some other taks's namespaces it has to lock
the task and then to get the desired namespace if the one exists. This is
slow on read-only paths and may be impossible in some cases.
E.g. Oleg recently noticed a race between unshare() and the (sent for
review in cgroups) pid namespaces - when the task notifies the parent it
has to know the parent's namespace, but taking the task_lock() is
impossible there - the code is under write locked tasklist lock.
On the other hand switching the namespace on task (daemonize) and releasing
the namespace (after the last task exit) is rather rare operation and we
can sacrifice its speed to solve the issues above.
The access to other task namespaces is proposed to be performed
like this:
rcu_read_lock();
nsproxy = task_nsproxy(tsk);
if (nsproxy != NULL) {
* work with the namespaces here
* e.g. get the reference on one of them
* NULL task_nsproxy() means that this task is
* almost dead (zombie)
rcu_read_unlock();
This patch has passed the review by Eric and Oleg :) and,
of course, tested.
[clg@fr.ibm.com: fix unshare()]
[ebiederm@xmission.com: Update get_net_ns_by_pid]
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
is_init() is an ambiguous name for the pid==1 check. Split it into
is_global_init() and is_container_init().
A cgroup init has it's tsk->pid == 1.
A global init also has it's tsk->pid == 1 and it's active pid namespace
is the init_pid_ns. But rather than check the active pid namespace,
compare the task structure with 'init_pid_ns.child_reaper', which is
initialized during boot to the /sbin/init process and never changes.
Changelog:
2.6.22-rc4-mm2-pidns1:
- Use 'init_pid_ns.child_reaper' to determine if a given task is the
global init (/sbin/init) process. This would improve performance
and remove dependence on the task_pid().
2.6.21-mm2-pidns2:
- [Sukadev Bhattiprolu] Changed is_container_init() calls in {powerpc,
ppc,avr32}/traps.c for the _exception() call to is_global_init().
This way, we kill only the cgroup if the cgroup's init has a
bug rather than force a kernel panic.
[akpm@linux-foundation.org: fix comment]
[sukadev@us.ibm.com: Use is_global_init() in arch/m32r/mm/fault.c]
[bunk@stusta.de: kernel/pid.c: remove unused exports]
[sukadev@us.ibm.com: Fix capability.c to work with threaded init]
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Acked-by: Pavel Emelianov <xemul@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
Cc: Herbert Poetzel <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Rename the child_reaper() function to task_child_reaper() to be similar to
other task_* functions and to distinguish the function from 'struct
pid_namspace.child_reaper'.
Cc: Pavel Emelianov <xemul@openvz.org>
With multiple pid namespaces, a process is known by some pid_t in every
ancestor pid namespace. Every time the process forks, the child process also
gets a pid_t in every ancestor pid namespace.
While a process is visible in >=1 pid namespaces, it can see pid_t's in only
one pid namespace. We call this pid namespace it's "active pid namespace",
and it is always the youngest pid namespace in which the process is known.
This patch defines and uses a wrapper to find the active pid namespace of a
process. The implementation of the wrapper will be changed in when support
for multiple pid namespaces are added.
Changelog:
- [Pavel Emelianov, Alexey Dobriyan] Back out the change to use
task_active_pid_ns() in child_reaper() since task->nsproxy
can be NULL during task exit (so child_reaper() continues to
use init_pid_ns).
to implement child_reaper() since init_pid_ns.child_reaper to
implement child_reaper() since tsk->nsproxy can be NULL during exit.
2.6.21-rc6-mm1:
- Rename task_pid_ns() to task_active_pid_ns() to reflect that a
process can have multiple pid namespaces.
Add kmem_cache to pid_namespace to allocate pids from.
Since both implementations expand the struct pid to carry more numerical
values each namespace should have separate cache to store pids of different
sizes.
Each kmem cache is name "pid_<NR>", where <NR> is the number of numerical ids
on the pid. Different namespaces with same level of nesting will have same
caches.
This patch has two FIXMEs that are to be fixed after we reach the consensus
about the struct pid itself.
The first one is that the namespace to free the pid from in free_pid() must be
taken from pid. Now the init_pid_ns is used.
The second FIXME is about the cache allocation. When we do know how long the
object will be then we'll have to calculate this size in create_pid_cachep.
Right now the sizeof(struct pid) value is used.
[akpm@linux-foundation.org: coding-style repair]
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Acked-by: Cedric Le Goater <clg@fr.ibm.com>
Acked-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Make get_pid_ns() return the namespace itself to look like the other getters
and make the code using it look nicer.
The set of functions process_session, task_session, process_group and
task_pgrp is confusing, as the names can be mixed with each other when looking
at the code for a long time.
The proposals are to
* equip the functions that return the integer with _nr suffix to
represent that fact,
* and to make all functions work with task (not process) by making
the common prefix of the same name.
For monotony the routines signal_session() and set_signal_session() are
replaced with task_session_nr() and set_task_session(), especially since they
are only used with the explicit task->signal dereference.
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
When a task enters a new namespace via a clone() or unshare(), a new cgroup
is created and the task moves into it.
This version names cgroups which are automatically created using
cgroup_clone() as "node_<pid>" where pid is the pid of the unsharing or
cloned process. (Thanks Pavel for the idea) This is safe because if the
process unshares again, it will create
/cgroups/(...)/node_<pid>/node_<pid>
The only possibilities (AFAICT) for a -EEXIST on unshare are
1. pid wraparound
2. a process fails an unshare, then tries again.
Case 1 is unlikely enough that I ignore it (at least for now). In case 2, the
node_<pid> will be empty and can be rmdir'ed to make the subsequent unshare()
succeed.
Changelog:
Name cloned cgroups as "node_<pid>".
[clg@fr.ibm.com: fix order of cgroup subsystems in init/Kconfig]
This patch is inspired by the discussion at
http://lkml.org/lkml/2007/4/11/187 and implements per cgroup statistics
as suggested by Andrew Morton in http://lkml.org/lkml/2007/4/11/263. The
patch is on top of 2.6.21-mm1 with Paul's cgroups v9 patches (forward
ported)
This patch implements per cgroup statistics infrastructure and re-uses
code from the taskstats interface. A new set of cgroup operations are
registered with commands and attributes. It should be very easy to
*extend* per cgroup statistics, by adding members to the cgroupstats
structure.
The current model for cgroupstats is a pull, a push model (to post
statistics on interesting events), should be very easy to add. Currently
user space requests for statistics by passing the cgroup file
descriptor. Statistics about the state of all the tasks in the cgroup
is returned to user space.
TODO's/NOTE:
This patch provides an infrastructure for implementing cgroup statistics.
Based on the needs of each controller, we can incrementally add more statistics,
event based support for notification of statistics, accumulation of taskstats
into cgroup statistics in the future.
Sample output
# ./cgroupstats -C /cgroup/a
sleeping 2, blocked 0, running 1, stopped 0, uninterruptible 0
sleeping 154, blocked 0, running 0, stopped 0, uninterruptible 0
If the approach looks good, I'll enhance and post the user space utility for
the same
Feedback, comments, test results are always welcome!
Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Jay Lan <jlan@engr.sgi.com>
This example subsystem exports debugging information as an aid to diagnosing
refcount leaks, etc, in the cgroup framework.
Cc: Serge E. Hallyn <serue@us.ibm.com>
Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com>
This example demonstrates how to use the generic cgroup subsystem for a
simple resource tracker that counts, for the processes in a cgroup, the
total CPU time used and the %CPU used in the last complete 10 second interval.
Portions contributed by Balbir Singh <balbir@in.ibm.com>
Remove the filesystem support logic from the cpusets system and makes cpusets
a cgroup subsystem
The "cpuset" filesystem becomes a dummy filesystem; attempts to mount it get
passed through to the cgroup filesystem with the appropriate options to
emulate the old cpuset filesystem behaviour.
Add the following files to the cgroup filesystem:
notify_on_release - configures/reports whether the cgroup subsystem should
attempt to run a release script when this cgroup becomes unused
release_agent - configures/reports the release agent to be used for this
hierarchy (top level in each hierarchy only)
releasable - reports whether this cgroup would have been auto-released if
notify_on_release was true and a release agent was configured (mainly useful
for debugging)
To avoid locking issues, invoking the userspace release agent is done via a
workqueue task; cgroups that need to have their release agents invoked by
the workqueue task are linked on to a list.
[pj@sgi.com: Need to include kmod.h]
Replace the struct css_set embedded in task_struct with a pointer; all tasks
that have the same set of memberships across all hierarchies will share a
css_set object, and will be linked via their css_sets field to the "tasks"
list_head in the css_set.
Assuming that many tasks share the same cgroup assignments, this reduces
overall space usage and keeps the size of the task_struct down (three pointers
added to task_struct compared to a non-cgroups kernel, no matter how many
subsystems are registered).
[akpm@linux-foundation.org: fix a printk]
Add:
/proc/cgroups - general system info
/proc/*/cgroup - per-task cgroup membership info
[a.p.zijlstra@chello.nl: cgroups: bdi init hooks]
